2017 Alltrack S - How to monitor Boost Pressure?
GRRNMO
Fredericksburg, VA, USA
C?ID=417860
Just want to monitor Boost Pressure so I have an idea of what the Neuspeed power Module did for the vehicle...(I have no # on my interface to add "code tags" so I tried the Gear Icon that says it toggles codes...srry if that is wrong...
Wednesday,30,September,2020,17:35:32:50530
VIN: 3VWH17AU0HM519811   License Plate: MINE
Mileage: 61124km-37980mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 22 42 44 52 5F 75
VIN: 3VWH17AU0HM519811   Mileage: 61124km-37980miles
Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 L    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0002
   Revision: --H13---
   Coding: 311D00122426002F0000
   Shop #: WSC 00066 790 00202
   ASAM Dataset: EV_ECM18TFS0208V0906264L 001003
   ROD: EV_ECM18TFS0208V0906264L.rod
   VCID: 45D7558D552DB003215-8010
Readiness: 1110 1101
   Part No SW: 0D9 300 014 M    HW: 02E 927 770 AS
   Component: DQ250-6A MQB  H54 5004
   Revision: 06254104    Serial number: TFK01610190477
   ROD: EV_TCMDQ250021.rod
   VCID: 221DEE11A443A73B647-8076
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AF    HW: 5Q0 614 517 AF
   Component: ESC           H62 0398
   Revision: 00000000    Serial number: 52876000000657
   Coding: 43FA6AA134210975807F130181C429C2562C9001C881943C00435050E00903
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019
   ROD: EV_Brake1UDSContiMK100ESP_035.rod
   VCID: 75B7E54D454D6083715-8020
   Part No SW: 5GM 907 426 C    HW: 5GM 907 426 C
   Component: AC Manuell    H03 1601
   Revision: 00001K03
   Coding: 02020004200100000000000000000002
   ASAM Dataset: EV_ACManueBHBVW37X 004132
   VCID: 48C95CB9623FAD6BDA3-801C
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 865821101601IV
   Coding: 000018464041804969E44000001407201000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 7AADF6716C530FFB1C7-802E
   Component: WWS    160924  043 0581
   Serial number:         161129153929
   Serial number: 003GCR065B60
   VCID: 47CB5F856F21A213D39-8012
   Occupant Detection:
   Serial number: IBH0000000000064MB7A
   Coding: 303135
   Subsystem 2 - Part No SW: -----------    HW: 480 003 009 16
   Serial number: 3570000000081161CE1G
   Subsystem 3 - Part No SW: -----------    HW: 480 003 009 16
   Serial number: 35800000000FC1B03E1U
   Subsystem 4 - Part No SW: -----------    HW: 480 403 009 16
   Serial number: 35100029B229A2E3B132
   Subsystem 5 - Part No SW: -----------    HW: 480 403 009 16
   Serial number: 35200029D229A2E29299
   Subsystem 6 - Part No SW: -----------    HW: 480 402 009 16
   Serial number: 3550002B9229A2E30371
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 009 16
   Serial number: 3560002B9229A2E031D6
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20161020500277
   Coding: 0410
   Shop #: WSC 66564 385 16448
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3FDB476537F1EAD36B9-806A
   Part No SW: 5G1 920 840 B    HW: 5G1 920 840 B
   Component: KOMBI         244 8311
   Coding: 0BB4100DA180CF0502086A001000000000000000
   VCID: 2615F201C86B5B1B08F-8072
   Part No SW: 5Q0 907 530 AL    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2265
   Revision: --------    Serial number: 08101610801564
   Coding: 0101000830085900FB0020081E0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07030
   ROD: EV_GatewConti_013.rod
   VCID: 7BA3F375636936F3071-802E
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0103
   Serial number: 29160002107160056417
   Coding: 31FFFF
   Serial number: HA1-00026.09.16
   Coding: 0001
   VCID: 4ACD66B17C335F7BCC7-801E
   Serial number: 1711160605009J
   Coding: 003A03200000020000000000
   VCID: 43D34B955B198E330F1-8016
   Serial number: 00000000000004655372
   Coding: 011000
   Component: EPS_MQB_ZFLS  129 1072
   Coding: 8102
   ROD: EV_SteerAssisMQB_013.rod
   Serial number: 141116060506Y6
   VCID: 42DD4E914403873B047-8016
   Serial number: 00000000000004722226
   Coding: 091000
   Part No SW: 3Q0 035 844 A    HW: 3Q0 035 844 A
   Component: MU-S-S-US     710 0751
   Coding: 02730200FF00000051220001001808009F0108D40120010002
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2D070D2DED9D6843C95-8078
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H53 1031
   Serial number: VWZ8Z9SJW01LA7
   Coding: 02730202C2821A017F1E06020000
   ROD: EV_OCULowMQB.rod
End----------(Elapsed Time: 01:13, VBatt start/end: 13.6V/13.6V)-----------
I'm fairly sure that these are VW's equivalents for Boost pressure
IDE00190 -- Charge air pressure specified value
IDE00191 -- Charge air pressure: actual value
Go to the ECU @ address hex01 and select Adv. Meas. values - then type "charge" into the search box on the top RHS.
The readings will be above atmospheric pressure and of course the measurements are made in proper SI units (Pascal, that is!) :D
PS: If you want to include ambient pressure into the readings, select IDE00361 -- Ambient air pressure
The first two are correct, but interestingly enough, this ECU doesn't appear to have IDE00362 . Instead it has:
IDE03931 -- Charge pressure actuator: actual position
IDE03932 -- Charge pressure actuator: specified position
IDE03933 -- Charge pressure actuator: specified value
My take-away from this is that it has a "more intelligent" charge pressure actuator with actual feedback, vs. an old school one that just responds to duty-cycle.
StorableComa
C?ID=219649
Sorry if this is ignorant, but doesn't the Neuspeed module create more power/boost by "fooling" the ECU, kinda like JB4? I would think you'd need a boost tap style gauge to get an accurate reading. Though if you have MIB2 with Navi, you could turn on the off road menu for in car display. I believe that shows current boost, but you have to subtract atmospheric pressure? Not sure, I have the Comp. Media w/out navi, so no off road screen for me.
Off Road Display activation
Enables additional screen in CAR menu, where you can check coolant temperature, oil temperature, compass, inclination and steering wheel angle.
Module: 5F (Information electronics)
Security Access → Code: 31347
Adaptation → Channel: Car Function Adaptations Gen2 - Menu Display Compass
New value: active
Adaptation → Channel: Car Function Adaptations Gen2 - Menu Display Compass Over Threshold High
New value: active
Adaptation → Channel: Car Function List BAP Gen2 - Compass_0x15
New value: active
Reboot infotainment unit by pressing and holding volume knob for 10 second
@StorableComa : Hi. I'm fairly certain that the Off-Road monitor does NOT display Boost-pressure. You might be confusing the function with Performance monitor (SportHMI) - maybe? The problem is that this latter facility is SWAP - so it can't be added by purely coding changes, alas.
GRRNMO
C?ID=417860
Well, because the Neuspeed says to drive it 20 miles before it remaps the boost settings, I confess this scan is AFTER installing the module and BEFORE driving it...
That's said - I look at charge pressure actuator!? 😂
GRRNMO
C?ID=417860
So, my completely unscientific report after driving it with the Neuspeed "un-tune" tune!?
Wow.
You have to hit [Start] to get it ready to sense the launch and start recording data. It will then base its calculations on the first non-zero vehicle speed it sees.
