Haldex Surge - What items should I log to track down issue?
MnHotRod
Minneapolis, USA
C?ID=419241
Hello, I've been experiencing an issue, and I'm not sure I can nail it down to the Haldex yet. Whatever is the issue, it is causing the Haldex to act up.
Whenever my car is started from being shutoff for three minutes or more, I experience a chattering vibration for a a second or two when I hit speeds above 40mph. The vibration is amplified if I pull onto the highway within 1/8th mile of start up. The vibration is short, maybe 1-2 seconds. When the car vibrates, it usually pulls to the right. If the roads are wet, the car becomes quite loose. The issue is most apparent on the highway. It consistantly has the issue four times over the course of two miles, then goes away until the next start up.
I purchased a VCDS Tool from Ross-Tech to log the issue. For now I am logging HALDEX CLUTCH STATUS-DEGREE OF BLOCKAGE, HALDEX CLUTCH PUMP CURRENT, HALDEX CLUTCH PUMP PWM SIGNAL and HALDEX CLUTCH PUMP VOLTAGE. I will attach a graph below.
There may be other things I should be logging. If anyone has suggestions on what to log, please feel free to express your ideas.
NOTE: The Haldex fluid has been changed and screen inspected. The fluid looked normal. The screen was clean. The oil in the differential was also changed. Everything looks normal.
VWT6
Finland
C?ID=295527
1. You do have identical tires front and rear?
2. The "spikes" look like Haldex self calibration.
3. You could disengage Haldex by removing controller's fuse.
4. I'd record the following
Front left wheel speedFront right wheel speedLeft rear wheel speedRight rear wheel speedHaldex clutch status-Degree of blockageAxle speed deltas
5. I'd bump up sampling rate by using "Group UDS requests".
6. Posting Auto-Scan would help to understand what kind of vehicle you have concerns of.
MnHotRod
Minneapolis, USA
C?ID=419241
Thank you for your response! We had a multi-day car rally last weekend. Got back home yesterday.
1. Stock - 255/30R19 Front and 235/35R19 Rear
2. Any idea what would cause this?
3. When AWD fuse is pulled, issue goes away.
4. I've done this, no spikes in wheels speeds or axle speed deltas.
5. I can try that.
6. Have Auto-Scan, will post.
This ghost has been difficult to nail down. The local Audi dealership had the car for a week with no joy. I pulled the AWD fuse as a test prior to purchasing my Ross-Tech VCDS cable. The issue goes away when the fuse is pulled. I recorded the items you noted. There were no spikes in wheels speed or axle speed deltas, so I turned them off to review the graph more easily. I'm new to VCDS, so I'll have to see if I can figure out how to bump sampling rate.
I like your review as "Haldex Self Calibration". It would be nice if I could get more information on how to track this down as the possible issue. IE: Would switching out the Haldex control module with one from another car help isolate the issue? The Haldex pump was inexpensive, relative to other items, so I ordered a new one. Still waiting to receive that.
VEHICLE: 2018 Audi RS3
MnHotRod
Minneapolis, USA
C?ID=419241
Monday,05,October,2020,21:47:19:06767
[URL="http://www.Ross-Tech.com"]www.Ross-Tech.com[/URL]
VIN: WUABWGFF6J1900010   License Plate:
Mileage: 46144mi   Repair Order:
Chassis Type: FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 29 2B 39 3C 42 44 47
          52 55 5F 6C BB BC CF D6 D7
VIN: WUABWGFF6J1900010   Mileage: 74263km-46144miles
[B]03-ABS Brakes -- Status: Malfunction 0010[/B]
[B]08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010[/B]
[B]15-Airbags -- Status: Malfunction 0010[/B]
[B]19-CAN Gateway -- Status: Malfunction 0010[/B]
Address 01: Engine (------DAZA)       Labels:. 07K-907-309-V1.clb
   Part No SW: 8V0 907 404 G    HW: 07K 907 309 E
   Component: R5 2.5l TFSI  H21 0004
   Revision: 53H21000
   Coding: 0A250032242600053620
   ASAM Dataset: EV_ECM25TFS0118V0907404G 001004
   ROD: EV_ECM25TFS0118V0907404G.rod
   VCID: 3D273D276DF00813795-8068
   Part No SW: 0DL 300 012 H    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2112
   Revision: 00H06V07
   VCID: 2E050A6BB096E38BF0F-807A
   Part No SW: 8V0 614 517 C    HW: 8V0 614 517 C
   Component: ESC           H25 0621
   Revision: 00000000    Serial number: 60457000000458
   Coding: 2EAA6B7DD4990BA989910B6581916974D62BD091D0819636024150D4828812
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
   ROD: EV_Brake1UDSContiMK100IPB_070.rod
   VCID: 392F293779D8343355D-806C
[B]1 Fault Found:
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 34
                    Mileage: 73335 km
                    Date: 2020.10.03
                    Time: 13:42:56[/B]
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0434000551
   Coding: 030C0C
   VCID: 3B23333F73E40623471-806E
   Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
   Component: AC Automat    H03 0130
   Revision: 20002000    Serial number: 00000001171511
   Coding: 03000015010000000000000000001400
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
   VCID: 40D944D31A0265FB123-8014
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: CB78C39800PAG0MUFU03
[B]1 Fault Found:
65544 - Button(s) or Switch(es) in Operating Device
          B1312 07 [008] - Mechanical Failure
                    Fault Frequency: 96
                    Reset counter: 36
                    Mileage: 72748 km
                    Date: 2020.09.29
                    Time: 08:24:24
                    Voltage terminal 30: 14.6 V
                    Outside air temperature: 13 °C
                    Pressing a button-Defrost: not activated
                    Pressing a button-Recirculating air: not activated
                    Pressing a button-Rear window defogger: not activated
                    Pressing a button-AC: not activated
                    Pressing a button-Left heated seat: not activated
                    Pressing a button-Right heated seat: not activated
                    Pressing a button-OFF: not activated
                    Pressing a button-AUTO: not activated
                    Pressing a button-Footwell air distribution: not activated
                    Pressing a button-Upper body vent air distribution: not activated
                    Pressing a button-Air distribution up: not activated
                    Pressing a button-Left cabin heater: not activated
                    Pressing a button-Right cabin heater: not activated[/B]
   Part No SW: 5Q0 937 085 BF    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H34 0236
   Serial number: 02001705301255
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7EA5FA2B2076D30B20F-802A
   Component: WWS371 170118  043 0585
   Serial number:         170201004606
   Coding: 0A47F7
   Serial number: 62658831
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 24 12 2016  00000716
   Serial number: 00000000000068519454
   Sun Roof:
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST001GIJAS00000
   Coding: 101F00
[B]1 Fault Found:
558100 - Databus
          [Airbag_02 Datenbus empfangener Fehlerwert]
                    Reset counter: 21
                    Mileage: 72824 km
                    Date: 2020.09.30
                    Time: 18:50:44[/B]
   Part No SW: 5QA 919 294 A    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0038
   Serial number: 000308418617049
   Coding: 0470155011
   ASAM Dataset: EV_EPHVA18AU3700000 009031
   VCID: 4ACD66FB2C3EAFABCC7-801E
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 G    HW: 8V0 907 376 F
   Component: DAEMPFUNGS-SG H11 0082
   Serial number:       090117063
   ASAM Dataset: EV_AudiMagneRide 002008
   ROD: EV_AudiMagneRide.rod
   VCID: 45D755C7052040D3215-8010
   Serial number: 003GCR07DTF-
   Coding: 9DCCFCC0008000005000001AC24800000065
   ROD: EV_AirbaVW20SMEVW37X_VW48.rod
   VCID: 47CB5FCF3F2C52C3D39-8012
   Belt Pretensioner left:
   Serial number: 34230167A28021750618
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34230168A28021740189
   Coding: 333135
   Occupant Detection:
   Serial number: 694000000000001KL5F
   Coding: 303337
   Subsystem 4 - Part No SW: -----------    HW: 480 002 402 17
   Serial number: 35700000000BD320712B
   Subsystem 5 - Part No SW: -----------    HW: 480 002 402 17
   Serial number: 358000000004E61D912N
   Subsystem 6 - Part No SW: -----------    HW: 480 401 502 17
   Serial number: 351000199247F133281V
   Subsystem 7 - Part No SW: -----------    HW: 480 401 002 17
   Serial number: 3520001BD244A742825/
   Subsystem 8 - Part No SW: -----------    HW: 480 401 601 17
   Serial number: 3550002B723A3F85C106
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 401 601 17
   Serial number: 3560002B723A3F8120C4
[B]2 Faults Found:
9445929 - Seat occupied recognition control module
          B1022 29 [008] - Signal Implausible
                    Reset counter: 21
                    Mileage: 72824 km
                    Date: 2020.09.30
                    Time: 18:50:48
9577755 - Sensor Mat for Seat Occupied Detection
          B1225 1B [008] - Resistance Too High
                    Reset counter: 21
                    Mileage: 72824 km
                    Date: 2020.09.30
                    Time: 18:50:43[/B]
   Part No SW: 8V0 953 521 KK    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 25021704400484
   Coding: A018
   ROD: EV_SMLSKLOMQB_019_AU37.rod
   VCID: 0D47ADE71DD0F893295-8058
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 790     HW: 8V0 920 790
   Component: FBenRDW       H14 0046
   Coding: 082D18533B8800080204EC041800001000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001023
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 79AFE9373958F43315D-802C
   Component: GW MQB High   515 5286
   Serial number: 25021710520131
   Coding: 03010004340860005B00822CB80B00000001010000000000000000000000
   ROD: EV_GatewNF_AU37.rod
   VCID: 2F3B176FB79CEA83FB9-807A
   Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0002
   Serial number: 20161015054644 20856
   Subsystem 3 - Part No SW: 8S0 915 181 C    HW: 8S0 915 181 C
   Serial number: 9404233204
[B]1 Fault Found:
8531970 - Quiescent Current
          U1406 00 [008] - Too High
          [Ruhestrom oberer Grenzwert überschritten]
                    Reset counter: 12
                    Mileage: 72748 km
                    Date: 2020.09.29
                    Time: 05:20:13
                    Supply voltage: Terminal 30: 12.3 V
                    Terminal 15: OFF[/B]
   Part No SW: 0CQ 907 554 K    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7762
   Serial number: HA1-00008.08.16
   Coding: 0601
   ROD: EV_AllWheelContrHA1VW37X_002.rod
   VCID: 4DC76DE7DD50B893E95-8018
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
   Component: LCM_MQB       H06 0017
   VCID: 42DD4EDB140E77EB047-8016
   Revision: 00000000    Serial number: 17000601886003
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 343118035EBAC95B86B-8060
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   Part No SW: 3Q0 907 566 D    HW: 3Q0 907 566
   Component: MRR1Rear      H16 0410
   Revision: --------
   Coding: 040002
   ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
   Serial number: 260117EAL03722
   Coding: 005D1B205C00048000000002
   VCID: 43D34BDF0B147EE30F1-8016
   Coding: 8106
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2D363B7CDE3F2B5C7-806E
   Part No SW: 81A 035 466     HW: 81A 035 466
   Component: MIB2_amp_P_A3 H10 0100
   Revision: 00000001    Serial number: AUZ8ZAGHX00LHJ-
   Coding: 0173030000AAAA2AAA0000010000
   ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
   ROD: EV_AMPMst16C9Gen2ALPI.rod
   VCID: 629DAE5BB4CE17EB247-8036
   Serial number: 280117EAR02858
   Coding: 005D13205E00048000000002
Address 55: Headlight Range (J745)       Labels:* None
   Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0230
   Coding: 0E62021123200400
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
   VCID: 3E253A2B60F6130B60F-806A
   Part No SW: 8V1 035 880 A    HW: 8V1 035 880
   Component: MU-P-LNS-US   053 0906
   Serial number: A702B0HS002237
   Coding: 017361020000000011220002041A00002F0028E4017001047E
   VCID: 38292C3342D22D3BAA3-806C
   Subsystem 1 - Part No SW: V03 959 801 GG    HW: -----------
   Component: NAR 2017  --- 0057
   Component: DU High  H49 0014
   Serial number: AUZ8Z9G1Y00Y4G
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL102021700010361
   Compact Disc Database:
   Component: Gracenote2---  --- 3011
   Coding: 0273010102002001400040
   Serial number: 180117EAH10024
   Coding: 000C13204000048000000002
   Serial number: 180117EAH06763
   Part No SW: 3Q0 907 590 D    HW: 3Q0 907 590
   Revision: --------
   Coding: 040002
   ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
   VCID: 3635220B48C6DB4BB8F-8062
   ROD: EV_LEDModLeftMELCOAU736_AU37.rod
   VCID: 176BCF8F2F0C0243839-8042
End----------(Elapsed Time: 01:52, VBatt start/end: 14.6V/14.5V)-----------
VWT6
Finland
C?ID=295527
Here is a thread on another Forum about 5th generation Haldex peculiarity - or actually how an ECU strangely controls Haldex clutch on another VAG platform ---> https://www.t6forum.com/threads/4motion-abnormality-and-subsequent-failure.7157/ However, as mentioned there the results were unique to that ECU, TCU, Haldex -combination and can't be generalized.
Haldex 5th gen self calibration is vaguely mentioned e.g. in VW Self-study Programme 515 - The Golf 2013, Running Gear and Four-wheel Drive Concept (cited below). Link ---> https://procarmanuals.com/vag-ssp-515-golf-2013-running-gear-four-wheel-drive-concept/
" The pressure-current characteristic curve calibration
The basic settings must be performed after each
pump and control unit replacement. The four-wheel
drive clutch is first vented, and then calibrated to 0
and 44bar, each time the basic settings are restored.
The calibration determines how much current is
required to build up a given pressure. Using the
characteristic curve (which is not a straight line) the
pump is fed different amounts of power by the control
unit in order to direct the torque transferred for the
respective driving situation to the rear axle. If the
basic settings are cancelled, the default values will be
used. Venting and calibration are carried out
automatically each time the vehicle is driven.
MnHotRod
Minneapolis, USA
C?ID=419241
VWT6 - Impressive research. Thank you for sharing your experience here.
I’m concerned about potential damage and wear the my “issue” is causing to the Haldex clutch assembly and other driveline components in my car. I can’t imagine what it will be like driving the car when it snows.
I ordered a new pump, which arrived a few days ago. I am planning to replace it myself. With your comment above, I’m interested to find out if the dealer has a procedure for calibrating the system when the pump is replaced.
morris39
Canada
C?ID=395084
automatically each time the vehicle is driven."
Can you clarify the last sentence which suggest that
Can you pls clarify the last sentence? Ia the venting/calibration a separate shop step following pump change (or other chnages?) or is the car driven to self calibrate and then the basic settings are done?
VWT6
Finland
C?ID=295527
AFAIK the car does self calibration while driving. When the pump was replaced on my car it was just it - no ODIS session. No mention about need of basic settings in workshop manual either (Erwin: Workshop Manual, Transporter 2016 ➤, Propshaft and rear final drive, Edition 01.2019).
Below is a clip of my own VCDS session immediately after replacement of full Haldex system. Doing steady 50km/h (in suburbs) at time stamp 547.17 seconds the pump builds up the pressure to the maximum for almost two seconds. That seemed to be it. I did drive&record for 30 minutes more.
Tuesday
19​
DecemberData version: 20171213 DS285.1
0AY 907 554 LADVMBHaldex4Motion H53 7620
G001G006G007G008G009G016G019G021G022
MarkerTIMELoc. IDE00019Loc. IDE00920Loc. IDE00921Loc. IDE00922Loc. IDE00923Loc. IDE04502-MAS04730Loc. IDE05707Loc. IDE05710Loc. IDE06111
STAMPVoltage terminal 30Front left wheel speedFront right wheel speedLeft rear wheel speedRight rear wheel speedHaldex clutch status-Degree of blockageHaldex clutch pump currentHaldex clutch pump voltageAxle speed deltas
Vkm/hkm/hkm/hkm/h%AVkm/h
544.77​
14.4​
51.2​
51.1​
51.5​
51.1​
8.3​
2.7​
3.5​
0.2​
545.01​
14.4​
51.5​
51​
51.1​
51​
8.3​
2.6​
3.5​
0​
545.25​
14.4​
51.4​
50.9​
51.4​
51.2​
8.3​
2.7​
3.5​
0.2​
545.49​
14.4​
51.4​
51.1​
51.5​
51.1​
8.3​
2.6​
3.4​
0​
545.74​
14.4​
51.6​
51​
51.6​
51.2​
8.3​
2.5​
3.4​
0.1​
545.98​
14.4​
51.6​
51.2​
51.8​
51.1​
8.3​
2.8​
3.5​
0.1​
546.22​
14.4​
51.7​
51.2​
51.9​
51.2​
8.3​
2.5​
3.4​
0.1​
546.45​
14.4​
51.8​
51.3​
51.6​
51.3​
8.3​
2.7​
3.5​
0​
546.69​
14.4​
51.7​
51.1​
51.8​
51.4​
8.3​
2.8​
3.5​
0.1​
546.92​
14.4​
51.5​
51.2​
51.7​
51.3​
8.3​
2.6​
3.5​
0.1​
547.17
14.1​
51.6​
51.3​
51.5​
51.2​
48.8
7.8​
6.6​
0.1​
547.40​
12​
51.6​
51.1​
51.4​
51​
98.4
12.0​
10.6​
0​
547.64​
12.1​
51.3​
50.9​
51.6​
50.8​
98.4
11.6​
10.4​
0​
547.88​
12.5​
51.6​
50.8​
51.5​
51​
98.4
11.3​
9.2​
0.1​
548.11​
12.9​
51.2​
50.8​
51.2​
51​
97.2
10.0​
8.1​
0.1​
548.33​
13.4​
51.5​
50.8​
51.5​
50.7​
70.1
7.9​
7​
0.1​
548.60​
13.8​
51.2​
50.9​
51.5​
51​
46.9
6.2​
6​
0.1​
548.83​
14.1​
51.1​
50.8​
51.3​
51.2​
29.9
4.6​
5​
0​
549.06​
14.3​
51.3​
50.7​
51.4​
50.8​
17.7
3.4​
4.3​
0​
549.32
14.3​
51.3​
50.8​
51.4​
50.9​
11.0
3.4​
3.7​
0.1​
549.56​
14.4​
51.2​
50.9​
51.4​
51.1​
8.3​
2.9​
3.4​
0.1​
549.80​
14.4​
51.3​
51​
51.3​
51.1​
8.3​
2.7​
3.4​
0.2​
550.04​
14.4​
51.1​
50.8​
51.3​
51​
8.3​
2.6​
3.4​
0.1​
550.27​
14.4​
51​
50.6​
50.9​
50.7​
8.3​
2.7​
3.4​
0.1​
550.50​
14.4​
51​
50.7​
51.2​
50.8​
8.3​
3.0​
3.4​
0.2​
550.74​
14.4​
50.9​
50.6​
51​
50.5​
8.3​
2.5​
3.4​
0​
550.98​
14.4​
50.7​
50.5​
51​
50.4​
8.3​
2.5​
3.4​
0​
551.21​
14.4​
50.9​
50.3​
50.9​
50.6​
8.3​
2.5​
3.4​
0.2​
551.46​
14.4​
50.5​
50.4​
50.5​
50.2​
8.3​
2.6​
3.4​
0​
551.70​
14.4​
50.4​
50.3​
50.6​
50.3​
8.3​
2.6​
3.4​
0.3​
551.94​
14.4​
50.3​
50.1​
50.5​
50.1​
8.3​
3.0​
3.4​
0​
552.18​
14.4​
50.2​
50.2​
50.3​
50.2​
8.3​
2.6​
3.4​
0​
552.41​
14.4​
50.4​
50.3​
50.4​
50.6​
8.3​
2.7​
3.4​
0​
Then another clip a week later after the replacement. Again time is from setting off - so at approx. 18 mins. This is what it seems to do - every now and then four short "pulses" about 10.3 seconds apart (as in @MnHotRod 's post above). The pulse "amplitude" seems to be related to vehicle speed - higher speed = less blockage (from other measuments).
To capture these short pulses need to bump up sampling rate (was approx 6 sample sets/second).
Monday 25.12.2017Data version: 20171213 DS285.1
MarkerTIMEIDE00920IDE04502-MAS04730IDE05707
Front left wheel speedHaldex clutch status-Degree of blockageHaldex clutch pump current
seckm/h%A
1053.26​
88.26.72.5
1053.42​
88.36.72.6
1053.59​
88.26.72.4
1053.75
88.227.65.7
1053.93​
88.20.40.8
1054.1​
88.22.03.0
1054.26​
88.16.72.3
1054.43​
88.26.72.4
1063.49​
88.76.72.5
1063.65​
88.65.92.4
1063.82​
88.75.92.3
1063.99​
88.56.32.5
1064.14
88.431.56.0
1064.32​
88.40.40.4
1064.5​
88.73.22.7
1064.66​
88.66.32.5
1064.82​
88.36.32.5
1073.84​
88.85.92.4
1074​
88.75.92.4
1074.17​
88.65.92.3
1074.35​
88.65.92.4
1074.5
88.723.25.5
1074.67​
88.80.40.8
1074.84​
88.94.32.4
1075.01​
88.95.92.4
1075.18​
88.85.92.4
1084.21​
88.85.52.2
1084.38​
895.12.4
1084.54​
88.85.12.3
1084.71​
88.85.12.4
1084.88
88.828.44.1
1085.05​
890.40.3
1085.21​
894.32.4
1085.38​
88.95.12.3
1085.56​
895.52.5
1085.72​
88.85.12.4
1085.9​
89.15.12.5
So thanks again Ross-Tech Team for your help and support to make all the above (and A LOT MORE) possible - I'm still thrilled.
morris39
Canada
C?ID=395084
Tuesday
19​
544.77​
14.4​
51.2​
51.1​
51.5​
51.1​
8.3​
2.7​
3.5​
0.2​
545.01​
14.4​
51.5​
51​
51.1​
51​
8.3​
2.6​
3.5​
0​
545.25​
14.4​
51.4​
50.9​
51.4​
51.2​
8.3​
2.7​
3.5​
0.2​
545.49​
14.4​
51.4​
51.1​
51.5​
51.1​
8.3​
2.6​
3.4​
0​
545.74​
14.4​
51.6​
51​
51.6​
51.2​
8.3​
2.5​
3.4​
0.1​
545.98​
14.4​
51.6​
51.2​
51.8​
51.1​
8.3​
2.8​
3.5​
0.1​
546.22​
14.4​
51.7​
51.2​
51.9​
51.2​
8.3​
2.5​
3.4​
0.1​
546.45​
14.4​
51.8​
51.3​
51.6​
51.3​
8.3​
2.7​
3.5​
0​
546.69​
14.4​
51.7​
51.1​
51.8​
51.4​
8.3​
2.8​
3.5​
0.1​
546.92​
14.4​
51.5​
51.2​
51.7​
51.3​
8.3​
2.6​
3.5​
0.1​
547.17
14.1​
51.6​
51.3​
51.5​
51.2​
48.8
7.8​
6.6​
0.1​
547.40​
12​
51.6​
51.1​
51.4​
51​
98.4
12.0​
10.6​
0​
547.64​
12.1​
51.3​
50.9​
51.6​
50.8​
98.4
11.6​
10.4​
0​
547.88​
12.5​
51.6​
50.8​
51.5​
51​
98.4
11.3​
9.2​
0.1​
548.11​
12.9​
51.2​
50.8​
51.2​
51​
97.2
10.0​
8.1​
0.1​
548.33​
13.4​
51.5​
50.8​
51.5​
50.7​
70.1
7.9​
7​
0.1​
548.60​
13.8​
51.2​
50.9​
51.5​
51​
46.9
6.2​
6​
0.1​
548.83​
14.1​
51.1​
50.8​
51.3​
51.2​
29.9
4.6​
5​
0​
549.06​
14.3​
51.3​
50.7​
51.4​
50.8​
17.7
3.4​
4.3​
0​
549.32
14.3​
51.3​
50.8​
51.4​
50.9​
11.0
3.4​
3.7​
0.1​
549.56​
14.4​
51.2​
50.9​
51.4​
51.1​
8.3​
2.9​
3.4​
0.1​
549.80​
14.4​
51.3​
51​
51.3​
51.1​
8.3​
2.7​
3.4​
0.2​
550.04​
14.4​
51.1​
50.8​
51.3​
51​
8.3​
2.6​
3.4​
0.1​
550.27​
14.4​
51​
50.6​
50.9​
50.7​
8.3​
2.7​
3.4​
0.1​
550.50​
14.4​
51​
50.7​
51.2​
50.8​
8.3​
3.0​
3.4​
0.2​
550.74​
14.4​
50.9​
50.6​
51​
50.5​
8.3​
2.5​
3.4​
0​
550.98​
14.4​
50.7​
50.5​
51​
50.4​
8.3​
2.5​
3.4​
0​
551.21​
14.4​
50.9​
50.3​
50.9​
50.6​
8.3​
2.5​
3.4​
0.2​
551.46​
14.4​
50.5​
50.4​
50.5​
50.2​
8.3​
2.6​
3.4​
0​
551.70​
14.4​
50.4​
50.3​
50.6​
50.3​
8.3​
2.6​
3.4​
0.3​
551.94​
14.4​
50.3​
50.1​
50.5​
50.1​
8.3​
3.0​
3.4​
0​
552.18​
14.4​
50.2​
50.2​
50.3​
50.2​
8.3​
2.6​
3.4​
0​
552.41​
14.4​
50.4​
50.3​
50.4​
50.6​
8.3​
2.7​
3.4​
0​
seckm/h%A
1053.26​
88.26.72.5
1053.42​
88.36.72.6
1053.59​
88.26.72.4
1053.75
88.227.65.7
1053.93​
88.20.40.8
1054.1​
88.22.03.0
1054.26​
88.16.72.3
1054.43​
88.26.72.4
1063.49​
88.76.72.5
1063.65​
88.65.92.4
1063.82​
88.75.92.3
1063.99​
88.56.32.5
1064.14
88.431.56.0
1064.32​
88.40.40.4
1064.5​
88.73.22.7
1064.66​
88.66.32.5
1064.82​
88.36.32.5
1073.84​
88.85.92.4
1074​
88.75.92.4
1074.17​
88.65.92.3
1074.35​
88.65.92.4
1074.5
88.723.25.5
1074.67​
88.80.40.8
1074.84​
88.94.32.4
1075.01​
88.95.92.4
1075.18​
88.85.92.4
1084.21​
88.85.52.2
1084.38​
895.12.4
1084.54​
88.85.12.3
1084.71​
88.85.12.4
1084.88
88.828.44.1
1085.05​
890.40.3
1085.21​
894.32.4
1085.38​
88.95.12.3
1085.56​
895.52.5
1085.72​
88.85.12.4
1085.9​
89.15.12.5
morris39
Canada
C?ID=395084
Thanks for your reply. Below is a modified log in which I wnated to see how the AWD responded on twisty roads and under intentional sudden power application. My results seem a bit different to yours. AWD behaves well funcionally.
Some notes:
Max PWM demand/Current:43%/6.3A on Launch Dontrol
Typ PWM value: 15%
Max wheel rot. delta 8km/hr. Frront wheels significantly less than rears
Max axles delata: 0.8%; typical 0-0.2%
Motor amps agree with PWM
Haldex Temp : 48-50C on 28C day.
It looks like your test was on straight roads and moderate loads or maybe your AWD is not working.:)
Module 22 Log 15.08.2020  Current VCDS version
G008    G009    G019    G020    G022
[B]Lrear    Rear    Pump A    PWM    Axle Delta[/B]
km/h     km/h     A     %     km/h
0    0    0.009    0    0
2.7    1.8    2.469    22    0.1
3.1    3.3    1.102    17    0.1
4.2    4.4    1.052    15    1
14.7    12.2    1.674    19    0.8
19.5    16.9    2.071    21    0.1
25.7    21.4    3.413    29    0.3
33.5    27.7    3.09    30    0
40.9    34.9    3.239    30    0
46.1    41.9    2.245    25    0
47.8    46.6    1.152    16    0
48.2    47.7    1.052    15    0
38.2    37    1.4    19    0
41.3    39.5    1.698    21    0.1
44.8    42.7    3.09    28    0
50.7    46.2    2.866    30    0
52.7    51.8    1.027    17    0
51.4    52.8    1.102    15    0.1
32.1    49.3    0.928    15    0.1
21.3    30.1    0.903    15    0.1
16.7    21.1    1.276    15    0.1
16    16.5    1.003    15    0
15.9    16.1    1.077    17    0
17.6    16.7    1.972    22    0
17.2    19.4    1.077    15    0.2
16.3    18.8    1.052    15    0.6
16.6    17.6    0.953    15    0.2
17.4    16.8    1.425    18    0.4
19.9    18.4    1.45    19    0.1
22.6    20.2    1.574    21    0.1
25.3    22.2    1.897    21    0.9
27.7    25.1    1.872    27    0
31.7    26.9    3.065    29    0
37.3    31.2    3.661    32    0.2
48.2    37.4    4.755    40    0.3
56.7    48.4    6.295    43    0
66.3    57.7    4.357    34    0
73.6    67.4    3.637    31    0.2
72.7    73.8    0.953    15    0
70.7    72.7    0.903    15    0
71.5    70.8    2.444    25    0.1
75.8    71.9    2.046    25    0.6
80.2    76.6    2.17    24    0.1
82.4    80.6    1.947    23    0
84    82.6    1.35    18    0
84.4    84    1.45    16    0.1
85.4    84.2    2.195    25    0.2
90.7    85.8    2.717    28    0.8
95.6    91.5    2.618    26    0.1
98.4    96.2    2.021    19    0.1
98.7    98.4    1.326    15    0.1
98.9    98.9    1.102    15    0.2
99    98.8    1.077    15    0.1
100.8    99.4    1.649    19    0.1
101.9    101.4    1.276    17    0.2
102.6    102.3    0.928    15    0.1
103.4    103.1    1.201    16    0.5
105    104    1.823    22    0.1
108.1    106.1    1.947    23    0
112.4    108.6    3.363    29    0.1
117.1    113.4    2.493    28    0
119    117.6    1.077    21    0.1
120.7    119.3    1.947    23    0
122.3    121.1    1.872    23    0.1
125.8    122.5    2.817    26    0
112.7    113.7    0.978    15    0.3
111.8    112.6    1.276    17    0.1
111.6    112    1.326    18    0.2
111.5    111.7    1.35    18    0.3
112.1    111.8    1.897    21    0.2
111.5    112.4    1.35    19    0.2
102.7    103.1    1.226    16    0
102.5    102.6    1.425    18    0.2
102.9    102.5    1.997    22    0
105.8    103.4    2.419    26    0
107.3    106.1    1.872    21    0.1
107.3    107.5    1.624    18    0
106.2    107.1    1.301    15    0.2
105.4    106.1    0.829    15    0.1
105.2    105.7    1.027    15    0.3
104.8    105.3    1.276    15    0.2
104.6    104.8    1.027    15    0.2
104    104.9    1.027    15    0.3
104.7    104.7    1.177    16    0.3
105.1    104.8    1.077    16    0.1
105.2    105.6    1.375    15    0.4
105.8    105.4    1.201    16    0
107.1    105.9    1.773    21    0
109.5    107.3    2.121    23    0.1
111    109.9    1.723    21    0
111.5    111.2    1.127    16    0.1
111.8    111.6    1.226    15    0.1
79.9    87.2    0.903    15    0
79    79.8    1.425    22    0.1
82.3    79.1    2.27    29    0.1
91.8    83.5    3.96    32    0.4
100.4    93.1    3.115    31    0.5
104.3    101.2    2.792    26    0.5
105.6    104.4    1.599    20    0
108    105.8    2.369    23    0
109.7    108.3    2.195    23    0.1
111    110.1    1.649    19    0
111.4    111.1    1.4    17    0
111.3    111.5    1.177    15    0.1
112.4    111.4    1.226    17    0.1
114.7    112.7    1.524    20    0
115.5    114.9    1.35    16    0.5
115.9    115.8    0.978    15    0.5
117    116.1    1.276    16    0.4
119.4    117.3    1.475    21    0.3
120.5    119.7    1.5    16    0.1
128.4    127.7    0.878    15    0.1
130.1    128.9    1.35    17    0.2
120.3    119.2    1.276    19    0.1
123.4    121    1.599    21    0.2
127.4    124.2    1.922    22    0.1
131.9    128    2.096    23    0.5
133.8    132.3    1.549    20    0.1
109.6    110.8    1.052    15    0
107.9    108.9    0.953    15    0.3
107    107.1    1.027    15    0
107.5    106.5    1.649    19    0
109.4    107.4    2.071    21    0.2
112.2    109.5    2.394    26    0.1
77.6    76.9    1.052    16    0.1
79.3    78.3    1.375    19    0.1
81.5    80.4    1.375    19    0.1
83.2    82.4    1.077    16    0.1
85.9    84.1    1.823    21    0
88.7    86.7    1.922    21    0.1
90.6    89.1    1.152    18    0.2
92.6    91    1.574    18    0
94    93.3    0.903    15    0.1
95.3    94    1.425    19    0
97.5    95.7    1.5    20    0.2
99.4    97.7    1.698    20    0.1
100    99.4    1.475    17    0.1
96.9    98.2    1.077    15    0
96.2    97    1.177    15    0.2
96.8    96.2    0.953    15    0.1
98.3    97.1    1.425    18    0
99.5    99    1.475    17    0.2
100.5    99.9    1.226    16    0
98.7    97.7    1.027    17    0.2
99.7    98.5    1.475    17    0.1
99.5    99.1    0.978    15    0.2
98.9    99.2    1.177    15    0.1
98.2    98.7    0.928    15    0.1
97.3    98.4    0.928    15    0
87.4    87.7    0.953    15    0.1
86.8    87.2    0.878    15    0
85.9    86.4    1.201    15    0
85.5    85.6    0.978    15    0.1
86.8    85.4    1.301    16    0.2
87.6    86.8    1.027    15    0.3
88.4    87.7    0.953    14    0.3
89.1    88.5    0.903    14    0.1
89.1    89.2    1.102    14    0
