2006 Golf (a/k/a Rabbit) Steering Assist question
DanVermont
Vermont, USA
C?ID=418840
The steering assist fails intermittently. Steering becomes heavy.
Car has over 120,000 miles. Battery is 2017 but car has undergone recent, professional(?) repairs under the hood.
Other discussions on forum suggest this may be a battery issue.
I suspect a bad connection ("open circuit"). Where should I look for the open circuit?
PS. Local garage that did all the work wants to replace the steering rack.
History:
  1. Transmission locked up.
  2. Local garage replaced transmission with used. Drives okay.
  3. Within a week, steering assist failed.
  4. Disconnected battery 15 min for "reset". Steering assist was restored.
  5. Within a week, alternator failed.
  6. Local garage replaced alternator with new.
  7. Within a week, steering assist failed (again). Could not reset.
  8. Bought VCDS for Auto Scan. See below. There are other DTCs.
  9. Code:
       Part No: 1K1 909 144 K
       Component: EPS_ZFLS Kl.5   D06 1701
       VCID: 33331B75373926339F1-8066
    00569 - Steering Motor Current
                        Mileage: 7920 km
                        Temperature: 42.0°C
  10. Used VCDS to clear all DTCs. Steering assist was restored.
  11. Waiting for next failure ........
DanVermont
Vermont, USA
C?ID=418840
I think there must be a grounding strap issue.
Here is the complete scan.
Tuesday,29,September,2020,12:27:22:50410
VCDS Version: 20.4.2.0  HEX-V2 CB: 0.4513.4
VIN: WVWCS71K26W184542   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWCS71K26W184542   Mileage: 263420km-163681miles
Address 01: Engine        Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 AP    HW: Hardware No
   Component: 2.5l R5/4V      G   6745
   Revision: --------    Serial number: VWZ7Z0F3684870
   Coding: 0000001
   Shop #: WSC 01279 785 00200
   VCID: 77ABEF6563C10A13639-8022
   Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
   Revision: 00H13001
   Coding: 0021122
   VCID: 71BFD17D0DA55423ADD-8024
   Part No: 1K0 820 047 EC
   Component: Climatic PQ35   090 0505
   VCID: 698FB91D2575ACE3E5D-803C
   Part No SW: 3C0 937 049 P    HW: 3C0 937 049 P
   Component: Bordnetz-SG     H46 1501
   Revision: 00H46000    Serial number: 00000005619264
   Coding: 108D8F214004150000140000001400000008730B5C0000
   Shop #: WSC 01017 444 53928
   VCID: 36352261244B331BB8F-8062
   Subsystem 1 - Part No: 1K1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  013  0402
   Coding: 00063445
   Shop #: WSC 01017
                    Fault Status: 01101100
                    Reset counter: 104
                    Voltage: 7.90 V
                    Fault Status: 00101001
                    Reset counter: 144
                    Mileage: 261996 km
                    Voltage: 13.75 V
   Part No SW: 1K0 909 605 P    HW: 1K0 909 605 P
   Component: 5L AIRBAG VW8R  032 7900
   Revision: 03032000    Serial number: 0038FD05MTKT
   Coding: 0013644
   Shop #: WSC 01269 785 00200
   VCID: 392F295D1555DC6355D-806C
   Subsystem 1 - Part No: 1K0 959 339 D
   Component: BF-Gewichtsens. 006 0006
   Subsystem 2 - Serial number: 6332MSME104F3B70C
   Subsystem 3 - Serial number: 6342MSME104F217AC
   Subsystem 4 - Serial number: 6352QSME0C592349L
   Subsystem 5 - Serial number: 6362QSME0C363D1FV
   Subsystem 6 - Serial number: 63727SME0A025D3A3
   Subsystem 7 - Serial number: 63827SME0965542E6
02513 - Belt Force Sensor for Seat Occupied Recognition (G453)
   Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
   Component: J0527           034 0070
   Coding: 0000022
   VCID: 78A9EC596EDF056B6A3-802C
   Part No: 1K0 920 953 C
   Component: KOMBIINSTRUMENT VDD 4312
   Coding: 0007203
   Shop #: WSC 01505 444 54606
   VCID: 2B030315EF097EF3D71-807E
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 280010641005A1
   Coding: 3D3F0340070002
   VCID: 2A0D0611E0F367FB2C7-807E
   Component: IMMO            VDD 4312
01176 - Key
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2373
   Coding: 0001205
00912 - Window Regulator Switch; Front Left (E40)
                    Mileage: 7920 km
                    Temperature: 42.0°C
   Part No: 1K0 959 433 AF
   Coding: 13C803281B09058F880F048050CC
   Shop #: WSC 01505 444 94845
   VCID: 74B1D86972B7610B46B-8020
   Part No: 1K0 959 702 K
   Coding: 0001205
   VCID: 372B2F652341CA13A39-8062
   Part No SW: 1K0 035 180 D    HW: 1K0 035 180 D
   Component: Radio PM6       016 0017
   Revision: 00016000    Serial number: VWZ5Z7F2067439
   Coding: 0040400
   VCID: 211FE13D9DC5A4A37DD-8074
   Part No: 1K0 959 703 F
   Component: Tuer-SG         021 2438
   Coding: 0000144
   Part No: 1K0 959 704 F
   Coding: 0000144
   VCID: 343118693237210B86B-8060
End----------(Elapsed Time: 01:02, VBatt start/end: 13.8V/13.7V)-----------
DanVermont
Vermont, USA
C?ID=418840
Geoffzie posted to this list back in July 2018 that the Steering Rack is grounded to the Transmission in his 1K "Passetta" (2.5L engine). Geoffzie cleaned this ground and the Steering Assist problem was fixed. I think this is my starting point. Still to be done.
It certainly wouldn't hurt to check all wiring/verify and connections to the rack.
