New User. BGU troubles
Nevilleh
South Africa
C?ID=415296
Vw caddy 1.6i petrol 2005 BGU motor
Vehicle starts, very poor idle, after few seconds the accelerator goes dead doesn't respond, if I restart vehicle it works for few seconds then trouble again.
Idle is bad, just fitted new throttle body
Mechanics in my town too busy to have a look at it
Please assist pointing me in the direction to start.
Scan:
Tuesday,29,September,2020,13:49:18:41558
[URL="http://www.Ross-Tech.com"]www.Ross-Tech.com[/URL]
Dealer/Shop Name: ATMT ELECTRONICS
VIN: WV1ZZZ2KZ5X065729   License Plate: CADDY1
Mileage: 273770km-170112mi   Repair Order:
Chassis Type: 2K (1K0)
Scan: 01 03 09 15 16 17 19 25 44 56
VIN: WV1ZZZ2KZ5X065729   Mileage: 273770km-170112miles
44-Steering Assist -- Status: Sporadic communication error 1000
Address 01: Engine        Labels: 06A-906-033-BGU.lbl
   Part No: 06A 906 033 CF
   Component: SIMOS71 1.6l 2VG    9867
   Revision: --H04---    Serial number: VWZ7Z0D1216935
   Coding: 0002031
   Shop #: WSC 00999 444 64523
   VCID: 65964EF7C96BE343C15-8030
10 Faults Found:
17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
            P1172 - 007 -
                    Bin. Bits: 00000001
                    Load: 16.5 %
                    Bin. Bits: 00000001
                    Load: 16.5 %
18107 - Powertrain Data Bus
            P1699 - 009 - Missing Message from Steering Wheel Electronics
                    Load: 7.5 %
                    Bin. Bits: 00000001
                    Load: 7.5 %
                    Bin. Bits: 00000001
17987 - Throttle Actuator (J338)
            P1579 - 008 - Adaptation Not Started
                    Bin. Bits: 00000001
                    Load: 16.5 %
                    Bin. Bits: 00000001
                    Load: 16.5 %
18057 - Powertrain Data Bus
            P1649 - 009 - Missing Message from ABS Controller - Intermittent
                    Mass Air / Rev.: 0.0 mg/str
                    Torque: 6.0 Nm
                    Bin. Bits: 00000000
                    Torque: 6.0 Nm
                    Bin. Bits: 00000000
18288 - Powertrain Data Bus
            P1880 - 009 - Missing Message from Diagnostic Gateway - Intermittent
                    Temperature: 19.5°C
                    Bin. Bits: 00000001
                    Temperature: 19.5°C
                    Bin. Bits: 00000001
16784 - EGR System
            P0400 - 008 - Malfunction - Intermittent
                    Voltage: 12.14 V
                    Load: 85.9 %
                    Voltage: 12.24 V
                    Load: 74.1 %
16726 - Camshaft Position Sensor (G40)
            P0342 - 009 - Signal too Low - Intermittent
                    RPM: 576 /min
                    Mass Air / Rev.: 414.2 mg/str
                    Bin. Bits: 00000010
                    Temperature: 18.0°C
17952 - Angle Sensor 1 for Throttle Actuator (G187)
            P1544 - 006 - Signal too Large - Intermittent
                    Bin. Bits: 00000001
                    Load: 100.0 %
                    Bin. Bits: 00000001
                    Load: 100.0 %
17950 - Angle Sensor 1 for Throttle Actuator (G187)
            P1542 - 008 - Implausible Signal - Intermittent
                    Mass Air / Rev.: 147.2 mg/str
                    Bin. Bits: 00000100
                    Load: 11.4 %
                    Mass Air / Rev.: 163.5 mg/str
                    Bin. Bits: 00000100
                    Load: 10.6 %
17978 - Engine Start Blocked by Immobilizer
            P1570 - 008 -  - Intermittent
                    Temperature: 43.5°C
                    Voltage: 12.75 V
                    Bin. Bits: 00000001
Readiness: 0010 1101
   Part No: 2K0 907 379 A
   Coding: 0017106
   Shop #: WSC 35110 377 08192
   VCID: 313EEAA7CD237FE3EDD-8064
Address 09: Cent. Elect.        Labels:. 1K0-937-049-21-B.lbl
   Part No SW: 1K0 937 049 P    HW: 1K0 937 049 P*
   Component: Bordnetz-SG 1.0 H32 0401
   Revision: 00H32000    Serial number: 00000001344702
   Coding: 00844F0000041000000000000000000000
   VCID: 3C20CB931A61828B4EB-8068
   Subsystem 1 - Part No: 2K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW357  012  0402
   Coding: 00065493
   Shop #: WSC 35110
Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
   Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
   Component: 09 AIRBAG VW52  023 2400
   Revision: 04023000    Serial number: 0037TD05D9SL
   Coding: 0012345
   Shop #: WSC 35110 377 00192
   VCID: 7DA6069741FB4B83395-8028
   Part No SW: 1K0 953 549 E    HW: 1K0 953 549 E
   Component: Lenksäulenmodul 521 0050
   Coding: 0000001
   VCID: 3430E3B332314ACB86B-8060
   Part No: 2K0 920 841 B
   Component: KOMBIINSTRUMENT VDD 0716
   Coding: 0016103
   Shop #: WSC 02232 996 63502
   VCID: 270A04FFF3E73153339-8072
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 2700104C040DDD
   Coding: 3D010140079001
   VCID: 290E02C7E5F3072325D-807C
                    Reset counter: 184
                    Mileage: 273750 km
                    Time: 01:32:09
01304 - Radio
                    Reset counter: 184
                    Mileage: 273750 km
                    Time: 01:32:14
                    Reset counter: 224
                    Mileage: 273757 km
                    Time: 00:56:44
   Component: IMMO            VDD 0716
   Part No: 1K2 909 144 H
   Component: EPS_ZFLS Kl.11      1502
Address 56: Radio
End----(Elapsed Time: 00:38, VBatt start/end: 12.6V/12.5V. VIgn 0.0V)------
This car is a mess of fault codes, most of which are flagged "Intermittent". That makes for a very low signal-to-noise ratio. Please clear all fault codes, then do another scan so we can see what comes back.
Nevilleh
South Africa
C?ID=415296
Hi
I cleared all errors, and then redone a scan, it came up with these errors
Wednesday,30,September,2020,08:21:06:41558
VIN: WV1ZZZ2KZ5X065729   License Plate: CADDY2
   Coding: 0002031
            P1172 - 007 -
                    Bin. Bits: 00000001
                    Load: 19.2 %
                    Bin. Bits: 00000001
                    Load: 19.2 %
                    Load: 11.4 %
                    Bin. Bits: 00000001
                    Load: 11.4 %
                    Bin. Bits: 00000001
                    Bin. Bits: 00000001
                    Load: 19.2 %
                    Bin. Bits: 00000001
                    Load: 19.2 %
                    Mass Air / Rev.: 152.6 mg/str
                    Bin. Bits: 00000100
                    Load: 11.4 %
Readiness: 0110 1101
   Coding: 0017106
   Coding: 00065493
   Shop #: WSC 35110
01835 - Bulb for Side-Blinkers; Right (M19)
   Coding: 0012345
   Coding: 0000001
   Coding: 0016103
                    Reset counter: 184
                    Mileage: 273775 km
                    Time: 00:06:36
01304 - Radio
                    Reset counter: 184
                    Mileage: 273775 km
                    Time: 00:06:40
Address 56: Radio
End----------(Elapsed Time: 00:37, VBatt start/end: 12.6V/12.4V)-----------
iichel
Eindhoven, NB, NL
C?ID=284912
edit: ignore this post. i misread.
iichel
Eindhoven, NB, NL
C?ID=284912
Apologies. Yes, golf_vendi is right. Please ignore my previous comment.
Then I'd start at the wiring and/or connectors to and from the actuator. Load test wires end to end and check connectors for corrosion.
Nevilleh
South Africa
C?ID=415296
Thanks alot for you'lls help.
When doing throttle body alignment with both old and new throttle body Result: "Error" only noticed now the wiring to throttle has been cut up and rejoined very poorly with joining wires coming from other components
Any idea where I can find the wiring layout/ diagrams for the engine bag electrical
MartinsX
Riga, Latvia
C?ID=268515
The exact WD and other factory repair information can be found in ErWin (it is not for free).
You can try to find something for free here (biggest part of info is in Russian language)
