All systems malfuntion after low coolant warning
wkeating
South Africa
C?ID=307967
Hi I had radiator leak , then low coolant level warning , repaired the radiator, then this problem popped up: oil sensor / low oil pressure warning and all systems malfuntion (accept one), Any advice as to what the problem could be, should i change out the sensor , reset code and see the outcome?
VW POLO 1.2 TSI 2014 Model
Tuesday,29,September,2020,11:52:03:42541
[URL="http://www.Ross-Tech.com"]www.Ross-Tech.com[/URL]
VIN: AAVZZZ6RZGU011655   License Plate:
Mileage: 72160km-44838mi   Repair Order: x
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 15 16 17 19 44 5F
VIN: AAVZZZ6RZGU011655   Mileage: 72160km-44838miles
16-Steering wheel -- Status: Cannot be reached 0100
Address 01: Engine (J623-CJZC)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 BB    HW: 04E 907 309 AF
   Component: R4 1.2l TFS   H22 9016
   Revision: R4H22---
   Coding: 01110012232410010000
   Shop #: WSC 31414 790 50316
   ASAM Dataset: EV_ECM12TFS01104E906027BB 001008
   ROD: EV_ECM12TFS01104E906027BB.rod
   VCID: 659640D9E5EBA4F3C15-8030
   CAN Converter 01:
14632 - Coolant Pump for Intercooler
          P190D 00 [040] - Mechanical Malfunction
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 13:22:56
                    Engine speed: 1783.00 /min
                    Normed load value: 17.3 %
                    Coolant temperature: 110 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 13.947 V
                    Mass flow through throttle valve: 10.7 kg/h
                    Median injection timing: 0.615 ms
                    Engine operating condition: Deceleration
                    Engine operating condition-Test_Program_Channel 87: 9
                    A/C compressor: load current: act. value: -415.50 A
4714 - Steering Column Control Module
          U0212 00 [047] - No Communications
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 00:01:16
                    Engine speed: 960.50 /min
                    Normed load value: 27.5 %
                    Coolant temperature: 69 °C
                    Intake air temperature: 29 °C
                    Voltage terminal 30: 13.900 V
                    selected gear-Bits 0-7: 0
5582 - Oil Pressure Switch for reduced Oil Pressure
          P164D 00 [047] - Malfunction
                    Fault Frequency: 12
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 13:24:34
                    Engine speed: 2277.50 /min
                    Normed load value: 11.0 %
                    Coolant temperature: 99 °C
                    Intake air temperature: 40 °C
                    Voltage terminal 30: 13.876 V
                    Mass flow through throttle valve: 15.2 kg/h
                    Median injection timing: 0.475 ms
                    Engine operating condition: Part. load
                    Engine operating condition-Test_Program_Channel 87: 6
                    Driver-side belt buckle status-Bits 0-7: 109
                    Engine torque: 15.7 Nm
7786 - Sensor for Ambient Air Temperature (G17)
          P0070 00 [175] - Malfunction
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 00:01:18
                    Engine speed: 944.50 /min
                    Coolant temperature: 70 °C
                    Mass flow through throttle valve: 10.2 kg/h
                    Median injection timing: 0.827 ms
                    Engine operating condition: Idling
                    A/C compressor: load current: act. value: -79.50 A
Readiness: 0000 0001
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 G    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0003
   Serial number: 08513789150706
   Coding: 23DD2885492433C1091A006E0056C41492CC90000005C9098000
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 3332EE811BBF0A439F1-8066
0716 - Databus
          [Scl_KBI_Aussen_Temp_gef_Error]
                    Fault Frequency: 8
                    Reset counter: 159
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 00:01:20
0717 - Databus
          [Scl_KBI_Aussen_Temp_gef_Invalid]
                    Reset counter: 156
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 00:01:20
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6C0 820 045 A    HW: 6C0 820 045 A
   Component: AC Manuell    H02 0103
   Serial number:  1404061B-0265
   Coding: 200000010000100000
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26.rod
   VCID: 1D6628398D3BAC33595-8048
262914 - Refrigerant Pressure
          B10AB F0 [012] - Too Low
                    Reset counter: 196
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 14:41:34
590082 - Control Circuit for A/C Compressor
          B10A9 15 [012] - Open or Short to Plus
                    Reset counter: 196
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 15:13:21
                    Compressor shut-off requirement: Outside air temperature too low
                    Compressor current: actual value: 1.275 mA
                    Compressor current: specified value: 0.000 mA
                    Voltage terminal 30: 14.0 V
459015 - Databus
          U1121 00 [012] - Missing Message
                    Fault Frequency: 32
                    Reset counter: 199
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 00:01:20
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
          B10F0 00 [012] - -
                    Reset counter: 198
                    Mileage: 72008 km
                    Date: 2020.09.28
                    Time: 15:11:28
                    Voltage terminal 30: 13.9 V
                    Compressor shut-off requirement: Shut-off of engine control module via CAN (T > 15 sec.)
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 C    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H08 0086
   Serial number: 001378108798
   Coding: 030008404053005B4F844080A107038000005B0053010000000000000000
   ASAM Dataset: EV_BCMA0 005005
   ROD: EV_BCMA0_005.rod
   VCID: 3038E18DEAA9315BE23-8064
   Drivers Door Control Module:
   Subsystem 1 - Part No SW: 6R0 959 802 AT    HW: 6R0 959 802 AT  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU015041441051164
   Coding: 1000A0
   Subsystem 2 - Part No SW: 6R0 959 801 BB    HW: 6R0 959 801 BB  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU021031440803452
   Coding: 0000A0
   Subsystem 3 - Part No SW: 6C0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY140691MEN
   Subsystem 4 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
   Component: J388__TSG_HL  003 8610
   Serial number: KU0KU010041441001612
   Coding: 0000A0
28 Faults Found:
5386 - Bulb for Front Right Turn Signal
          B11EA 15 [008] - Open or Short to Plus
                    Reset counter: 197
                    Mileage: 71996 km
                    Date: 2020.09.28
                    Time: 15:02:58
6666 - Bulb for Low Beam Headlamp Left
          B1217 15 [008] - Open or Short to Plus
                    Reset counter: 196
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 13:12:50
6922 - Bulb for Low Beam Headlamp Right
          B1218 15 [008] - Open or Short to Plus
                    Reset counter: 196
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 13:12:50
7434 - Bulb for High Beam Headlamp Right
          B121A 15 [008] - Open or Short to Plus
                    Reset counter: 197
                    Mileage: 72107 km
                    Date: 2020.09.28
                    Time: 19:30:05
8714 - Bulb for Left Fog Lamp
          B121F 15 [008] - Open or Short to Plus
                    Fault Frequency: 12
                    Reset counter: 199
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 19:05:15
8970 - Bulb for Right Fog Lamp
          B1220 15 [009] - Open or Short to Plus
                    Fault Frequency: 12
                    Reset counter: 159
                    Mileage: 71980 km
                    Date: 2020.09.25
                    Time: 10:03:06
9738 - Bulb for Left Parking Lamp
          B12E8 15 [008] - Open or Short to Plus
                    Reset counter: 196
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 13:12:50
9994 - Bulb for Right Parking Lamp
          B12E9 15 [009] - Open or Short to Plus
                    Fault Frequency: 15
                    Reset counter: 159
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 13:12:50
12307 - License Plate Light
          B12CA 01 [008] - Electrical Failure
                    Reset counter: 198
                    Mileage: 71980 km
                    Date: 2020.09.28
                    Time: 13:58:05
131330 - Supply voltage
          [Versorgungsspannung - unterer Grenzwert unterschritten >]
                    Reset counter: 196
                    Mileage: 71980 km
                    Date: 2020.09.26
                    Time: 12:56:47
          U1400 00 [009] - -
          [Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten >]
                    Reset counter: 156
                    Mileage: 71980 km
                    Date: 2020.09.26
                    Time: 12:56:47
132363 - Voltage Supply; Terminal 30; Left
          B140D 13 [008] - Open Circuit
                    Reset counter: 196
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 12:24:09
132619 - Voltage Supply; Terminal 30; Right
          B140E 13 [008] - Open Circuit
                    Reset counter: 196
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 13:02:42
133131 - Voltage Supply Terminal 30
          B1423 13 [008] - Open Circuit
                    Reset counter: 196
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 12:24:09
133387 - Voltage Supply; Terminal 30 for Central Locking
          B140F 13 [008] - Open Circuit
                    Reset counter: 196
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 12:24:09
134155 - Voltage Supply for Terminal 30 of Signal Horn
          B1898 13 [008] - Open Circuit
                    Reset counter: 196
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 12:24:09
134411 - Voltage Supply for Terminal 30 of Front Wipers
          B1899 13 [008] - Open Circuit
                    Reset counter: 196
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 13:03:16
134667 - Voltage Supply for Terminal 30 of Exterior Mirror Heating
          B1900 13 [008] - Open Circuit
                    Reset counter: 196
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 12:24:09
134923 - Voltage Supply for Terminal 30 of Rear Window Heating
          B1901 13 [008] - Open Circuit
                    Reset counter: 196
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 12:24:09
137217 - Outside temperature sensor
          B103F 1B [009] - Resistance Too High
                    Fault Frequency: 29
                    Reset counter: 159
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 00:01:17
262912 - Sensor for Anti-Theft Alarm System
          B1330 F5 [009] - Alert Emergency Activation Stage 1
                    Fault Frequency: 12
                    Reset counter: 159
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 17:45:17
264452 - No Communications with Anti-Theft Sensor
          U10F4 00 [008] - -
          [Sensor-DWA->kein Signal/ Kommunikation]
                    Reset counter: 196
589592 - Databus
          U1201 00 [008] - No Communications
          [CAN Keine Kommunikation]
                    Reset counter: 196
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 12:24:09
594436 - Window Regulator Motor; Front Driver Side
          B1321 02 [009] - Signal Failure
                    Reset counter: 159
                    Mileage: 71980 km
                    Date: 2020.09.25
                    Time: 10:03:00
594440 - Window Regulator Switch; Rear Driver Side
          B1323 29 [009] - Signal Implausible
                    Reset counter: 159
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:30:21
594948 - Window regulator motor; front passenger side
          B1322 02 [009] - Signal Failure
                    Fault Frequency: 98
                    Reset counter: 159
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 00:01:15
594952 - Window Regulator Switch; Rear Passenger Side
          B1324 29 [009] - Signal Implausible
                    Reset counter: 159
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:28:33
919560 - Light Switch
          B126A 29 [009] - Signal Implausible
                    Reset counter: 157
                    Mileage: 71988 km
                    Date: 2020.09.28
                    Time: 14:57:08
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 E    HW: 6C0 959 655 E
   Component: VW20Airbag00H 001 0360
   Revision: --------    Serial number: 003RH003FKYX
   Coding: 88C0C00000000000000000CA008800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3536D09915CB1473B15-8060
   Subsystem 1 - Part No SW: -----------    HW: 410 823 103 14
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00102830F3303C1
   Subsystem 2 - Part No SW: -----------    HW: 410 823 103 14
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00102830F31A140
   Subsystem 3 - Part No SW: -----------    HW: 442 152 904 14
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00B31534AC5E13C
   Subsystem 4 - Part No SW: -----------    HW: 442 151 504 14
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A009D1534AC4516E
9440027 - Driver's side; side-airbag igniter
          B100B 1B [137] - Resistance Too High
                    Fault Frequency: 11
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 00:01:17
Address 16: Steering wheel
   Part No SW: 6C0 920 740 C    HW: 6C0 920 740 C
   Component: KOMBI         201 1420
   Coding: 232509002080000801082A001000000000000000
   VCID: 221C1BC5B44593CB647-8076
13635840 - Supply voltage
          [Versorgungsspannung - unterer Grenzwert unterschritten Versorgungsspannung Spannung dauerhaft zu niedrig]
                    Reset counter: 196
                    Mileage: 71980 km
                    Date: 2020.09.26
                    Time: 00:03:01
13639936 - Databus
          [Steuergerät für BCM / Bordnetz / el. ZE: bitte Fehlerspeicher auslesen]
                    Fault Frequency: 23
                    Reset counter: 159
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 00:01:15
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H08 0086
   Revision: --------    Serial number: 001378108798
   Coding: 01010008200A560071000000000000000001010000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_013_VW26.rod
   Subsystem 1 - Part No SW: 6C0 959 442     HW: 6C0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAT  H04 0019
   Serial number: 2231406184900705AB1B
   Coding: 240000
131596 - Steering Column Control Module
          U0212 00 [009] - No Communications
          [Timeout Knoten 0x0C / 16 - Steuergerät für Lenksäulenelektronik]
                    Reset counter: 156
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 00:01:15
                    Supply voltage: Terminal 30: 14.0 V
                    Terminal 15: On
131699 - Control unit for information electronics 1
          U1054 00 [009] - No Communication
          [Timeout Knoten 0x73 / 5F - Steuergerät für Informationselektronik 1]
                    Reset counter: 156
                    Mileage: 71980 km
                    Date: 2020.09.24
                    Time: 00:01:15
                    Supply voltage: Terminal 30: 14.1 V
                    Terminal 15: On
131702 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [008] - -
          [Timeout Knoten 0x76 / 01 - Motorsteuergerät]
                    Reset counter: 196
                    Mileage: 71980 km
                    Date: 2020.09.26
                    Time: 19:03:12
                    Supply voltage: Terminal 30: 11.0 V
                    Terminal 15: OFF
197169 - Controls in Steering Wheel
          U108E 00 [008] - No Communications
          [MFL (LIN#2) Timeout]
                    Reset counter: 196
                    Supply voltage: Terminal 30: 12.1 V
                    Terminal 15: OFF
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C2 909 144 AG    HW: 6C2 909 144 D
   Component: EPS_TRW_ALow  322 3232
   Serial number: CF7I0575
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016026
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 6E843FF5301D67ABB0F-803A
End----------(Elapsed Time: 00:46, VBatt start/end: 14.1V/13.9V)-----------
   Revision: R4H22---
   CAN Converter 01:
          U0212 00 [039] - No Communications
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:52:44
                    Engine speed: 696.50 /min
                    Normed load value: 33.3 %
                    Coolant temperature: 66 °C
                    Voltage terminal 30: 13.735 V
          P0070 00 [039] - Malfunction
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:52:45
                    Engine speed: 687.00 /min
                    Voltage terminal 30: 13.923 V
                    Mass flow through throttle valve: 9.4 kg/h
                    Median injection timing: 0.991 ms
Readiness: 1110 0001
0716 - Databus
                    Reset counter: 159
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:52:48
0717 - Databus
                    Reset counter: 159
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:52:48
459015 - Databus
                    Reset counter: 199
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:52:47
   Coding: 1000A0
   Coding: 0000A0
   Coding: 0000A0
8 Faults Found:
                    Reset counter: 159
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:52:51
                    Reset counter: 159
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:52:51
                    Reset counter: 159
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:52:43
                    Reset counter: 159
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:52:42
                    Reset counter: 159
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:52:42
                    Reset counter: 159
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:52:42
                    Reset counter: 159
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:52:42
                    Reset counter: 159
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:52:42
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:52:45
13639936 - Databus
                    Reset counter: 159
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:52:42
   Coding: 240000
                    Reset counter: 159
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:52:42
                    Terminal 15: On
                    Reset counter: 159
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:52:42
                    Terminal 15: On
   Coding: 000700
End----------(Elapsed Time: 00:42, VBatt start/end: 14.1V/14.0V)-----------
   Revision: R4H22---
   CAN Converter 01:
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:58:38
                    Engine speed: 697.00 /min
                    Normed load value: 27.8 %
                    Coolant temperature: 90 °C
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:58:39
                    Engine speed: 701.50 /min
                    Voltage terminal 30: 13.970 V
                    Mass flow through throttle valve: 7.7 kg/h
                    Median injection timing: 0.867 ms
0716 - Databus
                    Reset counter: 160
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:58:42
0717 - Databus
                    Reset counter: 160
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:58:42
459015 - Databus
                    Reset counter: 200
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:58:41
   Coding: 1000A0
   Coding: 0000A0
   Coding: 0000A0
8 Faults Found:
                    Reset counter: 159
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:52:51
                    Reset counter: 159
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:52:51
                    Reset counter: 159
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:52:43
                    Reset counter: 159
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:52:42
                    Reset counter: 159
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:52:42
                    Reset counter: 159
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:52:42
                    Reset counter: 159
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:52:42
                    Reset counter: 159
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:52:42
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:58:39
13639936 - Databus
                    Reset counter: 160
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:58:36
   Coding: 240000
                    Reset counter: 160
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:58:36
                    Terminal 15: On
                    Reset counter: 160
                    Mileage: 72160 km
                    Date: 2020.09.29
                    Time: 11:58:36
                    Supply voltage: Terminal 30: 13.9 V
                    Terminal 15: On
   Coding: 000700
End----------(Elapsed Time: 00:41, VBatt start/end: 14.0V/14.1V)-----------
Address 01: DTCs cleared
wkeating
South Africa
C?ID=307967
ok been rectifying electrical issues ....lights windows etc, airbags, instruments and abs dts cleared
can someone give me some advice on how to repair '16-Steering wheel -- Status: Cannot be reached 0100 '
South Molton, UK
I would check the relevant fuses, a WD will help tell you which fuses they are.
Fred's Imports
Vermont, USA
C?ID=16454
Also the hood latch switch but even before doing that unplug the oil level sensor and see if communication comes back. Those things wreak havoc on BMW communication between modules.
wkeating
South Africa
C?ID=307967
Hi I thanks , replaced the oil pressure sender unit code cleared
my only issues now is the steering wheel fault code causing he engine malfunction code
