Monday,28,September,2020,16:18:22:18746
VCDS Version: 20.4.2.0
VIN: VSSZZZNHZD1017978 License Plate: SL13COH
Mileage: 251830km-156479mi Repair Order:
Chassis Type: NH-SK25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 2E 44 56 61 77
VIN: VSSZZZNHZD1017978 Mileage: 251830km-156479miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 QH HW: 03L 906 023 Q
Component: R4 1.6l TDI H33 9977
Revision: --H33--- Serial number:
Coding: 00114016002501080000
Shop #: WSC 73430 031 00065
ASAM Dataset: EV_ECM16TDI02103L906023QH 003007
ROD: EV_ECM16TDI02103L906023QE.rod
VCID: 7CFC25A9F7A25D664F-8028
7383 - Manifold Pressure / Boost Sensor (G31)
P0236 00 [096] - Implausible Signal
Engine speed: 0.00 /min
Vehicle speed: 255 km/h
Coolant temperature: 68 °C
Intake air temperature: 24 °C
Voltage terminal 30: 13.553 V
Charge air pressure: actual value-MAP_MMV: 912.76 hPa
Charge air pressure specified value-MAP_SP_MMV: 912.76 hPa
Ambient air pressure: 100 kPa abs
Particle filter: difference pressure-DIP_PF: 1087.21 hPa
6375 - Internal Control Module
P0606 00 [032] - Processor Fault
Coolant temperature: 74 °C
Intake air temperature: 26 °C
Voltage terminal 30: 3.275 V
Unlearning counter according OBD: 37
Engine status-SF_ENG_STATE: ES
ECM system status-Binary 16 Bit: 00000000 00000000
Hardware monitoring of EEPROM status-FRF_HWMT_EEPROM: 0
Freeze_Frame_1_for_processor_monitoring_error-ENVD_MON_3__1: 871
Freeze_Frame_2_for_processor_monitoring_error-ENVD_MON_3__2: 0
Part No SW: 6R0 614 517 BD HW: 6R0 614 517 BD
Component: EBC 460 ESP H08 0004
Serial number: A007JRU
Coding: 5229481409B200BB4A5012D990A80090480A00
ASAM Dataset: EV_Brake1ESPAEntryTRW 002011
ROD: EV_Brake1ESPAEntryTRW.rod
VCID: 76E83781C98E073639-8022
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6RA 959 654 HW: 6RA 959 654
Component: LENKW.SENSOR H02 0030
Serial number: 24051404210278
Coding: 01
ASAM Dataset: EV_LWSKLOVW25X 005002
ROD: EV_LWSKLOVW25X.rod
VCID: 0F266265D61456FE9A-805A
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6JA 820 045 A HW: 6JA 820 045 A
Component: Man AC H06 0101
Revision: 2013SH06
VCID: 356AF08D9C084C2EF0-8060
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 HW: 7H0 937 090
Component: BCM PQ25 Max4 H72 0708
Revision: B9072001 Serial number: 0531 060131224
Coding: 7D980B0000010000000809302E0B0C810E80400F60020040020000004000
Shop #: WSC 73430 790 00065
VCID: 6BDE16F58ACCCADED6-803E
Subsystem 1 - Part No SW: 6JA 959 538 A HW: 6JA 959 538 A
Component: E221__MFL-TAP H02 0103
Serial number: 00000000000000465316
Coding: E20000
Part No SW: 34D 959 655 B HW: 34D 959 655 B
Component: AirbagVW20 004 0364
Serial number: 003K7R00UBFR
Coding: 88CCC00000000000540000CA008000000045
ASAM Dataset: EV_AirbaVW20SMEVW253 001108
ROD: EV_AirbaVW20SMEVW253_SK25.rod
VCID: 346CCD899F725526C7-8060
Subsystem 1 - Part No SW: ----------- HW: 480 412 302 13
Component: SideSensor_Df 003 0148
Serial number: 349650A2595A1D033F8P
Subsystem 2 - Part No SW: ----------- HW: 480 412 502 13
Component: SideSensor_Pf 003 0148
Serial number: 350650A25D1911D28F7K
Subsystem 3 - Part No SW: ----------- HW: 480 412 502 13
Component: SideSensor_Dr 003 0148
Serial number: 351650A2589DD5C41C2U
Subsystem 4 - Part No SW: ----------- HW: 480 412 502 13
Component: SideSensor_Pr 003 0148
Serial number: 352650A25773D9223DAL
Part No SW: 6JA 920 940 A HW: 6JA 920 940 A
Component: KOMBI H16 0607
Coding: 420A00
ROD: EV_Kombi_UDS_VDD_RM09_004_SK25.rod
VCID: 3A70E3B1BD16A3561D-806E
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H72 0708
Revision: B9072001
Coding: 322300
VCID: 70E40199A3EA2906E3-8024
Component: IMMO H16 0607
VCID: 6AD013F18D36D3D6AD-803E
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial number: 7664402291
Coding: 030100
VCID: 2A50D3F145B613D66D-807E
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11230
Shop #: WSC 73430
VCID: 3064C199F76A6906A3-8064
Address 56: Radio (J503) Labels: None
Part No SW: 6JA 035 186 HW: 6JA 035 186
Component: Media2.0 H03 0007
Revision: 01000001 Serial number: SEZ1Z2N2066367
Coding: 01010400020000
VCID: 78F439B9CB9A71462B-802C
00856 - Radio Antenna
007 - Short to Ground
Fault Status: 01100111
Reset counter: 233
Mileage: 249222 km
Date: 2014.12.16
Time: 16:13:22
Part No SW: 7H0 907 534 HW: 7H0 937 090
Component: Batt.regelung H72 0708
Coding: 030B1A5A
Subsystem 1 - Part No SW: 6R0 915 181 E HW: 6R0 915 181 E
Component: J367-BDM H08 0181
Serial number: 00000000004970223464
02252 - Generator
Reset counter: 233
Mileage: 249222 km
Date: 2014.12.16
Time: 16:14:13
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664352121
Coding: 0200000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
End-------------------------(Elapsed Time: 02:49)--------------------------
