I am having the typical battery drain issue with my 2006 Golf GTI.
CAN Gateway has been changed twice, currently a 1K0 907 530AA is fitted and coded correctly (I think).
Previously I tried the 7N0 907 530J, but it had long coding issues and I couldn't get it to work, so I went back to the AA gateway.
In the car, after waiting for 5 minutes, I can still turn on the unit even with the key out and doors locked.
So the drain is still there. I have done a parasite drag test as well and it pulls about 0,5 amps with the upgraded unit fitted.
The unit fitted at the moment is the original RCD300. AutoScan was performed with it installed.
What could be wrong?
Please check the autoscan.
Sincerely,
Vuk
Sincerely,
Vuk
VIN: WVWZZZ1KZ6P020134 Mileage: 206370km-128232miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 J HW: 1K0 907 115 F
Component: 2.0l R4/4V TFSI 0030
Revision: --H14--- Serial number: VWZ7Z0E3136723
Coding: 0403000318070160
Shop #: WSC 40510 222 81648
VCID: 2D06F188A11E26D3C95-8078
012599 - Intake Manifold Runner Control
P3137 - 001 - Basic Setting not Completed - Intermittent
Fault Status: 00100001
Mileage: 206301 km
Temperature: 71.0°C
Temperature: 58.0°C
Absolute Pres.: 980.0 mbar
Voltage: 12.065 V
001602 - Sensor Reference Voltage A
P0642 - 002 - Voltage too Low - Intermittent
Mileage: 206301 km
Temperature: 71.0°C
Temperature: 58.0°C
Voltage: 12.065 V
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Revision: 00H13001
Coding: 0004738
Shop #: WSC 00028 028 00001
VCID: 71BE2DF87DA60233ADD-8024
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 BE
Component: ClimatronicPQ35 090 0808
VCID: 6B823F905F8AE8E3971-803E
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000003765369
Coding: ED8F8F3700041800001400001400000000097F075C
VCID: 2B02FF909F0A28E3D71-807E
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 013 0402
Coding: 00063445
Shop #: WSC 00028
Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 011 1110
Coding: 00207646
Shop #: WSC 00028
Part No SW: 1K0 909 605 R HW: 1K0 909 605 R
Component: 37 AIRBAG VW8 018 2200
Revision: 02018000 Serial number: 0038MD05369Q
Coding: 0013111
VCID: 3B22CFD06F6AB863471-806E
Subsystem 1 - Serial number: 6332MSME0D37213EE
Subsystem 2 - Serial number: 6342MSME0D4B3516F
Subsystem 3 - Serial number: 6352QSME03303D57B
Subsystem 4 - Serial number: 6362QSME07493C3BR
Part No SW: 1K0 953 549 AG HW: 1K0 953 549 AG
Component: J0527 034 0070
Coding: 0002022
VCID: 77AA13E013C25C03639-8022
Component: E0221 007 0050
Part No: 1K6 920 872 D
Component: KOMBIINSTRUMENT VDD 4312
Coding: 0007103
Shop #: WSC 80093 222 69422
VCID: 323CE2F4B820792B947-8066
Part No SW: 1K0 907 530 AA HW: 1K0 907 951
Component: J533 Gateway H07 0081
Revision: H07 01 Serial number: 130709F1002407
Coding: E9807F46000202000002
Shop #: WSC 00066 123 12345
VCID: 66944EA44468D58BC8F-8032
Component: IMMO VDD 4312
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2373
Coding: 0000180
VCID: 3634DEE45448650BB8F-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.3 D06 1701
VCID: 3332E7F0473A70239F1-8066
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 AR HW: 1K0 959 433 AR
Component: 01 KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 809002085103087F2D04840560084F00E0A440
VCID: 0058783C460C1BBB523-8054
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0000180
VCID: 372AD3E053429C03A39-8062
Part No: 1K0 035 186 P
Component: Radio GR0 015 0019
Revision: 0001503S Serial number: VWZ2Z2E3310458
Coding: 0040400
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 F
Component: Tuer-SG 021 2429
Coding: 0000144
Address 69: Trailer Labels: 8P0-907-383.clb
Part No SW: 8P0 907 383 HW: 8P0 907 383
Component: ANHAENGERELEKTR H01 0010
Coding: 0000001
VCID: 76B41EE414C8250B78F-8022
16347 - Control Module - EEPROM Error
014 - Defective
Fault Status: 01101110
Mileage: 262140 km
Date: 2001.09.15
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 F
Coding: 0000144
VCID: 3430E4EC4234771B86B-8060
End----------(Elapsed Time: 01:02, VBatt start/end: 12.3V/12.2V)-----------
