Tiguan 2020 SE R-Line
NNVirginia
C?ID=287168
So just got this vehicle, my second VW, updated to the current Rosstech as well.
Was having an issue getting Carnet setup. they had to pull a fuse and run a "Plan 5" or something similar.
Basically reset the Carnet software so that we could re-connect.
Trouble is now that I am looking at the code, I am seeing Malfunctions in a couple of areas. Thankfully they do not seem to have a high priority, and so I would like to make them go away.
Being as this a new vehicle for me, I am trying to do a little research before touching anything.
>>>Would I be able to erase DTC's to clear this? or well they clear themselves over a period of time? there are No engine lights or any other lights on the dash, only noticed this when I got onto my computer.
>>>Also when I attempted to access Module 9, Instrument panel, I was prompted with a dialogue box that stated something along the lines of: "This module has not been mapped yet", and although I think I was able to access it, the Bytes were All 00's and there was no information within it.
Would anyone be able to provide me any information regarding these two observations? I have included my Auto-scan below
Let me know if further information is needed for an analysis of this, Thanks so much in advance!
>2020 Tiguan SE, R-Line<
Monday,28,September,2020,13:31:24:15492
VCDS Version: 20.4.2.0  HEX-V2 CB: 0.4513.4
VIN: 3VV2B7AX0LM153794   License Plate:
Mileage: 1095km-680mi   Repair Order:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 3C 42 44 52 5F 6C 75 BB
          BC CA
VIN: 3VV2B7AX0LM153794   Mileage: 1095km-680miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DGUA)       Labels:. 06L-907-115-V1.clb
   Part No SW: 83A 907 115 B    HW: 06L 907 309 B
   Component: R4 2.0l TFS   H31 0005
   Revision: 1DH31000
   Coding: 012A00122426012F34000000000000000000000000000000
   Shop #: WSC 00066 790 00455
   ASAM Dataset: EV_ECM20TFS01183A907115B 001006
   ROD: EV_ECM20TFS01183A907115B.rod
   VCID: 2517F5568562CE63015-8070
   Part No SW: 09G 927 158 DT    HW: 09G 927 158
   Component: AISIN AQ8     206 3698
   Coding: 0002000100000000000000000000000000000000
   Shop #: WSC 00066 790 00441
   ROD: EV_TCMAQ450031_VW37.rod
   VCID: 08499CE212B0F30B1A3-805C
   Part No SW: 5Q0 614 517 DK    HW: 5Q0 614 517 BN
   Component: ESC           H35 0113
   Revision: 00000000    Serial number: 50790000002505
   Coding: 0BFA6BA450251B6FC57E0309A2C749D0D60AD8A3C045927430415058D28A4A0B00402F641A1B13111435351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
   ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
   VCID: 7DA7FD364D72A6A3395-8028
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0542001599
   Coding: 132C0C0723
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 45D755D665222E63215-8010
12718086 - Databus
          [Message WFS_01 missing]
                    Reset counter: 55
                    Mileage: 787 km
                    Date: 2020.09.26
                    Time: 12:05:14
                    Terminal_15_Kessy_specified_value: OFF
                    Terminal_15_Kessy_actual_value: OFF
                    Terminal_15_central electric_actual_value: OFF
                    Terminal_15red_Kessy_specified_value: OFF
                    Terminal_15red_Kessy_actual_value: OFF
                    Terminal_S_Kessy_specified_value: OFF
                    Terminal_S_Kessy_actual_value: OFF
                    Terminal_S_central electric_actual_value: OFF
                    Terminal_50_Kessy_specified_value: OFF
                    Terminal_50_Kessy_actual_value: OFF
                    ZAT_pressed: OFF
                    Request active: Condition not met
                    Enabling Steering Column Lock: Condition met
                    Enabling immobilizer: Condition not met
                    Control Module Voltage: 12.840 V
                    Vehicle speed: 0.0 km/h
                    Engine speed: 0.0 /min
                    Status of vehicle locking: Vehicle unlocked
                    Coding information: coded
                    Coding information: Not coded
                    Driver door: Open
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    ID sensor 1 authentication: status: No response
                    ID sensor 2 authentication: status: No response
                    ID sensor 3 authentication: status: No response
                    ID sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 5NN 907 044 AF    HW: 5NN 907 044 AF
   Component: AC Automat    H36 4901
   Revision: 20K04000    Serial number: 00000D00572612
   Coding: 0002002420011C00100400001211140C
   ASAM Dataset: EV_ACClimaPrehVW37X 002030
   VCID: 1079B4826AE0BBCBC23-8044
   Part No SW: 5Q0 937 087 BG    HW: 5Q0 937 087 BA
   Component: BCM PQ37BOSCH 038 0303
   Revision: --------    Serial number: C86408072003YQ
   Shop #: WSC 00066 790 00277
   ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
   ROD: EV_BCMBOSCH_020.rod
   VCID: 015F81C6318AC2435DD-8054
   Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 200303  034  0373
   Serial number: 20030121039810
   Subsystem 2 - Part No SW: 5Q0 955 555 A    HW: 5Q0 955 555 A
   Component: RLHSS  051  0207
   Serial number: S6Y20M02D26H11M04S47
   Coding: 0008DD
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
   Component: Lenks.Modul  H03  0170
   Serial number: 0300030720200C200490
539925 - Databus
          [Kombi_02 Datenbus fehlende Botschaft]
                    Reset counter: 55
                    Mileage: 787 km
                    Date: 2020.09.26
                    Time: 12:05:14
563221 - Databus
          [OCU Datenbus fehlende Botschaft]
                    Reset counter: 55
                    Mileage: 787 km
                    Date: 2020.09.26
                    Time: 12:05:14
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000259540420084
   Coding: 0471555011
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   VCID: 50F97482AA60FBCB823-8004
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Coding: 3200009210FF8728749C810500409700000000000000000004
   ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
   VCID: 43D34BCE6B1610530F1-8016
   Part No SW: 5Q0 959 655 BM    HW: 5Q0 959 655 BM
   Component: AirbagVW21    008 0403
   Serial number: 003FGM09ARY7
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   VCID: 0C41A0F206C89F2B3EB-8058
   Occupant Detection:
   Component: BF-Gewichtss.  H14 0022
   Serial number: IBH00000000000CXFHXR
   Coding: 303451
   Subsystem 2 - Part No SW: -----------    HW: 480 001 102 20
   Serial number: 357000000002E76C154N
   Subsystem 3 - Part No SW: -----------    HW: 480 001 102 20
   Serial number: 3580000000019C70E64Q
   Subsystem 4 - Part No SW: -----------    HW: 480 401 902 20
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001A6F3211B7732Z
   Subsystem 5 - Part No SW: -----------    HW: 480 401 703 20
   Component: SideSensor_Pr  004 6149
   Serial number: 35200012C62F5873512-
   Subsystem 6 - Part No SW: -----------    HW: 480 400 503 20
   Serial number: 35500010E6305412C5CZ
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 503 20
   Component: FrontSensor_P  004 6149
   Serial number: 35600011662FF3A242D8
   Part No SW: 5NA 920 850 D    HW: 5NA 920 850 D
   Component: KOMBI         343 6700
   Coding: 0BA40C0AA388CF0502882B0914010000A0000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009069
   VCID: 40D944C27A000B4B123-8014
9456681 - Key
          B104C 29 [008] - Implausible Signal
                    Mileage: 48 km
                    Date: 2020.09.18
                    Time: 19:51:20
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 06072000841225
   Coding: 030500347F085900FB0722481E0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 70B9D4020A20DBCBA23-8024
   Component: 5-00-14-00-04
   Subsystem 2 - Part No SW: 5NA 959 442 A    HW: 5NA 959 442 A
   Component: E221__MFL-TAT  H06 0025
   Serial number: 0442002395700237FE2B
   Coding: 280000
   Serial number: 5290247300
131604 - No Communication with Instrument Cluster
          U0155 00 [008] - -
          [Timeout Knoten 0x14 / 17 - Steuerger‰t f¸r Schalttafeleinsatz]
                    Reset counter: 55
                    Mileage: 787 km
                    Date: 2020.09.26
                    Time: 12:05:14
                    Supply voltage: Terminal 30: 12.7 V
                    Terminal 15: OFF
131687 - No Communications with Emergency Call Module
          U10E1 00 [008] - -
          [Timeout Knoten 0x67 / 75 - Notrufmodul]
                    Reset counter: 55
                    Mileage: 787 km
                    Date: 2020.09.26
                    Time: 12:06:08
                    Terminal 15: OFF
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00003.01.20
   Coding: 0101
   VCID: 4CC160F24648DF2BFEB-8018
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0148
   Serial number: 11230023377217
   Coding: 52954640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15.rod
   VCID: 392F292619DA5A8355D-806C
   Part No SW: 5Q4 959 393 K    HW: 5Q4 959 393 K
   Component: TSG FS        007 0485
   Serial number: 14058008701985
   Coding: 003013200000048000000000
   Shop #: WSC 01383 790 50316
   VCID: 4BC363EE4346D813F71-801E
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000005909338
   Coding: 011000
   Part No SW: 5QM 909 144 C    HW: 5QM 909 144 B
   Component: EPS_MQB_ZFLS  173 1082
   Coding: 811F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 51FF7186A16AF2C38DD-8004
   Part No SW: 5Q4 959 392 K    HW: 5Q4 959 392 K
   Component: TSG BFS       007 0485
   Serial number: 15058008905766
   VCID: 4ACD66EA4C3CC11BCC7-801E
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000005887489
   Coding: 091000
   Part No SW: 2GM 035 844 A    HW: 2GM 035 844 A
   Component: MU-S-S-US     726 0523
   Coding: 02730600BE00000051220001001808211F0506C40120050002
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 3FDB473E07FE74B36B9-806A
   Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
   Component: ABT_Std-2  261 8214
   Serial number: VWZ6ZMX1545193
3077 - Telephone baseplate
          B1051 13 [008] - Open Circuit
          [Bracket for mobile phone holder - open circuit]
                    Reset counter: 47
                    Mileage: 373 km
                    Date: 2020.09.20
                    Time: 14:20:33
                    Voltage terminal 30: 12.5 V
   Coding: 0123060122002017300040
   Part No SW: 5WA 035 283     HW: 5WA 035 283
   Component: OCUGen3Low    H10 0295
   Serial number: 0000000003NVFW1
   Coding: 0232602019682C008005461160100607
   ASAM Dataset: EV_OCUGen3Low 002036
   ROD: EV_OCUGen3Low_002_VW37.rod
   VCID: 025D8ECA348CD95B447-8056
7170 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Multi Function Display (0x0F) - Funktionseinschr‰nkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
                    Mileage: 786 km
                    Date: 2020.09.26
                    Time: 02:11:55
                    Voltage terminal 30: 12.4 V
          U1400 00 [008] - -
          [Functional restrictiondue to insufficient voltage]
                    Reset counter: 35
                    Mileage: 787 km
                    Date: 2020.09.26
                    Time: 12:05:14
                    Voltage terminal 30: 5.5 V
Address BB: Door Rear Drv
Address BC: Door Rear Pass
   Coding: 00804073260C
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   VCID: 75B7E5167542FEE3715-8020
End----------(Elapsed Time: 01:31, VBatt start/end: 12.9V/12.7V)-----------
@NNVirginia: Hi "Would I be able to erase DTC's to clear this? or will they clear themselves over a period of time? "
wrt the former question - yes
The information in the DTC detail holds the answer to the latter part of your question. Basically, the answer is also yes - Reset counter in the DTC record means that if the fault doesn't re-appear in an ignition cycle after the number indicated, the fault will clear automatically. The record Fault Frequency can also be informative because this tells you the number of times after the Date/Time stamp that the same fault has appeared in a subsequent ignition cycle. As an example, the DTC in the hex17 module in your auto scan has the following detail:
9456681 - Key
Mileage: 48 km
Date: 2020.09.18
Time: 19:51:20
Your scan was taken on 28,September,2020,13:31:24 - so Fault Frequency=1 above means that in the intervening 10 x days the "Implausible Signal" error has not re-appeared. If the car was in regular use, this piece of information can be telling!
The BCM (hover your mouse over the term) genuinely doesn't have a long code string on these MQB platform vehicles; all of the "normal" software switches on these newer modules reside in the adaptation channel database. However, the hex 17 module does indeed have a long code (see your auto-scan) and the VCDS software has attached a label file to the module - so you should be able to pull-up long-code-helper screens for the module,
PS: I'm not sure why the 2 x rear door modules are "out to lunch" (to borrow a Uwe phrase) in your auto-scan?
Because VW is totally inconsistent in the way they do things. The rear door modules show up as sub-systems of the fronts (look at 42 and 52 and you'll see them there, part numbers and all) but for some reason the Gateway has these new BB and BC addresses active, but nothing responds at those addresses. If things were done in an elegant or consistent manner, modules would either be sub-systems ("Slaves" before we got all PeeCee), in which case they shouldn't be listed in the Gateway separately, or they should be directly addressable at the address the Gateway claims for them. But this is obviously not the case here. I have no explanation for why VW did this, but I do see it occasionally,
FWIW: In our own 2018 Tiguan, the rear door modules are at separately addressable, BB and BC and they don't show up as slaves in 42 and 52. Of course this raises the question why VW decided to allocate two new addresses for them rather than just using the old 62 and 72 like they used to.. I have no explanation for that either. :confused:
