Webasto on Passat B8 problems
@DRI@N
Romania
C?ID=317777
Hy
Last week I finished to install WEBASTO PARKING HEATER on my Passat B8 BiTdi !!!!
All work in good, but I have one error and I don't know what is meen that :
Monday,28,September,2020,13:06:29:62612
VIN: WVWZZZ3CZFE400297   License Plate: GL 08 RMN
Mileage:    Repair Order: 28.09.2020
                Address 18: Aux. Heat       Labels: 5Q0-963-272.clb
Control Module Part Number: 5Q0 963 272 E    HW: 5Q0 963 272 E
  Component and/or Version: STH-MQB       007 0072
           Software Coding: 9309
            Work Shop Code: WSC 00028 028 00212
              ASAM Dataset: EV_AuxilParkiHeateWOS 002018 (VW48)
                      VCID: 382A202D42DCC28BAA3-806C
0368 - Fuel Transfer Pump
          B137D 52 [009] - Not activated
                    Reset counter: 42
                    Mileage: 67511 km
                    Date: 2020.09.28
                    Time: 12:56:17
                    Operating condition of parking heater: Start
                    78
                    Coolant temperature of parking heater: 25 °C
                    Coolant temperature: 26 °C
                    Engine running status: not recognized
                    Fuel level: 38 l
                    Heater output: 0 W
I want to make mention that the dosing pump works correctly
If anybody know what to code or adapt on webasto (address 18) or on another module to escape of this error I am grateful for his help !!!
Thanks,
Best regards .
This is a Retrofit, right? Moving to the appropriate section.
darkchina811
ITALY
C?ID=333184
go into module 01 and enable BYTE 3 BIT 3, et voilà :)
now I need your help, can you tell me the size of the fuel line you used (inner/outer diameter) and the path it's routed?
@DRI@N
Romania
C?ID=317777
Yes @Uwe, is an retrofit and I apologize if was posted in a wrong section .
Thanks for moving !
@darkchina811 for you unfortunately I don't have any answer because I don't made any measurement of the fuel line !
Sorry .
Anyway, thanks for answer and I try your coding of the address 01 !
Best regards .
