Hello All!
I just bought this TT cheap knowing that it had some transmission issues. Drives perfect for the first 10-15 minutes. Once car warms up, the violent jerking starts. From 1st to 2nd will almost break your neck. Sometimes it won't shift above 3rd. Once it does shift 5th/6th it is smooth sailing until you have to slow down. The downshifting is less violent but still noticeable.
From what I have read online, everything points to a bad valve body. I ran an auto-scan last night and fault code 17224 (P0840) popped up. Does this still point towards a bad valve body...or should I go a different direction?
Any help would be greatly appreciate.
Saturday,26,September,2020,15:06:27:48309
VIN: TRUTC28N431004928 License Plate: 2003TT
Chassis Type: 8N (8N - Audi TT (1999 > 2007))
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
Address 01: Engine Labels: 06A-906-032-AWP.lbl
Part No: 8N0 906 018 BD
Component: 1.8L R4/5VT G 0002
Coding: 07570
Shop #: WSC 01236
VCID: 74B1D8EE07A0E4FB46B-513C
TRUTC28N431004928 AUZ5Z0B9015009
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
16946 - System Voltage
P0562 - 35-10 - Too Low - Intermittent
Readiness: 0000 0001
Part No: 09G 927 750 L
Component: AQ 250 6F 0301
Coding: 0008201
Shop #: WSC 01236 785 00200
VCID: 3A2D36D66044528B5C7-513C
17224 - Transmission Fluid Pressure Sensor/Switch 1
P0840 - 003 - Electrical Malfunction - Intermittent - MIL ON
Address 03: ABS Brakes Labels: 8N0-907-379-MK60-F.lbl
Part No: 8N0 907 379 J
Component: ESP FRONT MK60 0101
Coding: 0019473
VCID: 43D34B32178E13430F1-513C
01130 - ABS Operation
Address 08: Auto HVAC Labels: 8N0-820-043.lbl
Part No: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00140
Shop #: WSC 01236
VCID: 2809FC9E8BE8D01B3A3-2578
30-00 - Open or Short to Plus
41-10 - Blocked or No Voltage - Intermittent
Address 15: Airbags Labels: 8N0-959-655.lbl
Part No: 8N0 959 655 B
Component: Airbag Front+Seite 6000
Coding: 01103
Shop #: WSC 01236
VCID: 3FDB47C27E6677A36B9-513C
Address 17: Instruments Labels: 8Nx-920-xxx-17.lbl
Part No: 8N1 920 980 E
Component: KOMBI+WEGFAHRS. M73 D14
Coding: 06244
Shop #: WSC 19506
VCID: 38292CDE5B48409BAA3-4B00
Address 35: Centr. Locks Labels:. 8Nx-962-267.lbl
Part No: 8N7 962 267 F
Component: Central Lock/Alarm D09
Coding: 15900
Shop #: WSC 19506
VCID: 43D34B32128E13430F1-4EEA
01366 - Opened Due to Crash Signal
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00009
Shop #: WSC 01236
VCID: 6597B5AABC7A0D73C15-5160
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 4B0 035 186 H
Component: concert II NP2 0050
Coding: 00202
VCID: 2517F5AAFCFACD73015-4E40
End----(Elapsed Time: 02:44, VBatt start/end: 10.3V/10.5V. VIgn 10.5V)-----
