Looking for ABS long code for Caddy (MK60EC1)
carter23
C?ID=194557
can any one help?
Sunday,13,September,2020,10:34:04:06635
VCDS Version: 20.4.2.0 (x64)
VIN: WV1ZZZ2KZDX039370   License Plate:
Chassis Type: 2K-VN35 (7N0)
VIN: WV1ZZZ2KZDX039370   Mileage: 146930km-91298miles
Address 01: Engine (J623-CAYD)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 TF    HW: 03L 907 425 C
   Component: R4 1.6l TDI   H43 9979
   Revision: --H43---    Serial number: 00000000000000
   Coding: 00114010030500080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM16TDI02103L906023TF 003003
   ROD: EV_ECM16TDI02103L997557M.rod
   VCID: 7DF11502ECE8856E78-8028
7300 - Throttle Position Sensor (G69)
          P0123 00 [036] - Signal too High
                    Engine speed: 0.00 /min
                    Coolant temperature: 2 °C
                    Intake air temperature: 6 °C
                    Ambient air pressure: 1030 mbar
                    Voltage terminal 30: 11.407 V
                    Throttle valve adapter: actual value-ANG_THR[0]: 99.997 %
                    Throttle_actuator_commanded_value-ANG_SP_THR[0]: 96.001 %
                    Throttle valve: activation-PWM_HBR_THR[0]: 0.000 %
                    Throttle valve adapter: uncond voltage actual value-V_THR[0]: 4.995 V
                    Throttle valve adapter: offset closed-V_THR_BOL[0]: 0.688 V
                    Throttle valve adapter: offset open-V_THR_TOL[0]: 4.600 V
                    Throttle valve adapter: status-LF_STATE_THR_DISP[0]: 0
6548 - Engine Control Module Incorrectly Coded
          P1612 00 [165] - -
                    Fault Frequency: 11
                    Mileage: 125747 km
                    Date: 2022.12.20
                    Time: 00:00:16
                    Coolant temperature: 17 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 11.294 V
                    Coding in the engine control module-FRF_VARCOD: 4
                    Number of resets of main unit-CTR_RST_MC: 0
                    Control Module temperature-TECU: 15 °C
                    Accelerator position: normalized-Accelerator position: 0.00 %
   Part No SW: 1K0 907 379 BH    HW: 1K0 907 379 BH
   Revision: 00H31001
   Shop #: WSC 35110 377 08192
   VCID: 79F90112F0C0B94E54-802C
                    Reset counter: 67
                    Mileage: 146933 km
                    Date: 2015.02.04
                    Time: 00:00:12
                    Count: 3
                    Count: 2
                    Count: 20992
                    Count: 195
                    Count: 42240
                    Count: 65280
                    Fault Status: 01100101
                    Reset counter: 67
                    Mileage: 146933 km
                    Date: 2015.02.04
                    Time: 00:00:17
                    Count: 2
                    Count: 2
                    Count: 20992
                    Count: 279
                    Count: 42496
                    Reset counter: 67
                    Mileage: 146933 km
                    Date: 2015.02.04
                    Time: 00:00:17
                    Count: 2
                    Count: 2
                    Count: 20992
                    Count: 295
                    Count: 42496
                    Reset counter: 67
                    Mileage: 146933 km
                    Date: 2015.02.04
                    Time: 00:00:17
                    Count: 2
                    Count: 2
                    Count: 20992
                    Count: 270
                    Count: 42496
   Part No SW: 7N0 907 426 AT    HW: 7N0 907 426 AT
   Component: AC Manuell    H19 0304
   Revision: 00001016
   Coding: 0000004002
   VCID: 06037AEEB93EC6B629-8052
9477141 - Position Sensor for Air Distribution Flap Motor
          B109C 15 [008] - Open or Short to Plus
                    Reset counter: 92
                    Mileage: 124940 km
                    Date: 2022.12.09
                    Time: 06:57:26
13701936 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 67
                    Mileage: 146933 km
                    Date: 2020.09.13
                    Time: 00:00:18
          B10AB F0 [009] - Too Low
                    Reset counter: 48
                    Mileage: 124868 km
                    Date: 2022.12.07
                    Time: 16:31:33
Address 09: Cent. Elect.        Labels: None
   VCID: 55A16DA2BC18BD2E10-FFFE
No Faults Found
   Component: VW10Airbag00U H06 0013
   Revision: --------    Serial number: 003HL007D5UA
   Coding: 000000000000000000000000000000003055
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3561CD2294589D2EF0-8060
   Part No SW: 1K5 953 507 M    HW: 5K0 953 549
   Revision: --------    Serial number:  90440KI6000V1
   Coding: 0080060000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 3B75DB1AB27C4B5E06-806E
   Part No SW: 2K0 920 965 G    HW: 2K0 920 965 G
   Component: KOMBI         H05 0705
   Coding: 480001
   VCID: 3365F33A9A2C831EDE-8066
9453842 - Oil Level Thermal Sensor
          B1041 35 [008] - Signal high time > maximum
                    Reset counter: 107
                    Mileage: 146933 km
                    Date: 2020.09.13
                    Time: 08:38:29
13635840 - Supply voltage
                    Reset counter: 180
                    Mileage: 146933 km
                    Date: 2020.09.13
                    Time: 09:23:08
   Part No SW: 7N0 907 530 H    HW: 1K0 907 951
   Component: J533  Gateway H42 1620
   Revision:   H42       Serial number: 030911F1000780
   Coding: 357401
   VCID: 3561CD229C589D2EF0-8060
00469 - Infotainment Databus in Single Wire Operation
                    Fault Status: 01101100
                    Reset counter: 67
                    Mileage: 125747 km
                    Date: 2017.05.12
                    Time: 00:00:03
01304 - Radio
                    Fault Frequency: 56
                    Reset counter: 67
                    Mileage: 124868 km
                    Date: 2017.04.29
                    Time: 16:31:50
   Component: IMMO          H05 0705
   VCID: 6ADB2E5E8D6602D6AD-803E
9456681 - Key
          B104C 29 [009] - Implausible Signal
                    Mileage: 146933 km
                    Date: 2020.09.13
                    Time: 00:00:17
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2110
   Coding: 0000560
   VCID: 489FB4D63BAA10C69B-801C
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 140    3201
   Revision: 00H20000
   VCID: 3467F02657228426C7-8060
                    Fault Status: 11100101
                    Battery Volts: 12.0 V
                        PD
                    Temperature: 19.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
Address 46: Central Conv.
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000560
   VCID: 479DB7EA36B41FBE92-8012
00936 - Electric Window Switch in Front Passenger Door (E107).
Address 56: Radio
End-------------------------(Elapsed Time: 02:13)--------------------------
How did it get lost?
What parts have been replaced?
Do you have any old scans from prior to the loss? Look in your Scans sub-folder.
carter23
C?ID=194557
THE VAN COMEIN LIKE IT HADE SECOND HAND ECU KIT FITTED THAY DID NOT SCAN IT BEFORE THAY DONE THE SWAP SO NO CODE HOPING SOME ONE ON HEAR CAN HELP
Is the VIN shown in the scan the correct one for the car?
Please post Advanced ID data from the 01-Engine and 25-Immobilizer.
carter23
C?ID=194557
no the one on the the van isWV1ZZZ2KZCX049525
THE ECU/CLOCKS/BODY CONTROL/FUSE BOX AND IGNITION WAS CHANGED
SORRY FOR THE CONFUSION THANKS PAUL
Monday,28,September,2020,16:42:25:06635
VCDS Version: Release 20.4.2 (x64)
                Address 01: Engine
Control Module Part Number: 03L 906 023 TF
  Component and/or Version: R4 1.6l TDI   H43 9979
           Software Coding: 00114014030500080000
            Work Shop Code: WSC 35110
Advanced Identification/FAZIT
     Identification: SJ8-FST
     Revision: --H43---
     Date: 26.08.12
     Manufacturer number: 0015
     Test stand number: 0017
Flash Status
     Programming Attempts(application): 2/3/2
     Successful Attempts(application): 2/2/2
     Programming Status: 00000000
     Flash Date: 00.00.00
Misc.
     Hardware number: 03L 907 425 C
     Workshop System Name: J623
     ASAM Dataset Revision: 003003
Car Info
Monday,28,September,2020,16:43:20:06635
                Address 25: Immobilizer
Control Module Part Number: 5K0 953 234
  Component and/or Version: IMMO          H05 0705
           Software Coding: 000000
            Work Shop Code: WSC 00000
     Identification: VDD-024
     Date: 21.08.12
     Manufacturer number: 1901
     Test stand number: 2374
Flash Status
Software
     OSEK-OS: 03.14.00
     HiSpd Net: 01.12.01
Misc.
     Hardware number: 5K0 953 234
     Workshop System Name: J334
     Equipment/PR Code: 2D2D2D2D2D2D2D2D
     Dataset Number: -----------
     Dataset Version: ----
     End of Line Equipment Level: ------------------
     ASAM Dataset Revision: A03709
Car Info
     Chassis Number: WV1ZZZ2KZDX039370
Immobilizer
     Transponder ID (Current val.): 520EDC99
     Transponder ID 1: D1940478
     Transponder ID 2: D1940B53
     Transponder ID 3: 520EDC99
VCDS Info:
       Labels: 5K0-920-xxx-25.clb
     Engine code: CAYD
VCDS Info:
       Labels: 03L-906-023-CAY.clb
       Readiness: No script available
