2011 Audi A4 Quattro 2.0
timgardner71
Pittsburgh, PA, USA
C?ID=352118
Trying to figure out a low oil pressure warning. Tested with gauge and had 20 psi at idle and 55 at 3k. Changed out both oil pressure sensors and got the low pressure warning back again. Generally occurs at idle after 15+ minutes of driving. Thanks for any help.
Saturday,26,September,2020,18:29:02:54027
VCDS Version: 20.4.2.0 (x64)  HEX-NET CB: 0.4513.4
VIN: WAUFFBFL8BN019632   License Plate:
Mileage: 180850km-112374mi   Repair Order:
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 6C
          72
VIN: WAUFFBFL8BN019632   Mileage: 180850km-112374miles
Address 01: Engine (0-----CAEB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AG    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H17 0002
   Revision: E1H17---
   Coding: 0104010A290F0160
   Shop #: WSC 44635 001 1048576
   ASAM Dataset: EV_ECM20TFS0118K2907115AG 001002
   ROD: EV_ECM20TFS0118K2907115AG.rod
   VCID: 74A420E3DF68242607-8020
5580 - Oil Pressure Switch
          P164B 00 [032] - Malfunction
                    Mileage: 180834 km
                    Date: 2020.09.25
                    Time: 08:46:59
                    Engine speed: 2745.00 /min
                    Normed load value: 7.1 %
                    Vehicle speed: 69 km/h
                    Coolant temperature: 76 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 13.052 V
5582 - Oil Pressure Switch for reduced Oil Pressure
          P164D 00 [044] - Malfunction
                    Fault Frequency: 17
                    Mileage: 180837 km
                    Date: 2020.09.25
                    Time: 08:51:19
                    Engine speed: 808.00 /min
                    Normed load value: 10.6 %
                    Coolant temperature: 78 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 12.321 V
Readiness: 0000 0001
   Part No SW: 8K0 927 158 K    HW: 0BK 927 156 N
   Component: 0BK 20TFSIUSA H08 1014
   Revision: --H08---
   Coding: 001112
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_TCMAL551211 001013
   ROD: EV_TCMAL551211_001.rod
   VCID: 3E30C2CBA1A4BE7621-806A
   Part No SW: 8K0 907 379 BJ    HW: 8K0 907 379 BJ
   Component: ESP8 quattro  H04 0050
   Coding: 1D0D18
   Shop #: WSC 02391 823 56573
   VCID: 0248763B9DDC1A9605-8056
   Part No SW: 8K0 907 064 CF    HW: 8K0 907 064 CF
   Component: BCM2 2.0      H04 0430
   Coding: 090100
   Shop #: WSC 02399 823 56573
   VCID: 76A01AEBC114363639-8022
   Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
   Component: FBSAUDIB8 IDG  H50 0071
   Serial number: 0810000086640008
   Serial number: 0210000159109015
   Revision: C1000000    Serial number: 01160820100117
   Coding: 64102000
   VCID: 004C7C3393D0088613-8054
   Component: BCM1 1.0      H29 0392
   Revision: 10029001    Serial number: 00000000765466
   Coding: 26001091063CAF010000080300003D0D0F1C520802010161000000
   VCID: 3C34C8C3BFB8AC660F-8068
   Component: WWS 200810  H06 0070
   Serial number: SWF10080205526
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 11018722
   Coding: 025028
   Component: E1 - LDS  H08 0090
   Serial number: 00000000000408101127
   Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
   Component: HOMELINK  H01 0010
   Part No SW: 8K0 919 475 Q    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0070
   Revision: 11001001    Serial number: 51231023210335
   Coding: 200103
   VCID: 47DEA72FF67EFFBE92-8012
   Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
   Component: AirbagVW-AU10 H41 0610
   Serial number: 003GLD0GED1B
   Coding: 303937354230303030304A55304C384B3053
   Shop #: WSC 02135 785 00200
   VCID: 45C2AD27C472EDAE60-8010
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R10000010WD
   Serial number: 6334MSME56616A52E
   Serial number: 6344MSME567215044
   Serial number: 6352QSME306918127
   Serial number: 6362QSME326C102CG
   Serial number: 63732SME6F6B062CE
   Serial number: 63832SME3E6A0A1CD
   Component: Lenks.Modul   H17 0014
   Revision: --------    Serial number: 90319JHN0007G
   Coding: 000016
   VCID: 3D32C5C7A4A2A56E38-8068
   Component: E221 - MFL  H02 0010
   Part No SW: 8K0 920 981 C    HW: 8K0 920 981 C
   Component: KOMBIINSTR.   H21 0258
   Revision: 00000000    Serial number: EJB210U7A
   Coding: 8B1709000300D705020000
   VCID: 3326E3FF92E6631EDE-8066
   Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0117
   Revision: EC000056    Serial number: 5600E10727837D
   Coding: 00C303
   VCID: 0346733F82C6139E0E-8056
   Component: J367-BDM  H07 0170
   Serial number: 1002B495040810
   Part No SW: 8T0 959 793 M    HW: 8T0 959 793 D
   Component: TSG FA        H08 1401
   Coding: 011C03204000410001
   VCID: 53E6837F3226431EFE-8006
   Revision: 00002001    Serial number: 0134089128
   Coding: 0106023A00FA440480B0013200000000
   Component: GTO BF  H06 0050
   Serial number: 00000000000000293616
   Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J245 PS039  H06 0041
   Part No SW: 8T0 959 792 M    HW: 8T0 959 792 D
   Component: TSG BF        H08 1401
   VCID: 52E8867B0D3C4A16F5-8006
   Revision: 00000003    Serial number: 10000000592359
   VCID: 3424E0E397E86426C7-8060
   Part No: 8K5 907 357
   Coding: 0000004
   VCID: 77BE17EF061E4F3E22-8022
   Part No SW: 4G0 035 082     HW: 4G0 035 082
   Component: Radio U SIRIU H51 0052
   Revision: AB001007    Serial number: 471HX0A7521625
   Coding: 020007020100000001
   VCID: 5DF2654744E2856E58-8008
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
                    Reset counter: 240
                    Mileage: 180134 km
                    Date: 2020.08.29
                    Time: 13:21:43
                    Voltage: 12.10 V
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
                    Reset counter: 243
                    Mileage: 180134 km
                    Date: 2020.08.29
                    Time: 13:21:43
                    Voltage: 12.10 V
   Part No SW: 8T1 035 664 C    HW: 8T1 035 664 B
   Component: H-BN-NA       H49 0116
   Revision: --------    Serial number: 490HA0A7579946
   Coding: 010200000006A1EF01000B0E000000030000
   VCID: 383CD4D38B808046EB-806C
   Subsystem 1 - Part No: 8R0 060 884 P
   Component: NAR 2010  0407
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H43 0084
   Serial number: 9466D+0B0570779
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Serial number: 00000000610420
   Component: CD-Database  1886
   Part No SW: 8T0 959 795 N    HW: 8T0 959 795 B
   Component: TSG HL        H06 1401
   Coding: 010C03204000210001
   VCID: 56E07A6B21D4563619-8002
   Revision: --H04---    Serial number: 525PA8-J079300
   Coding: 1000006
   Shop #: WSC 02391 785 00200
   VCID: 383CD4D34B808046EB-806C
No Faults Found
   Component: TSG HR        H06 1401
End----------(Elapsed Time: 02:11, VBatt start/end: 12.2V/12.0V)-----------
MartinsX
Riga, Latvia
C?ID=268515
Replace engine...
This is not the first case... Use search in forum and on Internet.
You can try to get some extra time/mileage by using thicker oil, maybe.
That seems like it's plenty, but... What was the oil temperature like when you tested it with a gauge? Oil temperature has a huge effect on pressure.
Replace engine...
I rarely question your advice, but what's the failure that would require replacing the whole engine?
MartinsX
Riga, Latvia
C?ID=268515
I had one case like that but after I found several similar cases on internet with this engine.
In my case car was just bought used and new owner did the oil change (new oil according spec.). Soon after symptoms like OP described appeared. Old oil coming out of engine looked like thicker that it should be...
Pressure measurements within spec. right after start but slowly goes down and after some 10-15 min idling below spec. New oil pump - the same. New oil pressure regulator - the same. New (used, low mileage) engine - fault is gone. Old engine disassembled for investigation - little wear-out everywhere but nothing critical found.
Compete rebuilding of engine with all new original parts was at least triple price than another used one...
I can't give exact advice to OP without having my own hands on on his car, I'm just telling my experience ;)
