ERROR: Function Not Available
villarroelfamily
Chandler, AZ, USA
C?ID=417417
Hey Everyone. Hope all is well. I finally got my HEX-V2 and connected it to my wife's 2003 Jetta GLX VR6. Currently, its not starting but its cranking. I ran the auto-scan and got the following results:
Friday,25,September,2020,23:58:52:09827
VIN: 3VWTH69M33M014441   License Plate:
Mileage: 262700km-163234mi   Repair Order:
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
          75 76
VIN: 3VWTH69M33M014441   Mileage: 262700km-163234miles
Address 01: Engine        Labels: 022-906-032-BDF.lbl
   Part No: 022 906 032 CR
   Component: MOTRONIC ME7.1.1G   0004
   Coding: 00033
   Shop #: WSC 22230
   VCID: 5DE79DE03423E8D3195-5160
   3VWTH69M33M014441     VWZ7Z0B5154235
16804 - Catalyst System; Bank 1
            P0420 - 35-10 - Efficiency Below Threshold - Intermittent
Readiness: 0000 1000
Address 02: Auto Trans        Labels: 09A-927-750.lbl
   Part No: 09A 927 750 AH
   Component: AG5 Getriebe 09A   0218
   VCID: 71BFD150D8BB7CB3ADD-5066
00300 - Transmission Fluid Temp. Sensor (G93)
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 M
   Coding: 0019970
   Shop #: WSC 00066 000 00000
   VCID: 34311844E229099B86B-5160
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 2.0.0
   Coding: 01000
   Shop #: WSC 00066
   VCID: 211FE11048DB8C337DD-51A8
            37-00 - Faulty
   Part No: 1C0 909 605 F
   Component: 04 AIRBAG VW61 0202 0001
   Coding: 12340
   Shop #: WSC 00066
   VCID: 270BFF0826FF7203339-513C
   Part No: 1J0 907 487 A
   Component: Lenkradelektronik   0004
   Coding: 00118
   Shop #: WSC 00066
   VCID: 2F3B17280E0F2A43FB9-523C
   Part No: 1J0 920 926 F
   Component: KOMBI+WEGFAHRSP VDO V63
   Coding: 07234
   VCID: 2D070D2004035853C95-513C
01304 - Radio
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70B9D454D3B175BBA23-513C
01304 - Radio
Address 36: Seat Mem. Drvr        Labels: 3B1-959-760.lbl
   Part No: 3B1 959 760 E
   Component: Sitzverstellung     0301
   VCID: 2F3B17280B0F2A43FB9-513C
01008 - Note; Emergency OFF Switch is Active!
   Part No: 1C0 959 799 C
   Component: 1H Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 00066
   VCID: 372B2F48F65FE283A39-4B00
   Component: 1H Tõrsteuer.FS KLO 0004
   Component: 1H Tõrsteuer.BF KLO 0004
   Component: 1H Tõrsteuer.HL KLO 0004
   Component: 1H Tõrsteuer.HR KLO 0004
Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
   Part No: 3B7 035 180
   Component:    Radio 001        0010
   Coding: 04031
   Shop #: WSC 00066
   VCID: 5DE79DE03423E8D3195-513C
End----(Elapsed Time: 04:46, VBatt start/end: 11.8V/11.7V. VIgn 11.7V)-----
However, my question is why am I getting ERROR: Function not available when I try to run Output Tests under 01-Engine. Instead of seeing options, I only see:
Based on videos I have seen, I should get a drop down. When I click on Start/Run, I get:
I also noticed, when I do the auto-scan, I can't use CAN, but I have to select M9. I thought this year/model Jetta, I was able to use CAN.
Thank you all.
Older engine control modules will refuse output tests if you try to run them more than once per ignition cycle, and will often refuse to run them again even after cycling the ignition of the engine has not been started. This logic is in the ECU software to protect the engine. The output test sequence includes the fuel injectors, which will put unburned fuel in the cylinders. This washes the oil off the cylinder walls, and in extreme cases, could hydro-lock the engine.
You would get a drop-down if the control module supports Selective Output tests. This ECU does not.
That's correct; the Mk.4 chassis cars do not support diagnostic communications via CAN; they are K-line only and do not have a Gateway with an installation list.
None of this is shortcoming in VCDS; it's all limitations in the module(s) in your older car.
villarroelfamily
Chandler, AZ, USA
C?ID=417417
Thanks so much for your reply. I was also thinking the same thing about the car being older. My goal was to remove 9 year old gas from the car by turning on the fuel pump using VCDS. Guess I need to figure out a safer way.
