Golf 7 CXXB Injector adaptation
MartinsX
Riga, Latvia
C?ID=268515
Hi!
I need some help.
Car VW Golf7, engine 1,6 TDI CR CXXB. All injectors replaced and entering new correction values "injector codes" is necessary.
Unfortunately ECU refuses my attempts.
SA 27971 is refused with message "Controller refused to send a seed! Error 7F: service not supported in active session"
Attempt to enter new correction values in adaptation channels IDE00263-IDE00265 without SA was refused with message "This workshop identification: WSC 12345 Importer 123 Equipment 12345 was rejected by the control module. The command will probably fail. Please change your values"
I changed my VCDS identificators to match those in ECU, result is the same.
Autoscan below.
Sunday,27,September,2020,00:14:17:32442
VCDS Version: 20.4.2.0
Workshop Code: 028 00028 000071
VIN: WVWZZZAUZGP533578   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZGP533578   Mileage: 189662km-117850miles
Address 01: Engine (2D2D2-CXXB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 056 CL    HW: 04L 907 445 B
   Component: R4 1.6l TDI   H06 2370
   Revision: 22004001
   Coding: 01114012432415092000
   Shop #: WSC 00028 028 00071
   ASAM Dataset: EV_ECM16TDI03004L906056CL 002005
   ROD: EV_ECM16TDI03004L906056_002_VW37.rod
   VCID: 79F987DBF8A7E84E54-802C
Readiness: N/A
   Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
   Component: ESC           H42 0625
   Revision: 00000000    Serial number: 62125000001520
   Coding: 04FA62A12423096F077C060741CB2520462490E06082A4F300400078C002
   VCID: 7EF394C7E189CF7661-802A
   Part No SW: 5G0 907 044 BC    HW: 5G0 907 044 BC
   Revision: 00001K08
   Coding: 02020104202100011005000000101002
   Shop #: WSC 00028 028 00066
   ROD: EV_ACClimaBHBVW37X_004_VW37.rod
   VCID: 69D9D79B880758CEA4-803C
   Air quality sensor:
   Part No SW: 5Q0 937 086 AH    HW: 5Q0 937 086 AH
   Revision: --------    Serial number: 86582407151784
   Coding: 00000842C24102FB4BE44080B10403081000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 000FEA3F9B7DB98613-8054
   Component: WWS    150716  043 0551
   Serial number:         150718185759
   Component: RLHS  037 0059
   Serial number: S3Y15M08D03H06M16S18
   Coding: 90A8DD
   Component: Sensor, DWA  006 0326
   Serial number: 000000000ZY1518837MT
   Serial number: 00000000000032863405
   Revision: --------    Serial number: 39331521006269
   Coding: 0031051001
   VCID: 43852533CAEB629E4E-8016
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Component: AirbagVW20    015 0388
   Serial number: 003F6R0ZRU1F
   Shop #: WSC 00028 028 00057
   VCID: 41892F3BD0F7708E5C-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 003 007 15
   Serial number: 35767000000CDC31C511
   Subsystem 2 - Part No SW: -----------    HW: 480 003 007 15
   Serial number: 3586700000051475D51R
   Subsystem 3 - Part No SW: -----------    HW: 480 402 907 15
   Serial number: 3516502C31B7E8E6118M
   Subsystem 4 - Part No SW: -----------    HW: 480 403 007 15
   Serial number: 35265029F1C52F4111AD
   Subsystem 5 - Part No SW: -----------    HW: 480 401 606 15
   Serial number: 3556502C11B5A87300CA
   Part No SW: 5Q0 953 521 K    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150811500550
   Coding: 0400
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3A7B58D7BD2123561D-806E
   Part No SW: 5G1 920 741 A    HW: 5G1 920 741 A
   Component: KOMBI         202 6420
   Coding: 07A412002380000801086A001400000000000000
   VCID: 25419BAB249FBCAE40-8070
   Part No SW: 5Q0 907 530 AE    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2227
   Revision: --------    Serial number: 22071510801096
   Coding: 030100041F087300FB000248080F00010001050000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 74E7B6EFDFC5952607-8020
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0038
   Serial number: 29150001528380095305
   Coding: 28FFFF
   Serial number: 5292477403
   Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
   Component: TSG FS        010 0031
   Serial number: 0000160813621
   Coding: 003003208000020000001000
   VCID: 45813B2BC4DF5CAE60-8010
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001939797
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0103
   Component: TSG BFS       010 0031
   Serial number: 0000160869173
   Coding: 003001208E00020000801000
   VCID: 46833C27F9D957B669-8012
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000009861389
   Coding: 090000
   Part No SW: 3Q0 035 874 A    HW: 3Q0 035 874 A
   Component: MU-S-ND-ER    H24 0241
   Serial number: VWZAZ2R0320956
   Coding: 02730201FF00000051111101008808001F0100C401200100CF
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 306F7AFF6B5DE906A3-8064
   Subsystem 1 - Part No SW: 3G0 919 605 D    HW: 3G0 919 605 D
   Component: ABT_Std-2_Nav  H52 1028
   Serial number: VWZ8Z9REN00GPH
   Subsystem 2 - Part No SW: 3G0 919 866 H    HW: -----------
   Component: ECE 2015/16  --- 0430
End-------------------------(Elapsed Time: 04:02)--------------------------
MartinsX
Riga, Latvia
C?ID=268515
Maybe it is not possible with HEX-CAN? Have no HEX V2 yet...
dieseldub
Bay Area, CA
C?ID=28764
*Usually* 27971 is reserved for basic setttings and 12233 is for adaptations.
Try 12233 then go to adaptations to enter the injector calibration codes.
MartinsX
Riga, Latvia
C?ID=268515
Thank You for suggestion! Will try tomorrow.
P.S. Then some improvements to VCDS is needed. In Security Access window the pop-up balloon showed me only "Enable adaptations: 27971"
NEtech
Denmark
C?ID=56995
Don't change it to the same as ECU, result would be the same as when 00000 000 00000 is used in VCDS.
27971 should be correct.
Try ignition ON
Ignition OFF 10 sec.
Ignition ON
Enter SA
But first check measurement value: "Security Access" is 0 (zero)
I think you mean this?
IDE00323 -- Security Access: Number of invalid keys
MartinsX
Riga, Latvia
C?ID=268515
Try ignition ON
Ignition ON
Enter SA
This does not work.
Always "Controller refused to send a seed! Error 7F: service not supported in active session"
The same with SA 27971 and 12233
IDE00323 -- Security Access: Number of invalid keys is 0 all the time.
NEtech
Denmark
C?ID=56995
Try login after you copied this file to:
C:\Ross-Tech\VCDS\Labels\User
