P261A P261C
Comtec
C?ID=1798
Taking the car for MOT last week, flashing coil and limp mode.
Cancelled appointment and came home.
Code P261A (coolant pump B open)
Bought non OEM pump from GSF (£100) 059121012A and fitted this morning in the pouring rain
Cleared codes, and now P261C (coolant pump B short) but i can confirm pump is running, and continues running for a short period after engine is turned off.
Fault with old pump / new pump disconnected
Saturday,26,September,2020,11:15:54:22544
VCDS Version: Release 20.4.2 (x64) Running on Windows 10 x64
                Address 01: Engine       Labels: 03L-906-012-CKT.clb
Control Module Part Number: 03L 906 012 A    HW: 03L 906 012 A
  Component and/or Version: R4 2.0l TDI   H26 9977
           Software Coding: 0119401020440C080000
            Work Shop Code: WSC 131071 1023 2097151
              ASAM Dataset: EV_ECM20TDI01103L906012A 002016 ()
                       ROD: EV_ECM20TDI01103L906012A_002.rod
                      VCID: 221C1368544A701B647-8076
4875 - Coolant Pump 2
          P261A 00 [167] - Open circuit
                    Mileage: 18582 km
                    Date: 2047.15.31
                    Time: 31:63:63
                    Engine speed: 924.00 /min
                    Normed load value: 24.3 %
                    Coolant temperature: 44 °C
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 14.500 V
                    Coolant temperature at radiator outlet: actual value: 14.5 °C
                    exh.gas recirc.: shut-off conditions-Bits 0-7: 0
                    exh.gas recirc.: shut-off conditions-Bits 0-7: 37
                    EGR cooling function: status-Bits 0-7: 0
                    exh.gas recirc. (EGR) cooler pump: specified value: 0.00 %
                    EGR Vacuum Regulator Solen.val.: activation: 60.28 %
                    Exh.gas temp.sen 1: 131.2 °C
Erased fault codes, installed new pump, the get this, 10 seconds after starting
Saturday,26,September,2020,11:01:59:22544
4878 - Coolant Pump 2
          P261C 00 [167] - Short to GND
                    Mileage: 18582 km
                    Date: 2047.15.31
                    Time: 31:63:63
                    Engine speed: 921.50 /min
                    Normed load value: 34.1 %
                    Coolant temperature: 25 °C
                    Intake air temperature: 10 °C
                    Voltage terminal 30: 14.460 V
                    Coolant temperature at radiator outlet: actual value: 11.6 °C
                    exh.gas recirc. (EGR) cooler pump: specified value: 77.02 %
                    EGR Vacuum Regulator Solen.val.: activation: 66.21 %
                    Exh.gas temp.sen 1: 133.5 °C
Could the non OE pump be out of spec, giving fault ??
Cheers SHaun
Possibly. Do you have wiring diagrams for this engine? Is this pump high-side switched or low-side switched?
Comtec
C?ID=1798
It is pump V400, EGR cooler
How do i add image to post ?
SHaun
NostraJackAss
Did you consider to qualify the fault can be vacated with a decade box to verify ECU stack and wiring yet and check values of pump further measuring as per RTFB?
Comtec
C?ID=1798
Like i said earlier, the pump is working, possibly drawing excess current, would i be correct in assuming high sided switched, as one of the three connections is permanent ground.
Shaun
Interesting. It's not terribly obvious how that pump is switched. It clearly has a connection to ground, a connection to the ECU, and a connection to D108, which looks like some kind of switched positive? Any idea where it comes from?
MartinsX
Riga, Latvia
C?ID=268515
I had a case with MB Sprinter (very similar to Crafter) and couple cases with Opel Movano (copletely different car) throwing clearly "electrical" fault codes (open/short) for circulation pumps because of air in cooling system...
Comtec
C?ID=1798
I had a case with MB Sprinter (very similar to Crafter) and couple cases with Opel Movano (completely different car) throwing clearly "electrical" fault codes (open/short) for circulation pumps because of air in cooling system...
I did clamp hoses, and lost no more than a cup full of coolant during the changeover, will try and bleed system to see if fault clears..
Shaun
Comtec
C?ID=1798
The part is OEM equivalent
SHaun
