Library for alz engine
zaharias
Romania
C?ID=409601
hi. i have vcds hex v2, and my car is audi a4 b6 1.6, 2002, with alz engine, i need library file for this, in english, thanks
South Molton, UK
An full unedited VCDS Auto-Scan would be a great help to understand what exactly you are looking for.
zaharias
Romania
C?ID=409601
06B-906-018-ALZ.lbl, this one is in german language, i want in english
zaharias
Romania
C?ID=409601
Friday,18,September,2020,18:16:40:17087
VIN: WAUZZZ8EX2A084839 License Plate:
Mileage: 193140km-120011mi Repair Order:
67 69 75 76 77
VIN: WAUZZZ8EX2A084839 Mileage: 193140km-120011miles
Address 01: Engine Labels: Redir Fail!
Part No: 8E0 906 018 AF
Component: 1,6l/2V SIMOS3 0001
Coding: 0006271
Shop #: WSC 63351 000 00000
VCID: 6C81C165FA9FDC9B9EB-5160
18107 - Powertrain Data Bus
P1699 - 008 - Missing Message from Steering Wheel Electronics
16497 - Intake Air Temp. Sensor (G42)
P0113 - 006 - Signal too High
18057 - Powertrain Data Bus
P1649 - 008 - Missing Message from ABS Controller - Intermittent
Readiness: 1010 1101
zaharias
Romania
C?ID=409601
Monday,21,September,2020,19:29:03:17087
Workshop Code: 000 63351 000000
Mileage: 194230km-120688mi Repair Order:
67 69 75 76 77
VIN: WAUZZZ8EX2A084839 Mileage: 194230km-120688miles
Address 01: Engine Labels: 06B-906-018-ALZ.lbl
Coding: 0006271
Readiness: 1110 1101
MartinsX
Riga, Latvia
C?ID=268515
If You already found the needed label (it is called "label", not "library") file in German, just copy it to Labels folder in VCDS directory. If You want, You can open it with notepad (it is plain text inside), study syntax and edit it by replacing German terms with translated ones in English or whatever language You would like ;)
It happens time by time that some lbl or clb files are available only in German because are created originally in German by Sebastian or someone else of German speaking members of RT team. I'm in doubt will RT take care of this for almost 20 years old engine ECU, they are really busy with making VCDS fully compatible with all new control modules VAG produces nowadays...
zaharias
Romania
C?ID=409601
thanks, very nice, enjoy to translate!
_Val
Latvia
C?ID=356659
Yes, it's easier to replace engine to compatible with vcds :D
