Octavia 3 BCM PQ37 Bosch coding(rear locks...) and turn sig."faults" (again)...
FandaTDI
Czech Republic
C?ID=204559
Hi,
I´ve triyng to solve (mostly successfully, but few issues still remains) the problem with not working lights, remote control a many other things/equip on Octavia 3. The owner firstly tried some guy, who probably messed it more... From the info not sure about amount of FOD, but there was totally f***ed up coding and in more ways(/channels) production mode active. So I deactivated production mode and try to code the BCM right according the present equipment. When I finally get to state with no faults (lights, remote, etc. working), rear doors doesn´t work ... So I checked it again with experimental description and get it work only with a faults of rear locks (in other ways in byte 9 without faults, but also not locking and seeing open rear doors...). As I´ve later compared to other similar Octavia3 scans/BCM codings, it looks like 0E in byte 9 could be the right one (maybe with some other change in other byte?), will check next time...
The other problem is again (https://forums.ross-tech.com/index.php?threads/14541/ ) with front turn signals faulty message on infotainment (and quick blinking on a dash, but outside everything blinking ok) but without any faults (both bulbs ok - btw.these are the "unchangeable"...).
Not sure if the solution(best/only...) is sw update or if is possible e.g.to lower the sensitivity for the fault message - what exactly represents values in these channels? :
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0 > current value 14 >change to 00
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0
> current value 34 > change to 00
Here is the full autoscan after coding and deactivating production mode:
Thursday,24,September,2020,20:44:14:12188
VCDS Version: 20.4.2.0 (x64)  HEX-NET CB: 0.4513.4
VIN: TMBJJ9NE1H0074758   License Plate:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F A5
VIN: TMBJJ9NE1H0074758   Mileage: 136661km-84917miles
Address 01: Engine (J623-CRMB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 BN    HW: 04L 907 309 R
   Component: R4 2,0L EDC   H23 1197
   Revision: B5H23---
   Coding: 01190012042401090000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM20TDI01104L906026BN 002002
   ROD: EV_ECM20TDI01104L906026BN_002.rod
   VCID: 77BE07D3CEE2D83E22-8022
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AF    HW: 5Q0 614 517 AF
   Component: ESC           H62 0398
   Revision: 00000000    Serial number: 52036000000728
   Coding: 1C07629124270970407E060541CB2438462490026082247200630070C02203
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019
   ROD: EV_Brake1UDSContiMK100ESP_035.rod
   VCID: 75A20DDBD4EEAA2E30-8020
   Part No SW: 5E0 907 044 AG    HW: 5E0 907 044 AG
   Component: Climatronic   H04 1601
   Revision: 00001K07
   Coding: 02010104002110011001000100101002
   ASAM Dataset: EV_ACClimaBHBVW37X 006142
   ROD: EV_ACClimaBHBVW37X_006_SK37.rod
   VCID: 6A982EA78D5075D6AD-803E
   Air quality sensor:
   Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Revision: --------    Serial number: 8658250816028H
   Coding: 0C840A4262473E7B0B004103010E22080000000000000000000000000000
   Shop #: WSC 73430 790 12345
   ROD: EV_BCMBOSCH_015.rod
   VCID: 034663038A3A849E0E-8056
   Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 160817  041 0570
   Serial number:         160825013224
   Coding: 5DFD00
   Component: RLHS  042 0105
   Serial number: S5Y16M09D03H03M56S07
   Coding: 00885D
   Part No SW: 5Q0 919 283 F    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0054
   Revision: --------    Serial number: 39231624505013
   Coding: 0001050001
   VCID: 3C34D8FFB7443B660F-8068
   Part No SW: 3Q0 959 655 AQ    HW: 3Q0 959 655 AQ
   Component: Airbag VW20   013 0200
   Revision: --------    Serial number: 003SNPHB8N4D
   Coding: 98FCC000000000005C5400CC000800000065
   Shop #: WSC 73430 790 00000
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 0D52453BDC7EC2EE68-8058
   Belt Pretensioner left:
   Serial number: 34169593C29081650643
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169592C07091650515
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 454 001 908 16
   Serial number: 3576U000000D2CD4DC1Z
   Subsystem 4 - Part No SW: -----------    HW: 454 001 908 16
   Serial number: 3586U00000024CD4DC1R
   Subsystem 5 - Part No SW: -----------    HW: 454 800 608 16
   Serial number: 3516R8D72040C0000002
   Subsystem 6 - Part No SW: -----------    HW: 454 801 608 16
   Serial number: 3526R0F7E040C0000009
   Subsystem 7 - Part No SW: -----------    HW: 454 802 606 16
   Serial number: 3556VA7741A0B000000E
   Part No SW: 5Q0 953 507 GD    HW: 5Q0 953 549 F
   Revision: --------    Serial number: 05091604220271
   Coding: 1400
   VCID: 7EB012F7E1D8E97661-802A
   Part No SW: 5E0 920 741 C    HW: 5E0 920 741 C
   Component: KOMBI         205 8311
   Coding: 07A50A006980000801086A021000000000000000
   VCID: 2404009F2FF463A657-8070
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1265
   Revision: --------    Serial number: 0005271474
   Coding: 030100045F087300EB00024E080F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 7CB418FFF7C4FB664F-8028
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000C1504260816
   Serial number: 75410803001609023809
   Component: TSG FS        010 0031
   Serial number: 0000213672308
   Coding: 00110120D000048000001100
   VCID: 47DEB713FE8268BE92-8012
   Serial number: 00000000000011177788
   Coding: 010200
   Component: EPS_MQB_ZFLS  129 1072
   Coding: 1107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45C2BD1BC48E7AAE60-8010
   Component: TSG BFS       010 0031
   Serial number: 0000212038143
   VCID: 46C0BA17F98871B669-8012
   Serial number: 00000000000011325587
   Coding: 190200
   Coding: 03CA00003F000000
   Shop #: WSC 73430 790 00063
   VCID: 40CCAC0FDBAC5F8653-8014
   Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0009
   Coding: 3E0000
   Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0009
   Coding: 3E0000
   Part No SW: 5Q0 035 874 B    HW: 5Q0 035 874 B
   Component: MU-S-ND-ER    H30 0359
   Serial number: SKZAZ2S5176892
   Coding: 03730201FF00000011111201008802232F0100C401200100CE
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 3326F3C39A1AF41EDE-8066
   Subsystem 1 - Part No SW: 5E0 919 605 J    HW: 5E0 919 605 J
   Component: ABT_Std-2_Nav  H43 1031
   Serial number: SKZ8Z9SLH01G76
   Subsystem 2 - Part No SW: 5L0 051 236 H    HW: -----------
   Component: ECE 2016  --- 0521
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H07 0060
   Serial number: 10000598202
   Coding: 0100000001030306000400000000000100
   Shop #: WSC 59174 001 1048576
   ROD: EV_MFKBoschAU370.rod
End----------(Elapsed Time: 01:25, VBatt start/end: 12.5V/12.5V)-----------
And fyi this is the autoscan when I read it first time(sorry for czech language):
Ètvrtek,24,Záøí,2020,18:58:22:12188
VCDS -- Windows VAG/VAS Emulator Bìží na Windows 10 x64
VCDS verze: SVO 20.4.1.1  HEX-NET CB: 0.4513.4
Verze dat: 20200331 DS317.0
www.vag-com.cz
VIN: TMBJJ9NE1H0074758   Výrobní štítek:
Model: NE-SK37 (5Q0)
Sken: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F A5
VIN: TMBJJ9NE1H0074758   Kilometry: 136661km
01-Motor -- stav: Nefunkèní 0010
03-ABS brzdy -- stav: OK 0000
08-Klima/topení -- stav: Nefunkèní 0010
09-Centrální elektrika -- stav: Nefunkèní 0010
10-Asist park./øízení -- stav: OK 0000
15-Airbagy -- stav: OK 0000
16-Elektronika volantu -- stav: OK 0000
17-Pøístrojová deska -- stav: OK 0000
19-CAN Gateway -- stav: OK 0000
42-El. dveøí øidièe -- stav: OK 0000
44-Posilovaè øízení -- stav: OK 0000
52-El. PP dveøí -- stav: OK 0000
55-Reg.sklonu svìtel -- stav: Nefunkèní 0010
5F-Elektro info -- stav: Nefunkèní 0010
A5-Pøední snímaè asistenta jízdy -- stav: OK 0000
Adresa 01: Motor (J623-CRMB)       Labely:. SVO\04L-907-309-V1.clb
   Øídící jednotka SW: 04L 906 026 BN    HW: 04L 907 309 R
   Díl: R4 2,0L EDC   H23 1197
   Revize: B5H23---
   Kódování: 01190012042401090000
   Dílna #: WSC 73430 031 00000
   VCID: 77BE07D3CEE2D83E3B-8022
1 nalezena chyba:
21607 - software nekompatibilni s ridici jednotkou pristrojove desky
          U0323 00 [175] - -
          Kontrolka závad ZAP - Potvrzeno - Testováno od smazání pamìti
             info o závadì:
                    Stav závad: 00000001
                    Priorita závad: 2
                    Frekvence závad: 1
                    Kilometry: 136660 km
                    Datum: 2020.09.23
                    Èas: 09:58:11
                    Otáèky motoru: 0.00 /min
                    Normovaná hodnota zátìže: 0.0 %
                    Rychlost vozidla: 0 km/h
                    Teplota chladicí kapaliny: 97 °C
                    Teplota nasávaného vzduchu: 83 °C
                    Okolní tlak vzduchu: 980 mbar
                    Napìtí svorky 30: 12.540 V
                    Èítaè zapomenutí po OBD: 40
                    Turbodm.1: vstup turbíny: snímaè teploty 1: øada 1: hr. hodnota: 130.9 °C
                    Turbodm.1: výstup turbíny: snímaè teploty 1: øada 1: hr.hodnota: 141.4 °C
                    Vstup filtru èástic: snímaè teploty 1: øada 1: hrubá hodnota: 142.8 °C
                    Výstup filtru èástic: snímaè teploty 1: øada 1: hrubá hodnota: -0.0 °C
                    Zp. vedení výf. plynù: snímaè teploty 2: øada 1: hrubá hodnota: 2222.0 °C
                    Èasovaè vypnutí: poslední doba vypnutí motoru: 162 s
Readiness: 1 1 0 0 1
Adresa 03: ABS brzdy (J104)       Labely:* SVO\5Q0-907-379-ESP-V1.clb
   Øídící jednotka SW: 5Q0 614 517 AF    HW: 5Q0 614 517 AF
   Díl: ESC           H62 0398
   Revize: 00000000    Seriové èíslo: 52036000000728
   Kódování: 1C07629124270970407E060541CB2438462490026082247200630070C02203
   Dílna #: WSC 73430 031 00063
   VCID: 75A20DDBD4EEAA2E29-8020
Nenalezena žádná chyba.
Adresa 08: Klima/topení (J255)       Labely:| SVO\5G0-907-044.clb
   Øídící jednotka SW: 5E0 907 044 AG    HW: 5E0 907 044 AG
   Díl: Climatronic   H04 1601
   Revize: 00001K07
   Kódování: 02010104002110011005000100101002
   VCID: 6A982EA78D5075D6B4-803E
   Øídicí jednotka vìtráku èerstvého vzduchu (vpøedu):
   Geber fuer Kaeltemitteldruck/Kaeltemitteltemperatur:
   Snímaè kvality vzduchu:
3 závad nalezeno.
459015 - Datová sbìrnice; chybìjící odezva
          U1121 00 [009] - -
          [Feuchtesensor innen - kein Signal/Kommunikation]
             info o závadì:
                    Priorita závad: 6
                    Frekvence závad: 1
                    Poèítadlo resetù: 112
                    Datum: 2020.09.23
                    Èas: 09:50:45
459527 - Datová sbìrnice; pøijatá chybová hodnota
          U1123 00 [009] - -
          [Klima_Sensor_02 - empfangener Fehlerwert]
             info o závadì:
                    Priorita závad: 6
                    Frekvence závad: 1
                    Datum: 2020.09.23
                    Èas: 09:58:13
1048833 - Omezení funkce kvuli odpojení kompresoru motorem
          B10F0 00 [009] - Neznámá chyba zpracování
             info o závadì:
                    Priorita závad: 6
                    Frekvence závad: 1
                    Kilometry: 136661 km
                    Datum: 2020.09.23
                    Èas: 10:00:24
                    Napìtí svorky 30: 13.1 V
                    Podmínka odpojení kompresoru: Vypnutí od øídicí jednotky motoru pøes CAN (T > 15 Sek.)
Adresa 09: Centrální elektrika (J519)       Labely:| SVO\5Q0-937-08X-HV1.clb
   Øídící jednotka SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Díl: BCM PQ37BOSCH 028 0162
   Revize: --------    Seriové èíslo: 8658250816028H
   Kódování: 00C7E0C020000C0708000103010222000000000000000000000000000000
   Dílna #: WSC 73430 790 12345
   VCID: 034663038A3A849E17-8056
   Øídicí jednotka motoru stìraèù:
   Subsystém 1 - Øídící jednotka SW: 5E1 955 119     HW: 5E1 955 119   Labely: SVO\5QX-955-119-V1.CLB
   Díl: WWS371 160817  041 0570
   Seriové èíslo:         160825013224
   Kódování: 5DFD00
   Øídicí jednotka støešní rolety:
6 závad nalezeno.
525056 - Režim výroby
          U1103 00 [009] - aktivní
             info o závadì:
                    Priorita závad: 6
                    Frekvence závad: 1
                    Poèítadlo resetù: 0
                    Datum: 2020.09.23
                    Èas: 09:55:19
929796 - Spínaè svìtel
          U110B 00 [009] - bez komunikace
          [Lichtschalterkeine Kommunikation]
             info o závadì:
                    Priorita závad: 2
                    Frekvence závad: 1
                    Datum: 2020.09.23
                    Èas: 09:54:53
657156 - Ventilátor 1 opìradla vlevo
          B14C9 31 [009] - Bez signalu
             info o závadì:
                    Priorita závad: 4
                    Frekvence závad: 1
                    Datum: 2020.09.23
                    Èas: 09:54:55
657668 - Ventilátor 1 sedáku vlevo
          B14CB 31 [009] - Bez signalu
             info o závadì:
                    Priorita závad: 4
                    Frekvence závad: 1
                    Datum: 2020.09.23
                    Èas: 09:54:52
658180 - Ventilátor 1 opìradla vpravo
          B14CD 31 [009] - Bez signalu
             info o závadì:
                    Priorita závad: 4
                    Frekvence závad: 1
                    Datum: 2020.09.23
                    Èas: 09:54:55
658692 - Ventilátor 1 sedáku vpravo
          B14CF 31 [009] - Bez signalu
             info o závadì:
                    Priorita závad: 4
                    Frekvence závad: 1
                    Datum: 2020.09.23
                    Èas: 09:54:55
Adresa 10: Asist park./øízení (J446)       Labely:| SVO\5Q0-919-283.clb
   Øídící jednotka SW: 5Q0 919 283 F    HW: 5Q0 919 283
   Díl: PARKHILFE 4K  H10 0054
   Revize: --------    Seriové èíslo: 39231624505013
   Kódování: 0001050001
   VCID: 3C34D8FFB7443B6616-8068
Adresa 15: Airbagy (J234)       Labely:| SVO\5Q0-959-655.clb
   Øídící jednotka SW: 3Q0 959 655 AQ    HW: 3Q0 959 655 AQ
   Díl: Airbag VW20   013 0200
   Revize: --------    Seriové èíslo: 003SNPHB8N4D
   Kódování: 98FCC000000000005C5400CC000800000065
   Dílna #: WSC 73430 790 00000
   VCID: 0D52453BDC7EC2EE71-8058
   Napínaè pásu vlevo:
   Subsystém 1 - Øídící jednotka SW: 5G0 980 945 B    HW: 5G0 980 945 B
   Díl: BeltPretRevFL  H37 0350
   Seriové èíslo: 34169593C29081650643
   Kódování: 333135
   Napínaè pásu vpravo:
   Subsystém 2 - Øídící jednotka SW: 5G0 980 946 B    HW: 5G0 980 946 B
   Díl: BeltPretRevFR  H37 0350
   Seriové èíslo: 34169592C07091650515
   Kódování: 333135
   Snímaè nárazu boèního airbagu: strana øidièe:
   Subsystém 3 - Øídící jednotka SW: -----------    HW: 454 001 908 16
   Díl: SideSensor_Df  008 0887
   Seriové èíslo: 3576U000000D2CD4DC1Z
   Kódování: 2D2D2D
   Snímaè nárazu boèního airbagu: strana spolujezdce:
   Subsystém 4 - Øídící jednotka SW: -----------    HW: 454 001 908 16
   Díl: SideSensor_Pf  008 0887
   Seriové èíslo: 3586U00000024CD4DC1R
   Kódování: 2D2D2D
   Snímaè nárazu boèního airbagu vzadu: strana øidièe:
   Subsystém 5 - Øídící jednotka SW: -----------    HW: 454 800 608 16
   Díl: SideSensor_Dr  301 0148
   Seriové èíslo: 3516R8D72040C0000002
   Kódování: 2D2D2D
   Snímaè nárazu boèního airbagu vzadu: strana spolujezdce:
   Subsystém 6 - Øídící jednotka SW: -----------    HW: 454 801 608 16
   Díl: SideSensor_Pr  301 0148
   Seriové èíslo: 3526R0F7E040C0000009
   Kódování: 2D2D2D
   Snímaè nárazu èelního airbagu: strana øidièe:
   Subsystém 7 - Øídící jednotka SW: -----------    HW: 454 802 606 16
   Díl: FrontSensor_D  304 0149
   Seriové èíslo: 3556VA7741A0B000000E
   Kódování: 2D2D2D
Adresa 16: Elektronika volantu (J527)       Labely:| SVO\5Q0-953-549.clb
   Øídící jednotka SW: 5Q0 953 507 GD    HW: 5Q0 953 549 F
   Díl: Lenks. Modul  003 0140
   Revize: --------    Seriové èíslo: 05091604220271
   Kódování: 1400
   VCID: 7EB012F7E1D8E97678-802A
Adresa 17: Pøístrojová deska (J285)       Labely:| SVO\5G0-920-XXX-17.clb-SRI3
   Øídící jednotka SW: 5E0 920 741 C    HW: 5E0 920 741 C
   Díl: KOMBI         205 8311
   Kódování: 07A40A006980000801086A021000000000000000
   VCID: 2404009F2FF463A64E-8070
Adresa 19: CAN Gateway (J533)       Labely:| SVO\5Q0-907-530-V1.clb
   Øídící jednotka SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
   Díl: GW MQB High   128 1265
   Revize: --------    Seriové èíslo: 0005271474
   Kódování: 030100045F087300EB00024E080F00010001050000000000000000000000
   VCID: 7CB418FFF7C4FB6656-8028
   Alternátor:
   Øídicí jednotka multifunkèního volantu:
   Subsystém 2 - Øídící jednotka SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Díl: E221__MFL-PR6  H02 0150
   Seriové èíslo: 000000000C1504260816
   Øídicí jednotka hlídání akumulátoru:
   Subsystém 3 - Øídící jednotka SW: 5Q0 915 181 J    HW: 5Q0 915 181 J
   Díl: J367-BDMConti  H03 1050
   Seriové èíslo: 75410803001609023809
Adresa 42: El. dveøí øidièe (J386)       Labely:| SVO\5QX-959-X93-42.clb
   Øídící jednotka SW: 5Q4 959 593 E    HW: 5Q4 959 593 B
   Díl: TSG FS        010 0031
   Seriové èíslo: 0000213672308
   Kódování: 00110120D000048000001100
   VCID: 47DEB713FE8268BE8B-8012
   Øídicí jednotka dveøí: strana øidièe vzadu:
   Subsystém 1 - Øídící jednotka SW: 5Q0 959 811 A    HW: 5Q0 959 811 A  Labely: SVO\5QX-959-81X-V1.CLB
   Díl: FOND_FHSG_DRV  005 0005
   Seriové èíslo: 00000000000011177788
   Kódování: 010200
Adresa 44: Posilovaè øízení (J500)       Labely:| SVO\5Q0-909-144.clb
   Øídící jednotka SW: 5Q0 909 144 T    HW: 5Q0 909 144 R
   Díl: EPS_MQB_ZFLS  129 1072
   Kódování: 1107
   VCID: 45C2BD1BC48E7AAE79-8010
Adresa 52: El. PP dveøí (J387)       Labely:| SVO\5QX-959-X92-52.clb
   Øídící jednotka SW: 5Q4 959 592 E    HW: 5Q4 959 592 B
   Díl: TSG BFS       010 0031
   Seriové èíslo: 0000212038143
   VCID: 46C0BA17F98871B670-8012
   Øídicí jednotka dveøí: strana spolujezdce vzadu:
   Subsystém 1 - Øídící jednotka SW: 5Q0 959 812 A    HW: 5Q0 959 812 A  Labely: SVO\5QX-959-81X-V1.CLB
   Díl: FOND_FHSG_PSG  005 0005
   Seriové èíslo: 00000000000011325587
   Kódování: 190200
Adresa 55: Reg.sklonu svìtel (J745)       Labely:| SVO\7P6-907-357.clb
   Øídící jednotka SW: 7P6 907 357 D    HW: 7P6 907 357 A
   Díl: AFS-ECU       H07 0090
   Revize: --------    Seriové èíslo: --------------
   Kódování: 03CA00003F000000
   Dílna #: WSC 73430 790 00063
   VCID: 40CCAC0FDBAC5F864A-8014
   Výkonový modul svìtlometu vlevo:
   Subsystém 1 - Øídící jednotka SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labely: SVO\3D0-941-329.CLB
   Díl: LeiMo links  H06 0009
   Kódování: 3E0000
   Výkonový modul svìtlometu vpravo:
   Subsystém 2 - Øídící jednotka SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labely: SVO\3D0-941-329.CLB
   Díl: LeiMo rechts  H06 0009
   Kódování: 3E0000
1 nalezena chyba:
13705478 - Datová sbìrnice; chybìjící odezva
          U1121 00 [009] - -
          [RLS_01 Datenbus fehlende Botschaft]
             info o závadì:
                    Priorita závad: 6
                    Frekvence závad: 1
                    Datum: 2020.09.23
                    Èas: 09:47:59
Adresa 5F: Elektro info (J794)       Labely:| SVO\3V0-035-MIB-STD2.clb
   Øídící jednotka SW: 5Q0 035 874 B    HW: 5Q0 035 874 B
   Díl: MU-S-ND-ER    H30 0359
   Seriové èíslo: SKZAZ2S5176892
   Kódování: 03730201FF00000011111201008802232F0100C401200100CE
   VCID: 3326F3C39A1AF41EC7-8066
   Zobrazovací a ovládací jednotka 1 elektroniky informací:
   Subsystém 1 - Øídící jednotka SW: 5E0 919 605 J    HW: 5E0 919 605 J
   Díl: ABT_Std-2_Nav  H43 1031
   Seriové èíslo: SKZ8Z9SLH01G76
   Datový nosiè:
   Subsystém 2 - Øídící jednotka SW: 5L0 051 236 H    HW: -----------
   Díl: ECE 2016  --- 0521
   Seriové èíslo: --------------------
5 závad nalezeno.
7176 - Omezení funkce kvuli chybející odezve
          U1111 00 [009] - -
          [Interior light (0x08) - function restriction due to communication error - BapErr_retry not successful]
             info o závadì:
                    Priorita závad: 6
                    Frekvence závad: 1
                    Datum: 2020.09.23
                    Èas: 09:47:22
                    Napìtí svorky 30: 13.7 V
                    BAP-BAP_Function_ID: 02
7177 - Omezení funkce kvuli chybející odezve
          U1111 00 [009] - -
          [Exterior light (0x09) - function restriction due to communication error - BapErr_retry not successful]
             info o závadì:
                    Priorita závad: 6
                    Frekvence závad: 1
                    Datum: 2020.09.23
                    Èas: 09:47:22
7180 - Omezení funkce kvuli chybející odezve
          U1111 00 [009] - -
          [Front/rear windshield wiper (0x0C) - function restriction due to communication error - BapErr_retry not successful]
             info o závadì:
                    Priorita závad: 6
                    Frekvence závad: 1
                    Datum: 2020.09.23
                    Èas: 09:47:22
7181 - Omezení funkce kvuli chybející odezve
          U1111 00 [009] - -
          [Central locking/window (0x0D) - function restriction due to communication error - BapErr_retry not successful]
             info o závadì:
                    Priorita závad: 6
                    Frekvence závad: 1
                    Datum: 2020.09.23
                    Èas: 09:47:22
7182 - Omezení funkce kvuli chybející odezve
          U1111 00 [009] - -
          [Mirror (0x0E) - function restriction due to communication error - BapErr_retry not successful]
             info o závadì:
                    Priorita závad: 6
                    Frekvence závad: 1
                    Datum: 2020.09.23
                    Èas: 09:47:22
Adresa A5: Pøední snímaè asistenta jízdy (R242)       Labely:| SVO\5Q0-980-653.clb
   Øídící jednotka SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Díl: MQB_MFK       H07 0060
   Seriové èíslo: 10000598202
   Kódování: 0100000001030306000400000000000100
   Dílna #: WSC 59174 001 1048576
Konec-------(Uplynulý èas: 01:31, VBat zaèátek/konec: 12.3V/12.3V)---------
Thanks for any ideas/hints.
FandaTDI
Czech Republic
C?ID=204559
I have some update... Been looking for newest sw and in Škoda flashdaten(2020/09) isn´t this BCM, in VW is sw 0163, but this will not solve the problem (not the same as in quoted topic), because I´ve seen this unit in two Passats 2016 which has a LED turn lights in headlamps. Therefore the question is if it´s possible (I believe it is, just know where exactly...) to change settings from LED to (probalbly)"Glühlampe 12W"(I see ENG-116953-ENG116195, but there are the same values... ). Any ideas?
