Service not supported in active session
Skinner51
HUC-2H
Hi trying service regen dpf in basic settings and get the message Service not supported in active session
I have also tried other items in this menu and get the same error. Any ideas please
Please post an Auto-Scan for context, so people can see exactly what this vehicle is made of.
Skinner51
HUC-2H
Sunday,27,September,2020,12:23:53:01789
VCDS Version: 20.4.2.0 (x64)
VIN: WV1ZZZ7HZHH073521   License Plate: FC58RYE
Mileage: 160140km-99506mi   Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 37 5F 61
VIN: WV1ZZZ7HZHH073521   Mileage: 160140km-99506miles
Address 01: Engine (2D2D2-CXHA)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KL    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 3802
   Revision: 23002001
   Coding: 00194014432501090000
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ECM20TDI03004L906056KL 004003
   ROD: EV_ECM20TDI03004L906056JS_004.rod
   VCID: 010990E9900FF78E1C-8054
31391 - Manifold / Barometric Pressure Sensor (G71) / (F96)
          P0105 00 [032] - Malfunction
                    Date: 2044.01.10
                    Time: 17:41:44
                    Engine speed: 0.00 /min
                    Coolant temperature: 27 °C
                    Intake air temperature: 1 °C
                    Voltage terminal 30: 0.085 V
                    Unlearning counter according OBD: 31
                    Air mass at air mass meter 1: 0.0 kg/h
                    Standardised airflow ratio: 1.000 counts
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: -0.83 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.00 %
                    Charge air pressure specified value: 0.000 bar
                    Absolute intake pressure: 102 kPa abs
                    Mean injection quantity: 0 mg/stroke
                    Index of current engine mode: 4
                    Index of next requested engine mode: 4
                    Index of engine target mode: 4
Readiness: N/A
   Revision: 00000000    Serial number: 42796000000447
   Coding: 517E4098256984818A7A0278A48321E6790000
   Shop #: WSC 02739 790 50316
   VCID: 3F8D5611A67B417E2A-806A
   Serial number: 15101613470715
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF3EB15E1F1887661-802A
   Part No SW: 7E0 907 047 AK    HW: 7E0 907 047 AK
   Component: Climatic-T5   H22 0708
   Revision: 00001002
   Coding: 0000000003
   ROD: EV_ClimaT5Basis.rod
   VCID: 73E5CA21DAB3D51E1E-8026
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 296161045
   Coding: B8AC303A0A61343193284F746CEB8E748F84708F60CC6960320400220840
   Shop #: WSC 02737 022 143099
   VCID: 2A5B174545F9D4D66D-807E
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 071016 04  42  0106
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801 P    HW: 7E0 959 801 P
   Component: J386__TSG_FT  003 0653
   Serial number: KU0KU012101662868080
   Coding: 1400B0
   Subsystem 3 - Part No SW: 7E0 959 802 P    HW: 7E0 959 802 P
   Component: J387__TSG_BT  003 0653
   Serial number: KU0KU006101662804730
   Coding: 0400A0
   Subsystem 4 - Part No: 7E1 951 172
   Subsystem 5 - Part No: 1K0 951 605 C
   Subsystem 6 - Part No: 7E1 951 172
   Subsystem 7 - Part No SW: 7E0 959 442     HW: 7E0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 29160001768330106363
   Coding: B0FFFF
03303 - Response Closing Status of Rear Left Door
                    Reset counter: 30
                    Mileage: 159628 km
                    Date: 2020.09.11
                    Time: 08:17:46
01495 - Bulb for High-Beams; Left (M30)
                    Fault Status: 00101010
                    Fault Frequency: 91
                    Reset counter: 32
                    Mileage: 159549 km
                    Date: 2020.09.09
                    Time: 19:52:05
                    Fault Status: 01101010
                    Fault Frequency: 14
                    Reset counter: 233
                    Mileage: 159548 km
                    Date: 2020.09.09
                    Time: 19:51:34
   Part No SW: 7E0 919 475 T    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0212
   Revision: --------    Serial number: 32961626402705
   Coding: 10800A
   ASAM Dataset: EV_VW75XParkAssis4K 001013
   ROD: EV_VW75XParkAssis4K_001_VN75.rod
   VCID: 43855AE1CA93259E4E-8016
   Part No SW: 7E0 959 655 G    HW: 7E0 959 655 G
   Component: VW10Airbag021 H08 0018
   Revision: --------    Serial number: 003V3002KMRM
   Coding: 000000000000000000000000000000003231
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3A7B2705BD5964561D-806E
   Part No SW: 7E0 920 970 S    HW: 7E0 920 970 S
   Coding: 7519010300
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
          U1101 00 [008] - Active
                    Fault Frequency: 12
                    Reset counter: 33
                    Mileage: 159492 km
                    Date: 2020.09.05
                    Time: 12:13:46
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 042305
   VCID: 68DFAD4D9B7526C6BB-803C
   Component: IMMO          H03 1104
   VCID: 6ADBD7458D7914D6AD-803E
Address 37: Navigation
   Part No SW: 5C0 035 680 G    HW: 5C0 035 680 G
   Component: MU-S-ND-ER    H41 0478
   Serial number: VWZAZ2T5290938
   Coding: 02630401FF00000011111101008808001F0104C600200100CF
   Shop #: WSC 00020 999 12345
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 2541E47924E7FBAE40-8070
   Subsystem 1 - Part No SW: 3G0 919 866 AQ    HW: -----------
   Component: ECE1 2017  --- 0730
          B201A 00 [009] - -
                    Reset counter: 209
                    Mileage: 159492 km
                    Date: 2020.09.05
                    Time: 12:13:46
                    Voltage terminal 30: 12.1 V
                    Status_Software_Version_Management-module_name:
          B2000 87 [009] - Missing message
                    Reset counter: 209
                    Mileage: 159492 km
                    Date: 2020.09.06
                    Time: 10:47:14
                    Voltage terminal 30: 14.7 V
                    System_Software_Error-SW_Status_Consistency: 04 01 01
                    System_Software_Error-SW_Status_Device: o
15360768 - Component Protection
          U1101 00 [009] - Active
                    Reset counter: 209
                    Mileage: 159492 km
                    Date: 2020.09.05
                    Time: 12:13:46
0517 - Front Right Bass Speaker
          B1062 13 [009] - Open Circuit
                    Reset counter: 209
                    Mileage: 159492 km
                    Date: 2020.09.05
                    Time: 12:13:49
0531 - Connection to Rear Left Loudspeakers
          B110C F0 [008] - Short Circuit Between Poles
                    Reset counter: 1
                    Mileage: 159531 km
                    Date: 2020.09.09
                    Time: 09:17:16
                    Voltage terminal 30: 12.3 V
2565 - GPS Antenna
          B1054 13 [009] - Open Circuit
                    Reset counter: 209
                    Mileage: 159492 km
                    Date: 2020.09.05
                    Time: 12:13:46
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H81 0744
   Coding: 030B1A73
   Shop #: WSC 02739 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Serial number: 75410903001609301559
02256 - Quiescent Current
                    Fault Status: 00100001
                    Reset counter: 10
                    Date: 2020.09.14
                    Time: 00:36:02
End-------------------------(Elapsed Time: 03:22)--------------------------
Clear fault codes from the ECU first.
Have you done a Security Access?
Skinner51
HUC-2H
I have tried but won’t accept the code
Skinner51
HUC-2H
Anyone got any ideas on this issue ? have cleared engine codes but can’t clear cluster and radio faults
Component Protection faults cannot be cleared off-line. Those will need to be handled on-line to the servers aboard VAG's mothership.
Skinner51
HUC-2H
Ok is this affecting my issue ?
I doubt it. But it wouldn't surprise me if the P0105 fault in the ECU is.
Skinner51
HUC-2H
But I can I have cleared faults in ECU and it still does it.
Do you think that with a software update from VW would help ?
South Molton, UK
If the problem causing the fault code is present then the fault code will come right back, you need to fix the underlying problem not just keep clearing the fault code.
Skinner51
HUC-2H
This is the first time the fault come up and been having this issue before this fault appeared
South Molton, UK
A dpf regen certainly won't happen until you sort out the problem causing the P0105 code, so you need to sort that out first.
