BLIND SPOT MONITORING
StuartWood
New Zealand
H11-2H
Good Morning Team.
Firstly, my account says Pirate, however now have the OEM VCDS.
My car, 2017 PE1 GTI with blind spot monitoring.
It failed a few years back (previous owner).
I have installed a new MASTER UNIT in the RH Rear of the car as that was the issue as the unit had failed.
Now, I get a NO .ROD FILE FOUND / DATA SHEET REQUIRED message for the unit and does not work.
Al coding is correct etc.
Anyone got some insight into this? I did some googling and there was a SEAT that had a similar issue. The post stated two solutions.
A: Drive the car it will learn
B: Need to get calibrated or load with data sheet.
Any accurate info would be greatly appreciated.
Please see full scan below.
Friday,25,September,2020,21:25:53:54382
VCDS Version: 20.4.2.0 (x64)  HEX-V2 CB: 0.4526.4
VIN: WVWZZZAUZHW374712   License Plate:
Mileage: 43228km-26860mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 10 13 14 15 16 17 19 29 32 39 3C 42 44 4B 52
          5F A5 A9 D6 D7
VIN: WVWZZZAUZHW374712   Mileage: 43228km-26860miles
Address 01: Engine (J623-DLBA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 N    HW: 06K 907 425 J
   Revision: --H13---
   Coding: 092500324464050B2000
   ASAM Dataset: EV_ECM20TFS0205G0906259N 002003
   ROD: EV_ECM20TFS0205G0906259N_002.rod
   VCID: 392F286409D4D42355D-806C
Readiness: 1010 0001
   Part No SW: 0GC 300 020 A    HW: 0GC 927 711 G
   Component: GSG DQ381     H06 1401
   Revision: 00H06V07
   ROD: EV_TCMDQ381061.rod
   VCID: 2019E5008A4EA5EB723-8074
   Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
   Component: ESC           H62 0743
   Revision: 00000000    Serial number: 60947000001981
   Coding: 01FA93A154272170477E060140C56980C92A84E260029677384250B9C2A9430000000012121212B835351919323200
   VCID: 79AFE8644954142315D-802C
   Part No SW: 5G0 907 044 CE    HW: 5G0 907 044 CE
   Revision: 00001K08
   Coding: 0012001420010000110500001210142A
   VCID: 6C81C1303606B18B9EB-8038
   Air quality sensor:
          B10CD 00 [008] - -
                    Reset counter: 67
                    Mileage: 43215 km
                    Date: 2020.09.25
                    Time: 20:43:40
                    Voltage terminal 30: 10.5 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up light: OFF
   Part No SW: 5Q0 937 084 CF    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H34 0236
   Serial number: 02001710902294
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7EA5FB78507A331B20F-802A
   Component: WWS    170322  042 0551
   Serial number:         170412084557
   Component: RLHS  042 0105
   Serial number: S7Y17M04D20H15M08S03
   Coding: 00A8DD
   Serial number: 00000000000068880941
   Sun Roof:
   Subsystem 4 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST001JVIA700000
   Coding: 181901
264452 - No Communications with Anti-Theft Sensor
          U10F4 00 [009] - -
          [Sensor-DWA->kein Signal/ Kommunikation]
                    Reset counter: 27
                    Mileage: 43215 km
                    Date: 2020.09.25
                    Time: 20:05:34
   Part No SW: 5QA 919 298 B    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0038
   Serial number: 000308417617103
   Coding: 0371167051
   ASAM Dataset: EV_EPHVA2CAU3700000 009032
   VCID: 4FFB76BCA7506A939B9-801A
13688835 - Databus
          [Steuergerät für Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
                    Reset counter: 27
                    Mileage: 43215 km
                    Date: 2020.09.25
                    Time: 20:32:17
   Part No SW: 5Q0 907 572 H    HW: 3QF 907 572
   Coding: 330067C159FFC428949C810580300600000000000000000000
   VCID: 3C21317006E6E10B4EB-8068
   Serial number: 15031741350009
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 38292D6032DECD2BAA3-806C
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0318
   Serial number: 003TDR2WDR6N
   Coding: 98CCC000000000005C000000008800000065
   VCID: 1079B5C07AEE356BC23-8044
   Belt Pretensioner left:
   Serial number: 34169661E06041750058
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169662E06041750162
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 104 17
   Serial number: 357000000008A5F0C22Q
   Subsystem 4 - Part No SW: -----------    HW: 480 002 104 17
   Serial number: 358000000003FBC8C12.
   Subsystem 5 - Part No SW: -----------    HW: 480 402 703 17
   Serial number: 3510001B324D9E668369
   Subsystem 6 - Part No SW: -----------    HW: 480 401 004 17
   Serial number: 3520001A524D8E639605
   Subsystem 7 - Part No SW: -----------    HW: 480 402 004 17
   Serial number: 3550001B5254CB156774
   Part No SW: 5Q0 953 507 GK    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 22041708491184
   Coding: 0C10
   VCID: 0557949435AC60C3615-8050
   Part No SW: 5G1 920 791     HW: 5G1 920 791
   Component: KOMBI         409 2180
   Coding: 27AD19087F8C000801886B0B5401000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009052
   VCID: 698FB82439F4A4A3E5D-803C
   Component: GW MQB High   418 4286
   Revision: --------    Serial number: 0006213389
   Coding: 030100347F085900FB00027F9C0F00010001050000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 2F3B163CC7900A93FB9-807A
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Serial number: 39170001028620057152
   Coding: 2DFFFF
   Serial number: 7900343504
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   VCID: 47CB5E9C4F20B2D3D39-8012
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8042
   Serial number: HA1-00004.03.17
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Serial number: 0401581391
   Coding: 02011203
   ROD: EV_HREntryHella_VW37.rod
   Lane Change Assistant 2:
   Serial number: 0438984639
   Coding: 020112
267520 - invalid data record
          B2005 00 [009] - -
          [Control Unit - Invailed dataset]
                    Reset counter: 27
   Serial number: 260217EBQ04176
   Coding: 003E02208001048100001000
   VCID: 43D34A8C7B189EF30F1-8016
   Coding: 9307
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2D37680CD2DF3B5C7-806E
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Component: FCM MQB Low   001 0285
   Serial number: 15041710521701
   Coding: 000000050100164E07204F01020000000000000000000000000000000000
   VCID: 72BDDF481422677B547-8026
   Serial number: 080417ED730592
   Coding: 003E00208E01048100801000
   VCID: 42DD4F88640297FB047-8016
   Part No SW: 3Q0 035 864 B    HW: 3Q0 035 864 B
   Component: MU-S-N-ER     840 0753
   Coding: 02731008FF00000051510001000808001F0503F601200002CF
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 30391540DAAE156BE23-8064
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H41 8084
   Serial number: VWZ6ZHT1140790
   Subsystem 2 - Part No SW: 5NA 919 866 AD    HW: -----------
   Component: MRM3 2020  --- 1310
   Serial number: 19041711P20431
   Coding: 000307000000010100021354C050490094000E300040
   VCID: 3B23326C03E8E633471-806E
   Part No SW: 5G0 907 159 G    HW: 4H0 907 159 A
   Serial number: 170104202485
   VCID: 323D1F48D4A2277B947-8066
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 01:48, VBatt start/end: 14.4V/14.4V)-----------
I've removed the "Pirate" designation. Your "OEM VCDS" appears to be a second-hand system?
I do not see a "no ROD file found" in your scan. I see an "Invalid data record" fault.
siLc
Tallinn, Estonia
C?ID=330192
B is much more likely. From which donor did the part come from?
downtime
Finland
C?ID=280813
siLc is correct, you need to upload correct datarecod to the master unit. That you cannot do with VCDS.
StuartWood
New Zealand
H11-2H
Thank you for that!
I have a picture, I will post below now.
Hmm, that wasn't a problem previously:
   Coding: 02011203
Are you using the same interface, or have you reverted to using your previous clone? ;)
In the case pictured above, it appears VCDS may have been confused about the car it was plugged into since it is looking for VW48 platform data rather than VW37. Try connecting to the Engine or the Instrument Cluster first.
StuartWood
New Zealand
H11-2H
   Coding: 02011203
hahaha. Negative. Threw that a way long ago. I did the right thing.
I was using my friends interface to do this as did not have my cable on me at the time. I have my own OEM interface
In auto scan, it did not show any .ROD errors, but only when going into the 3C.
I will connect to Engine or instrument cluster first.
What are the exact steps you recommend I do?
Appreciate the assistance on a Sunday
