Navigation Database not found - Cupra Ateca
benp
C?ID=411857
Seeking advice from the experts.
I purchased a VCDS cable to allow me to program in a towbar (which I fitted and configured successfully this weekend)
However I appear to have "lost" my Navigation card from module 5F. I was having a play around to resolve a issue with this module being incorrectly coded. I managed to clear that issue with a little trial and error (It appears that the dealer had changed the headhunt splash screen - it did not have one when I collected the car, so did not think to check). I was only doing the initial check on the car when I found the faults, and from the looks of it must have been the dealer as some of the faults are marked the 13th Sept and I did not receive my cable until the 15th. This was a non SEAT/Cupra dealer around 6hour round trip from my house.
Majority of faults were transitory and cleared with an initial wipe, however issues with modules 5F and 6C remained. 6C requires a trip to a dealer to calibrate the cameras. Please note the final scan shows a tower, that I fitted this weekend, however I have the logs from before fitting showing the same issue.
I fixed the error relating to the incorrect coding, however got a new error regarding the missing nav database. I reverted back to the original long code and got two errors (coding and nav). So I must have done something else, but cannot recall anything other than the long coding. I did make a backup of module 5F before making any changes, however when I restore, I have the original error, plus the missing Nav database.
I have absolutely no idea what has happened to the link to the SD card (card is recognised when installed, so have to assume the system thinks the card is incorrect).
Logs in following posts.
Any assistance would be appreciated (however I am assuming it is going to be a dealer fix)
benp
C?ID=411857
Initial scan taken on 15th Sept. Picked car up AM 14th Sept
Tuesday,15,September,2020,13:56:26:55718
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 20.4.2.0  HEX-V2 CB: 0.4526.4
VIN: VSSZZZ5FZK6534501   License Plate:
Chassis Type: 5F-SE37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 2B 42 44 4B 52 5F 6C
          D6 D7
VIN: VSSZZZ5FZK6534501   Mileage: 7974km-4954miles
Address 01: Engine (J623-DNUE)       Labels: None
   Part No SW: 81A 906 259     HW: 06K 907 425 J
   Revision: --H13---
   Coding: 0B2540322426050B3004
   Shop #: WSC 33361 790 00173
   ASAM Dataset: EV_ECM20TFS02081A906259 001003
   ROD: EV_ECM20TFS02081A906259_VW37.rod
   VCID: 698FB9A849F47823E5D-803D
17186 - Databus
                    Mileage: 7829 km
                    Date: 2020.09.13
                    Time: 18:31:58
                    Engine speed: 1366.75 /min
                    Normed load value: 1.6 %
                    Coolant temperature: 37 °C
                    Intake air temperature: 25 °C
                    Voltage terminal 30: 10.585 V
                    Unlearning counter according OBD: 34
                    ACC variants (coding): CCS
                    CCS Switch: CCS operating unit
                    Cruise control switch actuation-Main switch: not activated
                    Cruise control switch actuation-Setting: not activated
                    Cruise control switch actuation-Activation: not activated
                    Cruise control switch actuation-Accelerate: not activated
                    Cruise control switch actuation-Decelerate: not activated
                    Cruise control switch actuation-Cancel: not activated
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Limit button: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    Cruise control switch actuation-Large increment: not activated
                    ACC variants: ACC
                    Engine: operating status: IS
   Part No SW: 0GC 300 014 A    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2401
   Revision: 00H06V07
   ROD: EV_TCMDQ381061.rod
   VCID: 2313EB80EB5862736F1-8077
   Part No SW: 5Q0 614 517 EE    HW: 5Q0 614 517 BN
   Component: ESC           H35 0107
   Revision: 00000000    Serial number: 63168000001456
   Coding: 21EE939250232470877C070062C46984C90A24E1E0469677304250F4E2064B010040100252522424025E833B485266E4
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 78A9ECEC025ED1AB6A3-802D
0128 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [undervoltage]
                    Reset counter: 16
                    Mileage: 7366 km
                    Date: 2020.05.06
                    Time: 00:00:04
4542 - Control Switch for Hill Descent
          C113B 00 [008] - -
          [HDC_SWITCH_FAILURE]
                    Reset counter: 229
                    Mileage: 7366 km
                    Date: 2020.06.01
                    Time: 15:51:16
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0499825231
   Coding: 132C0C0707
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43D34B000B1842730F1-8017
   Part No SW: 5F0 907 044 AK    HW: 5F0 907 044 AK
   Component: Climatronic   H05 1801
   Revision: 00001K09
   Coding: 06100204200114011005004000101020
   Shop #: WSC 33361 790 00112
   VCID: 6FBBD7B077109613BB9-803B
   Air quality sensor:
   Part No SW: 5Q0 937 084 DD    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H38 0273
   Serial number: 00001832901636
   ROD: EV_BCMBOSCH_019.rod
   VCID: 7DA7FDF82D7CF483395-8029
   Subsystem 1 - Part No SW: 81A 955 555 A    HW: 81A 955 555
   Serial number: 22110617X81A955555A0
   Coding: 80007E
   Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY182211J9A
   Serial number: 00000000000045704062
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 521 AA    HW: 5Q1 953 569 A
   Component: Lenks.Modul  H13 0170
   Serial number: 0100011120180C200350
204290 - Remote key 1
          B1479 18 [008] - Current Too Low
                    Reset counter: 26
                    Mileage: 7882 km
                    Date: 2020.09.14
                    Time: 14:20:57
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417618325
   Coding: 0371261051
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   VCID: 51FF7148C164A0E38DD-8005
   Part No SW: 2Q0 907 572 Q    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0342
   Coding: 3200608358FF8728749C814500408700000000000000000000
   ASAM Dataset: EV_ACCMRRCONTIVW376 003015
   ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
   VCID: 42DD4E0414024B7B047-8017
   Serial number: 27101841350224
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 38292CEC42DE11ABAA3-806D
   Part No SW: 3Q0 959 655 CM    HW: 3Q0 959 655 CM
   Component: Airbag VW21   006 0720
   Revision: --------    Serial number: 003Z2PQ2RDX.
   Coding: 98CCC0C0000000005C5400CC008800000065
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 0B43A32063C8CA33371-805F
   Subsystem 1 - Part No SW: -----------    HW: 454 001 411 18
   Serial number: 357000000006A1CCA53V
   Subsystem 2 - Part No SW: -----------    HW: 454 001 311 18
   Serial number: 35800000000AA8ACA53+
   Subsystem 3 - Part No SW: -----------    HW: 454 801 411 18
   Serial number: 351002AF9E116000000O
   Subsystem 4 - Part No SW: -----------    HW: 454 801 511 18
   Serial number: 352001EEBC416000000U
   Subsystem 5 - Part No SW: -----------    HW: 454 803 110 18
   Serial number: 35500A148A316000000D
   Part No SW: 5F0 920 790 A    HW: 5F0 920 790 A
   Component: KOMBI         609 1701
   Coding: 24AD601BBB800E00018862011001000080000000
   Shop #: WSC 73430 031 00173
   ASAM Dataset: EV_DashBoardVDDMQBA0 001026
   ROD: EV_DashBoardVDDMQBA0_SE37.rod
   VCID: 270BFF909F608E53339-8073
   Serial number: 29111811600656
   Coding: 030500F42F085900E903A2489E0F00010001070000000000000000000000
   Shop #: WSC 33361 790 00170
   ROD: EV_GatewNF_SK26.rod
   VCID: 6E85CAB4701A9F1BB0F-803B
   Component: 0-00-03-00-04
   Subsystem 2 - Part No SW: 5F0 959 537 D    HW: 5F0 959 537 D
   Serial number: 000000000H2192311018
   Coding: 012000
   Serial number: 758860020018111814EE
8526361 - LV Energy Management
          B1802 F1 [008] - Warning Triggered
                    Reset counter: 26
                    Mileage: 7829 km
                    Date: 2020.09.13
                    Time: 18:30:46
                    Supply voltage: Terminal 30: 10.9 V
                    Terminal 15: On
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00003.10.18
   Coding: 0001
   VCID: 4CC1603C26468D0BFEB-8019
   Serial number: 18000360876006
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_AU37.rod
   VCID: 33331BC05BB8F2F39F1-8067
   Part No SW: 5Q4 959 593 F    HW: 5Q4 959 593 F
   Component: TSG FS        006 0246
   Serial number: 0000356451197
   Coding: 00351220D001020000001000
   VCID: 48C95C2C323E612BDA3-801D
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E
   Serial number: 00000000000025431848
   Coding: 3D0000
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Coding: 83170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C2130FC76E63D8B4EB-8069
   Component: FCM MQB Low   002 0345
   Serial number: 26111810800669
   Coding: 000000070900065607000900000000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW41.rod
   VCID: 353725D855CCECC3B15-8061
0004 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [Functional restriction due to undervoltage]
                    Reset counter: 17
                    Mileage: 7366 km
                    Date: 2020.05.06
   Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0246
   Serial number: 0000356326805
   Coding: 00351020D401020000001000
   VCID: 47CB5F103F206E53D39-8013
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E
   Serial number: 00000000000025395027
   Coding: 250000
196724 - Motors for Central Locking
          B122B 13 [008] - Open Circuit
                    Reset counter: 28
                    Mileage: 7951 km
                    Date: 2020.09.15
                    Time: 12:50:53
Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-HGH2.clb
   Part No SW: 5F0 035 020 H    HW: 5F0 035 020
   Component: MU-H-ND-EU    H55 1409
   Serial number: A678K0JB014951
   Coding: 04230601FF00000011110101008808212F050CE601200400DE
   ASAM Dataset: EV_MUHig6C1Gen2HBAS 001001
   ROD: EV_MUHig6C1Gen2HBAS.rod
   VCID: 1D67DD78CD3C5483595-8049
   Subsystem 1 - Part No SW: 575 919 606     HW: 575 919 606
   Component: ABT_High-2_N  H41 1041
   Serial number: SEZ8Z9V1S02NF8
   Subsystem 2 - Part No SW: V03 959 802 MN    HW: -----------
   Component: ECE 2019  --- 0172
   Compact Disc Database:
   Component: Gracenote2  --- 1017
          U1014 00 [009] - -
                    Reset counter: 241
                    Mileage: 7829 km
                    Date: 2020.09.13
                    Time: 18:34:46
                    Voltage terminal 30: 13.5 V
   Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Component: Areaview 2    H13 0608
   Serial number: C854707JG041958
   Coding: 06230601260FA00000606094
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
   VCID: 392F29E879D408A355D-806D
10489856 - No Basic Setting
          B2010 00 [009] - -
                    Reset counter: 244
                    Mileage: 7888 km
                    Date: 2020.09.14
                    Time: 17:34:48
9618000 - Left Surroundings Camera
          B127E 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 241
                    Mileage: 7888 km
                    Date: 2020.09.14
                    Time: 17:34:48
9618001 - Right Surroundings Camera
          B127F 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 241
                    Mileage: 7888 km
                    Date: 2020.09.14
                    Time: 17:34:48
   ROD: EV_LED_PLUS_L_KEBODAVW416_SE37.rod
   VCID: 7EA5FAF4207AEF9B20F-802B
0774 - Light Bulb for Low Beam
          C1198 29 [040] - Signal Implausible
                    Reset counter: 0
                    Mileage: 7366 km
                    Date: 2020.05.06
                    Reset counter: 0
                    Mileage: 7366 km
                    Date: 2020.05.06
End----------(Elapsed Time: 01:41, VBatt start/end: 12.1V/12.0V)-----------
benp
C?ID=411857
Latest scan taken this morning. I think I have a suspect battery as I have had the low battery message a number of times, I have charged the battery, and keep it on charge when making any changes.
Friday,25,September,2020,10:04:05:55718
Workshop Code: 000 00001 000000
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 2B 42 44 4B 52 5F 69
          6C D6 D7
VIN: VSSZZZ5FZK6534501   Mileage: 8352km-5189miles
   Revision: --H13---
   Revision: 00H06V07
   Coding: 132C0C0707
   Revision: 00001K09
   Air quality sensor:
   Coding: 80007E
   Coding: 0371261151
   Coding: 3200608B58FF8728749C814500408700000000000000000000
   Shop #: WSC 00001 000 00000
   Coding: 2428601BBB800E00018862011001000080000000
   Coding: 012000
   Coding: 0001
   Coding: 3D0000
   Coding: 83170000
   Coding: 250000
   Coding: 04230601FF00000011110101008808212F050AE601200400FE
   Subsystem 2 - Part No SW: V03 959 800 EG    HW: -----------
2563 - Navigation System
          B126C F1 [009] - Navigation Database Missing
                    Reset counter: 248
                    Mileage: 8302 km
                    Date: 2020.09.22
                    Time: 12:43:02
                    Voltage terminal 30: 14.0 V
6672 - Optical Data Bus for Display in Instruments
          U10CF 00 [008] - Intermittent Disruption
          [Optical data bus: sporadic open circuit in instrument cluster display]
                    Reset counter: 34
                    Mileage: 8302 km
                    Date: 2020.09.22
                    Time: 17:03:59
                    Voltage terminal 30: 14.6 V
                    Temperature of MOST transceiver-max.value: -50 °C
                    Temperature of MOST transceiver-min.value: -11 °C
                    Temperature of MOST transceiver-Current: 31 °C
   Part No SW: 5Q0 907 383 L    HW: 5Q0 907 383 L
   Component: Anhaenger     H27 0260
   Revision: 8C001005    Serial number: 0551036025
   Coding: 0100000202000000
   VCID: 40D9440C1A0E596B123-8015
          B2010 00 [009] - -
                    Fault Frequency: 12
                    Reset counter: 249
                    Mileage: 8302 km
                    Date: 2020.09.22
                    Time: 12:42:59
                    Reset counter: 248
                    Mileage: 8302 km
                    Date: 2020.09.22
                    Time: 12:42:59
                    Reset counter: 248
                    Mileage: 8302 km
                    Date: 2020.09.22
                    Time: 12:42:59
End----(Elapsed Time: 01:37, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
@benp: I'm by no means an expert on your Cupra, but the "6672" DTC in the hex5F module seems to be quite specific (and very telling)!! The optical cables linking the hex17 and hex5F modules (it's a ring architecture - so 2 x optical cables which are both terminated on the one connector) carry the MOST protocol messages for the AID dashboard - which facilitates functions like SATNAV.
The error message strongly suggests that there are intermittent connection problems with these optical fiber cables - perhaps the first step is to eye-ball the connectors to make sure that they are seated properly on the module housing sockets and to check that they are not damaged, maybe?
benp
C?ID=411857
Don,
Many thanks. I have taken out the MIB unit and unplugged and plugged in the white two "wire" connection just to check it was not this. Once the battery was plugged back in, I wiped all DTC's, and I am left with just the missing navigation (5F) and the camera calibration (6C). I'll keep checking to see if the optical fault comes back up.
I am going to book the car in, due to the suspect battery and see how much they want for resolving my nav issue!
B
