ABS Control Unit Long Coding (MK60EC1)
Grayo
Australia
C?ID=96682
Hi All,
Is there anybody out there that could supply me with the long coding for an ABS Control Unit please. Attached is the latest autoscan data. Look forward to your reply's.
Many thanks,
Grayo.
Tuesday,01,September,2020,17:49:04:17246
VCDS Version: 20.4.1.0 (x64)
VIN: WVWZZZ1KZ6U031820   License Plate:
Mileage: 70230km-43638mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
VIN: WVWZZZ1KZ6U031820   Mileage: 70230km-43638miles
04-Steering Angle -- Status: Cannot be reached 1100
   Part No SW: 1K0 907 115 J    HW: 1K0 907 115 F
   Component: 2.0l R4/4V TFSI     0030
   Revision: --H14---    Serial number: VWZ7Z0F3618438
   Coding: 040300031C070160
   Shop #: WSC 20059 067 57207
   VCID: 2D5083C8B45260EE90-8078
000406 - Engine Oil Temp. Sensor (G8)
               P0196 - 004 - Implausible Signal - Intermittent
                    Mileage: 70234 km
                    Time: 09:03:23
                    Temperature: 17.0°C
                    Temperature: 20.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 10.541 V
000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage - Intermittent
                    Mileage: 70234 km
                    Temperature: 14.0°C
                    Temperature: 17.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 11.938 V
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
Readiness: 0110 0101
   Part No SW: 02E 300 043 Q    HW: 02E 927 770 AE
   Component: GSG DSG         081 1305
   Revision: 04508010    Serial number: 00000704230198
   Shop #: WSC 44551 111 44551
   VCID: 224A60F4FD8CAF963D-8076
18036 - Powertrain Data Bus
            P1628 - 000 - Missing Message from Steering Angle Sensor
                    Fault Frequency: 255
                    Mileage: 70234 km
18259 - Powertrain Data Bus
            P1851 - 000 - Missing Message from ABS Controller - Intermittent
18262 - Powertrain Data Bus
            P1854 - 000 - Hardware Malfunction - Intermittent
                    Mileage: 70235 km
18261 - Powertrain Data Bus
            P1853 - 000 - Implausible Message from ABS Controller - Intermittent
                    Mileage: 70235 km
   Part No SW: 1K0 907 379 AP    HW: 1K0 907 379 AP
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 00066 000 00000
   VCID: 000E0A7C93405D860B-8054
7 Faults Found:
                    Fault Status: 00100101
                    Reset counter: 0
                    Mileage: 70235 km
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 212
                    Count: 42240
                    Count: 21760
                    Fault Status: 01101100
                    Reset counter: 0
                    Mileage: 70235 km
                    Count: 16391
                    Count: 12
                    Count: 272
                    Count: 42240
                    Count: 256
                    Count: 21760
                    Fault Status: 01100101
                    Reset counter: 0
                    Mileage: 70235 km
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 279
                    Count: 42240
                    Count: 21760
                    Reset counter: 0
                    Mileage: 70235 km
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 295
                    Count: 42240
                    Count: 21760
                    Reset counter: 0
                    Mileage: 70235 km
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 270
                    Count: 42240
                    Count: 21760
                    Reset counter: 197
                    Mileage: 70235 km
                    Count: 16391
                    Count: 12
                    Count: 195
                    Count: 42240
                    Count: 256
                    Count: 21760
                    Reset counter: 197
                    Mileage: 70235 km
                    Count: 2
                    Count: 2
                    Count: 12800
                    Count: 107
                    Count: 41984
                    Count: 256
                    Count: 21760
   Part No SW: 1K0 907 044 CP    HW: 1K0 907 044 CP
   Component: ClimatronicPQ35 130 1212
   Revision: 00130022    Serial number: 00000000000000
   VCID: 77FC61A0068E1A3E3A-8022
   Revision: 00H54000    Serial number: 00000007101175
   Coding: E58D8F2700041500471400001400000000087F075C000100000000000000
   Shop #: WSC 00046 412 00000
   VCID: 71E85FB868EA440EF4-8024
   Component: Wischer 110707 020  0501
   Coding: 00049109
   Shop #: WSC 00046
   Component: RLS     171007 046  0204
   Coding: 00208933
   Shop #: WSC 00046
02092 - Enabling Heated Seat
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 197
                    Mileage: 70234 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.75 V
                    Reset counter: 237
                    Mileage: 70235 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 7.55 V
                    Reset counter: 237
                    Mileage: 70235 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 7.10 V
00154 - Windshield Wiper Motor;  Passenger Side (V217)
                    Reset counter: 237
                    Mileage: 70235 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.55 V
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
                    Reset counter: 237
                    Mileage: 70235 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.55 V
   Component: 1P AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD162JLC
   Coding: 0012624
   VCID: 3D70B3886432F06E20-8068
   Subsystem 1 - Serial number: 6332MSME296349026
   Subsystem 2 - Serial number: 6342MSME3445237BB
   Subsystem 3 - Serial number: 6352QSME43714567E
   Subsystem 4 - Serial number: 6362QSME4304392FI
            002 - Lower Limit Exceeded - Intermittent - MIL ON
            004 - No Signal/Communication - Intermittent - MIL ON
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Component: J0527           636 0070
   Coding: 0012122
   VCID: 01080F78584A548E04-8054
   Part No: 1K6 920 862 D
   Component: KOMBIINSTRUMENT VDD 4312
   Coding: 0007703
   Shop #: WSC 20059 551 00000
   VCID: 31689FB8A86A040EB4-8064
00771 - Fuel Level Sensor (G)
   Revision:   H07 01    Serial number: 300507F2000008
   Coding: ED807F061002020003
   VCID: 306E9ABCA3600D06BB-8064
                    Reset counter: 197
                    Mileage: 70235 km
                    Time: 00:00:28
00469 - Infotainment Databus in Single Wire Operation
                    Fault Status: 00101100
                    Reset counter: 237
                    Mileage: 70235 km
                    Time: 00:00:02
01304 - Radio
                    Reset counter: 197
                    Mileage: 70235 km
                    Time: 00:00:32
   Component: IMMO            VDD 4312
   Shop #: WSC 12222 000 00000
   Component: Tuer-SG         006 120B
   Coding: 0000692
   VCID: 387EA29C4B10D546F3-806C
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.069 H08 1901
   VCID: 3662ACA441042336E1-8062
02546 - Steering Limit Stop
                    Mileage: 70220 km
                    Temperature: 19.0°C
                    Voltage: 13.40 V
                    Voltage: 13.20 V
00573 - Steering Torque Sensor (G269)
                    Mileage: 70220 km
                    Temperature: 15.0°C
                    Voltage: 6.00 V
                    Voltage: 5.80 V
   Coding: 819002005103087F2D04840570085FC690FC00
   VCID: 030405704256469E16-8056
   Subsystem 2 - Component:       NGS No Answer
   Subsystem 3 - Component:      IRUE No Answer
                    Fault Frequency: 15
                    Reset counter: 197
                    Mileage: 70234 km
                    Time: 04:48:50
00323 - Vehicle Inclination Sensor (G384)
                    Fault Frequency: 15
                    Reset counter: 197
                    Mileage: 70234 km
                    Time: 04:48:51
                    Fault Status: 00110010
                    Reset counter: 237
                    Mileage: 70235 km
                    Time: 00:04:40
                    Reset counter: 237
Address 47: Sound System        Labels: 3C0-035-456.clb
   Part No SW: 1K6 035 456 B    HW: 1K6 035 456 B
   Component: 08K Audioverst.     0006
   Revision: 00004000    Serial number: 00000008144840
   VCID: 2B548DD08A466EDE8E-807E
7 Faults Found:
00419 - Left Front DSP Midrange Speaker (R103)
00875 - Treble Speaker Front Right (R22)
00420 - Front Right DSP Midrange Speaker (R104)
00877 - Treble Speaker Rear Right (R16)
   Component: Tuer-SG         006 1210
   Coding: 0000692
   VCID: 3978A798701ACC4E0C-806C
00097 - Front Passengers Central Locking (Safe) Motor (V162)
Address 56: Radio
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         006 1201
   Coding: 0000192
   Shop #: WSC 00046 412 1012544
01813 - Supply Voltage for Door Controller; Rear Left (J388)
00098 - Rear Left Central Locking (Safe) Motor (V163)
00122 - Outside Warning Light/Door Exit Light; Rear Left
00102 - Rear Left Interior Locking Button (E310)
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Component: Tuer-SG         005 0912
   Coding: 0000144
01814 - Supply Voltage for Door Controller; Rear Right (J389)
            014 - Defective
00099 - Rear Right Central Locking (Safe) Motor (V164)
End-------------------------(Elapsed Time: 01:50)--------------------------
How was the coding lost? What parts have been replaced?
Do you have any older scans from this car from before the coding was lost? Look in your Scans sub-folder.
Grayo
Australia
C?ID=96682
Hi Uwe,
I’m not sure how it has lost its coding. I’ve inherited this vehicle from another workshop and information is very sketchy. I’ve coded these abs units before with help from this forum so I’m pretty sure I just need somebody to generate the correct long coding for me.
Cheers
Grayo.
