I know this configuration isn't supported, but someone has to have tried this and I'm wondering if anyone might know what's going on here.
I have a laptop that's dual boot Win10/Ubuntu. I installed Oracle VirtualBox on Ubuntu, installed Windows 10 in a guest, and then installed VCDS in the Windows 10 guest. I had success in getting VCDS to see the cable, and then I went out to try an auto-scan. I did an autoscan both with VCDS installed in a VirtualBox guest, and also with VCDS running on Windows 10 on bare metal, and got different results. Specifically, if run inside VirtualBox, VCDS will not scan the airbag controller.
The car is an '01 New Beetle with a 2.0 gas engine.
Windows 10 inside VirtualBox:
And on bare metal:
Only thing I can figure is, I do have one of the "bad" airbag controller part numbers that presented problems with earlier versions of VCDS, and the software or the driver is blocking it for that reason. Any clues?
Thursday,24,September,2020,17:35:49:10877
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VirtualBox)
VCDS Version 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
Mileage: 222710km-138385mi Repair Order:
Chassis Type: 1C - VW New Beetle (1998 > 2010)
Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
Mileage: 222710km-138385miles
Address 01: Engine Labels: 06A-906-032-AVH.lbl
Part No: 06A 906 032 BS
Component: 2.0l R4/2V G *3655
Coding: 00003
Shop #: WSC 00066
VCID: 70B92E7093B1B45BA23-5161
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No: 01M 927 733 JF
Component: AG4 Getriebe 01M 4719
Coding: 00000
VCID: 7DA70744D4E3C933395-0963
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 P
Component: ABS 20 IE CAN 0001
Coding: 03504
Shop #: WSC 00066
VCID: 3E25C0489965122B60F-4B1F
Address 17: Instruments Labels: 1C0-920-xx0.lbl
Part No: 1C0 920 901 X
Component: KOMBI+WEGFAHRS. M73 V07
Coding: 03202
Shop #: WSC 09141
VCID: 313FEB74583BFD53EDD-4B1F
Subsystem 1 - Part No: Ident
Component: Nr. Wegfahrs.:VWZ5Z0B2142050
Ident.-Nr. Wegfahrs.:VWZ5Z0B2142050
Part No: 6N0 909 901
Component: Gateway K<->CAN V072
Coding: 00007
Shop #: WSC 09141
VCID: 70B92E7093B1B45BA23-4B1F
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AJ
Component: 5X Zentral-SG Komf. 0001
Coding: 00257
Shop #: WSC 00066
VCID: 065568A881358AEB68F-4B1F
Subsystem 1 - Part No: 1J2959802C
Component: 5X Tõrsteuerger. FS0002r
Subsystem 2 - Part No: 1J2959801D
Component: 5X Tõrsteuerger. BF0002r
End----(Elapsed Time: 03:37, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Thursday,24,September,2020,17:44:58:10877
Coding: 00003
Shop #: WSC 00066
VCID: 70B92E7093B1B45BA23-5160
Coding: 00000
VCID: 7DA70744D4E3C933395-0962
Coding: 03504
Shop #: WSC 00066
VCID: 3E25C0489965122B60F-4B1E
Part No: 6Q0 909 605 A
Component: 16 AIRBAG VW5 0D 0004
Coding: 12598
Shop #: WSC 00066
VCID: 3537DF64AC53D173B15-4B3C
Coding: 03202
Shop #: WSC 09141
VCID: 313FEB74583BFD53EDD-4B1E
Coding: 00007
Shop #: WSC 09141
VCID: 70B92E7093B1B45BA23-4B1E
Coding: 00257
Shop #: WSC 00066
VCID: 065568A881358AEB68F-4B1E
End----(Elapsed Time: 03:34, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
