VW MK Jetta TDI Auto scan
StaticB5
Canada
C?ID=412418
Ran an autoscan on my brothers jetta was just wondering what you guys could see is wrong with it, we know its got a few bulbs out and needs new suspension not sure if the scan can tell anything else. thanks!
Thursday,24,September,2020,16:19:34:42261
VIN: 3VWST81K26M825863   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWST81K26M825863   Mileage: 297160km-184646miles
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine        Labels: 038-906-016-BEW.lbl
   Part No SW: 03G 906 016 AB    HW: 028 101 223 8
   Component: R4 1,9L EDC G000SG  7550
   Revision: --H02---    Serial number: VWZ7Z0F3782301
   Coding: 0050071
   Shop #: WSC 00008 128 00289
   VCID: 6393AB93675FE9432F1-8036
005746 - Coolant Fan Control 1
               P1672 - 000 - Open or Short to Ground - Intermittent
                    Voltage: 11.55 V
                    Bin. Bits: 00001100
                    Temperature: 0.9°C
                    Duty Cycle: 9.7 %
005697 - Please check DTC Memory of A/C Controller
               P1641 - 000 -
                    Mileage: 296671 km
                    Time: 00:00:34
                    Voltage: 11.86 V
                    Bin. Bits: 00001100
                    Temperature: 0.9°C
                    (no units): 16.0
000833 - Camshaft Position Sensor (G40)
               P0341 - 000 - Implausible Signal - Intermittent
                    Mileage: 296693 km
                    Time: 01:02:45
                    RPM: 798 /min
                    Voltage: 14.21 V
                    Bin. Bits: 00001000
                    Idle Stabilization: 0.0°KW
                    (no units): 48.0
005659 - Glowplug for Cylinder 2 (Q11)
               P161B - 000 - Open Circuit - Intermittent
                    Fault Status: 00110000
                    Mileage: 296879 km
                    Time: 01:11:32
                    RPM: 777 /min
                    Voltage: 14.44 V
                    Bin. Bits: 00001000
                    Temperature: 18.9°C
                    Bin. Bits: 10110000
   Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
   Revision: 00H13001
   Coding: 0021122
   Shop #: WSC 00066 000 00000
   VCID: 71BFD1DBADA34BD3ADD-8024
            013 - Check DTC Memory
   Part No: 1K0 820 047 DQ
   Component: Climatic PQ35   090 0505
   VCID: 76B5E2C7C4CD6CEB78F-8022
            009 - Open or Short to Ground
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Revision: 00H37000    Serial number: 00000000326256
   Coding: 10018E234004150000140000001400000008730B5C
   Shop #: WSC 93363 999 84250
   VCID: 2A0D06B740F5780B2C7-807E
   Component: Wischer 111006 020  0501
   Coding: 00038805
   Shop #: WSC 93363
10 Faults Found:
                    Fault Status: 01101100
                    Reset counter: 33
                    Mileage: 296671 km
                    Voltage: 12.55 V
                    Reset counter: 33
                    Mileage: 282451 km
                    Voltage: 14.50 V
                    Reset counter: 33
                    Mileage: 296671 km
                    Voltage: 11.90 V
                    Reset counter: 33
                    Mileage: 296879 km
                    Voltage: 14.25 V
                    Reset counter: 73
                    Mileage: 297167 km
                    Voltage: 8.35 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 33
                    Mileage: 296671 km
                    Voltage: 11.90 V
01049 - Supply Voltage Term 50
                    Fault Status: 00101100
                    Reset counter: 73
                    Mileage: 297167 km
                    Voltage: 8.25 V
                    Reset counter: 73
                    Mileage: 297167 km
                    Voltage: 6.30 V
00154 - Windshield Wiper Motor;  Passenger Side (V217)
                    Fault Frequency: 21
                    Reset counter: 73
                    Mileage: 296670 km
                    Voltage: 9.50 V
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
                    Fault Frequency: 21
                    Reset counter: 73
                    Mileage: 296670 km
                    Voltage: 9.50 V
   Part No SW: 1K0 909 605 P    HW: 1K0 909 605 P
   Component: 3B AIRBAG VW8R  032 7900
   Revision: 03032000    Serial number: 0038FD057J7Y
   Coding: 0013122
   VCID: 392F29FBB553C39355D-806C
   Subsystem 1 - Serial number: 6332MSME0E2D0B10C
   Subsystem 2 - Serial number: 6342MSME0E5E6207K
   Subsystem 3 - Serial number: 6351HSME0942446B7
   Subsystem 4 - Serial number: 6361HSME09411844%
   Subsystem 5 - Serial number: 637  SME
   Subsystem 6 - Serial number: 638  SME
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
            008 - Implausible Signal - MIL ON
            002 - Lower Limit Exceeded - Intermittent - MIL ON
01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
   Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
   Component: J0527           034 0070
   Coding: 0000021
   VCID: 78A9ECFFCED91A9B6A3-802C
   Part No: 1K0 920 853 D
   Component: KOMBIINSTRUMENT 3HL 4312
   Coding: 0023303
   Shop #: WSC 00000 067 57207
   VCID: 2B0303B34F0F6103D71-807E
00771 - Fuel Level Sensor (G)
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001063120468
   Coding: 3D3F0B40071002
                    Reset counter: 67
                    Time Indication: 15
                    Reset counter: 73
                    Mileage: 297166 km
                    Time: 19:45:56
   Component: IMMO            3HL 4312
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2377
   Coding: 0001269
   VCID: 363522C7844D2CEBB8F-8062
00913 - Window Regulator Switch; Front Right Driver (E81)
00109 - Left Mirror Turn Signal Lamp (L131)
   Part No: 1K1 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 33331BD3973F39C39F1-8066
   Part No: 1K0 959 433 AF
   Coding: 137803281B09058F880F048051A0
   VCID: 74B1D8CFD2B17EFB46B-8020
   Part No: 1K0 959 702 K
   Coding: 0001269
   VCID: 372B2FC38347D5E3A39-8062
01035 - Electric Window Thermal Protection Active; Passenger
Address 56: Radio        Labels: 1K0-035-161.lbl
   Part No SW: 1K0 035 161 A    HW: 1K0 035 161 A
   Component: Radio DE2       012 0015
   Revision: 00012000    Serial number: VWZ4Z7F6135766
   Coding: 0040400
   VCID: 1D67DD6B01BB9FB3595-8048
00856 - Radio Antenna
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2434
   Coding: 0000144
   VCID: 313F11DB6D230BD3EDD-8064
01813 - Supply Voltage for Door Controller; Rear Left (J388)
00934 - Electric Window Motor; Rear Left (V26)
   Part No: 1K0 959 704 D
   Coding: 0000144
   VCID: 323D1ED7682530CB947-8066
01814 - Supply Voltage for Door Controller; Rear Right (J389)
00935 - Electric Window Motor; Rear Right (V27)
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   VCID: 2D070DAB711B6F33C95-8078
00361 - Heater Element for Auxiliary Heater (Z35)
            014 - Defective
End----------(Elapsed Time: 01:29, VBatt start/end: 14.4V/14.4V)-----------
Hi and welcome.
Many of those fault codes are flagged "Intermittent". That means the fault condition that set the code did not exist (or could not be detected) at the time the scan was performed.
Since this is an older car with a lot of miles on it, that's apparently hasn't had very fastidious maintenance, the first thing I'd do is clear all the fault codes and see what comes back.
PS: Since you didn't tell us what you want to Retrofit, I'm not sure why you posted in that section. Moving to Car Repair Support.
