ESP MK60EC1 Long Coding error
sharan94
New Member
Italy
C?ID=42684 (NRRT)
Good evening,
I have replaced my abs / esp with an identical new one, but when I go to code I have problems.
I have a problem with the long coding of this car:
VIN = WAUZZZ8P89B021776
SYSTEM DESCRIPTION = ESP MK60EC1
MODEL = AUDI A3 SPORTBACK 2.0 TDI
HARDWARE NUMBER = 1K0 907 379 AD
HARDWARE VERSION = H35
SOFTWARE NUMBER = 1K0 907 379 CD
SOFTWARE VERSION = 0120
How do I go to write the encoding 11424012092400FB881202EB901F00443800 gives me bad coded ECU error.
It only accepts right-hand drive car encodings, instead my car has left-hand drive.
You can help me ?
Thank's in advance.
We'll need to see at least a full unedited VCDS Auto-Scan of your A3 - that MAY show the need for some additional data such as Advanced IDs from some modules?
sharan94
New Member
Italy
C?ID=42684 (NRRT)
Here is what you requested.
The logs is in Italian language eìand in english.
I wanted to clarify that I do not have a scan done before changing the ABS / ESP because the car arrived at the workshop already with a changed control unit.
Thank you very much.
Thursday,24,September,2020,17:41:49:05685
VCDS Version: 20.4.1.0 (x64)
VIN: WAUZZZ8P89B021776   License Plate:
Mileage: 182310km-113282mi   Repair Order:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: WAUZZZ8P89B021776   Mileage: 182310km-113282miles
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 LS    HW: 03L 906 022 BQ
   Component: R4 2.0l TDI 0000SG  9978
   Revision: 13H01---    Serial number: AUX7Z0I2FN90VH
   Coding: 0000072
   Shop #: WSC 00046 412 00000
   VCID: 010C1025581F3F8E04-8054
   Part No SW: 1K0 907 379 CD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0120
   Revision: 00H35001
   Coding: 11424012492400FB881202EB921F00423800
   Shop #: WSC 12345 123 12345
   VCID: 76E673F9C1D1083621-8022
00003 - Control Module
                    Fault Status: 01100101
                    Reset counter: 254
                    Mileage: 182302 km
                    Date: 2020.08.24
                    Time: 20:26:25
                    Count: 3
                    Count: 6
                    Count: 4096
                    Count: 143
                    Count: 43008
                    Reset counter: 254
                    Mileage: 182302 km
                    Date: 2020.08.24
                    Time: 20:26:25
                    Count: 3
                    Count: 6
                    Count: 4096
                    Count: 8192
                    Count: 43008
   Part No SW: 8P0 820 043 BG    HW: 8P0 820 043 BG
   Component: KlimavollautomatH09 0100
   Revision: 000563      Serial number: 8P0820043BG
   VCID: 72EE4FE96DB914160D-8026
Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
   Part No SW: 8P0 907 279 N    HW: 8P0 907 279 N
   Component: Bordnetz-SG     H54 2801
   Revision: 00H54000    Serial number: 00000009451608
   Coding: 158A0F8190141380EF00000A0000000000094E056406040364A000000000
   Shop #: WSC 00046 412 253952
   VCID: 489ACD013BA5CEC683-801C
   Subsystem 1 - Part No: 8P1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H10 0040
   Coding: 00056595
   Shop #: WSC 00046
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 J    HW: 8P0 959 655 J
   Component: Airbag AU1042 H06 0090
   Revision: --------    Serial number: 003CA005L2NX
   Coding: 303142383038303030354A55304C38503053
   Shop #: WSC 00046 412 188416
   ROD: EV_Airba10AURB4.rod
   VCID: 499CC805E8AF37CE9C-801C
   Serial number: 3572DRB400008A34828T
   Serial number: 3582DRB4000088E4923Z
   Serial number: 35128RB400004BE5F05T
   Serial number: 35228RB400004BDA230J
   Serial number: 35547RB4000047745D4O
   Serial number: 35647RB4000047744F3P
   Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
   Coding: 0000012
   Shop #: WSC 00046 412 196608
   VCID: 78FA7DC10BC57E4633-802C
   Part No SW: 8P0 920 931 S    HW: 8P0 920 931 S
   Component: KOMBIINSTR. VDO H19 0860
   Revision: D0H19007    Serial number: 2242I007080732
   Coding: 0004128
   Shop #: WSC 00001 001 00001
   VCID: 4380DA2D0283ED9E56-8016
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533__Gateway   H-- 0210
   Revision:   H--       Serial number: 00000000000000
   Coding: E9817F06000202000101
   VCID: 3778BEFD465BB13EFA-8062
   Revision: D0H19007    Serial number: AUX7Z0I2FN90VH
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX3.lbl
   Part No SW: 8P0 959 801 J    HW: 8P0 959 801 J
   Component: Tuer-SG         H03 0060
   Coding: 0004348
   VCID: 428EDF291D99E4965D-8016
   Part No: 1K0 909 144 E
   Component: EPS_ZFLS Kl. 232    2501
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2C5291918F1D02E687-8078
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 L
   Component:    KSG          H11 0080
   Coding: 1880200002186D0985054C8F0167
   VCID: 4584C4350CB7D3AE78-8010
00332 - Control Circuit for Tank Flap
   Part No SW: 8P0 959 802 J    HW: 8P0 959 802 J
   Coding: 0004348
   Shop #: WSC 00046 412 172032
   Part No: 8P3 907 357
   Coding: 0000013
   VCID: 7AFE67C935C96C5645-802E
Address 56: Radio        Labels: 8J0-035-1xx-56.clb
   Part No SW: 8P0 035 152 C    HW: 8P0 035 152 C
   Component: R Chorus2+      H20 0270
   Revision: 00H20000    Serial number: AUZ1Z2I9607304
   Coding: 0000221
   VCID: 2B50928D8A1305DE8E-807E
   Part No SW: 8P4 959 801 E    HW: 8P4 959 801 E
   Component: Tuer-SG         H04 0040
   Coding: 0000216
   Shop #: WSC 00046 412 1012544
   VCID: 418CD025189FFF8E44-8014
   Part No SW: 8P4 959 802 E    HW: 8P4 959 802 E
   Coding: 0000216
End-------------------------(Elapsed Time: 01:57)--------------------------
sharan94
New Member
Italy
C?ID=42684 (NRRT)
Good morning,
I managed to understand my problem. Unfortunately I bought an abs unit with control unit that was mounted on a right-hand drive car, so when I'm going to do the coding, the ecu only accepts right-hand drive coding.
Now I ask you, do you think it is possible to modify the firmware to be able to accept left-hand drive encodings?
Thank's in advance.
MartinsX
Riga, Latvia
C?ID=268515
In all MK60EC1 RHD/LHD can be changed by coding, no different module or different firmware, how far I know.
Is the old module still available? Can it be connected to car and scanned? (no mechanical installation necessary, just connect it). Do the replacement module is correct/compatible part number for this car? Checked with ETKA, PL24 or dealers parts department? Where did You get current coding from? BTW coding in first post does not match the one in the scan.
