Coding II greyed out
Racediagnostics
C?ID=86930
Hi, can anyone help with this, I planned to install my new G450 sensor today but the "Coding II! box was greyed out.
This is my cable.
From last week.
Friday,11,September,2020,15:09:39:60357
VCDS Version: 20.4.2.0
[URL="http://www.Ross-Tech.com"]www.Ross-Tech.com[/URL]
VIN: WVWZZZAUZFW231345   License Plate:
Mileage: 109366km-67956mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZFW231345   Mileage: 109366km-67956miles
Address 01: Engine (J623-CRKB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 FD    HW: 04L 907 309 E
   Component: R4 1,6L EDC   H22 8122
   Revision: 86H22---
   Coding: 01190012030511096000
   ASAM Dataset: EV_ECM16TDI01104L906021FD 002008
   ROD: EV_ECM16TDI01104L906021FD.rod
   VCID: 6CDC34F8876032E6DF-8038
10 Faults Found:
7158 - Please Check DTC Memory in CAN Gateway (J533)
          U1008 00 [032] - -
19226 - Particulate Trap Bank 1
          P2002 00 [237] - Efficiency Below Threshold
                    Mileage: 107066 km
                    Date: 2020.06.11
                    Time: 16:59:48
                    Engine speed: 1808.50 /min
                    Normed load value: 30.6 %
                    Vehicle speed: 53 km/h
                    Coolant temperature: 66 °C
                    Intake air temperature: 63 °C
                    Voltage terminal 30: 14.680 V
                    Exhaust mass flow of low-pressure EGR: calculated: 23.338
                    Differential pressure ratio: low-pressure EGR: 31.4 kg/h
                    Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 864.9 hPa
                    Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 1057.0 hPa
                    Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 1.21 %
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 46.03 %
5597 - Clutch Position Sensor (G476)
          P3082 00 [032] - Implausible Signal
4377 - Please Check Fault Codes in Control Module for Electrical Parking Brake
          U1010 00 [032] - -
5946 - Exhaust Pressure Control Valve
          P0478 00 [032] - Short to Plus
5939 - Exhaust Pressure Control Valve
          P0477 00 [032] - Signal too Low
5941 - Exhaust Pressure Control Valve
          P0475 00 [032] - Electrical Malfunction
23599 - Active Radiator Shutter 1
          P05A0 00 [032] - Stuck Open
5599 - Starter Interlock Signal
          P1724 00 [032] - Short to Ground
5923 - Exhaust Pressure Control Valve
          P047F 00 [032] - Stuck Open
Readiness: 1 1 0 0 0
   Part No SW: 3Q0 907 379 F    HW: 3Q0 907 379 F
   Component: ESC           H42 0609
   Revision: 00000000    Serial number: 60065000000347
   Coding: 01FA8AA12423096D077A060441C82580512490E06082A4F300400078C002
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
   VCID: 3D7AC9BCAC9A6B6E38-8068
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 243
                    Mileage: 61072 km
                    Date: 2017.10.13
                    Time: 14:03:20
   Part No SW: 5G0 907 426 T    HW: 5G0 907 426 T
   Component: AC Manuell    H02 1001
   Revision: 00001K06
   Coding: 00120104202100001000000000000000
   VCID: 3C7CC4B8B78062660F-8068
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-BV1.clb
   Part No SW: 5Q0 937 084 AF    HW: 5Q0 937 084 AF
   Component: BCM MQBAB B   H18 0137
   Serial number: 01011435100165
   Coding: 03000842C20100530BA44000000403081000000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 7CFC04B8F700A2664F-8028
   Component: WWS    141210  042 0551
   Serial number:         141219012505
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Serial number: 003F6R0EU85M
   VCID: 4182B54CD0620F8E5C-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 000 801 15
   Serial number: 357670000009CA5C131
   Subsystem 2 - Part No SW: -----------    HW: 480 000 801 15
   Serial number: 3586700000027A79621U
   Subsystem 3 - Part No SW: -----------    HW: 480 401 612 14
   Serial number: 3516502A7188FBF1322J
   Subsystem 4 - Part No SW: -----------    HW: 480 401 612 14
   Serial number: 3526502A7188FBF250EX
   Subsystem 5 - Part No SW: -----------    HW: 480 401 612 14
   Serial number: 3556502A3196FF61907M
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 AB    HW: 5Q0 953 549
   Revision: --------    Serial number: 03011504400335
   Coding: 0600
   VCID: 76E81690C92CF83639-8022
No ASAM data for: "EV_SMLSKLOMQB" (VW37)
   Part No SW: 5G1 920 931     HW: 5G1 920 931
   Component: KOMBI         106 5295
   Coding: 27A4020023002600010808000400000000000000
   ASAM Dataset: EV_DashBoardJCIMQBAB 009003
   ROD: EV_DashBoardJCIMQBAB_009.rod
   VCID: 65CA41DC648A03AE80-8030
9456433 - Key
          B104B 31 [008] - No Signal
                    Reset counter: 248
   Part No SW: 5Q0 907 530 AA    HW: 5Q0 907 530 D
   Component: GW MQB Low    126 1204
   Revision: --------    Serial number: 0002907145
   Coding: 030000040F087300EF000048080E00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011020
   ROD: EV_GatewLear_011.rod
   VCID: 70E42088AB48D606E3-8024
   Subsystem 2 - Part No SW: 5Q0 915 181 G    HW: 5Q0 915 181 G
   Serial number: 0054415303
   Part No SW: 5Q0 959 393 D    HW: 5Q0 959 393 B
   Serial number: 151214BLF01178
   Coding: 003002208001040100001000
   VCID: 4084B048DB68068653-8014
   Component: EPS_MQB_ZFLS  125 1061
   Coding: 0102
   VCID: 438EBF44CA7E1D9E4E-8016
   Part No SW: 5Q0 959 392 D    HW: 5Q0 959 392 B
   Serial number: 101214BL90863A
   Coding: 003000208001040100801000
   VCID: 3F86B3B4A696797E2A-806A
   Part No SW: 5G0 035 820 A    HW: 5G0 035 820 A
   Component: MU-S-D-ER     041 0421
   Serial number: V5C00701151552
   Coding: 02730000FF00000021111201000800001F0100060100010001
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 1F4613340656197E0A-804A
   Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
   Component: ABT_Std_Radio  H60 0030
   Serial number: VWZ8Z9PS206LHM
0004 - Antenna 2 for radio
          B111A 11 [008] - Short to Ground
                    Reset counter: 214
                    Mileage: 108657 km
                    Date: 2020.08.03
                    Time: 23:49:18
                    Voltage terminal 30: 14.3 V
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Short circuit
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 2 for radio-Reception level antenna 2: 255 dBµV
End-------------------------(Elapsed Time: 03:38)--------------------------
OBD DTCs erased
Jef
HQ
When a function button is greyed out like that, the control module doesn't support that function. Use [Security Access - 16] instead. This is "normal" bacause that is how the Germans designed that specific control module. Other control modules can and will have different designs, thus may have [Coding II - 11], but not this one.
Racediagnostics
C?ID=86930
Thanks, I'll give that a try.
Racediagnostics
C?ID=86930
[Security Access - 16] did not offer any solutions to adapt the new G450 sensor.
Instead I found this in the wiki.
UDS Protocol (G450) procedure
Key ON, Engine OFF
[Basic Settings]
Select Adaptation of diff. pressure sensor particulate filter
[Go!]
to activate the Basic Setting.
After the result of Finished Correctly appears click [Stop]
Select Resetting of learned values of difference pressure sensor
[Go!]
[Done, Go Back]
I tried the first part which was successful, however the was no option to "Select Resetting of learned values of difference pressure sensor"
So far the engine light is off and there are no DTCs.
