Aufi A4 Multitronic issue
Souriau
Newry, NI, UK
C?ID=86928
2012 Multitronic OAW gearbox will not change gears upward at the correct time, you need tp rev up yo 4000 RPM before the gear change up.
Gear change down no issue.
Driving forward then come to a stop, the clutch will not engage and the engine stalled.
Any Idea what it the problem?
Thursday,24,September,2020,11:47:13:46973
VCDS Version: 20.4.2.0  HEX-NET CB: 0.4513.4
Workshop Code: 000 18261 018261
VIN: WAUZZZ8K0CA101476   License Plate:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 47 52 53 56 62 69 72
          77
VIN: WAUZZZ8K0CA101476   Mileage: 122620km-76192miles
Address 01: Engine (J623-CAGA)       Labels:| 03L-906-022-CAG.clb
   Part No SW: 03L 906 022 MK    HW: 03L 906 022 B
   Component: R4 2.0l TDI   H14 9981
   Revision: 11H14---
   Coding: 0104002C02072920
   Shop #: WSC 53484 001 1048576
   ASAM Dataset: EV_ECM20TDI03L906022MK A01016
   ROD: EV_ECM20TDI03L906022C.rod
   VCID: FAB8BBB57D68A456DD-80AE
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 8K0 927 155 AF    HW: 0AW 927 156 K
   Component: 0AW 20TDI RdW H04 0009
   Revision: --H04---    Serial number: 0000001195
   Coding: 000002
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_TCMVL381 A02017
   ROD: EV_TCMVL381.rod
   VCID: F7BEA2814E7AB93EA2-80A2
   Part No SW: 8K0 907 379 BH    HW: 8K0 907 379 BH
   Component: ESP8 front    H04 0060
   Coding: 17C500
   Shop #: WSC 00251 210 91751
   VCID: 804CC95D13B4FE8693-80D4
   Part No SW: 8K0 907 064 CN    HW: 8K0 907 064 CN
   Component: BCM2 2.0      H05 0435
   Coding: 011200
   VCID: FEB0B7A569408876E1-80AA
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H60 0072
   Serial number: 0511000070117007
   Serial number: 2311000245097011
   Part No SW: 8T2 820 043 AF    HW: 8T2 820 043 AF
   Component: KLIMA 3 ZONEN H08 0182
   Revision: D0000000    Serial number: 01181120110587
   Coding: 34040000
   VCID: F6A0AF854170C036B9-80A2
   Part No SW: 8K0 907 063 K    HW: 8K0 907 063 K
   Component: BCM1 1.0      H30 0392
   Revision: 06030001    Serial number: 00000001108486
   Coding: 690040B10034A7010001000000005F5F001D660802000141000000
   VCID: B73E628106FA793E62-80E2
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 221111  H06 0070
   Serial number: SWF11110225883
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 11787676
   Coding: 025028
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000711111111
                    Fault Status: 01101100
                    Reset counter: 202
                    Mileage: 122612 km
                    Date: 2020.09.23
                    Time: 12:18:00
   Part No SW: 8K0 919 475 AA    HW: 8P0 919 475 N
   Component: PARKHILFE 8K  H01 0081
   Revision: 11001001    Serial number: 12591114686236
   Coding: 100103
   VCID: F8BCA1BD4B64B646AB-80AC
   Part No SW: 8K0 959 655 L    HW: 8K0 959 655 L
   Component: AirbagVW-AU10 H44 0610
   Serial number: 003JMD0HHTXO
   Coding: 30533435363030303030554A3052384B3053
   VCID: C6C01F45791010B6E9-8092
   Serial number: 6334MSME67042E2DL
   Serial number: 6344MSME666221715
   Serial number: 6352QSME3B640F68U
   Serial number: 6362QSME1B644854L
   Serial number: 63732SME4063045AV
   Serial number: 63832SME40634F44/
   Part No SW: 8R0 953 568 M    HW: 8R0 953 568 M
   Component: Lenks.Modul   H07 0156
   Revision: 00000000    Serial number: 20130222001030
   Coding: 000017
   Shop #: WSC 20273 000 1048576
   VCID: CBD62E716A72EDDE36-809E
   Component: E221 - MFL  H02 0010
   Part No SW: 8K0 920 981 D    HW: 8K0 920 981 D
   Component: KOMBIINSTR.   H31 0258
   Revision: 00000000    Serial number: EJD57KJCC
   Coding: 2F06100002002600010000
   VCID: B424558D178C922647-80E0
   Part No SW: 8T0 907 468 AF    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0121
   Revision: GB901054    Serial number: 5400G11B108343
   Coding: 00C303
   Shop #: WSC 41556 002 1048576
   VCID: 8542D8490C96DBAEA0-80D0
   Component: J367-BDMHella  H03 8040
   Serial number: 2216866001
   Part No SW: 8K0 959 793 N    HW: 8K0 959 793 N
   Component: TSG FA        H12 0357
   Revision:             Serial number: 0000018490919
   Coding: 011002204001410001
   Revision: 00002001    Serial number: 0163846810
   Coding: 013B062220B904008020023280000000
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8R0 035 223 G    HW: 8R0 035 223 E
   Component: DSP STD       H11 0460
   Revision: 00000000    Serial number: 00000000000001
   Coding: 0203010102
   VCID: B02C599DE394AE0623-80E4
   Part No SW: 8K0 959 792 N    HW: 8K0 959 792 N
   Component: TSG BF        H12 0357
   Revision:             Serial number: 0000018505794
   VCID: CAD82B756508F4D60D-809E
   Revision: 00000003    Serial number: 10000000871203
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8T2 035 186 P    HW: 8T2 035 186 P
   Component: Concert3      H06 0350
   Revision: 00000011    Serial number: AUZ5Z6K1669583
   Coding: 0502008201028D00035B070000
   VCID: C5C218494C161BAEE0-8090
   Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
   Component: Display
   Part No SW: 8K0 959 795 F    HW: 8K0 959 795 F
   Component: TSG HL        H11 0357
   Revision:             Serial number: 0000018756020
   Coding: 010002204001210001
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Revision: 1A001001    Serial number: 00000192078578
   Coding: 0100000000000000
   VCID: B6206F8501F0803679-80E2
   Component: TSG HR        H11 0357
   Revision:             Serial number: 0000018756120
   Part No SW: 8T0 862 335 F    HW: 8T0 862 335 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005450210
   Coding: 0010320
   VCID: BD3270A9E4C6536EB8-80E8
End----------(Elapsed Time: 01:33, VBatt start/end: 14.4V/14.4V)-----------
;SW:8K0-927-155-AF HW:0AW-927-156-K --- Auto Trans
;Component:0AW 20TDI RdW H04 0009Coding:000002
;EV_TCMVL381A02017EV_TCMVL381.rod
;Thursday
24​
September
2020​
11:48:06:46973
;VCDS Version: Release 20.4.2 Data version: 20200730 DS317.0
;VCID: F7BEA2814E7AB93EA2-80A2
GroupDescriptionActual
IDE00018Voltage terminal 15
14.3​
V
IDE00019Voltage terminal 30
14.338​
V
IDE00020Terminal 15 statusTerminal 15 on
IDE00021Engine speed
831​
/min
IDE00022Transmission input speed
1​
/min
IDE00023Transmission output speed
1​
/min
IDE00024Transmission fluid temperature
70​
°C
IDE00025Coolant temperature
175​
°C
IDE00026Vehicle speed from transmission
3.2​
km/h
IDE00027-MAS00179Status of brake signals-Brake Light Switchnot activated
IDE00027-MAS00180Status of brake signals-Brake pressure switchnot activated
IDE00027-MAS00181Status of brake signals-Validity of brake pressure informationvalid
IDE00027-MAS00182Status of brake signals-Validity of brake pedal informationvalid
IDE00028Road resistance index
127​
IDE00075Vehicle speed
0​
km/h
IDE00077Transmission Input Speed (RPM) 2
1​
/min
IDE00079Activation current of disc set adjustment
587​
mA
IDE00080Activation current of clutch activation
261​
mA
IDE00081Activation current of cooling and safety valve
1​
mA
IDE00082Gear Ratio
13.01​
IDE00085Normed load value
25.5​
IDE00086Accelerator position
15​
IDE00087-MAS00115Tiptronic status-Tiptronic gatenot active
IDE00087-MAS00116Tiptronic status-Tiptronic +not active
IDE00087-MAS00117Tiptronic status-Tiptronic -not active
IDE00087-MAS00118Tiptronic status-Tiptronic steering wheel +not active
IDE00087-MAS00119Tiptronic status-Tiptronic steering wheel -not active
IDE00088-MAS00120Status of vehicle condition influence-Anti-slip regulation (ASR)not active
IDE00088-MAS00121Status of vehicle condition influence-Electronic Differential Locknot active
IDE00088-MAS00122Status of vehicle condition influence-Electronic Stability Programnot active
IDE00088-MAS00123Status of vehicle condition influence-Engine torque towing regulationnot active
IDE00088-MAS00125Status of vehicle condition influence-Cruise control systemNot available
IDE00088-MAS00126Status of vehicle condition influence-Kickdownnot active
IDE00088-MAS00127Status of vehicle condition influence-brakesnot active
IDE00089Driving positionP
IDE00090selected gearwithout traction
IDE00091Status of starter lockOFF
IDE00092Adaptation of clutch char. curve for forward crawl torque
270​
mA
IDE00093Adaptation of clutch char. curve for backward crawl torque
251​
mA
IDE00094Kick-down statusnot active
IDE00095Status of selector lever lockactive
IDE00096Selector lever positionautomatic
IDE00098Transmission positionP
IDE00099-MAS00172Driving mode sensor-Hall sensor Anot active
IDE00099-MAS00173Driving mode sensor-Hall sensor Bnot active
IDE00099-MAS00174Driving mode sensor-Hall sensor Cactive
IDE00099-MAS00175Driving mode sensor-Hall sensor Dnot active
IDE00100Engine torque
0​
Nm
IDE00101Engine specified torque during transmission intervention
1022​
Nm
IDE00102Control Module temperature
69​
°C
IDE00103-IDE00018Snapshot-Voltage terminal 15
14.3​
V
IDE00103-IDE00019Snapshot-Voltage terminal 30
14.202​
V
IDE00103-IDE00020Snapshot-Terminal 15 statusTerminal 15 on
IDE00103-IDE00021Snapshot-Engine speed
830.5​
/min
IDE00103-IDE00022Snapshot-Transmission input speed
1​
/min
IDE00103-IDE00023Snapshot-Transmission output speed
1​
/min
IDE00103-IDE00024Snapshot-Transmission fluid temperature
88​
°C
IDE00103-IDE00079Snapshot-Activation current of disc set adjustment
587​
mA
IDE00103-IDE00080Snapshot-Activation current of clutch activation
257​
mA
IDE00103-IDE00081Snapshot-Activation current of cooling and safety valve
1​
mA
IDE00103-IDE00086Snapshot-Accelerator position
0​
IDE00103-IDE00100Snapshot-Engine torque
-1​
Nm
IDE00103-IDE00101Snapshot-Engine specified torque during transmission intervention
1022​
Nm
IDE00103-IDE00102Snapshot-Control Module temperature
89​
°C
IDE00103-IDE00107Snapshot-System time in normal operation
3444​
s
IDE00103-IDE00108Snapshot-System time in after-run
0​
s
IDE00103-IDE00113Snapshot-Adaptation of clutch characteristic curve forwards
591​
mA
IDE00103-IDE00115Snapshot-Adaptation of clutch char. curve forwards: minimum torque
274​
mA
IDE00103-IDE00116Snapshot-Adapt. of clutch char. curve forw.: max. torque in driving cyc.
801​
mA
IDE00103-IDE00117Snapshot-Adaptation of clutch char. curve backwards: min. torque
246​
mA
IDE00103-IDE00118Snapshot-Adapt. of clutch char. curve back.: max. torque in driving cyc.
550​
mA
IDE00103-IDE00119Snapshot-Clutch pressure adaptation: current at 0 bar
232​
mA
IDE00103-IDE00120Snapshot-Clutch pressure adaptation: current at 10 bar
529​
mA
IDE00103-IDE00123Snapshot-Travel reinforcement of disc set regulation
100​
IDE00103-IDE00131Snapshot-Clutch pressure
1.6​
bar
IDE00103-IDE00133Snapshot-Torque sensor pressure
3.5​
bar
IDE00103-IDE00301Snapshot-Distance
122624​
IDE00103-IDE00611Snapshot-Malfunction that has caused the ambient data to be stored00 08 DF
IDE00103-MAS00106Snapshot-Year
2020​
IDE00103-MAS00107Snapshot-Month
9​
IDE00103-MAS00108Snapshot-Day
24​
IDE00103-MAS00109Snapshot-Hours
11​
IDE00103-MAS00110Snapshot-Minutes
23​
IDE00103-MAS00111Snapshot-Seconds
49​
IDE00103-MAS00115Snapshot-Tiptronic gatenot active
IDE00103-MAS00116Snapshot-Tiptronic +not active
IDE00103-MAS00117Snapshot-Tiptronic -not active
IDE00103-MAS00118Snapshot-Tiptronic steering wheel +not active
IDE00103-MAS00119Snapshot-Tiptronic steering wheel -not active
IDE00103-MAS00120Snapshot-Anti-slip regulation (ASR)not active
IDE00103-MAS00121Snapshot-Electronic Differential Locknot active
IDE00103-MAS00122Snapshot-Electronic Stability Programnot active
IDE00103-MAS00123Snapshot-Engine torque towing regulationnot active
IDE00103-MAS00125Snapshot-Cruise control systemNot available
IDE00103-MAS00126Snapshot-Kickdownnot active
IDE00103-MAS00127Snapshot-brakesactive
IDE00103-MAS00172Snapshot-Hall sensor Anot active
IDE00103-MAS00173Snapshot-Hall sensor Bnot active
IDE00103-MAS00174Snapshot-Hall sensor Cactive
IDE00103-MAS00175Snapshot-Hall sensor Dnot active
IDE00103-ENG101265Snapshot-Adaptation Value - Vü_Nullpunktadaption - i_vue_ breite
40​
mA
IDE00103-ENG101151Snapshot-Adaptation Value - Vü_Nullpunktadaption - i_vue_mittel
576​
mA
IDE00103-ENG102317Snapshot-Adaptation Value Overdrive Gear Ratio mechanical
2.12​
IDE00103-ENG100144Snapshot-Adaptation Value Underdrive Gear Ratio mechanical
13.43​
IDE00103-ENG101959Snapshot-Knick Adaptation - Anteil_dm_nach_knick
100​
IDE00103-ENG99913Snapshot-Knick Adaptation - Pressure Value
9.1​
bar
IDE00103-ENG103993Snapshot-State Transmission Functions
16​
IDE00103-ENG101752Snapshot-Transmission Condition 1
0​
IDE00103-ENG103460Snapshot-Transmission Condition 2
0​
IDE00109Selector lever maximum pulse width High
3.983​
ms
IDE00110Selector lever minimum pulse width High
3.963​
ms
IDE00111Selector lever maximum pulse width Low
55.74​
ms
IDE00112Selector lever minimum pulse width Low
3.975​
ms
IDE00113Adaptation of clutch characteristic curve forwards
595​
mA
IDE00114Adaptation of clutch char. curve forwards: maximum torque
623​
mA
IDE00115Adaptation of clutch char. curve forwards: minimum torque
270​
mA
IDE00116Adapt. of clutch char. curve forw.: max. torque in driving cyc.
623​
mA
IDE00117Adaptation of clutch char. curve backwards: min. torque
251​
mA
IDE00118Adapt. of clutch char. curve back.: max. torque in driving cyc.
534​
mA
IDE00119Clutch pressure adaptation: current at 0 bar
196​
mA
IDE00120Clutch pressure adaptation: current at 10 bar
549​
mA
IDE00121Underdrive transmission
13.01​
IDE00122Overdrive transmission
2.18​
IDE00123Travel reinforcement of disc set regulation
100​
IDE00124-ENG99298Adaptation of the forwards start-up behavior-Statecompleted successfully
IDE00125-ENG99298Adaptation of the backwards start-up behavior-Statecompleted successfully
IDE00126Disc set excessive contact pressurenot active
IDE00127Excessive clutch contactnot active
IDE00128Transmission Input Speed (RPM): specified value
0​
/min
IDE00129Engine specified idle RPM
830​
/min
IDE00130Transmission specified idle RPM
635​
/min
IDE00131Clutch pressure
1.8​
bar
IDE00132Specified clutch pressure
2.1​
bar
IDE00133Torque sensor pressure
3.9​
bar
IDE00134Engine torque: maximum value
113​
Nm
IDE00135Specified clutch torque
10​
Nm
IDE00136Torque gradient: maximum value
2550​
Nm/s
IDE00137After-runnot active
IDE00138Total driving time
2735.25​
H
IDE00139Economical driving time portion
98.4​
IDE00140Sport driving time portion
1.2​
IDE00141Manual driving time portion
0​
IDE00142Counter of clutch pressure monitor
0​
IDE00143Non-debounce counter of clutch pressure monitor
0​
IDE00144-IDE00095Transmission status-Status of selector lever lockactive
IDE00144-MAS00145Transmission status-Starter locknot active
IDE00144-MAS00155Transmission status-Synchronous operationasynchronous
IDE00144-MAS00156Transmission status-Driving directionnot recognized
IDE00145Clutch status
13​
IDE00146Status of cooling and safety valve
0​
IDE00147Engine speed: discrete
828​
/min
IDE00301Distance
121850​
km
IDE00445Unlearning counter according OBD
255​
IDE00538Run-in counter 1
2​
IDE00539Run-in counter 2
1​
IDE00601Monitoring status since erasing DTC memory
IDE00602Monitoring status in current driving cycle
IDE00911-MAS00106Load profile-Year
153​
IDE00911-MAS00107Load profile-Month
18​
IDE00911-MAS00108Load profile-Day
49​
IDE00911-MAS00109Load profile-Hours
0​
0​
IDE00911-MAS00110Load profile-Minutes
0​
0​
IDE00911-MAS00111Load profile-Seconds
0​
0​
IDE00911-MAS01229Load profile-Vehicle Identification Number (VIN) operating time 2-----------
IDE00912-MAS01231Status of purge function of the clutch control valve-Number of purge processes
0​
IDE00912-MAS01232Status of purge function of the clutch control valve-Number of ineffective purge processes
0​
IDE00914-MAS00106Start-up behavior-Year
32​
IDE00914-MAS00107Start-up behavior-Month
9​
IDE00914-MAS00108Start-up behavior-Day
36​
IDE00914-MAS00109Start-up behavior-Hours
17​
IDE00914-MAS00110Start-up behavior-Minutes
64​
IDE00914-MAS01237Start-up behavior-Delayed start up counter
3​
IDE00914-MAS01239Start-up behavior-Status of delayed start upNo
IDE00953Specified value of drive speed gradient
-395​
1/min/s
IDE00954Drive speed gradient
0​
1/min/s
IDE00955Specified current of ratio valve
587​
mA
IDE01562Offset for clutch pressure sensor
0​
bar
IDE01563Offset for torque sensor pressure sensor
-0.5​
bar
IDE02279Minimum temperature for creep adaptation
70​
°C
IDE02280Maximum temperature for creep adaptation
95​
°C
IDE03008-MAS03911Stop process prevented-Oil temperature too lownot active
IDE03008-MAS03912Stop process prevented-Transmission fluid temperature too highnot active
IDE03008-MAS03913Stop process prevented-Adaptation procedure activenot active
IDE03008-MAS03918Stop process prevented-Brake acceleration too greatnot active
IDE03008-MAS03960Stop process prevented-Shifting process activenot active
IDE03010-MAS03911Number of prevented stop processes-Oil temperature too low
0​
IDE03010-MAS03912Number of prevented stop processes-Transmission fluid temperature too high
0​
IDE03010-MAS03913Number of prevented stop processes-Adaptation procedure active
0​
IDE03010-MAS03918Number of prevented stop processes-Brake acceleration too great
0​
IDE03010-MAS03960Number of prevented stop processes-Shifting process active
0​
IDE03127-IDE03008Prevented stop processes (ring memory)-Stop process preventedUnknown (255)
IDE03127-MAS00106Prevented stop processes (ring memory)-Year
2127​
IDE03127-MAS00107Prevented stop processes (ring memory)-Month
15​
IDE03127-MAS00108Prevented stop processes (ring memory)-Day
31​
IDE03127-MAS00109Prevented stop processes (ring memory)-Hours
31​
IDE03127-MAS00110Prevented stop processes (ring memory)-Minutes
63​
IDE03127-MAS00111Prevented stop processes (ring memory)-Seconds
63​
IDE03212Start-stop conditionsStop release
IDE03213Start-stop enablingSystem malfunction
IDE03764Reduction in specified clutch slip
0​
/min
IDE04896Clutch pressure for forward creep torque
2​
bar
IDE04897Clutch pressure for backward creep torque
1.6​
bar
IDE04898Creep adaptation: cause for cancellation
0​
IDE04899Creep adaptation: start conditions
63​
IDE04900Creep adaptation: lock conditions
12​
IDE04901Creep adaptation: hydraulic path
8​
IDE04902Mileage since last creep adaptation: forward
2​
km
IDE04903Mileage since last creep adaptation: backward
2​
km
IDE05032Temperature offset after return pressure detection
3​
K
ENG101413Calibration Identification8K0927155AF 0009
ENG99697Calibration Verification Number00 00 D7 39
ENG105523Clutch_preset_torque_at_backflow_pressure
0​
Nm
ENG105921Driving_direction_at_backflow_pressurenot recognized
ENG100152ECUNAME-
ENG100152-ENG28381ECUNAME-AcronymTCM-TransmisCtrl
ENG100152ECUNAMETransmisCtrl
ENG104986Engine speed
827​
/min
ENG106220Engine_speed_at_backflow_pressure
0​
/min
ENG106452F003_Driver Preset Torque
0​
Nm
ENG105256Front left wheel speed
3.2​
km/h
ENG105255Front right wheel speed
3.2​
km/h
ENG106768Gear_ratio_control_pressure_at_backflow_pressure
0​
bar
ENG102399Immobilizer_ambient_data00 00 00 00 00 00
ENG107130J001_Pknick
9.1​
bar
ENG107131J002_Portion_dm_after_knick
100​
ENG107132J003_i_vue_mittel
577​
mA
ENG107133J004_i_vue_breite
40​
mA
ENG107134J005_Adapted Mass of Vehicle
500​
kg
ENG107150K004_Calculated Ascent
1​
ENG107152K005_Deviation of Road Resistance
0​
Nm
ENG107155K006_Sport Index
0​
ENG107157K007_Modified Accelerator Pedal Value
8​
ENG107159K008_Warm Up Index
11​
ENG107161K009_Requested Engine Speed ECM
5000​
/min
ENG107222KL30_failed_of_shutoff_path
12.345​
V
ENG107223KL30_start_of_shutoff_path
12.345​
V
ENG107331-ENG101735L001_Engine Coding Information-Emission TypeEOBD: no OBD (US)
ENG107331-ENG98541L001_Engine Coding Information-Engine code
5​
ENG107331-ENG98980L001_Engine Coding Information-Transmission codeVL381
ENG107497M008_Driving Directionnot recognized
ENG107498M009_Transmission Condition 1
0​
ENG107500M010_Transmission Condition 2
0​
ENG107501M011_State of Gear Ratio Controller
13​
ENG107502-ENG99153M012_State Of Engine Torque Engagement-Regeneration Bitnot active
ENG107502-ENG104058M012_State Of Engine Torque Engagement-Status Of Engine Torque Engagement request/forcednot active
ENG107618Micro_slip_quality_control
0​
ENG100218Occurrence_counter_over_length_of_life
255​
ENG107905-ENG101287Offset_values_for_clutch_pressure_sensor-Offset_Pkaint_status
48​
ENG107905-ENG101594Offset_values_for_clutch_pressure_sensor-Pressure_Offset_Pkaint_0
0​
bar
ENG107905-ENG100844Offset_values_for_clutch_pressure_sensor-Pressure_Offset_Pkaint_1
0​
bar
ENG107905-ENG99565Offset_values_for_clutch_pressure_sensor-Pressure_Offset_Pkaint_2
0​
bar
ENG107905-ENG102375Offset_values_for_clutch_pressure_sensor-Pressure_Offset_Pkaint_3
0​
bar
ENG107905-ENG99482Offset_values_for_clutch_pressure_sensor-Pressure_Offset_Pkaint_4
0​
bar
ENG107905-ENG99820Offset_values_for_clutch_pressure_sensor-Pressure_Offset_Pkaint_5
-0.2​
bar
ENG107905-ENG99164Offset_values_for_clutch_pressure_sensor-Pressure_Offset_Pkaint_6
0​
bar
ENG107905-ENG100380Offset_values_for_clutch_pressure_sensor-Pressure_Offset_Pkaint_7
0​
bar
ENG107905-ENG102859Offset_values_for_clutch_pressure_sensor-Temperature_Offset_Pkaint_0
-15​
°C
ENG107905-ENG102633Offset_values_for_clutch_pressure_sensor-Temperature_Offset_Pkaint_1
5​
°C
ENG107905-ENG104172Offset_values_for_clutch_pressure_sensor-Temperature_Offset_Pkaint_2
25​
°C
ENG107905-ENG101673Offset_values_for_clutch_pressure_sensor-Temperature_Offset_Pkaint_3
45​
°C
ENG107905-ENG104073Offset_values_for_clutch_pressure_sensor-Temperature_Offset_Pkaint_4
72​
°C
ENG107905-ENG102578Offset_values_for_clutch_pressure_sensor-Temperature_Offset_Pkaint_5
88​
°C
ENG107905-ENG101243Offset_values_for_clutch_pressure_sensor-Temperature_Offset_Pkaint_6
105​
°C
ENG107905-ENG99244Offset_values_for_clutch_pressure_sensor-Temperature_Offset_Pkaint_7
125​
°C
ENG107906-ENG103385Offset_values_for_ratio_control_pressure_sensor-Offset_Pmfint_status
48​
ENG107906-ENG99700Offset_values_for_ratio_control_pressure_sensor-Pressure_Offset_Pmfint_0
-0.5​
bar
ENG107906-ENG99441Offset_values_for_ratio_control_pressure_sensor-Pressure_Offset_Pmfint_1
-0.5​
bar
ENG107906-ENG100472Offset_values_for_ratio_control_pressure_sensor-Pressure_Offset_Pmfint_2
-0.5​
bar
ENG107906-ENG102615Offset_values_for_ratio_control_pressure_sensor-Pressure_Offset_Pmfint_3
-0.5​
bar
ENG107906-ENG102560Offset_values_for_ratio_control_pressure_sensor-Pressure_Offset_Pmfint_4
-0.5​
bar
ENG107906-ENG103561Offset_values_for_ratio_control_pressure_sensor-Pressure_Offset_Pmfint_5
-0.7​
bar
ENG107906-ENG99310Offset_values_for_ratio_control_pressure_sensor-Pressure_Offset_Pmfint_6
-0.5​
bar
ENG107906-ENG103865Offset_values_for_ratio_control_pressure_sensor-Pressure_Offset_Pmfint_7
-0.5​
bar
ENG107906-ENG103628Offset_values_for_ratio_control_pressure_sensor-Temperature_Offset_Pmfint_0
-15​
°C
ENG107906-ENG104239Offset_values_for_ratio_control_pressure_sensor-Temperature_Offset_Pmfint_1
5​
°C
ENG107906-ENG102366Offset_values_for_ratio_control_pressure_sensor-Temperature_Offset_Pmfint_2
25​
°C
ENG107906-ENG103311Offset_values_for_ratio_control_pressure_sensor-Temperature_Offset_Pmfint_3
45​
°C
ENG107906-ENG99332Offset_values_for_ratio_control_pressure_sensor-Temperature_Offset_Pmfint_4
72​
°C
ENG107906-ENG102238Offset_values_for_ratio_control_pressure_sensor-Temperature_Offset_Pmfint_5
88​
°C
ENG107906-ENG101760Offset_values_for_ratio_control_pressure_sensor-Temperature_Offset_Pmfint_6
105​
°C
ENG107906-ENG102073Offset_values_for_ratio_control_pressure_sensor-Temperature_Offset_Pmfint_7
125​
°C
ENG108362-ENG102813Q001_OBD Cycle And MIL State-Driving Cycleactive
ENG108362-ENG98734Q001_OBD Cycle And MIL State-milnot active
ENG108362-ENG99968Q001_OBD Cycle And MIL State-WarmUp Cyclenot active
ENG105258Rear left wheel speed
3.2​
km/h
ENG105257Rear right wheel speed
3.2​
km/h
ENG109020Ss1_speed_sen1
0​
/min
ENG109021Ss1_speed_sen1_at_step_detected_error_sen1
0​
/min
ENG109022Ss1_speed_sen1_at_step_detected_error_sen2
0​
/min
ENG109023Ss1_speed_sen1_old_value_at_step_detected
0​
/min
ENG109024Ss1_speed_sen2
0​
/min
ENG109025Ss1_speed_sen2_at_step_detected_error_sen1
0​
/min
ENG109026Ss1_speed_sen2_at_step_detected_error_sen2
0​
/min
ENG109027Ss1_speed_sen2_old_value_at_step_detected
0​
/min
ENG109028Ss2_speed_at_step_detected
0​
/min
ENG109029Ss2_speed_esp_at_step_detected
0​
/min
ENG109030Ss2_speed_old_at_step_detected
0​
/min
ENG109087-ENG102982State_of_creep-Creep_forward_too_powerfulNo
ENG109087-ENG102326State_of_creep-Creep_reverse_too_powerfulNo
ENG107495-ENG99379Status data bus communication diagnostic interface-State Deashboard receivedreceived
ENG107495-ENG101987Status data bus communication diagnostic interface-State ECM receivedreceived
ENG107495-ENG102056Status data bus communication diagnostic interface-State ESP receivedreceived
ENG107495-ENG103751Status data bus communication diagnostic interface-State Gateway receivedreceived
ENG107495-ENG104211Status data bus communication diagnostic interface-State Parking Brake receivedreceived
ENG107495-ENG101883Status data bus communication diagnostic interface-State Steering Angle receivedreceived
ENG107495-ENG102283Status data bus communication diagnostic interface-State Steering Assist receivedreceived
ENG107872-ENG101695System Supplier Boot Software Identification (BB)-System Supplier Boot Identification
209​
ENG107872-ENG101202System Supplier Boot Software Identification (BB)-System Supplier Calibration Data IdentificationB8 20lCR BRBH EU5 Avant
ENG107872-ENG101224System Supplier Boot Software Identification (BB)-System Supplier HW Version1F
ENG107872-ENG103214System Supplier Boot Software Identification (BB)-System Supplier HW Version 2Series
ENG107872-ENG99311System Supplier Boot Software Identification (BB)-System Supplier Software IdentificationE2B0
ENG105259Transfer speed from ESP
0​
km/h
ENG109574Transmission_fluid_temperature_at_backflow_pressure
0​
°C
ENG109839Valve_voltage
14.1​
V
Elapsed Time: 00:18
;Thursday
24​
September
2020​
11:48:25:46973
IDE00820-Activating and deactivating all development messagesnot active
1​
IDE04111-Single gear displayD on/S on
1​
IDE04159-Deactivation of start-stop functionnot active
1​
IDE05560-Wheel torque limitationactive
1​
ENG109348-TCM_VMS00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01
16​
Elapsed Time: 00:01
DrPeter
16.4905° S, 151.7375° W
Have you checked the basics? Transmission fluid leaks, fluid level and quality, dirty/contaminants, etc?
Also in the "Coolant temperature" seems crazy high at [175 °C], that is almost 350°F - maybe it is not correct?
Was there any fault codes in memory? I ask because it seems that there could have been a code of:
2271 - Clutch Torque Adaptation: Limit Reached
from "Snapshot-Malfunction that has caused the ambient data to be stored"
[00 08 DF] = [2271]
I could be wrong... ??
Found this on an old Ross-Tech forum post I responded to...
Possible causes:
- Malfunction in ECM (check ECM fault codes, if applicable)
- Poor Transmission fluid quality
- Faulty Transmission.
Hope this helps,
drpeter
