climatic control retrofit for vw transporter t5(2015)
Gileswater
France
C?ID=282472
Could anyone please advise me regarding a retrofit on a Volkswagen t5 mk 2 van (2015) .
The situation as follows-
I have retrofitted rear passenger A.C .
This has necessitated the need to change the driver cab heater control unit (j301)for a model that has an additional rear switch , which now sends power to a separate rear( roof liner mounted )control unit .
Apart from the additional rear switch it is similar in design .
In fact the retrofit functions and no error messages appear using diagnostics , but i do have a minor issue ,as follows-
The temperature control on the j301 does not operate correctly and only delivers heat when in the fully open position .When the dial is in in the coolest setting position, the hot air flap is closed(normal) ,when in the middle position the flap is still completely closed . The hot air flap begins to open and only FULLY ,when the dial is in the hottest position
Also i can see what is happening from observing flap motor and lever through a gap in the dashboard .
I have followed the instructions in basic settings (as per Rosstech instructions)for resetting flaps ( showing as completed ) with some improvement and have also tried the option compressor "run in /automatic "-(error message shows up) - so no luck with that .
However I am a little confused with all this.
Do i need to recode for the new heat control unit or does is it automatically recognised ? if necessary to recode how do i obtain a code ? is there a method of knowing precisely, if the flap and motor are responding correctly with the correct temperature?
thanks for all replies and assistance
Please post an Auto-Scan for context. I understand that there are no fault codes, but a scan will show people how the vehicle is equipped and configured.
Gileswater
France
C?ID=282472
Hi thanks for the reply
I have checked the heater control VW part n0 against the n0 featured in the RossTech app scan info and it appears to be correct ( which means that it has recognized the control)
However As a result of messing around with the settings, I now have no AC. ( and this now shows as an error on the autoscan )
as mentioned previously -the auto flaps reset in basic settings is showing as completed but the compressor run in shows up as an error
Unfortunately the Rosstech instruction/options s from the' golf 5 climatic' page differ slightly from the options available in the App. so it is difficult to understand what to do
information requested below
maybe I should contact you(rossstech) via phone?
Friday,25,September,2020,14:13:36:47253
VCDS Version: 20.4.2.0 (x64)
VIN: WV2ZZZ7HZFH161208   License Plate:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 18 19 25 37 56 61 69 6E 77 0B
VIN: WV2ZZZ7HZFH161208   Mileage: 66140km-41097miles
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (J623-CAAD) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 FJ HW: 03L 907 309 L
Component: R4 2,0L EDC X38 6294
Revision: 22X38--- Serial number: 00000000000000
Coding: 0111401A233401080000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM20TDI01103L906019FJ 003007
ROD: EV_ECM20TDI01103L906019FH_003.rod
   VCID: 78FF94B9C36BDE462B-802C
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 L HW: 7E0 907 379 L
Component: ESP MK25A XT H50 0113
Revision: 00H50001
Coding: 608724AD09AA069624A49071B96692
Shop #: WSC 02757 790 49152
   VCID: 3B754BB5BADD355E06-806E
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 20051504650779
Coding: 01
ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF382A1E14FE07661-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 BL HW: 7E5 907 047 BL
Component: Climatic-T5 H20 0506
Revision: 00001012
Coding: 0000000002
Shop #: WSC 02757 790 50316
ROD: EV_ClimaT5Basis.rod
   VCID: 7AFB8EB1FD67CC565D-802E
9477872 - AC Compressor First Run-In
B109E F0 [009] - Not Performed
Reset counter: 27
Mileage: 66145 km
Date: 2020.09.25
                    Time: 02:15:13
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 D HW: 7H0 937 090
Component: BCM PQ25 Max4 H78 0725
Revision: B9078001 Serial number: 0671 136151341
Coding: A0A4393A0A613412922849706C2B8CD40790602F7E844C40320000020800
Shop #: WSC 02739 790 12345
   VCID: 2F6D6FE57EA5D9FEBA-807A
   Subsystem 1 - Part No SW: 7E0 959 801 K    HW: 7E0 959 801 K  Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 8653
Serial number: KU0KU028041551184563
   Coding: 1400B1
   Subsystem 2 - Part No SW: 7E0 959 802 K    HW: 7E0 959 802 K  Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 8653
Serial number: KU0KU008051551281833
   Coding: 0400A1
   Subsystem 3 - Part No: 7E1 951 172
   Subsystem 5 - Part No: 7E1 951 172
   Subsystem 6 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H07 0023
Serial number: 70000000000000888287
   Coding: E20000
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 7N0 919 475
Component: PARKHILFE 8K H06 0106
Revision: -------- Serial number: 28231505606361
Coding: 118004
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_VW75XParkAssis8K 001003
ROD: EV_VW75XParkAssis8K_001_VN75.rod
   VCID: 3B754BB5B2DD355E06-806E
Part No SW: 7E0 959 655 C HW: 7E0 959 655 C
Component: VW10Airbag01X H07 0013
Revision: -------- Serial number: 003HM006B88W
Coding: 000000000000000000000000000000003158
Shop #: WSC 02754 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 36635A8189FFE836F9-8062
   Serial number: 3495ZRB400A531S4ROSD
   Serial number: 3505ZRB400A531S4SPM1
Part No SW: 7E0 920 970 N HW: 7E0 920 970 N
Component: KOMBI H04 0805
Coding: 460B01
Shop #: WSC 02737 790 50316
   VCID: 35615D8D94F9E32EF0-8060
Address 18: Aux. Heat Labels: None
Part No: 7E0 815 071 C
Component: J737__Standheizung 0605
Revision: 00087000 Serial number: 09024900A00000
Coding: 0020031
Shop #: WSC 02757 790 00000
   VCID: 25418DCDEC5993AE40-8070
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H78 0725
Revision: B9078001
Coding: 042300
   VCID: 70EFAC99A31B8606E3-8024
Component: IMMO H04 0805
   VCID: 6ADBBEF18DC77CD6AD-803E
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 680 T HW: 1T0 035 680 T
Component: RNS-MID H32 5274
Revision: AB001001 Serial number: VWZ6ZZN8254101
Coding: 06010002010000A10000
   VCID: 3F8D3FA5AEC5297E2A-806A
   Component: EU West V13  8348
00857 - CD Changer Unit (R41)
Reset counter: 27
Mileage: 66144 km
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Reset counter: 27
Mileage: 66144 km
Reset counter: 27
Mileage: 66144 km
Part No SW: 7H0 907 534 HW: 7H0 937 090
Component: Batt.regelung H78 0725
Coding: 330B1A73
Shop #: WSC 02737 790 00000
   VCID: 6BD5BBF58A3D65DED6-803E
   Subsystem 1 - Part No SW: 7E0 915 181 E    HW: 7E0 915 181 E
Component: J367-BDM H08 0223
   Serial number: 52106150494261879673
Component: ConWysTrailer H07 0100
Revision: 3A001001 Serial number: 00000132425721
Coding: 0100000100000000
Shop #: WSC 00007 223 174336
   VCID: 306F6C99639BC606A3-8064
Address 6E: Ctrl Head Roof (J702) Labels:. 7E5-919-037-L2.clb
Part No SW: 7E5 919 037 F HW: 7E5 919 037 F
Component: Dachdisplay H16 0185
Revision: 11100011 Serial number: 378030
Coding: 000106
Shop #: WSC 02739 790 00000
   VCID: 346760899783FA26C7-8060
Part No SW: 7P6 035 730 M HW: 7P6 035 730 M
Component: TELEFON H16 4217
Revision: 1B001001 Serial number: 00007670411012
Coding: 0A01020000010101
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
   VCID: 3C7748A9B7D332660F-8068
Address 0B: Sec. Air Heating Labels: None
Part No: 7E0 819 006 H
Component: J604 Standheizung 0401
Revision: L100400A Serial number: 00000000000000
   VCID: 2C5778E98CB3A2E69F-5140
02245 - Connection; RF Remote Control
End-------------------------(Elapsed Time: 03:28)--------------------------
We do not do retrofit support over the phone, sorry.
Moreover none of us have any personal experience with retrofitting rear A/C (or anything else for that matter) in a T5 because the T5 was never sold in the NAR market. This is why we still keep a T4 as our company truck! :)
NEtech
Denmark
C?ID=56995
There are 2 different basic setting available for "AC Compressor First Run-In"
Test it, I would let the engine running at idle.
Gileswater
France
C?ID=282472
ok thanks
thats either the manual or automatic option
i have only tried automatic as per instructions on the rosstech VW Golf (5K) Climatic webpage
and as mentioned previously an error message appears
( worded -"conditions not correct or request sequence error")
The adaptation option which is recommended if an error appears , is confusing and i do not understand the 120 part ( extract below )
I guess that the issue must be something simple because the compressor worked fine before i started fiddling with the Vcds app
and the only difference with the old heater control unit is the additional rear control switch
Any advice appreciated
Necessary when the Climatic control module (J301) is replaced.
Prerequisites to start the basic setting A/C compressor first run:
  • Engine at idle
  • Transmission in Park or Neutral
  • Do not cycle the ignition
  • Basic setting was performed for the flaps
  • Inside blower motor is switched on
  • Air vents fully open
  • Load management not active
"AC Compressor First Run-In" Steps:
Start engine and allow it to Idle.
Adapt flap end stops as described above.
[Basic Settings - 04]
Select IDE02259-ENG167462 "Compressor run in: automatic start" from the drop-down list.
[Go!]
  • It will show completed, but wait 120 sec (2 Min) and observe the flashing A/C button light on the HVAC panel.
  • After the Basic Settings has completed, the A/C light will quit flashing and the fault code will clear.
[Stop]
Note:
If Basic Settings reports Error the module may need to see an Adaptation change before this can be completed. Go to Adaptation and change "Driving time for compressor run in" from 120 -to- 120 and save it followed by repeating the entire procedure.
Gileswater
France
C?ID=282472
it doesn,t work in manual either
Gileswater
France
C?ID=282472
ok
I have managed to fix the issue .Not sure how though.
still no luck with compressor run in options / error messages and adaptation instructions however
can anyone clarify ??
