Steering Rack Advice please
sealover1
UK DEVON
C?ID=413332
Hi guys getting this fault and have seen it come up a lot on the mk2 (00573 steering torque sensor)
its looking more and more like I may need to change the rack what I wanted to know do you have to code them into the ECU or would a 2nd hand one fit in and work?
thought I should add that I do have VCDS (Ross Tech) I just dont know how to code it
2007 skoda scout Estate 2.0L TDi 4x4
My Skoda Vin Code
17 digit Vin Code
TMBKE21Z788009343
sealover1
UK DEVON
C?ID=413332
Hi Uwe and thank you for any help you can give, here is the last scan I done when I 1st got the problem, I had to put the car in to have the shocks changed
if a fresh scan is needed please let me know and will get a lift to the car and scan it again,
This is my 1st Scanner so new to it all but hoping to learn
VIN: TMBKE21Z788009343   License Plate:
Mileage: 310730km-193078mi   Repair Order: 2
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 55 56 62 72 76
VIN: TMBKE21Z788009343   Mileage: 310730km-193078miles
Address 01: Engine        Labels: 03G-906-021-BMM.clb
   Part No SW: 03G 906 021 SS    HW: 03G 906 021 AB
   Component: R4 2,0L EDC G000SG  1302
   Revision: --H07---    Serial number: SKZ7Z0G4311023
   Coding: 0000172
   Shop #: WSC 66565 257 00032
   VCID: 025C73D48807A2BB447-8056
013112 - Control Circuit for Glow Plug Controller 1
               P3338 - 000 - Electrical Malfunction - Intermittent
                    Mileage: 310730 km
                    Time: 00:01:10
                    Voltage: 12.54 V
                    Bin. Bits: 00101100
                    Temperature: 33.3°C
                    Bin. Bits: 01010000
005213 - Exhaust Gas Temperature Sensor 3
               P145D - 000 - Short to Plus - Intermittent
                    Mileage: 310730 km
                    Time: 00:01:10
                    Voltage: 12.54 V
                    Temperature: 20.7°C
                    Temperature: 60.0°C
                    Temperature: 60.0°C
                    Temperature: 324.0°C
Address 03: ABS Brakes        Labels:. 1K0-614-517-MK60AT.clb
   Part No SW: 1K0 614 517 AD    HW: 1K0 614 517 AD
   Component: ESP 4MOTION MK60-AT 0102
   Revision: 00H14001
   Coding: 0023170
   Shop #: WSC 73430 790 00000
   VCID: 698E4478957151E3E5D-803C
   Part No SW: 1Z0 907 044 R    HW: 1Z0 907 044 R
   Component: ClimatronicPQ35 110 0402
   Revision: 00110021    Serial number: 00000000000000
   VCID: 45D6A8C8D9A95583215-8010
   Revision: 00H54000    Serial number: 00000005018991
   Coding: E18A0F130004100000110D000000000000087F065C000000000000000000
   Shop #: WSC 07894 067 57207
   VCID: 71BE2C18BDA1A923ADD-8024
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 060607 022  0601
   Coding: 00055223
   Shop #: WSC 07894
   Component: RLS     250607 046  0204
   Coding: 00471077
   Shop #: WSC 07894
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1A3RTX
   Coding: 0020788
   VCID: 3D26C028B1791D43795-8068
   Subsystem 1 - Serial number: 6332MSME184A620EG
   Subsystem 2 - Serial number: 6342MSME1C044D46G
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Coding: 0002042
   VCID: 015E7CD88D01B9A35DD-8054
   Part No SW: 1Z0 920 942 D    HW: 1Z0 920 942 D
   Component: KOMBIINSTRUMENT VD1 1612
   Revision: V1612036    Serial number: SKZ7Z0G4311023
   Coding: 0007402
   Shop #: WSC 11111 067 57207
   VCID: 392ED438A551216355D-806C
   Revision:   H07 01    Serial number: 160607F2000472
   Coding: E9837F0E0002022303
   VCID: 3038E91C762BE02BE23-8064
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 L
   Component: Haldex 4Motion      0116
   Coding: 0000001
   VCID: 3634DF04944FCE1BB8F-8062
   Component: IMMO            VD1 1612
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         006 1204
   Coding: 0000758
   VCID: 3828D13C9E5B386BAA3-806C
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
   Shop #: WSC 73430 000 90108
   Coding: 81801A085283007F3F02050FC0085F96907C00
   VCID: 035276D0971DABB34F1-8056
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008
   Coding: 00000000
   Shop #: WSC 73430
   Subsystem 6 - Component:   Sounder No Answer
   Subsystem 7 - Component:       NGS n.mounted
                    Reset counter: 101
                    Mileage: 310730 km
                    Time: 00:05:56
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Coding: 0000758
   Part No: 1T0 907 357
   Coding: 0000008
   VCID: 74B0250CC2B39C0B46B-8020
   Part No SW: 1Z0 035 161 C    HW: 1Z0 035 161 C
   Component: Radio FO3       019 0040
   Revision: 00019000    Serial number: SKZ7Z3G0019189
   Coding: 0000402
   VCID: 2E04F7646C1FF6DBF0F-807A
   Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
   Component: Tuer-SG         006 1201
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
   VCID: 372AD20093453713A39-8062
   Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
   Coding: 0000144
Address 76: Park Assist        Labels: 1Z0-919-283.lbl
   Part No SW: 1Z0 919 283 B    HW: 1Z0 919 283 B
   Component: Parkhilfe 4-Kan H04 0020
   Coding: 0000001
End----------(Elapsed Time: 01:18, VBatt start/end: 14.0V/14.0V)-----------
MartinsX
Riga, Latvia
C?ID=268515
Nothing steering assist system related in this scan...
But faults in ECU need immediate attention!
You may get the DPF clogged if driving with those faults present!
Coding: 0000172
Mileage: 310730 km
Time: 00:01:10
Voltage: 12.54 V
Bin. Bits: 00101100
Temperature: 33.3°C
Bin. Bits: 01010000
Mileage: 310730 km
Time: 00:01:10
Voltage: 12.54 V
Temperature: 20.7°C
Temperature: 60.0°C
Temperature: 60.0°C
sealover1
UK DEVON
C?ID=413332
Thanks MartinsX I think I need to get an up to date scan will drive down there tomorrow and get an up to date scan and post it on this thread. I have had the ECU tested and it come back ok
Thanks guys will get that done asap.
if a steering rack is needed do they need coding I rang a suppler that does reconditioned ones and they said no just turn the steering left and right
sealover1
UK DEVON
C?ID=413332
Hiu Guys Took this scan this morning UK time hope you can help got no power steering at all now and the instrument panel steering light is red with a yellow engine light
Friday,25,September,2020,10:26:26:35642
VIN: TMBKE21Z788009343   License Plate: NX57GHB
Mileage: 310750km-193091mi   Repair Order: scout 2
VIN: TMBKE21Z788009343   Mileage: 310750km-193091miles
   Coding: 0000172
005658 - Glowplug for Cylinder 1 (Q10)
               P161A - 000 - Open Circuit
                    Mileage: 310751 km
                    Time: 22:13:44
                    Voltage: 12.69 V
                    Bin. Bits: 00101100
                    Temperature: 7.2°C
                    Bin. Bits: 00110000
005659 - Glowplug for Cylinder 2 (Q11)
               P161B - 000 - Open Circuit
                    Mileage: 310751 km
                    Time: 22:13:44
                    Voltage: 12.69 V
                    Bin. Bits: 00101100
                    Temperature: 7.2°C
                    Bin. Bits: 00110000
005660 - Glowplug for Cylinder 3 (Q12)
               P161C - 000 - Open Circuit
                    Mileage: 310751 km
                    Time: 22:13:44
                    Voltage: 12.69 V
                    Bin. Bits: 00101100
                    Temperature: 7.2°C
                    Bin. Bits: 00110000
005661 - Glowplug for Cylinder 4 (Q13)
               P161D - 000 - Open Circuit
                    Mileage: 310751 km
                    Time: 22:13:44
                    Voltage: 12.69 V
                    Bin. Bits: 00101100
                    Temperature: 7.2°C
                    Bin. Bits: 00110000
   Revision: 00H14001
   Coding: 0023170
   Coding: 00055223
   Shop #: WSC 07894
   Coding: 00471077
   Shop #: WSC 07894
   Coding: 0020788
   Coding: 0002042
   Coding: 0007402
   Coding: 0000001
   Coding: 0000758
00573 - Steering Torque Sensor (G269)
   Coding: 00000000
   Shop #: WSC 73430
                    Reset counter: 103
                    Mileage: 310751 km
                    Time: 22:21:24
   Coding: 0000758
   Coding: 0000008
   Coding: 0000402
   Coding: 0000144
   Coding: 0000144
   Coding: 0000001
End----------(Elapsed Time: 01:17, VBatt start/end: 12.7V/12.7V)-----------
sealover1
UK DEVON
C?ID=413332
Thanks Uwe I,ve seen that before, we checked all them sounds like the rack is gone then?
does it need coding?
As far as I can see in your scan, the rack doesn't support coding, so I don't think it needs coding.
sealover1
UK DEVON
C?ID=413332
sealover1
UK DEVON
C?ID=413332
forgot to ask can we post links to parts?
Yes. Since we don't sell parts, and this forum isn't beholden to any advertisers, there's no problem with that.
