2007 EOS, 2.0t/DSG-6spd, unknown code: 17252 - P0868 - 001 "Trans. Fluid Pressure Adaptation at Limit"
bobster
Daytona area, FL, USA
C?ID=406029
A family friend I would even call a "nephew" bugged me to sell him this car. 2007 EOS, 2.0t FSI/BPY with 6-speed DSG. A thou or two over 100k miles from an older original owner who had become ill and was not able to maintain the car but did take care of it up until that point. Then it got flooded inside because the windows were open and battery was dead. I cleaned and repaired the dirt and debris in the interior over the course of a year as well as replace many electrical components and got the top working. I soldered a new plug and 18 wires for the chassis driver's seat connector. As a condition of sale, we did a DSG fluid change with VW parts. All went well with the service but the next day he had codes for a shifter issue which went away and didn't come back. I think he was slamming the shifter around playing with the "modes", etc. :rolleyes: I sold it to him with the agreement that as soon as he put the key in the ignition, the warranty was over. ;) With both of us knowing he was hard on his cars, it was fair to both of us. But I'm not heartless either and the kid has money he will spend so I help him when I can.
His latest issue is the tranny is bucking as it downshifts. Various codes are shown. I don't really feel sorry for him because he constantly thrashes the car and posts up on social media about it... :rolleyes: The engine codes are because he had a straight pipe put in from the light-off back. He also has hit a curb, tire blew out and tore the right-rear fender liner and venting for the gas fill off. And it needs a T-stat. Other issues I will test with spares--probably needs a couple modules and/or actuators for the A/C.
I'll probably remove/clean/reinstall the trans connector and go through the "Basic Setting" procedure tomorrow to see if it is just a hiccup. The only issue is the "unknown" code: 17252 - P0868 - 001 "Trans. Fluid Pressure Adaptation at Limit" Can't seem to find too much info on it...
Tuesday,22,September,2020,15:29:54:64029
VCDS Version: 20.4.2.0
VIN: WVWBA71F37V023772   License Plate: EOSDSG
Mileage: 198200km-123155mi   Repair Order:
Chassis Type: 1F (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 26 42 44 46 52 56 62 63
          65 72
VIN: WVWBA71F37V023772   Mileage: 198200km-123155miles
0F-Digital Radio -- Status: Cannot be reached 1100
26-Auto Roof -- Status: Malfunction 0010
63-Entry Assist,D -- Status: Malfunction 0010
   Part No SW: 1Q0 907 115 E    HW: 8P0 907 115 B
   Revision: 5BH15---    Serial number: VWX7Z0F93NQ8SU
   Coding: 041C010A1C070160
   Shop #: WSC 05055 444 54363
   VCID: 2E533F41B9ED58F6B1-807A
009217 - EVAP Leak Detection Pump Control Circuit
               P2401 - 002 - Short to GND - MIL ON
                    Fault Status: 11100010
                    Mileage: 165757 km
                    Time: 02:35:42
                    RPM: 1410 /min
                    Load: 12.9 %
                    Temperature: 50.0°C
                    Temperature: 38.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.081 V
008577 - Performance Malfunction in Cooling System
               P2181 - 008 -
                    Fault Status: 01101000
                    Mileage: 165792 km
                    Time: 21:18:38
                    RPM: 2805 /min
                    Load: 100.0 %
                    Speed: 60.0 km/h
                    Temperature: 68.0°C
                    Temperature: 36.0°C
                    Voltage: 13.970 V
001056 - Catalyst System; Bank 1
               P0420 - 002 - Efficiency Below Threshold - MIL ON
                    Mileage: 196621 km
                    Time: 11:56:57
                    RPM: 2186 /min
                    Load: 25.9 %
                    Speed: 68.0 km/h
                    Temperature: 76.0°C
                    Temperature: 40.0°C
                    Voltage: 13.716 V
Readiness: 0000 0100
   Part No SW: 02E 300 043 R    HW: 02E 927 770 AE
   Component: GSG DSG         070 1302
   Revision: 04507000    Serial number: 00000610130621
   Shop #: WSC 44551 111 44551
   VCID: 2345DE75E22FE59E2E-8076
18115 - Interference in Mechatronic Module
            P1707 - 007 -  - Intermittent
                    Fault Status: 00100111
                    Fault Frequency: 255
                    Reset counter: 11
                    Mileage: 196653 km
17252 - Transmission Fluid Pressure Adaptation at Limit
            P0868 - 001 -  - Intermittent
                    Fault Status: 00100001
                    Reset counter: 2
                    Mileage: 197526 km
18227 - Pressure Control Valve 2
            P1819 - 008 - Open or Short to Ground - Intermittent
                    Reset counter: 36
                    Mileage: 198036 km
18222 - Pressure Control Valve 1
            P1814 - 008 - Open or Short to Ground - Intermittent
                    Reset counter: 36
                    Mileage: 198047 km
   Revision: 00H11001
   Coding: 0021218
   Shop #: WSC 00020 000 00000
   VCID: 73E5EE35124F351E1E-8026
00493 - ESP-Sensor Unit (G419)
            014 - Defective
   Part No SW: 1Q0 907 044 J    HW: 1Q0 907 044 J
   Component: ClimatronicPQ35 121 0303
   Revision: 00121021    Serial number: 00000000000000
   VCID: 34672D2957C17226C7-8060
   Part No SW: 3C0 937 049 Q    HW: 3C0 937 049 Q
   Component: Bordnetz-SG     H46 1501
   Revision: 00H46000    Serial number: 00000006277628
   Coding: 058C8F0340041500470000000F00000000285D035C0000
   VCID: 377D1A2546B7993EE2-8062
   Component: Wischer 201006 020  0501
   Coding: 00038805
   Shop #: WSC 00020
                    Fault Status: 01101100
                    Reset counter: 248
                    Mileage: 193943 km
                    Voltage: 13.40 V
00156 - Control Circuit for Windshield Washer Pump
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 248
                    Mileage: 193939 km
                    Voltage: 12.35 V
02398 - Control Circuit for Rear Windshield Washer Pump
                    Reset counter: 248
                    Mileage: 193939 km
                    Voltage: 12.35 V
Address 0F: Digital Radio
Address 15: Airbags        Labels: 1Q0-959-655.lbl
   Part No SW: 1Q0 959 655 A    HW: 1Q0 959 655 A
   Component: 13 Airbag VW8C      0180
   Revision: 92009018    Serial number: 003B30012XX0
   Coding: 0012595
   VCID: 3A7B031175A584561D-806E
   Subsystem 1 - Serial number: 633  RB4        4
   Subsystem 2 - Serial number: 634  RB4        5
   Subsystem 3 - Serial number: 637  RB4        8
   Subsystem 4 - Serial number: 638  RB4        9
01217 - Side Airbag Igniter; Driver Side (N199)
            001 - Upper Limit Exceeded - Intermittent - MIL ON
                    Fault Status: 10110001
                    Mileage: 162542 km
                    Time: 02:32:18
00003 - Control Module
            014 - Defective - MIL ON
                    Fault Status: 11101110
                    Mileage: 179007 km
                    Time: 00:05:38
   Part No SW: 1K0 953 549 AP    HW: 1K0 953 549 AP
   Component: Lenksäulenmodul 036 0070
   Coding: 0010041
   VCID: 000FB1F953F91E8613-8054
   Part No SW: 1Q0 920 973 B    HW: 1Q0 920 973 B
   Revision: V0003000    Serial number: VWX7Z0F93NQ8SU
   Coding: 0023207
   Shop #: WSC 05226 444 85901
   VCID: 326B2B31ADD57C16D5-8066
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H12 0170
   Revision:   H12       Serial number: 33001069208969
   Coding: 3FBF23600F025000
   VCID: 2F6D2245BEE751FEBA-FFFE
01304 - Radio
02649 - Digital Radio Tuner
   Part No SW: 1Q0 919 965     HW: 1Q0 919 965
   Component: Kompass         002 0001
   Revision: 00002000    Serial number: 1350208TK4MH02
   VCID: 79F9DC1D30234F4E54-802C
   Component: IMMO            VDD 1610
Address 26: Auto Roof        Labels: 1Q0-959-255.clb
   Part No SW: 1Q0 959 255 B    HW: 1Q0 959 255 B
   Component: Verdecksteuergeraet 0622
   Revision: 0032000K    Serial number: 062830034
   Coding: 0655360
02364 - Closing Assistance
                    Fault Status: 00101110
                    Fault Frequency: 168
                    Reset counter: 23
                    Mileage: 197831 km
                    Time: 00:43:52
                    Voltage: 12.50 V
                    Voltage: 12.50 V
                    Voltage: 4.90 V
                    Error Code: 0
02805 - System Interference
                    Fault Status: 00111110
                    Reset counter: 28
                    Mileage: 197831 km
                    Time: 00:44:02
                    Voltage: 12.50 V
                    Voltage: 12.50 V
                    Voltage: 4.90 V
                    Error Code: 11
   Part No SW: 1Q0 959 701 D    HW: 1Q0 959 701 D
   Component: Tuer-SG         004 1203
   Coding: 0001207
   VCID: 3561102D5CBB6B2EF0-8060
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.070 H07 1806
   Component:    KSG PQ35 RDK 052 0218
   Coding: 13908A800186281B0804040FB0080E0488DC00
   VCID: 0407BDE947E102A637-8050
   Part No SW: 1Q0 959 702 F    HW: 1Q0 959 702 F
   Component: Tuer-SG         008 2023
   Coding: 0017590
   Shop #: WSC 00020 790 00000
   VCID: 387F19194BA99646EB-806C
Address 56: Radio
   Part No SW: 1Q0 959 703 A    HW: 1Q0 959 703 A
   Coding: 0000144
   Shop #: WSC 05226 444 1012557
Address 63: Entry Assist,D        Labels: 1Q0-959-790.lbl
   Part No SW: 1Q0 959 790 A    HW: 1Q0 959 790 A
   Component: J572  EASYENTRY FS  0603
   Revision: 00H02000    Serial number: 5DS008646-01--
   Coding: 0000002
01445 - Sensor for Driver Seat Fore/Aft (G227)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 28
                    Reset counter: 248
                    Mileage: 193939 km
                    Time: 21:54:09
   Component:    RDK              0440
   Coding: 0100100
   Shop #: WSC 131071 102 209715
   Part No SW: 1Q0 959 704 A    HW: 1Q0 959 704 A
   Coding: 0000144
   Shop #: WSC 00020 790 1012544
End-------------------------(Elapsed Time: 02:20)--------------------------
bobster
C?ID=406029
Why do you call this fault, "Unknown"?
Let me rephrase that: "lesser known". ;) It didn't show up in the code list here and only gave 2 or 3 inconclusive search hits. Already have the basic setting sheet printed out, thanks. Maybe when I get a set of keys I'll work on it... :rolleyes:
