Black screen on rear camera 2017 Passat R-Line (NMS)
C?ID=313143
The rear camera only displays a black screen on the MIB2 in my 2017 Passat (NMS). I've replaced the camera and still have the same issue. 5F shows the fault B1102 31 [009] - No Signal for the camera. Is there an adaption I need to do?
Autoscan:
Tuesday,22,September,2020,16:59:11:41190
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(Parallels)
VCDS Version 20.4.2.0 (x64)  HEX-V2 CB: 0.4513.4
VIN: 1VWDT7A30HC063309   License Plate:
Mileage: 64980km-40376mi   Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 08 09 13 15 16 17 19 25 3C 42 44 46 4F 52 5F 61 62
          72
VIN: 1VWDT7A30HC063309   Mileage: 64980km-40376miles
Address 01: Engine (J623-CPRA)       Labels:. 06K-907-425-V2.clb
   Part No SW: 06K 906 071 BJ    HW: 06K 907 425 C
   Component: R4 1.8l TFS   H13 4891
   Revision: --H13---
   Coding: 001A0092242400170000
   Shop #: WSC 06050 062 00200
   ASAM Dataset: EV_ECM18TFS02006K906071BJ 001010
   ROD: EV_ECM18TFS02006K906071BG.rod
   VCID: 74B2D4815E3121CB46B-8021
Readiness: 0000 0100
   Part No SW: 09G 927 158 BD    HW: 09G 927 158
   Component: AISIN AG6 G3  202 3121
   Coding: 010200000C000000000000000000000000000000
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW23.rod
   VCID: 76B6EE89484D33DB78F-8023
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: C54BC0F5492800FDA30E03E49222004120F0F01A
   VCID: 75B4E98555CB38C3715-8021
02214 - Tire Pressure Warning
                    Reset counter: 61
                    Mileage: 64531 km
                    Date: 2020.09.16
                    Time: 15:15:18
                    Count: 32768
                    Count: 4608
                    Count: 16401
                    Count: 49277
                    Count: 2
                    Count: 1022
   Part No SW: 561 907 044 BD    HW: 561 907 044 BD
   Component: Climatronic   H08 0910
   Revision: 00001K05
   Coding: 0070019002
   VCID: 5AEE9A39DC9577BB7C7-800F
   Part No SW: 5K0 937 087 AL    HW: 5K0 937 087 AL
   Component: BCM PQ35 H++  122 0184
   Revision: BN122001
   Coding: EF200E38982B08D4088802010400044800F1000640801D20E48062000C70
   VCID: 7F580BAD67F772932B9-802B
   Part No SW: 7N0 907 572 C    HW: 7N0 907 572
   Serial number: 12011704400055
   Coding: 01001000FE07B9
   ROD: EV_ACCBEGVW361.rod
   VCID: 36362E8908CD73DBB8F-8063
1058 - Databus
          [FAULT_CIS_ECD_NOTAVAILABLE]
                    Reset counter: 59
                    Mileage: 64469 km
                    Date: 2020.09.15
                    Time: 10:45:59
                    Control Module temperature: 26 °C
                    Voltage terminal 15: 12.2 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
Address 15: Airbags (J234)       Labels:* 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    008 0210
   Serial number: 003RXM0AYGHX
   Coding: 8CCCCC00000000005000001A020800000065
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411.rod
   VCID: 6390A7DDEBDFB6732F1-8037
   Serial number: IBH000000000006GMAW3
   Coding: 30324C
   Subsystem 2 - Part No SW: -----------    HW: 480 002 012 16
   Serial number: 3570000000065BF4002F
   Subsystem 3 - Part No SW: -----------    HW: 480 002 012 16
   Serial number: 35800000000F4BF4002O
   Subsystem 4 - Part No SW: -----------    HW: 480 021 912 16
   Component: SideSensor_Dr  000 0148
   Serial number: 3510001BF237EE360638
   Subsystem 5 - Part No SW: -----------    HW: 480 021 912 16
   Component: SideSensor_Pr  000 0148
   Serial number: 3520001B3237EE347452
   Subsystem 6 - Part No SW: -----------    HW: 480 023 011 16
   Component: FrontSensor_D  000 0189
   Serial number: 3550001C922F97549305
   Subsystem 7 - Part No SW: -----------    HW: 480 023 011 16
   Component: FrontSensor_P  000 0189
   Serial number: 3560001C922F97544266
   Part No SW: 1K5 953 521 CM    HW: 5K0 953 569 BC
   Revision: FF010042    Serial number: 20170104301972
   Coding: 0892440008
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 7AAEFAB97C5557BB1C7-802F
   Subsystem 1 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A  Labels: 3C8-959-537.CLB
   Serial number: 3201604271200523AC1B
   Coding: 290000
   Part No SW: 561 920 971 B    HW: 561 920 971 B
   Coding: 221E010000
   VCID: 1A6EDA399C15B7BBBC7-804F
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1682
   Revision:   H56       Serial number: 22011703010852
   Coding: 461020
   VCID: 7BA0FFBD73EF6EB3071-802F
                    Reset counter: 60
                    Mileage: 64470 km
                    Date: 2020.09.15
                    Time: 17:19:29
   Component: IMMO          H03 1104
   VCID: 6A8ECAF90CF5E73BEC7-803F
   Serial number: 0423652086
   Coding: 01011102
   ROD: EV_HREntryHella_VW27.rod
   VCID: 3C223CA136E1A98B4EB-8069
   Lane Change Assistant 2:
   Serial number: 0426702292
   Coding: 010111
   Part No SW: 561 959 701 C    HW: 3C0 959 793 J
   Component: TUER-SG FT    002 0637
   Revision: 12100010    Serial number: 0010828641
   Coding: 0404F5
   ASAM Dataset: EV_TSGFPQ25BRFVW46X A04004
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 1E66D629803DDB9B40F-804B
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 C    HW: 561 959 811 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  022 1472
   Serial number: 14202746170220200803
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 311    3501
   Revision: 00H22000
   Shop #: WSC 19460 666 12345
   VCID: 392C25B535539CA355D-806D
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
   Component: EZE_2         H56 1682
   Coding: 00000008
   VCID: 6FB8DBED37970213BB9-803B
   Subsystem 1 - Part No SW: 561 919 204 C    HW: 561 919 204 C
   Component: Analoguhr  002 0003
   Part No SW: 561 959 702 C    HW: 3C0 959 792 J
   Component: TUER-SG BT    002 0637
   Revision: 14100010    Serial number: 0010861936
   Coding: 0405F4
   ASAM Dataset: EV_TSGBPQ25BRFVW46X A04004
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1F18EB2D8737D2934B9-804B
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 C    HW: 561 959 812 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  022 1472
   Serial number: 14102747170221001127
   Part No SW: 5C0 035 200 B    HW: 5C0 035 200 B
   Component: MU-S-S-US     H31 0359
   Serial number: VWZAZ2T1026654
   Coding: 02140100BE00000011220001001808009F0106D40020010002
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 1472B4017EF181CBE6B-8041
6720 - Rear View Camera
                    Reset counter: 19
                    Mileage: 64470 km
                    Date: 2020.09.15
                    Time: 12:11:45
                    Voltage terminal 30: 14.2 V
   Component: Batt.regelung H56 1682
   Coding: E1200859
   VCID: 71BCDD9521A314E3ADD-8025
End----------(Elapsed Time: 01:00, VBatt start/end: 12.4V/12.5V)-----------
downtime
Finland
C?ID=280813
And you have checked the wiring? And I presume you have OEM lowline rear view camera?
C?ID=313143
Yeah. The wiring was checked and verified by a VW. The said the coax shows no signs of damage.
C?ID=313143
Anyone?
downtime
Finland
C?ID=280813
If your infotainment says :
                    Reset counter: 19
                    Mileage: 64470 km
                    Date: 2020.09.15
                    Time: 12:11:45
You honestly presume it's a coding issue? The wiring has a problem or the camera unit is dead. No signal is a definitive sign that physically it's not getting from point x to point y.
C?ID=313143
No I “presume” it’s a coding issue. It was a question. I’ve replaced the camera. I’m trying to not replace the main body harness at $1200. Forgive me for looking for something. No need to be condescending.
siLc
Tallinn, Estonia
C?ID=330192
No need to replace the whole body harness. Seperate camera video cables are available such as this -> https://www.aliexpress.com/item/32948058703.html?spm=2114.12010612.8148356.27.f98f5cd5LFCbrE
De-pin the existing camera video feed at radio Quadlock connector blue plug pins 6 and 12. Connect the video cable directly to the camera - does the RVC image appear? You can test it out without permanently running the cable. If it doesn't help, it at least helped narrow things down a bit.
downtime
Finland
C?ID=280813
Yes, what siLC proposed is the easiest way to do. Also if you are familiar on how to use multimeter you could check the wiring conductivity and resistance and check that way as well is the cable ok, without even getting a new cable yet.
And sorry, my intention was not to be rude and judgemental. I merely wanted to point out that the error so clearly indicates there's a connectivity issue. VW service saying wiring is ok they've checked it is something you can trust 0%. They'll only want to sell you a new camera and new wiring harness.
MartinsX
Riga, Latvia
C?ID=268515
I agree.
Unfortunately dealers mainly use guided fault finding function in ODIS and just follow given test steps without deeper understanding how things are made and how they should work...
C?ID=313143
Sorry been busy at work for a bit. I actually went ahead and ordered a cable much like the one in the link above. After de-pin/re-pin, the issue is the same. Does the cam communicate with the gateway? I got so annoyed with it that I coded out the cam for the time being. I REALLY want to get it working again. FML lol
C?ID=313143
I completely agree. It absolutely indicates a cabling issue. I just can't figure it out. I'm wondering if somewhere along the line some of the wires got pinched/ground (the 4 white ones) and shorted something out? Has anyone seen this? I need to locate the other end of those to test continuity.
downtime
Finland
C?ID=280813
You have highline camera which can be connected with VCDS? Meaning it is visible in gateway?
How many wires the camera have? Have you got wiring diagram for it?
C?ID=313143
There are 5 not including the coax cable in the harness. 2 of which go to the trunk release. The part number is 561827566D. I do not have a wiring diagram. I can't find one.
downtime
Finland
C?ID=280813
Did you change the coax? That is most likely the problem here.
C?ID=313143
I did. I bought a cable EXACTLY like the one linked above and here
MartinsX
Riga, Latvia
C?ID=268515
Sorry for offtopic :p
I never paid attention before, but why wire from the lid release button goes to RVC?
@MartinsX : I assume that the "MIB2 in.....2017 Passat (NMS)" shares some of the attributes of MQB model vehicles which also link their highlline cameras to the rear lid switch. If so, here is my very unofficial, and extremely pithy WD for said camera.
Yours is an excellent question: I suspect that the rear lid switch disables the camera when the hatch is open. Why is this needed? The only situation that I can think-of is if the car is reversing with the hatch open - maybe (i.e. selecting reverse gear will turn-on the camera via the CAN bus - but the Rear lid switch status is not a CAN message).
Yes, I agree that it's a low probability event - perhaps there's a regulation somewhere in the EU (or/and in US) for this - maybe?
If not, maybe it's just a convenience that the good Burghers in Germany have allowed their customers - nice lot those German folk! :D
C?ID=313143
There are only 5 wires in the harness including the trunk button. The coax is a separate cable. I noticed last night, when you press the trunk button, you can hear the fuse blow.
downtime
Finland
C?ID=280813
Hmm. Variant Passat or Sedan? There’s a short circuit somewhere in the connection.
