abs MK60EC1 lost coding
carter23
C?ID=194557
Hi everyone, i have a question that is about a 2011 Volkswagen Caddy's ABS ECU.
I am after the coding for the ABS ECU system on this vehicle, as it has been deleted from the van by somebody else and the codes are not recoverable before this job was passed onto me. The VIN of the van as it follows.
VIN : WV1ZZZ2KZDX039370
If anybody could help me get the ABS coding for this vehicle. it would be greatly appreciated.
many thanks,
Paul.
Hi and welcome.
Please post a complete Auto-Scan from the vehicle in question so people can see exactly how it is equipped and configured.
carter23
C?ID=194557
Wednesday,23,September,2020,09:06:21:06635
VCDS Version: 20.4.2.0 (x64)
VIN: WV1ZZZ2KZDX039370   License Plate:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52
VIN: WV1ZZZ2KZDX039370   Mileage: 146930km-91298miles
04-Steering Angle -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAYD)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 TF    HW: 03L 907 425 C
   Component: R4 1.6l TDI   H43 9979
   Revision: --H43---    Serial number: 00000000000000
   Coding: 00114014030500080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM16TDI02103L906023TF 003003
   ROD: EV_ECM16TDI02103L997557M.rod
   VCID: 7DF11502ECE8856E78-8028
   Part No SW: 1K0 907 379 BH    HW: 1K0 907 379 BH
   Revision: 00H31001
   Shop #: WSC 35110 377 08192
   VCID: 79F90112F0C0B94E54-802C
                    Reset counter: 67
                    Mileage: 146935 km
                    Count: 7
                    Count: 2
                    Count: 4608
                    Count: 195
                    Count: 45824
                    Count: 65280
                    Fault Status: 01100101
                    Reset counter: 67
                    Mileage: 146935 km
                    Count: 2
                    Count: 2
                    Count: 4608
                    Count: 279
                    Count: 45824
                    Count: 65280
                    Reset counter: 67
                    Mileage: 146935 km
                    Count: 7
                    Count: 2
                    Count: 4608
                    Count: 295
                    Count: 45824
                    Count: 65280
                    Reset counter: 67
                    Mileage: 146935 km
                    Count: 2
                    Count: 2
                    Count: 4608
                    Count: 270
                    Count: 45824
                    Count: 65280
   Part No SW: 7N0 907 426 AT    HW: 7N0 907 426 AT
   Component: AC Manuell    H19 0304
   Revision: 00001016
   Coding: 0000004002
   VCID: 06037AEEB93EC6B629-8052
13701936 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 107
                    Mileage: 146935 km
                    Date: 2020.09.22
                    Time: 19:59:42
          B10AB F0 [009] - Too Low
                    Reset counter: 67
                    Mileage: 146935 km
                    Date: 2020.09.22
                    Time: 19:59:43
   Part No SW: 5K0 937 085 R    HW: 5K0 937 085 R
   Component: BCM PQ35 B+   021 0068
   Revision: BB021001
   Coding: 491A583A8025F16B08800082900000640301728852020060648000000040
   VCID: 428BA6FEDD963A9645-8016
   Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 26081  26  0512
   Coding: 009795
                    Reset counter: 67
                    Mileage: 146936 km
                    Date: 2020.09.22
                    Time: 20:38:55
                    Voltage: 14.10 V
                    Reset counter: 67
                    Mileage: 146935 km
                    Date: 2020.09.22
                    Time: 20:12:54
                    Voltage: 14.10 V
03156 - Sensor for Anti-Theft System (G578)
                    Reset counter: 67
                    Mileage: 146935 km
                    Date: 2020.09.22
                    Time: 20:12:55
                    Voltage: 14.20 V
   Component: VW10Airbag00U H06 0013
   Revision: --------    Serial number: 003HL007D5UA
   Coding: 000000000000000000000000000000003055
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3561CD2294589D2EF0-8060
   Part No SW: 1K5 953 507 M    HW: 5K0 953 549
   Revision: --------    Serial number:  90440KI6000V1
   Coding: 0080060000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 3B75DB1AB27C4B5E06-806E
   Part No SW: 2K0 920 965 G    HW: 2K0 920 965 G
   Component: KOMBI         H05 0705
   Coding: 480001
   VCID: 3365F33A9A2C831EDE-8066
10485825 - Internal Control Module Memory Check Sum Error
          B2000 41 [137] - General checksum failure
10485824 - Internal Control Module Memory Check Sum Error
   Part No SW: 7N0 907 530 H    HW: 1K0 907 951
   Component: J533  Gateway H42 1620
   Revision:   H42       Serial number: 030911F1000780
   Coding: 357401
   VCID: 3561CD229C589D2EF0-8060
                    Reset counter: 67
                    Mileage: 146936 km
                    Date: 2020.09.22
                    Time: 20:38:54
                    Mileage: 146936 km
                    Date: 2020.09.22
                    Time: 21:03:57
   Component: IMMO          H05 0705
   VCID: 6ADB2E5E8D6602D6AD-803E
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2110
   Coding: 0000560
   VCID: 489FB4D63BAA10C69B-801C
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 140    3201
   Revision: 00H20000
   VCID: 3467F02657228426C7-8060
                    Fault Status: 11100101
                    Mileage: 146935 km
                    Date: 2020.09.22
                    Time: 19:59:41
                    Battery Volts: 12.6 V
                        DD
                    Temperature: 31.0°C
                    Count: 3
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000560
   VCID: 479DB7EA36B41FBE92-8012
End-------------------------(Elapsed Time: 02:00)--------------------------
New thread, same vehicle. Please carry on there:
