Golf VII 2013: Fault codes after retrofitting gen3 A5 camera
tamperfing
Denmark
C?ID=157812
Hello everyone! This is my first post so bear with me if the post is lacking important information :D Please ask away if I omitted something that could be helpful for solving my problem.
I am in the midst of preparing a Golf VII 2013 for PACC activation. The car had ACC and lane assist (A5 camera) from factory. The currently installed ACC radar (3QF907561D) and A5 camera (3Q0980654H) are 3rd gen versions necessary for PACC. Furthermore, the ABS control unit has been exchanged for a newer version to support the 3rd gen radar. Other than that, I will be changing the door modules for a newer version, since the original ones apparently don't support PACC (supposedly it has something to do with disabling PACC if the doors are opened).
Currently, I am blocked by fault codes on the A5 camera - I know that one of the fault codes is caused by missing calibration. As far as I know, the A5 camera has to be error-free before attempting calibration (other than the calibration error).
Please see autoscans below. During the first autoscan I had an A5 camera installed with software 3Q0 980 654 H and hardware 3Q0 980 654 A. The A5 camera in the second run is with software 3Q0 980 654 L. Both cameras have fault codes with "camera interference" and "imager". I have tried searching for these kind of fault codes on the forum and elsewhere online but I have not been able to find any solution for them. Mind you that I have tried running the autsocan with a third A5 camera from a car with functioning PACC receiving same fault codes, so I think we can rule out faulty A5 cameras.
Any input on the A5 camera fault codes is greatly appreciated!
Autoscan with A5 camera SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 69 A5
Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DT    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 8127
   Revision: 83H22---
   Coding: 011D0032036405083000
   Shop #: WSC 00014 204 00000
   ASAM Dataset: EV_ECM20TDI01104L906021DT 002008
   ROD: EV_ECM20TDI01104L906021DT_002.rod
   VCID: 7AADF2F55C5CA70B1C7-802E
   Part No SW: 0D9 300 040 A    HW: 02E 927 770 AN
   Component: DQ250-6F MQB  H52 3613
   Revision: 05652103    Serial number: TFK01211090090
   ROD: EV_TCMDQ250021.rod
   VCID: 1577C14955026873915-8040
   Revision: 00000000    Serial number: 63265000000280
   Coding: 01FA62A124240972077F060141C62980462490E0608294F31862507AD202
   Shop #: WSC 36421 324 37462
2 Faults Found
8352 - Databus
          [FCAN: TSG_FT_02 is not received]
                    Reset counter: 245
                    Date: 2020.09.18
                    Time: 18:19:12
32868 - Databus
          [IPB_BUS: Gateway_72 / ZV_02_alt invalid]
                    Reset counter: 245
                    Date: 2020.09.18
                    Time: 18:19:12
Address 05: Acc/Start Auth. (J518)       Labels:* None
   Part No SW: 5Q0 959 435     HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0500
   Revision: 00021000    Serial number: 0191684323
   Coding: 030C0C
   VCID: 79AFEDF9595AAC1315D-802C
   Part No SW: 5G0 907 044 R    HW: 5G0 907 044 R
   Component: Climatronic   H02 0503
   Revision: 00001K06
   Coding: 00020114202100011105000000101000
   ASAM Dataset: EV_ACClimaBHBVW37X 002017
   ROD: EV_ACClimaBHBVW37X_002_VW37.rod
   VCID: 363526C528C4836BB8F-8062
   Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
   Component: BCM MQBAB H   H14 0106
   Serial number: 00011232700730
   Coding: 00131E46C20122FB0F244080B11C0708180A000000000000000000000000
   ASAM Dataset: EV_BCMCONTI 010001
   ROD: EV_BCMBOSCH_010.rod
   VCID: 46D55605582413EB28F-8012
   Component: WWS    121102  042 0551
   Serial number:         121108002358
   Coding: 0E4DD5
   Component: RLFS  024 0042
   Serial number: Y12M12D04H22M46S43S1
   Coding: 00A8DD
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY12285039J
   Serial number: 00000000000055271981
   Sun Roof:
   Subsystem 5 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.009  H02 0007
   Serial number:     WOO19245768
   Coding: 181801
   Part No SW: 5Q0 919 298 A    HW: 5Q0 919 298
   Component: PARKHILFE PLA 011 0029
   Revision: --------    Serial number: 61131229807446
   Coding: 0031163151
   ASAM Dataset: EV_EPHVA2CAU3700000 003014
   ROD: EV_EPHVA2CAU3700000_003.rod
   VCID: 3D2739E90DF25033795-8068
   Part No SW: 5Q0 907 572 R    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0771
   Coding: 32197F49DDFFC728949F812781400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 003014
   ROD: EV_ACCBOSCHVW416_003.rod
6 Faults Found
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Reset counter: 245
                    Mileage: 141921 km
                    Date: 2020.09.18
                    Time: 18:19:13
                    Control Module temperature: 37 °C
                    Voltage terminal 15-Voltage: 12.9 V
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.00 m/s²
                    Adaptive distance regulation: status: ACC_Init
2063 - Databus
          [FAULT_MAINSWITCH_INIT]
                    Reset counter: 30
                    Mileage: 141921 km
                    Date: 2020.09.18
                    Time: 18:19:42
                    Voltage terminal 15-Voltage: 11.9 V
1126 - Databus
          [FAULT_TIMEOUT_MOTOR_35]
                    Reset counter: 245
                    Mileage: 141921 km
                    Date: 2020.09.18
                    Time: 18:19:13
                    Control Module temperature: 36 °C
1086 - Databus
          [FAULT_TIMEOUT_TSG_FT_02]
                    Reset counter: 245
                    Mileage: 141921 km
                    Date: 2020.09.18
                    Time: 18:19:12
                    Voltage terminal 15-Voltage: 13.0 V
1085 - Databus
          [FAULT_TIMEOUT_TSK_08]
                    Reset counter: 245
                    Mileage: 141921 km
                    Date: 2020.09.18
                    Time: 18:19:13
1139 - Databus
          [FAULT_TIMEOUT_TSK_Ausrollkurve_01]
                    Reset counter: 245
                    Mileage: 141921 km
                    Date: 2020.09.18
                    Time: 18:19:12
   Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
   Component: AirbagVW20    011 0361
   Serial number: 003F5R01J4L9
   VCID: 40D9401D7A003DDB123-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 002 711 12
   Serial number: 357670000000B8394C0W
   Subsystem 2 - Part No SW: -----------    HW: 480 002 711 12
   Serial number: 358670000004868C2C0
   Subsystem 3 - Part No SW: -----------    HW: 480 400 911 12
   Serial number: 35165029D0D19C43C12F
   Subsystem 4 - Part No SW: -----------    HW: 480 400 911 12
   Serial number: 3526502AD0D63B344329
   Subsystem 5 - Part No SW: -----------    HW: 480 402 711 12
   Serial number: 3556502AD0CAF164D2C
   Part No SW: 5Q0 953 507 BM    HW: 5Q0 953 549
   Revision: --------    Serial number: 2410120003006G
   Coding: 0C00
   VCID: 025D8A15348CEFCB447-8056
Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI3
   Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
   Component: KOMBI         408 3195
   Coding: 03A501186F94000801887A030400000000000000
   VCID: 2A0D02B5EC7CD78B2C7-807E
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5344
   Serial number: 11101810522712
   Coding: 030100040B087300EF00065A1C0F00010001000000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   Component: 1-01-03-01-04
   Component: E221__MFL-DC1  H12 0034
   Serial number: 23120001946340020291
   Coding: 2D0000
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 0482118601
   Part No SW: 5Q0 905 861     HW: 5Q0 905 861
   Component: ELV-MQBA      H06 0010
   Revision: 00000000    Serial number: 12000211974003
   Coding: 4900000000000000
   ASAM Dataset: EV_ELVMarquMQB 003008
   ROD: EV_ELVMarquMQB_003.rod
   VCID: 73B3DFD17B36D6435F1-8026
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 21111200010782
   Coding: 003B1220D000040100001000
   VCID: 3FDB43E107FE42236B9-806A
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Coding: 13
   ROD: EV_SteerAssisMQB_008.rod
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 17111200091155
   Coding: 003B1020DE00040100801000
   VCID: 3E253EE500F44B2B60F-806A
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 029A00104F010200
   Subsystem 1 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A
   Component: LeiMo links  H05 0012
   Coding: 900000
   Subsystem 2 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A
   Component: LeiMo rechts  H05 0012
   Coding: 900000
2 Faults Found
13705479 - Databus
          [Kamera_FDD_Obj01 Datenbus fehlende Botschaft]
                    Reset counter: 245
                    Mileage: 141921 km
                    Date: 2020.09.18
                    Time: 18:19:13
13705995 - Databus
          [Kamera_Status: Fehlerwert im Signal Kamera_FDD_Funktionsstatus]
                    Reset counter: 245
                    Mileage: 141921 km
                    Date: 2020.09.18
                    Time: 18:19:43
   Part No SW: 5NA 035 020 D    HW: 5NA 035 020
   Component: MU-H-ND-EU    H55 1367
   Serial number: A845I0JS508182
   Coding: 02730001FF0000007111010100880A001F0100F4012004009F
   VCID: 323D1AD5C4AC9F4B947-8066
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H52 9130
   Serial number: VWZ6ZJW0401196
   Subsystem 2 - Part No SW: V03 959 806 N    HW: -----------
   Component: ECE 2020/2021  --- 0187
   Compact Disc Database:
   Component: Gracenote2  --- 1017
   Part No SW: 5Q0 907 383 H    HW: 5Q0 907 383 C
   Component: Anhaenger     H21 0204
   Revision: 8B001003    Serial number: 0416388810
   Coding: 0100000202000000
   VCID: 3C2134ED16E8593B4EB-8068
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 0272
   Serial number: 09101815K21817
   Coding: 0003070000000401002213458140A90098000E100020
2 Faults Found
0768 - No Basic Setting
          B2010 00 [009] - -
          [Calibration_VIN_mismatch]
                    Reset counter: 245
                    Mileage: 141921 km
                    Date: 2020.09.18
                    Time: 18:19:13
                    Control Module temperature: 24 °C
                    Outside air temperature: 20.0 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 2.9 s
                    Voltage terminal 15: 12.8 V
                    mid: 00 53
                    Status of camera: System malfunction
                    Engine_Running_Info: 0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1293 - Camera Interference
          C1104 00 [009] - -
          [Imager_A_BIST_error_on_Zynq_0]
                    Reset counter: 245
                    Mileage: 141921 km
                    Date: 2020.09.18
                    Time: 18:19:13
                    mid: 00 30
                    Status of camera: operational
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
End----------(Elapsed Time: 01:30, VBatt start/end: 12.7V/12.0V)-----------
Autoscan with A5 camera SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Revision: 83H22---
1 Fault Found
17156 - Databus
          U1123 00 [047] - Received Error Message
                    Fault Frequency: 39
                    Mileage: 141189 km
                    Date: 2020.09.12
                    Time: 12:35:58
                    Engine speed: 0.00 /min
                    Coolant temperature: 47 °C
                    Intake air temperature: 46 °C
                    Voltage terminal 30: 13.180 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 0
                    Acceleration: 0.000 m/s²
Address 02: Auto Trans (J743)       Labels: None
1 Fault Found
          P1734 00 [002] - -
2 Faults Found
8352 - Databus
                    Reset counter: 228
                    Mileage: 141189 km
                    Date: 2020.09.12
                    Time: 13:23:48
32868 - Databus
                    Reset counter: 228
                    Mileage: 141189 km
                    Date: 2020.09.12
                    Time: 13:23:48
   Coding: 030C0C
   Revision: 00001K06
   Coding: 0E4DD5
   Coding: 00A8DD
   Sun Roof:
   Coding: 181801
1 Fault Found
934149 - Rain/Light Recognition Sensor
          B1366 76 [008] - Wrong mounting position
                    Reset counter: 15
                    Mileage: 141234 km
                    Date: 2020.09.12
                    Time: 14:51:31
Address 10: Park/Steer Assist (J791)       Labels:* None
   Coding: 0031163151
7 Faults Found
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Reset counter: 228
                    Mileage: 141189 km
                    Date: 2020.09.12
                    Time: 13:23:28
                    Control Module temperature: 42 °C
                    Voltage terminal 15-Voltage: 13.3 V
                    Adaptive distance regulation: status: ACC_irreversible error
2063 - Databus
                    Fault Frequency: 37
                    Reset counter: 30
                    Mileage: 141189 km
                    Date: 2020.09.12
                    Time: 13:27:44
                    Control Module temperature: 40 °C
                    Voltage terminal 15-Voltage: 12.2 V
0836 - Databus
          [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                    Fault Frequency: 116
                    Reset counter: 25
                    Mileage: 141703 km
                    Date: 2020.09.16
                    Time: 16:35:38
                    Control Module temperature: 28 °C
                    Voltage terminal 15-Voltage: 14.1 V
                    Vehicle speed: 10.07 m/s
                    Longitudinal acceleration: 0.92 m/s²
1126 - Databus
                    Reset counter: 228
                    Mileage: 141189 km
                    Date: 2020.09.12
                    Time: 13:23:28
1086 - Databus
                    Reset counter: 228
                    Mileage: 141189 km
                    Date: 2020.09.12
                    Time: 13:23:28
1085 - Databus
                    Reset counter: 228
                    Mileage: 141189 km
                    Date: 2020.09.12
                    Time: 13:23:28
1139 - Databus
                    Reset counter: 228
                    Mileage: 141189 km
                    Date: 2020.09.12
                    Time: 13:23:28
   Coding: 0C00
2 Faults Found
16777010 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_LDW_0x19 keine Kommunikation]
                    Reset counter: 30
                    Mileage: 141189 km
                    Date: 2020.09.12
                    Time: 13:23:22
16777012 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_VZA_0x21 keine Kommunikation]
                    Reset counter: 30
                    Mileage: 141189 km
                    Date: 2020.09.12
                    Time: 13:23:22
   Coding: 2D0000
   Coding: 13
   Coding: 900000
   Coding: 900000
2 Faults Found
13705479 - Databus
                    Reset counter: 245
                    Mileage: 141921 km
                    Date: 2020.09.18
                    Time: 18:09:40
13705995 - Databus
                    Fault Frequency: 35
                    Reset counter: 245
                    Mileage: 141189 km
                    Date: 2020.09.12
                    Time: 13:54:14
2 Faults Found
1561 - predictive route data
          B1630 02 [008] - Signal Failure
                    Reset counter: 25
                    Mileage: 141703 km
                    Date: 2020.09.16
                    Time: 16:35:37
                    Voltage terminal 30: 14.3 V
6672 - Optical Data Bus for Display in Instruments
          U10CF 00 [008] - Intermittent Disruption
          [Optical data bus: sporadic open circuit in instrument cluster display]
                    Reset counter: 26
                    Mileage: 141705 km
                    Date: 2020.09.16
                    Time: 16:38:00
                    Temperature of MOST transceiver-max.value: -50 °C
                    Temperature of MOST transceiver-min.value: -9 °C
                    Temperature of MOST transceiver-Current: 34 °C
Address 69: Trailer (J345)       Labels:* None
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 0610
   Serial number: 15101815P20298
   Coding: 0003070000000401002213458040A10098000E10002000
   ROD: EV_MFKBoschMQBB_002.rod
2 Faults Found
          B2010 00 [009] - -
                    Reset counter: 245
                    Mileage: 141921 km
                    Date: 2020.09.18
                    Time: 18:11:27
                    Control Module temperature: 23 °C
                    System run time: 110.1 s
                    Voltage terminal 15: 11.6 V
                    mid: 00 53
                    Engine_Running_Info: 1
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
1380 - Camera Interference
          C1104 00 [009] - -
          [Temperature_Sensor_Imager_Too_Low_Error]
                    Reset counter: 245
                    Mileage: 141921 km
                    Date: 2020.09.18
                    Time: 18:11:27
                    System run time: 110.2 s
                    mid: 01 01
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
End----------(Elapsed Time: 01:32, VBatt start/end: 12.1V/12.1V)-----------
downtime
Finland
C?ID=280813
Did you change the windscreen for 3Q0 camera? Or do you have a custom install?
tamperfing
Denmark
C?ID=157812
Windscreen is changed to a facelift one.
downtime
Finland
C?ID=280813
Check that the wiring is ok. Have you compared the pre-facelift and facelift wiring that they are the same for the camera? Mainly I'm concerned on the heating pad wiring for example.
tamperfing
Denmark
C?ID=157812
Actually, I have not checked whether the wiring is identical on ETKA or something like that. I do however know that several others have made the retrofit and that the wiring/plugs were more or less plug and play. The heating pad in the new windscreen plugs straight into the wiring coming from the camera - it also only has two wires just like the heating pad from the old windscreen. The wiring for the rear view mirror was too short for the new windscreen/mirror so the wires were extended.
downtime
Finland
C?ID=280813
Reason I'm asking is this error :
C1104 00 [009] - -
It indicates a problem in wiring
tamperfing
Denmark
C?ID=157812
Any idea on how I would go about controlling for a possible wiring problem? Get both wiring diagrams and compare?
Also, do you make anything of the error occurring with a different camera?:
C1104 00 [009] - -
downtime
Finland
C?ID=280813
Yes, I think it's the easiest option. Buy one hour quality time in VW Erwin and download the wiring diagrams. Easier to debug also a possible problem with the wiring.
@tamperfing: Hi. Most definitely follow @downtime suggestion, but my quick review of the R242 wiring suggests that it ain't a complicated arrangement; Power-supply, Heater, Extended CAN and 2 x wires into J428 (ACC module).
Alas, I don't have much information about your new camera, but are you sure that the PACC facility will happily coexist with the current 3QF ACC radar (see DTCs in hex13 module)?
tamperfing
Denmark
C?ID=157812
After looking up the wiring diagram on Erwin I found out that the ground wire from the heating plate goes to pin 10 in the A5 plug in cars from May 2016, while in cars until may 2016 it goes into pin 5 along with ground to the camera.
Surely this could be causing the error code? It is worth while trying to change up the wiring anyways.
@DV52 Yes I'm pretty sure that PACC will coexist with the radar once everything is coded, activated and calibrated. I'll update this post once it all works.
downtime
Finland
C?ID=280813
That would be the problem. Change the wiring and it should fix the heating error.
lukkii
Czech Republic
C?ID=337474
As to this topic: 3QFxxx radar is suitable for pACC retrofitting, but of course, you have to make several further SW steps before making this unit correctly working.
3Q980654x camera is OK too - maybe flash to index L, that you already did... . BUT your error below ist definitely HW issue and I meet very often these broken units, bought mostly from some (here not named) e-shop. Buy another one.
C1104 00 [009] - -
The error VIN mismatch is no problem to solve. Other mistakes are the coding issue..
Lukas
tamperfing
Denmark
C?ID=157812
@lukkii You might be right. I am getting the same errors after changing the wiring. I have considered broken units but as I already wrote, I have tried 3 A5 units of which one definitely is not broken.
lukkii
Czech Republic
C?ID=337474
Write me just a private message - I can try to help you
tamperfing
Denmark
C?ID=157812
So 3 A5 units were tried yesterday after I changed up the wiring. All 3 of them still had the imager error. One of the A5 units was tried in another car which has functioning pACC and there was no imager error. I am starting to think that the heating plate is broken.
Regarding the wiring, do we agree that from Z113 (heating plate) only one ground wire goes to the T12ar (plug for the R242) in cars from May 2016? Meaning that the shorter ground wire from the Z113 going to connection point 277 is void.
siLc
Tallinn, Estonia
C?ID=330192
If the heating plate is broken, there should be an "open circuit" DTC.
downtime
Finland
C?ID=280813
I think I might have a solution for the imager error. Do you have possibility to upload a dataset to the camera? I mean the other tool?
tamperfing
Denmark
C?ID=157812
Sure, I could arrange that.
tamperfing
Denmark
C?ID=157812
The pACC is now working :thumbs: All it took was countless tries with 5 different cameras :eek: Turns out that the 4 first cameras all were faulty (bought used ones). Finally, I decided to try with a brand new camera instead. Luckily, I found a reasonably priced one on Ebay. A brand new camera, however, offers an extra challenge, since it does not contain any data.
Rich (BB code):
The only thing I need to figure out now, is a minor problem with the Dynamic Road Sign Display. Whenever the ignition is turned off, the cluster forgets the last setting of the Road Sign Display - meaning I have to activate it on the 5f after each ignition for it to appear in the cluster.
