Hi to everyone on this beautiful forum, hope someone can help me with my issue, on this vw the TCU/TCM. was replaced new from the dealer. can someone help me with the long coding? and what are other procedures that need to be done on it? posting the log. thank you in advance.
Tuesday,22,September,2020,10:04:37:50448
VCDS Version: 20.4.2.0 HEX-NET CB: 0.4513.4
VIN: 3VW217AU8HM073610 License Plate: MODENA
Mileage: 12863km-7992mi Repair Order: modena
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 2B 3C 42 44 52 5F 75
VIN: 3VW217AU8HM073610 Mileage: 12863km-7992miles
2B-Steer. Col. Lock -- Status: Malfunction 0010
Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 K HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0003
Revision: --H13---
Coding: 091A00122424002F1000
Shop #: WSC 00066 790 00020
ASAM Dataset: EV_ECM18TFS0208V0906264K 001004
ROD: EV_ECM18TFS0208V0906264K.rod
VCID: 44C4B257CF5ECFA677-8010
Readiness: 0010 1101
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 158 AR HW: 09G 927 158
Component: AISIN AG6 G3 202 3198
Coding: 0100000000000000000000000000000000000000
ROD: EV_TCMAQ250031_002_VW23.rod
VCID: 0346714B8AD0089E0E-8056
Address 03: ABS Brakes (J104) Labels:* 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 614 517 AQ HW: 5Q0 614 517 AF
Component: ESC H62 0400
Revision: 00000000 Serial number: 51247000000231
Coding: 01FA6AA12427096F407D020180C32980562490024001943410405050C082430000000012121212B835351919323200
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
ROD: EV_Brake1UDSContiMK100ESP_036.rod
VCID: 004C7E479BC6138613-8054
16401 - Tire Pressure Warning
C102D 00 [137] - -
Reset counter: 193
Mileage: 12863 km
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0439820340
Coding: 032C0C
VCID: 3B36C9ABB2A0B05E06-806E
Part No SW: 5GM 907 426 E HW: 5GM 907 426 E
Component: AC Manuell H03 1801
Revision: 00001K04
Coding: 00020004200100000000000000000002
ROD: EV_ACManueBHBVW37X_004.rod
VCID: 4AD89C6FED7A19D68D-801E
262914 - Refrigerant Pressure
B10AB F0 [009] - Too Low
Reset counter: 191
Mileage: 12848 km
Date: 2012.08.14
Time: 04:23:26
Outside air temperature: 30.0 °C
Engine speed: 600 /min
Temperature after evaporator: 38.7 °C
System run time-Engine running time: 255 s
System run time-Terminal 15 on: 255 s
Part No SW: 5Q0 937 087 AN HW: 5Q0 937 087 AN
Component: BCM PQ37BOSCH 032 0223
Revision: -------- Serial number: C86416051701CL
Shop #: WSC 00066 790 00206
ROD: EV_BCMBOSCH_017.rod
VCID: 075E655BBEE824BE52-8052
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 170403 043 0551
Serial number: 97022066170422003327
Subsystem 2 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 042 0105
Serial number: S9Y17M04D21H01M58S41
Coding: 00A8DD
Sun Roof:
Subsystem 3 - Part No SW: 5GD 959 591 A HW: 5GD 959 591 A
Component: J245 PS60.006 H07 0170
Serial number: 03691602661902171118
Coding: 181803
558100 - Databus
[Airbag_02 Datenbus empfangener Fehlerwert]
Fault Frequency: 10
Reset counter: 233
Mileage: 12848 km
Date: 2012.08.14
Time: 05:00:39
722437 - Control Module for Power Sunroof
B13C6 54 [009] - Missing Calibration / Basic Setting
Reset counter: 191
Mileage: 12848 km
Date: 2012.08.14
Time: 04:23:34
Part No SW: 5Q0 907 572 H HW: 5Q0 907 572 H
Coding: 3500000101FFC428949C810500301600000000000000000000
VCID: 3C34CAB7B7AEB7660F-8068
2093 - Functional Restriction due to Brake Over-Temp
B106F F0 [008] - Unknown Error Elaboration
[FAULT_BRKOVHT_FAIL]
Reset counter: 231
Mileage: 12848 km
Date: 2012.08.14
Time: 04:23:39
Control Module temperature: 56 °C
Voltage terminal 15: 13.5 V
0863 - Databus
[FAULT_ESP_QBIT_WEGIMPULS]
Reset counter: 231
Mileage: 12848 km
Date: 2012.08.14
Time: 04:23:39
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM]
Reset counter: 231
Mileage: 12848 km
Date: 2012.08.14
Time: 04:23:39
0815 - Databus
[FAULT_ESP_WEGIMPULS_HL_ERROR]
Reset counter: 231
Mileage: 12848 km
Date: 2012.08.14
Time: 04:23:39
Serial number: 003GCR07ZA1P
VCID: 47DEA55BFE68E4BE92-8012
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000007ADPS0
Coding: 303135
Subsystem 2 - Part No SW: ----------- HW: 480 001 904 17
Serial number: 35700000000186C8032C
Subsystem 3 - Part No SW: ----------- HW: 480 001 904 17
Serial number: 35800000000CC591032H
Subsystem 4 - Part No SW: ----------- HW: 480 402 604 17
Serial number: 3510001B325DA8824695
Subsystem 5 - Part No SW: ----------- HW: 480 402 704 17
Serial number: 3520001B9254249512AW
Subsystem 6 - Part No SW: ----------- HW: 480 402 808 15
Serial number: 3550002A11CF1D348366
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 401 505 17
Serial number: 3560002AB24F3840C1CC
Part No SW: 5Q0 953 507 HL HW: 5Q0 953 549 E
Revision: -------- Serial number: 30041708490852
Coding: 0410
Part No SW: 5G1 920 840 B HW: 5G1 920 840 B
Component: KOMBI 244 8311
Coding: 0BA4191AA188CF0502886A095000000000000000
VCID: 260008DF59221DB649-8072
Component: GW MQB High 518 5286
Serial number: 19061700841241
Coding: 0101000870085900FA0000081C0F00000001050000000000000000000000
Shop #: WSC 00066 790 00067
ROD: EV_GatewNF_VW37.rod
VCID: 2F2EEDFB76D85CFEBA-807A
Subsystem 2 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0103
Serial number: 39170001251680037193
Coding: 31FFFF
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 17000100948007
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3424E2979FFE7F26C7-8060
13637378 - Databus
[Errorvalue ESP_Wegimpulse]
Fault Frequency: 7
Reset counter: 231
Mileage: 12848 km
Date: 2012.08.14
Time: 04:24:11
ELV State: 04
Information Clamps: 77 60
CoCo State: A0 01
WFS State: 08 06
Vehicle speed: 0.00 km/h
Voltage: 77
AD-Value H-bridge: 3A
Clamp15 flip flop: SSTx: button contacts: 06
CAN signals: 00
Component: HRE_Master H12 0071
Serial number: 0437420056
Coding: 01011103
ROD: EV_HREntryHella_VW37.rod
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H12 0071
Serial number: 0438632352
Coding: 010111
337792 - Databus
[ESP_10::ESP_QBit_Wegimpuls_HL - Ersatz_Init_oder_Fehlerwert]
Reset counter: 231
Mileage: 12848 km
Date: 2012.08.14
Time: 04:24:15
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 030617A0080649
Coding: 003013200000020000000000
VCID: 41CABB43D04CDA8E5C-8014
Serial number: 00000000000006687728
Coding: 011000
Part No SW: 5QM 909 144 A HW: 5QM 909 144 A
Component: EPS_MQB_ZFLS 171 1072
Coding: 0102
ROD: EV_SteerAssisMQB_013.rod
VCID: 4FEE8D7B16183CFEDA-801A
19716 - Databus
[ESP_10 Botschaft - SNA-Check]
Reset counter: 231
Mileage: 12848 km
Date: 2012.08.14
Time: 04:24:26
Motor status: 02
System status: Driving mode
Supply voltage: 13.50 V
Temperature: 43.0 °C
KFC: 4D
KFA: 00 04
Environmental conditions: 21
uioUdNotFilt_xdu16: 13.67 V
uAdSensI_SwitchedKl30_xdu16: 13.66 V
NoInitCause_AsicSens: [0x00] ASC_CTRL_SAS_NO_ERR
NoInitCause_RackPos_Rohwert: 00 00
RP_VALCNTSAV: not activated
RP_DIAGJOB: not activated
RP_RPS: not activated
RP_KMN_RACKPOS_SET: not activated
RP_STARTUP: not activated
RP_L2PLAUSI: not activated
RP_INDEXPLAUSI: not activated
RP_WHLSPDPLAUSI: not activated
RP_RUKUCNTR: not activated
RP_UNDERVOLT: not activated
RP_CNTERR: not activated
20228 - Databus
[ESP_19 Botschaft - SNA-Check]
Reset counter: 231
Mileage: 12848 km
Date: 2012.08.14
Time: 04:24:26
Motor status: 02
KFC: 4F
KFA: 00 04
uioUdNotFilt_xdu16: 13.50 V
uAdSensI_SwitchedKl30_xdu16: 13.51 V
Part No SW: 5Q0 959 392 E HW: 5Q0 959 392 B
Component: TSG BFS 020 0041
Serial number: 290517A0080EY2
VCID: 40CCBE47DB46D38653-8014
Serial number: 00000000000006513331
Coding: 091000
Part No SW: 3Q0 035 844 A HW: 3Q0 035 844 A
Component: MU-S-S-US 710 0753
Coding: 02730000FF00000051220001001808009F0100D40120010002
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 2D12F7F37CD42EEE88-8078
Subsystem 1 - Part No SW: 3G0 919 605 H HW: 3G0 919 605 H
Component: ABT_Std-2 H53 1031
Serial number: VWZ8Z9TJW02T94
0020 - Tuner for Satellite Radio
B11CF 53 [009] - Deactivated
Reset counter: 191
Mileage: 12848 km
Date: 2012.08.14
Time: 04:25:23
Voltage terminal 30: 13.6 V
SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
SDARS_tuner_status_2-Channel selection for satellite radio: 0
SDARS_tuner_status_2-Audio Signal: Available
SDARS_tuner_status_2-Antenna current: 146 mA
SDARS_tuner_status_2-Reception quality: optimum_signal
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
Component: OCULowMQBUS 007 0570
Coding: 02730002C2823A017F1E06000000
ROD: EV_OCULowMQB.rod
VCID: 43C6B14BCA50C89E4E-8016
End----------(Elapsed Time: 01:26, VBatt start/end: 12.2V/12.1V)-----------
