2017 VW GOLF 1.8 AUTO TCU/TCM replaced new
dd1
C?ID=826
Hi to everyone on this beautiful forum, hope someone can help me with my issue, on this vw the TCU/TCM. was replaced new from the dealer. can someone help me with the long coding? and what are other procedures that need to be done on it? posting the log. thank you in advance.
Tuesday,22,September,2020,10:04:37:50448
VCDS Version: 20.4.2.0  HEX-NET CB: 0.4513.4
VIN: 3VW217AU8HM073610   License Plate: MODENA
Mileage: 12863km-7992mi   Repair Order: modena
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 2B 3C 42 44 52 5F 75
VIN: 3VW217AU8HM073610   Mileage: 12863km-7992miles
Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 K    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 091A00122424002F1000
   Shop #: WSC 00066 790 00020
   ASAM Dataset: EV_ECM18TFS0208V0906264K 001004
   ROD: EV_ECM18TFS0208V0906264K.rod
   VCID: 44C4B257CF5ECFA677-8010
Readiness: 0010 1101
   Part No SW: 09G 927 158 AR    HW: 09G 927 158
   Component: AISIN AG6 G3  202 3198
   Coding: 0100000000000000000000000000000000000000
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW23.rod
   VCID: 0346714B8AD0089E0E-8056
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AQ    HW: 5Q0 614 517 AF
   Component: ESC           H62 0400
   Revision: 00000000    Serial number: 51247000000231
   Coding: 01FA6AA12427096F407D020180C32980562490024001943410405050C082430000000012121212B835351919323200
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
   ROD: EV_Brake1UDSContiMK100ESP_036.rod
   VCID: 004C7E479BC6138613-8054
16401 - Tire Pressure Warning
          C102D 00 [137] - -
                    Reset counter: 193
                    Mileage: 12863 km
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0439820340
   Coding: 032C0C
   VCID: 3B36C9ABB2A0B05E06-806E
   Part No SW: 5GM 907 426 E    HW: 5GM 907 426 E
   Component: AC Manuell    H03 1801
   Revision: 00001K04
   Coding: 00020004200100000000000000000002
   VCID: 4AD89C6FED7A19D68D-801E
262914 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
                    Reset counter: 191
                    Mileage: 12848 km
                    Date: 2012.08.14
                    Time: 04:23:26
                    Outside air temperature: 30.0 °C
                    Engine speed: 600 /min
                    Temperature after evaporator: 38.7 °C
                    System run time-Engine running time: 255 s
                    System run time-Terminal 15 on: 255 s
   Part No SW: 5Q0 937 087 AN    HW: 5Q0 937 087 AN
   Component: BCM PQ37BOSCH 032 0223
   Revision: --------    Serial number: C86416051701CL
   Shop #: WSC 00066 790 00206
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017.rod
   VCID: 075E655BBEE824BE52-8052
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    170403  043 0551
   Serial number: 97022066170422003327
   Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  042 0105
   Serial number: S9Y17M04D21H01M58S41
   Coding: 00A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5GD 959 591 A    HW: 5GD 959 591 A
   Component: J245 PS60.006  H07 0170
   Serial number: 03691602661902171118
   Coding: 181803
558100 - Databus
          [Airbag_02 Datenbus empfangener Fehlerwert]
                    Reset counter: 233
                    Mileage: 12848 km
                    Date: 2012.08.14
                    Time: 05:00:39
722437 - Control Module for Power Sunroof
          B13C6 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 191
                    Mileage: 12848 km
                    Date: 2012.08.14
                    Time: 04:23:34
   Part No SW: 5Q0 907 572 H    HW: 5Q0 907 572 H
   Coding: 3500000101FFC428949C810500301600000000000000000000
   VCID: 3C34CAB7B7AEB7660F-8068
2093 - Functional Restriction due to Brake Over-Temp
          B106F F0 [008] - Unknown Error Elaboration
          [FAULT_BRKOVHT_FAIL]
                    Reset counter: 231
                    Mileage: 12848 km
                    Date: 2012.08.14
                    Time: 04:23:39
                    Control Module temperature: 56 °C
                    Voltage terminal 15: 13.5 V
0863 - Databus
          [FAULT_ESP_QBIT_WEGIMPULS]
                    Reset counter: 231
                    Mileage: 12848 km
                    Date: 2012.08.14
                    Time: 04:23:39
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 231
                    Mileage: 12848 km
                    Date: 2012.08.14
                    Time: 04:23:39
0815 - Databus
          [FAULT_ESP_WEGIMPULS_HL_ERROR]
                    Reset counter: 231
                    Mileage: 12848 km
                    Date: 2012.08.14
                    Time: 04:23:39
   Serial number: 003GCR07ZA1P
   VCID: 47DEA55BFE68E4BE92-8012
   Occupant Detection:
   Serial number: IBH000000000007ADPS0
   Coding: 303135
   Subsystem 2 - Part No SW: -----------    HW: 480 001 904 17
   Serial number: 35700000000186C8032C
   Subsystem 3 - Part No SW: -----------    HW: 480 001 904 17
   Serial number: 35800000000CC591032H
   Subsystem 4 - Part No SW: -----------    HW: 480 402 604 17
   Serial number: 3510001B325DA8824695
   Subsystem 5 - Part No SW: -----------    HW: 480 402 704 17
   Serial number: 3520001B9254249512AW
   Subsystem 6 - Part No SW: -----------    HW: 480 402 808 15
   Serial number: 3550002A11CF1D348366
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 505 17
   Serial number: 3560002AB24F3840C1CC
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 30041708490852
   Coding: 0410
   Part No SW: 5G1 920 840 B    HW: 5G1 920 840 B
   Component: KOMBI         244 8311
   Coding: 0BA4191AA188CF0502886A095000000000000000
   VCID: 260008DF59221DB649-8072
   Component: GW MQB High   518 5286
   Serial number: 19061700841241
   Coding: 0101000870085900FA0000081C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 00067
   ROD: EV_GatewNF_VW37.rod
   VCID: 2F2EEDFB76D85CFEBA-807A
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0103
   Serial number: 39170001251680037193
   Coding: 31FFFF
   Revision: 00000000    Serial number: 17000100948007
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3424E2979FFE7F26C7-8060
13637378 - Databus
          [Errorvalue ESP_Wegimpulse]
                    Reset counter: 231
                    Mileage: 12848 km
                    Date: 2012.08.14
                    Time: 04:24:11
                    ELV State: 04
                    Information Clamps: 77 60
                    CoCo State: A0 01
                    WFS State: 08 06
                    Vehicle speed: 0.00 km/h
                    Voltage: 77
                    AD-Value H-bridge: 3A
                    Clamp15 flip flop: SSTx: button contacts: 06
                    CAN signals: 00
   Serial number: 0437420056
   Coding: 01011103
   ROD: EV_HREntryHella_VW37.rod
   Lane Change Assistant 2:
   Serial number: 0438632352
   Coding: 010111
337792 - Databus
          [ESP_10::ESP_QBit_Wegimpuls_HL - Ersatz_Init_oder_Fehlerwert]
                    Reset counter: 231
                    Mileage: 12848 km
                    Date: 2012.08.14
                    Time: 04:24:15
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 030617A0080649
   Coding: 003013200000020000000000
   VCID: 41CABB43D04CDA8E5C-8014
   Serial number: 00000000000006687728
   Coding: 011000
   Part No SW: 5QM 909 144 A    HW: 5QM 909 144 A
   Component: EPS_MQB_ZFLS  171 1072
   Coding: 0102
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 4FEE8D7B16183CFEDA-801A
19716 - Databus
          [ESP_10 Botschaft - SNA-Check]
                    Reset counter: 231
                    Mileage: 12848 km
                    Date: 2012.08.14
                    Time: 04:24:26
                    Motor status: 02
                    System status: Driving mode
                    Supply voltage: 13.50 V
                    Temperature: 43.0 °C
                    KFC: 4D
                    KFA: 00 04
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 13.67 V
                    uAdSensI_SwitchedKl30_xdu16: 13.66 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
20228 - Databus
          [ESP_19 Botschaft - SNA-Check]
                    Reset counter: 231
                    Mileage: 12848 km
                    Date: 2012.08.14
                    Time: 04:24:26
                    Motor status: 02
                    KFC: 4F
                    KFA: 00 04
                    uioUdNotFilt_xdu16: 13.50 V
                    uAdSensI_SwitchedKl30_xdu16: 13.51 V
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 290517A0080EY2
   VCID: 40CCBE47DB46D38653-8014
   Serial number: 00000000000006513331
   Coding: 091000
   Part No SW: 3Q0 035 844 A    HW: 3Q0 035 844 A
   Component: MU-S-S-US     710 0753
   Coding: 02730000FF00000051220001001808009F0100D40120010002
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2D12F7F37CD42EEE88-8078
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H53 1031
   Serial number: VWZ8Z9TJW02T94
          B11CF 53 [009] - Deactivated
                    Reset counter: 191
                    Mileage: 12848 km
                    Date: 2012.08.14
                    Time: 04:25:23
                    Voltage terminal 30: 13.6 V
                    SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
                    SDARS_tuner_status_2-Audio Signal: Available
                    SDARS_tuner_status_2-Antenna current: 146 mA
                    SDARS_tuner_status_2-Reception quality: optimum_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
   ROD: EV_OCULowMQB.rod
   VCID: 43C6B14BCA50C89E4E-8016
End----------(Elapsed Time: 01:26, VBatt start/end: 12.2V/12.1V)-----------
I don't suppose you have any scans from before the TCM was replaced? Check your Scans sub-folder.
I've not see a coding chart for this TCM. However, based on a search for other TCMs with this exact part number, I would try:
010200000C000000000000000000000000000000
dd1
C?ID=826
THANK YOU, i will give it a try. no, the original was gone, due to an accident it is missing.
dd1
C?ID=826
thank you, worked very well.
