Hi. Brand new user and complete novice. (MK60EC1)
Scott Chambers
Cowdenbeath. UK
C?ID=417855
Hi guys.
I’ve got an Audi A3 2010 2.0TFSI Cabriolet and the dashboard instrument cluster stopped working. Sent it away to get fixed and it came back a threw up a few errors regarding coding missing. How do I go about recoding finding the codes I need? Thanks in advance.
Scott Chambers
Cowdenbeath. UK
C?ID=417855
VIN: TRUZZZ8P791011495 Mileage: 77430km-48112miles
Address 01: Engine (CAW) Labels:. 06J-906-026-CAW.clb
Part No SW: 8P7 907 115 B HW: 8P0 907 115 J
Component: 2.0l R4/4V TFSI 0020
Revision: A7H06--- Serial number: AUX7Z0H9FND09U
Coding: 011B00031C070060
Shop #: WSC 01236 785 00200
VCID: 38292C532E57C6ABAA3-806C
South Molton, UK
We always for a complete unedited VCDS Auto-Scan not just an edited section like you have posted - without seeing the detail of ALL the fault codes we can't advise how to correct them :thumbs:
Scott Chambers
Cowdenbeath. UK
C?ID=417855
My bad. I watched the video afterwards. I’ll try and do it now. Apologies.
Scott Chambers
Cowdenbeath. UK
C?ID=417855
Tuesday,22,September,2020,17:59:28:17622
VIN: TRUZZZ8P791011495   License Plate:
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 26 42 44 46 47 52 56 62 72 77
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 000 - Implausible Signal - MIL ON
                    Fault Status: 11100000
                    Fault Frequency: 8
                    Mileage: 77276 km
                    Date: 2020.03.06
                    Time: 15:10:21
                    RPM: 3244 /min
                    Load: 42.7 %
                    Speed: 32.0 km/h
                    Temperature: 59.0°C
                    Temperature: 13.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.970 V
001674 - ECM Power Relay Load Circuit
               P068A - 000 - Opens Too Early - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 21.0°C
                    Temperature: 27.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 10.287 V
001378 - System Voltage
               P0562 - 000 - Too Low - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 17.0°C
                    Temperature: 23.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 8.382 V
Readiness: 0000 0001
   Part No SW: 02E 300 051 R    HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 1959
   Revision: 04844002    Serial number: 00000810310313
   VCID: 221DEE3B98CBBC7B647-8076
   Part No SW: 1K0 907 379 CE    HW: 1K0 907 379 AE
   Revision: 00H35001
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 43340 002 1048576
   VCID: 77ABEF6F6FC909D3639-8022
                    Reset counter: 144
                    Mileage: 77434 km
                    Date: 2020.08.12
                    Time: 22:39:07
                    Count: 7
                    Count: 14
                    Count: 12288
                    Count: 195
                    Count: 43008
                    Fault Status: 01100101
                    Reset counter: 144
                    Mileage: 77434 km
                    Date: 2020.08.12
                    Time: 22:39:07
                    Count: 7
                    Count: 14
                    Count: 12288
                    Count: 291
                    Count: 43008
   Part No SW: 8P0 820 043 BC    HW: 8P0 820 043 BC
   Component: KlimavollautomatH03 0110
   Revision: 291247      Serial number: 8P0820043BC
   VCID: 6E85CA0B1C93481BB0F-803A
Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
   Part No SW: 8P0 907 279 N    HW: 8P0 907 279 N
   Component: Bordnetz-SG     H54 2801
   Revision: 00H54000    Serial number: 00000009156740
   Coding: 91242E01B0141080EF00001C0000000000084E013301001F002000000000
   VCID: 48C95C935EB7B62BDA3-801C
   Subsystem 1 - Part No: 8P2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H10 0040
   Coding: 00056595
   Shop #: WSC 01236
00985 - Right Tail Light (M2)
                    Fault Status: 01101100
                    Reset counter: 144
                    Mileage: 77434 km
                    Date: 2020.08.12
                    Time: 22:39:00
                    Voltage: 11.80 V
Address 15: Airbags        Labels: 8P7-959-655.clb
   Part No SW: 8P7 959 655     HW: 8P7 959 655
   Component: SR Airbag 9.43  H01 0020
   Revision: 93H01002    Serial number: 003BS000JDVJ
   Coding: 0021330
   VCID: 065592AB1423605B68F-8052
   Subsystem 1 - Serial number: 6332DRB408830B09M
   Subsystem 2 - Serial number: 6342DRB4088609AB-
   Subsystem 3 - Serial number: 63747RB40491D2E1R
   Subsystem 4 - Serial number: 63847RB40491D0F0Q
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H36 0070
   Coding: 0011111
   VCID: 41DF41B77D8D87631DD-8014
   Component: E0221           H02 0030
   Part No SW: 8P0 920 982 E    HW: 8P0 920 982 E
   Component: KOMBIINSTR. VDO H18 0830
   Revision: D0H18006    Serial number: 2249H006004044
   Coding: 0000428
   Shop #: WSC 33922 001 1048576
   VCID: 3B23335F1F61EDB3471-806E
00003 - Control Module
            014 - Defective
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533__Gateway   H16 0210
   Revision:   H16       Serial number: 3400K08A03847A
   Coding: ED807F26100602009101
   VCID: 372B2F6F2349C9D3A39-8062
01304 - Radio
                    Reset counter: 144
                    Mileage: 77434 km
                    Date: 2020.08.12
                    Time: 22:39:12
   Revision: D0H18006    Serial number: AUX7Z0H9FND09U
Address 26: Auto Roof        Labels: Redir Fail!
   Part No: 8P7 959 255
   Component: VSG AUDI A3     H14 0100
   VCID: 025D8EBB380B5C7B447-8056
   Part No SW: 8P7 959 801 C    HW: 8P7 959 801 C
   Component: Tuer-SG         H02 0020
   Coding: 0000692
   VCID: 42DD4EBB788B9C7B047-8016
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 233    2301
   Revision: 00H15000
   VCID: 2A0D061BE0FB643B2C7-807E
                    Fault Status: 11100101
                    Mileage: 77434 km
                    Date: 2020.08.12
                    Time: 22:39:06
                    Battery Volts: 12.0 V
                        DD
                    Temperature: 24.0°C
                    Count: 3
                    Steering Angle: 0.00°
                        SteerAng n.Init
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 J
   Component:    KSG          H11 0080
   Coding: 1990200042386D09812D4C9ED633
   VCID: 43D34BBF679195730F1-8016
   Subsystem 2 - Part No: 8P7 951 177
   Component: DWA-Sensor      H03 0030
00332 - Control Circuit for Tank Flap
            007 - Short to Ground
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P7 035 382     HW: 8P7 035 382
   Component: AB2 SUBWOOFERBOXH06 0160
   Revision: 00005       Serial number: 30703841016292
   VCID: 74B1D86372BF62CB46B-8020
   Part No SW: 8P7 959 802 C    HW: 8P7 959 802 C
   Coding: 0000692
Address 56: Radio
   Part No SW: 8P7 959 811 A    HW: 8P7 959 811 A
   Component: Tuer-SG         H01 0030
   Coding: 0000144
   Shop #: WSC 01236 785 1012552
   Part No SW: 8P7 959 812 A    HW: 8P7 959 812 A
   Coding: 0000144
   Part No SW: 8P0 862 335 S    HW: 8P0 862 335 S
   Component: FSE_256x BT     H34 0550
   Revision: 00000000    Serial number: 00000005052464
   Coding: 0000102
   VCID: 46D552AB54A3A05B28F-8012
01304 - Radio
                    Reset counter: 144
                    Mileage: 77434 km
                    Date: 2020.08.12
                    Time: 22:39:06
End----(Elapsed Time: 01:24, VBatt start/end: 12.0V/12.0V. VIgn 0.0V)------
I guess you turned the ignition on while the cluster was out of the car?
I don't suppose you have any scans from before you pulled the cluster out? Check your Scans sub-folder.
Scott Chambers
Cowdenbeath. UK
C?ID=417855
I’m not sure. I paid a mechanic to do it. I’d like to think he did it properly. I don’t have any scans of before the cluster got taken out.
Scott Chambers
Cowdenbeath. UK
C?ID=417855
I re read that. Sorry yes I did turn the ignition on while the cluster was out. 😊
Teaching moment number 1: Always do an Auto-Scan before starting any work.
Teaching moment number 2: Doing that will cause an MK60EC1 to lose coding.
Hopefully someone here who is more up to speed on MK60EC1 codings than I am will be able to build a working coding for you.
Scott Chambers
Cowdenbeath. UK
C?ID=417855
Anybody got any ideas what I can do regarding next steps?
Boki Ar
Arandjelovac, Serbia
C?ID=57300
VIS: The following code has been computed for the control unit MK60EC1: 11424012092300FB880F02ED901E0042B900
You have new generation interface and can use VIS base.
