2007 toaureg no starter after motor swap
iambatman
C?ID=408958
just completed putting a new/rebuilt motor into my 2007 3.6 T1 Touareg, motor came from a reputable supplier with warranty. after we got everything buttoned up we have a no fire situation. the car had sat for 10 months and the battery had died so at first try it was hooked to a booster after sitting on charge for 5+ hours, i did an auto scan and got many many codes for low voltage and such as the ones that comes when battery dies, but also one for engine coolant temp sensor and one for signal line for fuel pump, and a bunch for ecu communications. today we tested both fuel pumps by hooking them direct to 12 volts with a brand new battery in it. the second scan shows the same, coolant temp sesnor, and signal line for fuel pump, all other ecu related ones cleared.
im at a loss here and dont know what to do next, there is a fuel pump control module that goes from the ecu to the module then to the fuel pumps, just like a mini ecu, perhaps thats the issue? looking for some insight befor i drop another 250 on parts that wont fix the issue. i will post the auto scan before and after new battery
Friday,18,September,2020,18:18:50:07410
[URL='http://www.Ross-Tech.com']www.Ross-Tech.com[/URL]
VIN: WVGZE77L17D017731   License Plate:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGZE77L17D017731   Mileage: 215280km-133768miles
Address 01: Engine        Labels: 03H-906-032-BLV.clb
   Part No SW: 03H 997 033 R    HW: 03H 906 032 E
   Component: T 3.6-FSI-LEV2  G00 2374
   Revision: --H05---    Serial number: VWZ3Z0F2515451
   Coding: 0001175
   Shop #: WSC 31414 790 00001
   VCID: 3C21314E6A7A68CB4EB-5184
000279 - Engine Coolant Temp. Sensor (G62)
               P0117 - 001 - Signal too Low
                    Fault Status: 01100001
                    Mileage: 215288 km
                    Temperature: 139.0°C
                    Temperature: 24.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 11.811 V
012425 - Signal Line for Fuel Pump Electronics
               P3089 - 004 - Electrical Malfunction
                    Mileage: 215288 km
                    RPM: 169 /min
                    Load: 86.2 %
                    Temperature: 24.0°C
                    Voltage: 10.668 V
Readiness: 0110 0101
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No SW: 09D 927 750 FF    HW: 09D 927 750 FF
   Component: AL 750 6A           1274
   Revision: 00H51000    Serial number:
   Coding: 0004216
   Shop #: WSC 08126 444 54583
   VCID: 77ABEE6213DC8B93639-5160
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 G
   Component: ESP ALLRAD MK25     0203
   Coding: 0014338
   VCID: 3D273C4A716061C3795-5184
Address 05: Acc/Start Auth.        Labels: None
   Part No SW: 7L0 909 135 A    HW: 5WK 485 01
   Component:    Kessy            6700
   Revision: 67006015    Serial number: VWZ3Z0F2515451
   Coding: 0000232
   VCID: 2F3B1602AB0C8353FB9-5184
7 Faults Found:
01176 - Key
00087 - Terminal 30 for Starting Relevant Consumers
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 T
   Component: CLIMAtronic R/L     4222
   Coding: 0020030
   VCID: 41DF40BA0D9805231DD-5184
            007 - Short to Ground
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 M
   Component:                     3003
   Coding: 0100575
   VCID: 46D553A624B6221B28F-5184
            010 - Open or Short to Plus
00576 - Terminal 15
   Part No: 3D0 909 601 H
   Component: 05 Airbag 8.4E++H01 0562
   Revision: BB38727     Serial number: 0009279>
   Coding: 0012341
   VCID: 2809FD1E8EE2D46B3A3-5184
   Subsystem 1 - Part No: 7L0 959 339 C
   Component: BF-Gewichtsens. 006 0008
                    Fault Frequency: 18
                    Reset counter: 39
02511 - Control Module for Seat Occupied Recognition (J706)
            008 - Implausible Signal - Intermittent - MIL ON
                    Fault Status: 10101000
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 H
   Coding: 0010031
   VCID: 44D149AE128A100B36B-5184
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 971 G
   Component: KOMBIINSTRUMENT RB8 2111
   Coding: 0007231
01517 - Control Module for Trailer/Towing Sensor (J345)
01304 - Radio
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: 70B9D57E76B2DCABA23-5184
00484 - Vehicle Position Recognition Control Module (J603)
01304 - Radio
Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
   Part No: 7L6 919 879 A
   Component: JCI PathPoint       2200
   VCID: 45D754AA19B02903215-5184
00926 - Terminal 30
00926 - Terminal 30
   Part No: 0AD 927 755 BE
   Component: TRANSFERCASE        0119
   VCID: 7F5B06423BECB3D32B9-5160
01312 - Powertrain Data Bus
   Part No: 7L0 959 760
   Component: Sitzverstellung     0702
   VCID: 77ABEE6213DC8B93639-5184
02341 - Position Sensor for Seat Fore/Aft Adjustment (G441)
            006 - Short to Plus - Intermittent
01915 - Lumbar Support Height Adjustment Sensor (G374)
Address 46: Central Conv.        Labels: 7L0-959-933.lbl
   Part No: 7L0 959 933 H
   Component: YM HSG              0400
   Coding: 0000085
   VCID: 41DF40BA0D9805231DD-4B3C
   Subsystem 1 - Part No: 7L0 959 701 G
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 G
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703 C
   Component: Tuersteuergeraet HL 0201
   Subsystem 4 - Part No: 7L0 959 704 C
   Component: Tuersteuergeraet HR 0201
18 Faults Found:
Address 55: Headlight Range        Labels: 7L6-907-357.lbl
   Part No SW: 7L6 907 357     HW: 7L6 907 357
   Component: AFS-Steuergeraet    0003
   Revision:   H09       Serial number:
   Coding: 0000007
   VCID: 78A9ED5E1EC284EB6A3-5184
   Subsystem 1 - Part No: ID-L fehlt    Labels: ID-55-01.CLB
   Component: AFS-Lst.-Modul l    ....
   Coding: 00000255
   Subsystem 2 - Part No: 7L6 941 330
   Component: AFS-Lst.-Modul r    X018
   Coding: 00000034
8 Faults Found:
02234 - Right Headlight Power Output Stage (J668)
                    Reset counter: 215
02233 - Left Headlight Power Output Stage (J667)
                    Fault Status: 11100100
                    Reset counter: 175
                    Reset counter: 212
                    Reset counter: 215
            000 - - - MIL ON
                    Fault Status: 11100000
                    Reset counter: 175
02656 - Power Output Stage for Left Headlight (J667); Not Coded
            000 - - - MIL ON
                    Reset counter: 175
02657 - Power Output Stage for Right Headlight (J668); Not Coded
            000 - - - MIL ON
                    Reset counter: 175
                    Fault Status: 11100101
                    Reset counter: 175
Address 56: Radio        Labels: 7L6-035-180-56.lbl
   Part No: 7L6 035 180 H
   Component: Radio DE2           0003
   Coding: 0001405
   VCID: 323D1F76B83EAEBB947-5184
00850 - Control Output Active; Radio Amplifier
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L0 955 119 K
   Component: Front Wiper         4027
   Coding: 0000341
   Shop #: WSC 31414 790 376833
   Subsystem 2 - Part No: 1K0 955 559 AB  Labels: 1K0-955-559-AF.CLB
   Component: RLS     071006 020  0105
   Coding: 00208933
   Shop #: WSC 31414
Address 6D: Trunk Elect.        Labels: 7L6-959-107.clb
   Part No SW: 7L6 959 107     HW: 7L6 959 107
   Component: J605  HECKKLAPPE    1110
   Revision: --H05---    Serial number: --------005023
   Coding: 0022110
03234 - Functionality Limited due to Critical Electrical Condition
                    Fault Frequency: 22
                    Reset counter: 109
03277 - Functionality Limited due to Missing Stand-Time Data
                    Reset counter: 24
                    Fault Status: 00100001
                    Reset counter: 109
                    Reset counter: 89
                    Reset counter: 105
Address 6E: Ctrl Head Roof        Labels: None
   Part No: 7L6 919 044 T
   Component: DACHDISPLAY         0539
   Revision: 00900539    Serial number: 2009289.07
   VCID: 48C95D9E2EA2346BDA3-5184
   Part No: 7L0 919 283 F
   Component: 0E Einparkhilfe     1107
   VCID: 392F285A65485DE355D-5184
End----(Elapsed Time: 08:39, VBatt start/end: 11.7V/11.6V. VIgn 11.5V)-----
Monday,21,September,2020,16:56:18:07410
   Coding: 0001175
                    Mileage: 215288 km
                    Temperature: 20.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 12.319 V
                    Mileage: 215288 km
                    RPM: 194 /min
                    Load: 94.5 %
                    Temperature: 20.0°C
                    Voltage: 11.303 V
   Coding: 0004216
   Coding: 0014338
   Coding: 0000232
   Coding: 0020030
   Component:                     3003
   Coding: 0100575
00967 - Left Turn Signals
01494 - Bulb for Parking Lamps; Left (M1)
01495 - Bulb for High-Beams; Left (M30)
   Coding: 0012341
   Coding: 0010031
   Coding: 0007231
00771 - Fuel Level Sensor (G)
   Coding: 0000006
   Coding: 0000085
   Coding: 0000007
   Coding: 00000255
   Coding: 00000034
            000 - - - MIL ON
                    Reset counter: 175
            000 - - - MIL ON
                    Reset counter: 175
            000 - - - MIL ON
                    Reset counter: 175
                    Reset counter: 175
                    Reset counter: 175
01328 - Convenience System Data Bus
                    Fault Status: 11101101
                    Reset counter: 175
   Coding: 0001405
   Coding: 0000341
   Coding: 00208933
   Shop #: WSC 31414
   Coding: 0022110
End----(Elapsed Time: 08:30, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
Controller Software Versions:
ECU 1 = Engine        2374
ECU 2 = Auto Trans        1274
ECU 3 = ABS Brakes        0203
ECU 4 = Acc/Start Auth.        670
Sub ECU 4 > 1 = Acc/Start Auth.        XXX
ECU 5 = Auto HVAC        4222
ECU 6 = Cent. Elect.        3003
ECU 7 = Airbags        0562
Sub ECU 7 > 1 = Airbags        6000
ECU 8 = Steering wheel        3401
ECU 9 = Instruments        Labels:
ECU 10 = CAN Gateway        0101
ECU 11 = Position Sensing        22
ECU 12 = AWD        0119
ECU 13 = Seat Mem. Drvr        0702
ECU 14 = Central Conv.        0400
Sub ECU 14 > 1 = Central Conv.        S020
Sub ECU 14 > 2 = Central Conv.        F020
Sub ECU 14 > 3 = Central Conv.        L020
Sub ECU 14 > 4 = Central Conv.        R020
ECU 15 = Headlight Range        000
Sub ECU 15 > 1 = Headlight Range        ...
Sub ECU 15 > 2 = Headlight Range        X01
ECU 16 = Radio        0003
ECU 17 = Wiper Electr.        4027
Sub ECU 17 > 1 = Wiper Electr.        0105
ECU 18 = Trunk Elect.        1110
ECU 19 = Ctrl Head Roof        0539
ECU 20 = Park Assist        1107
Jef
HQ
Time to break out the wiring diagrams. Coolant temp sensor, G62, this can be due to an open circuit. Need to ohm test the sensor itself as well as the wiring back to the ECM.
Same thing with the Fuel Pump Control Module, J538. Do you have good power and ground at /3 and /4? Is /5 a good electrical path back to the ECM? Also, when you hotwire the lift pump directly, how many amps does it draw?
iambatman
C?ID=408958
First let me apologize for my spelling, I am by no means illiterate. I wrote this is a hurry and while he flustered over this TREG, Everything seems to be getting power as it should, went over all the fuse and relay boxes and tested every fuse location. My mechanic tested to the pumps so I’m not sure what it was drawing, I’ll look into that tomorrow. I have been attempting to locate all the ground locations but can’t find anything online. Everything was working as it should before the motor swap,that leads me to believe it’s related. I ran readiness tests, all cycled. My mechanic said something about the fuel pump control module not sending a signal to the fuel pump, he had a diagram and the wire from the module to ecu had 12v but the wire from module to pumps had nothing, to me that means either the sensor is bad or the ecu is telling the module not to run the fuel pumps?
NostraJackAss
Clear codes, reboot car with battery Jesus and investigation of terminal 15 and fresh auto scan?
iambatman
C?ID=408958
The second scan was a brand new battery after codes have been cleared
