CJKERRZO1
- Sep 15, 2020
- 8
- 1
- Dundee, UK
- HN1 (2nd hand)
Would anyone be able to check coding for this abs module as i cant seem to generate the correct one?
Monday,21,September,2020,15:45:05:17039
VCDS Version: 20.4.2.0 (x64) HEX-NET CB: 0.4526.4
VIN: WVWZZZAUZEW103207 License Plate: AREK VWCODING
Mileage: 24394km-15157mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEW103207 Mileage: 24394km-15157miles
Address 01: Engine (J623-CHPA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 016 G HW: 04E 907 309 A
Component: 1,4l R4 TSI H08 5761
Revision: WAH08---
Coding: 01250032242405082000
ASAM Dataset: EV_ECM14TFS01104E906016G 002008
ROD: EV_ECM14TFS01104E906016G.rod
VCID: 2600261E59A582B649-8072
17158 - Databus
U1123 00 [039] - Received Error Message
Mileage: 24394 km
Date: 2020.03.30
Time: 23:14:34
Engine speed: 0.00 /min
Coolant temperature: 16 °C
Intake air temperature: 18 °C
Voltage terminal 30: 12.133 V
Mass flow through throttle valve: 0.0 kg/h
Median injection timing: 0.000 ms
Engine operating condition: Idling
4716 - No Communications with Parking Brake Control Module
U0128 00 [039] - -
Mileage: 24394 km
Date: 2020.03.29
Time: 23:04:34
Coolant temperature: 14 °C
Intake air temperature: 15 °C
Voltage terminal 30: 12.015 V
selected gear-Bits 0-7: 0
Readiness: 1110 0001
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 045 HW: 0AM 927 769 G
Component: GSG DQ200-MQB H43 4530
Revision: 00043014 Serial number: CU501308047084
ROD: EV_TCMDQ200021_VW31.rod
VCID: 76A0365EC985B23639-8022
21221 - No Communications with Parking Brake Control Module
U0128 00 [011] - -
Fault Frequency: 8
Mileage: 24394 km
Date: 2020.03.29
Time: 23:04:35
Engine speed: 63.75 /min
Engine torque: 920 Nm
Vehicle speed: 255 km/h
Control Module temperature: 215 °C
CURRENT pressure: -10.0 bar
selected gear: GANG_6
Driving position: N
Accelerator position: 100.0 %
DTC memory status: 65280
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 62243000000DE6
ROD: EV_Brake1UDSContiMK100IPB_033.rod
VCID: 7BB6276AF2A7EF5E46-802E
13 Faults Found:
0195 - Control module not coded
U1013 00 [137] - -
[ECU marked as Not Configured because vehicle ID is invalid]
Reset counter: 114
Date: 2020.03.23
Time: 23:27:11
C1017 54 [137] - Missing Calibration / Basic Setting
Reset counter: 114
Date: 2020.03.23
Time: 23:27:11
C1079 54 [137] - Missing Calibration / Basic Setting
Reset counter: 114
Date: 2020.03.23
Time: 23:27:11
0279 - Brake Pressure Sensor 1
C107A 54 [137] - Missing Calibration / Basic Setting
Reset counter: 114
Date: 2020.03.23
Time: 23:27:11
0295 - Steering angle sensor
B1168 54 [008] - Missing Calibration / Basic Setting
Reset counter: 154
Date: 2020.03.23
Time: 23:27:11
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Reset counter: 155
Mileage: 24391 km
Date: 2020.03.23
Time: 23:29:42
0398 - Control Module Incorrectly Coded
U1014 00 [009] - -
[Vehicle equipped with vacuum sensor but no vacuum sensor coded]
Reset counter: 114
Mileage: 24391 km
Date: 2020.03.23
Time: 23:27:13
4161 - Coding invalid
U10DA 00 [008] - -
[mismatch between VIN on CAN and VIN in coding word]
Reset counter: 116
Mileage: 24394 km
Date: 2020.03.30
Time: 23:19:27
8278 - Control Module Incorrectly Coded
U1014 00 [137] - -
[FCAN: Mismatch between bytecoding and Lenkerposition signal]
Reset counter: 114
Date: 2020.03.23
Time: 23:27:11
8290 - Coding Not Possible
U10BC 00 [137] - -
[FCAN: Unplausible VIN number]
Reset counter: 114
Mileage: 24391 km
Date: 2020.03.23
Time: 23:27:16
8306 - Databus
U1122 00 [137] - Implausible Message
Reset counter: 114
Mileage: 24391 km
Date: 2020.03.23
Time: 23:27:16
8308 - Control Module Incorrectly Coded
U1014 00 [009] - -
[FCAN: StartStop not coded but MO_StartStopp_Status not equal 0]
Reset counter: 116
Date: 2020.03.23
Time: 23:27:11
32848 - Control Module for Electric Parking Brake
C10E2 F1 [137] - Switches/Motors Detected
Reset counter: 114
Date: 2020.03.23
Time: 23:27:11
Part No SW: 5G0 907 044 T HW: 5G0 907 044 T
Component: Climatronic H02 0705
Revision: 00001K06
Coding: 00120004200100001005000012101800
VCID: 383CF86683110446EB-806C
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 S HW: 5Q0 937 084 S
Component: BCM MQBAB M H14 0112
Serial number: 00011323300535
Coding: 03001842C24102FB4BE4400000040308100A000000000000000000000000
ROD: EV_BCMBOSCH_011.rod
VCID: 48DC88A6F3F174C69B-801C
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 130802 042 0551
Serial number: 130816035328
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M08D14H19M09S07S1
Coding: 00A8DD
204549 - Remote key 2
B147A 54 [008] - Missing Calibration / Basic Setting
Reset counter: 156
Mileage: 24394 km
Date: 2020.04.01
Time: 06:44:53
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H02 0033
Revision: -------- Serial number: 94231323101379
Coding: 0031151011
ASAM Dataset: EV_EPHVA18AU3700000 002019
VCID: 3B36E76AB2272F5E06-806E
12658704 - Databus
[Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
Reset counter: 114
Mileage: 24391 km
Date: 2020.03.23
Time: 23:27:11
13637426 - Databus
Reset counter: 114
Mileage: 24391 km
Date: 2020.03.23
Time: 23:27:11
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 014 0385
Serial number: 003F6R003A4P
Coding: 98CCC000000000005C00000000C800000065
VCID: 41CA9582D0CB458E5C-8014
Subsystem 1 - Part No SW: ----------- HW: 480 001 508 13
Serial number: 35767000000B91388D0
Subsystem 2 - Part No SW: ----------- HW: 480 001 508 13
Serial number: 35867000000AF1896D05
Subsystem 3 - Part No SW: ----------- HW: 480 402 408 13
Serial number: 3516502B110EDE41E31D
Subsystem 4 - Part No SW: ----------- HW: 480 402 408 13
Serial number: 3526502C71088B01029$
Subsystem 5 - Part No SW: ----------- HW: 480 402 608 13
Serial number: 3556502B110EDE42028A
B13BC F2 [137] - No function
Mileage: 24394 km
Date: 2020.03.29
Time: 23:07:14
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0085
Revision: FF026026 Serial number: 20130816400059
Coding: 0400
ASAM Dataset: EV_SMLSVALEOMQB 001011
ROD: EV_SMLSVALEOMQB.rod
VCID: 3FCE937AA63F337E2A-806A
Part No SW: 5G0 920 861 HW: 5G0 920 861
Component: KOMBI 204 3390
Coding: 27A419082380000800086A00040000
ASAM Dataset: EV_DashBoardJCIMQBAB 008011
ROD: EV_DashBoardJCIMQBAB_008.rod
VCID: 6680661E992542B689-8032
16776967 - Databus
[EPB_02 keine Kommunikation]
Reset counter: 114
Mileage: 24391 km
Date: 2020.03.23
Time: 23:27:10
16776973 - Databus
[RKA_01 keine Kommunikation]
Reset counter: 114
Mileage: 24391 km
Date: 2020.03.23
Time: 23:27:10
Part No SW: 5Q0 907 530 L HW: 5Q0 907 530 E
Component: GW MQB Mid 124 1144
Revision: -------- Serial number: 0000875090
Coding: 030100342B086400EF0006481C0F00010001000000000000000000000000
ROD: EV_GatewLear_009.rod
VCID: 3A38E26EBD1D16561D-806E
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J Labels: 3C8-959-537.CLB
H14 0035
Serial number: 27130001279130073322
Coding: 28FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 3774991103
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 04081304080323
Coding: 003A03208001040000000000
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000002416554
Coding: 0D0000
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 M
Component: EPS_MQB_ZFLS 127 1021
Coding: 01
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D32E972AC33216E38-8068
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 10081304080705
Coding: 003A03208E01040000800000
VCID: 3E30EE7EA1353A7621-806A
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000002460316
Coding: 050000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 846 A HW: 5G0 035 846 A
Component: MU-S-N-ER 040 0421
Serial number: V1F02508131172
Coding: 02730008FF00000011510001000900001F0100960100010245
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 271E2B1A5EAF9BBE72-8072
Subsystem 1 - Part No SW: 5G0 919 605 D HW: 5G0 919 605 D
Component: ABT_Std_Nav H51 0022
Serial number: VWZ8Z9NJ900K09
Subsystem 2 - Part No SW: 5G0 919 866 A HW: -----------
Component: ROW 2013 --- 0022
End----(Elapsed Time: 01:08, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
