AFS Control Module Jetta
DoubleXDeezy
Australia
C?ID=406852
I've installed Bixenon headlights and AFS in my 2013 Jetta, I've done a pretty good job of it so far for someone who has never done anything like this. The problem I have now is the AFS control module that I purchased has the parameters for a Passat on it so it's not working (l know, rookie error), I have found a Jetta AFS control module but it is from a US version Jetta, will it work correctly on my AU version Jetta? or are there differences in LHD and RHD modules?
Hi and welcome.
Please post an Auto-Scan for context.
I'm not aware of any difference in AFS modules between RHD and LHD cars. Of course the headlights themselves are different...
DoubleXDeezy
Australia
C?ID=406852
 Tuesday,22,September,2020,21:38:07:52456
VIN: WVWZZZ16ZDM082048   License Plate:
Chassis Type: 16-VW32 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 55 56 62 72
          77
VIN: WVWZZZ16ZDM082048   Mileage: 136670km-84922miles
2E-Media Player 3 -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Malfunction 1010
Address 01: Engine (CCZ)       Labels:. 06J-907-115-CCZ.clb
   Part No SW: 06J 906 027 DN    HW: 06J 907 309 A
   Component: MED17.5.2           2578
   Revision: P3H07---    Serial number:
   Coding: 0403000C1C070160
   Shop #: WSC 00066 000 00000
   VCID: 7AADF762F0D3975B1C7-802E
001089 - EVAP Emission Control Sys
               P0441 - 000 - Incorrect Flow - Intermittent
                    Mileage: 136471 km
                    Date: 2015.01.21
                    Time: 00:27:39
                    RPM: 761 /min
                    Load: 18.4 %
                    Temperature: 72.0°C
                    Temperature: 27.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.970 V
000604 - Fuel Pump Control Module
               P025C - 000 - Short to Ground - Intermittent
                    Temperature: -40.0°C
                    Voltage: 11.684 V
001378 - System Voltage
               P0562 - 000 - Too Low - Intermittent
                    Mileage: 136433 km
                    Date: 2015.01.09
                    Time: 00:00:01
                    Speed: 255.0 km/h
                    Temperature: 11.0°C
                    Temperature: 16.0°C
                    Voltage: 6.604 V
001674 - ECM Power Relay Load Circuit
               P068A - 000 - Opens Too Early - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 10.0°C
                    Temperature: 11.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 11.303 V
   Part No SW: 02E 300 058 N    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3520
   Revision: 05651213    Serial number: 00001302110744
   Shop #: WSC 02069 000 90108
   VCID: 2517F41E29EDC8A3015-8070
   Revision: 00H31001
   Coding: A63B60F8092A00FC650B06E890210081251000
   VCID: 7DA7FC7EEDFDA063395-8028
                    Reset counter: 22
                    Mileage: 136433 km
                    Date: 2015.01.09
                    Time: 00:01:22
                    Count: 7
                    Count: 15
                    Count: 12288
                    Count: 128
                    Count: 23552
                    Count: 1
02846 - Button for Tire Pressure Monitoring Display (E492)
                    Reset counter: 27
                    Mileage: 136355 km
                    Date: 2014.12.20
                    Time: 00:00:31
                    Count: 16391
                    Count: 12
                    Count: 24832
                    Count: 157
                    Count: 43776
02214 - Tire Pressure Warning
                    Reset counter: 55
                    Mileage: 136284 km
                    Date: 2014.12.03
                    Time: 14:13:26
                    Count: 32768
                    Count: 12800
                    Count: 397
                    Count: 50689
                    Count: 65024
   Part No SW: 3AA 907 044 AG    HW: 3AA 907 044 AG
   Component: Climatronic   H03 0303
   Revision: 00001K02
   Coding: 0010002002
   Shop #: WSC 00066 000 00121
   ROD: EV_ClimaAutoBasis_VW32.rod
   VCID: 75B7E45ED54DF823715-8020
13635840 - Supply voltage
          [Versorgungsspannung - unterer Grenzwert unterschritten]
                    Reset counter: 21
                    Mileage: 136433 km
                    Date: 2020.08.18
                    Time: 00:06:11
   Part No SW: 5K0 937 086 M    HW: 5K0 937 086 M
   Component: BCM PQ35 M    021 0068
   Revision: BC021001
   Coding: 00000A3AD82D00C040880080340089C803E5008871A08D60E48408040040
   Shop #: WSC 00066 123 12345
   VCID: 3E253B72A07B7B7B60F-806A
   Component: RLS 060313 05  54  0403
   Coding: 06300A
17 Faults Found:
                    Fault Frequency: 12
                    Reset counter: 21
                    Mileage: 136433 km
                    Date: 2015.01.09
                    Time: 10:22:09
                        Term 15 Off
                    Voltage: 7.00 V
                    Reset counter: 21
                    Mileage: 136433 km
                    Date: 2015.01.09
                    Time: 00:00:03
                        Term 15 Off
                    Voltage: 6.60 V
                    Fault Status: 00100111
                    Reset counter: 27
                    Mileage: 136471 km
                    Date: 2015.01.21
                    Time: 00:17:33
                    Voltage: 14.10 V
                    Fault Status: 00101010
                    Reset counter: 21
                    Mileage: 136355 km
                    Date: 2014.12.25
                    Time: 21:13:45
                    Voltage: 14.05 V
                    Reset counter: 27
                    Mileage: 136471 km
                    Date: 2015.01.21
                    Time: 00:17:33
                    Voltage: 14.10 V
                    Reset counter: 21
                    Mileage: 136433 km
                    Date: 2015.01.09
                    Time: 00:03:07
                        Term 15 Off
                    Voltage: 11.50 V
00984 - Left Tail Light (M4)
                    Fault Status: 01101010
                    Fault Frequency: 33
                    Reset counter: 18
                    Mileage: 136279 km
                    Date: 2014.12.02
                    Time: 16:32:25
                    Voltage: 11.40 V
00985 - Right Tail Light (M2)
                    Fault Frequency: 33
                    Reset counter: 18
                    Mileage: 136279 km
                    Date: 2014.12.02
                    Time: 16:32:25
                    Voltage: 11.40 V
                    Fault Frequency: 78
                    Reset counter: 18
                    Mileage: 136355 km
                    Date: 2014.12.25
                    Time: 21:13:45
                    Voltage: 13.90 V
01495 - Bulb for High-Beams; Left (M30)
                    Reset counter: 236
                    Mileage: 136355 km
                    Date: 2014.12.25
                    Time: 21:13:45
                    Voltage: 13.90 V
                    Fault Frequency: 76
                    Reset counter: 18
                    Mileage: 136433 km
                    Date: 2015.01.09
                    Time: 00:05:34
                    Voltage: 11.05 V
                    Reset counter: 236
                    Mileage: 136433 km
                    Date: 2015.01.09
                    Time: 00:05:34
                    Voltage: 11.05 V
                    Reset counter: 27
                    Mileage: 136355 km
                    Date: 2014.12.26
                    Time: 00:39:11
                    Voltage: 14.00 V
                    Reset counter: 236
                    Mileage: 136355 km
                    Date: 2014.12.25
                    Time: 21:13:45
                    Voltage: 13.95 V
                    Reset counter: 236
                    Mileage: 136433 km
                    Date: 2015.01.09
                    Time: 00:05:38
                    Voltage: 11.10 V
                    Fault Frequency: 70
                    Reset counter: 242
                    Mileage: 136355 km
                    Date: 2014.12.25
                    Time: 21:13:47
                    Voltage: 14.25 V
                    Fault Frequency: 69
                    Reset counter: 242
                    Mileage: 136433 km
                    Date: 2015.01.09
                    Time: 00:02:37
                    Voltage: 11.25 V
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 5C6 919 475     HW: 7E0 919 475 A
   Component: PARKHILFE 8K  H10 0005
   Revision: --------    Serial number: 07381311300548
   Coding: 308101
   Shop #: WSC 00066 123 00121
   ASAM Dataset: EV_EPHVA18VW3610000 001003
   ROD: EV_EPHVA18VW3610000.rod
   VCID: 71BFD04EA125D403ADD-8024
          U1400 00 [008] - -
          [Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten]
                    Fault Frequency: 11
                    Reset counter: 21
                    Mileage: 136433 km
                    Date: 2020.08.18
                    Time: 02:00:26
   Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
   Component: AirbagVW10    013 0613
   Serial number: 003G6M0994RA
   Coding: 00003245
   Shop #: WSC 00066 790 00187
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 323D1F4264A3AF1B947-8066
   Serial number: 3572MSME371A7672ZZZ-
   Serial number: 3582MSME071A7672ZZZY
   Serial number: 3516KSME5B401223ZZZH
   Serial number: 3526KSME425F1223ZZZO
          [Powersupply  lower threshold fall short of]
                    Reset counter: 21
                    Mileage: 136433 km
                    Date: 2020.08.18
                    Time: 00:06:11
   Part No SW: 1K5 953 507 T    HW: 5K0 953 549 B
   Component: Lenks.Modul   008 0090
   Revision: --------    Serial number:  90440MBB001C8
   Coding: 0892140000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 42DD4F82D4031F9B047-8016
   Subsystem 1 - Part No SW: 5G0 959 442 L    HW: 5G0 959 442 L
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29170002178680037413
   Coding: A40000
114178 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 21
136194 - Supply voltage
                    Reset counter: 21
147464 - Terminal 15
          B1148 29 [008] - Signal Implausible
   Part No SW: 5C6 920 872     HW: 5C6 920 872
   Component: KOMBI         H07 0705
   Coding: 171F01
   VCID: 6A8DC7228CF327DBEC7-803E
13639168 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Leuchtweitenregelung: keine Kommunikation]
                    Reset counter: 29
                    Mileage: 136433 km
                    Date: 2020.08.18
                    Time: 08:36:48
          [Supply voltage too low]
                    Reset counter: 21
   Part No SW: 7N0 907 530 AF    HW: 7N0 907 530 AF
   Component: J533  Gateway H52 1634
   Revision:   H52       Serial number: 08041303270901
   Coding: 351003
   VCID: 74B1D95ADEB7E12B46B-8020
                    Fault Status: 00110100
                    Reset counter: 28
                    Mileage: 136433 km
                    Date: 2015.01.09
                    Time: 08:36:44
00469 - Infotainment Databus in Single Wire Operation
                    Reset counter: 18
                    Mileage: 135991 km
                    Date: 2014.11.17
                    Time: 20:32:56
                    Mileage: 136433 km
                    Date: 2015.01.09
                    Time: 00:00:18
                    Reset counter: 20
                    Mileage: 136433 km
                    Date: 2015.01.09
                    Time: 00:02:05
03272 - Control Module for Audio Interface
                    Reset counter: 209
                    Mileage: 135991 km
                    Date: 2014.11.17
                    Time: 20:32:60
   Component: IMMO          H07 0705
Address 2E: Media Player 3
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0515
   Revision: 12110009    Serial number: 0006573464
   Coding: 0012F7
   Shop #: WSC 01383 790 50316
   VCID: 1C61D1FA1627096BAEB-8048
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 704 B    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  009 1508
   Serial number: 00000007739351
   Coding: 0002D0
          B11EC 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 24
66304 - Switch for Drivers Side Window Regulator
          B11F0 29 [008] - Signal Implausible
                    Mileage: 136570 km
                    Date: 2020.09.13
                    Time: 10:47:46
67074 - Motors for Central Locking
          B122B 01 [008] - Electrical Failure
                    Fault Frequency: 162
                    Reset counter: 58
                    Mileage: 135991 km
                    Date: 2020.06.26
                    Time: 20:58:26
67330 - Switch for Central Locking
          B122D 29 [008] - Signal Implausible
                    Fault Frequency: 205
                    Reset counter: 58
                    Mileage: 135991 km
                    Date: 2020.06.26
                    Time: 20:58:26
65793 - Supply voltage
          [Front DCU undervoltage]
                    Reset counter: 21
131329 - Rear Door Control Module
          B11ED F0 [008] - Supply Voltage too Low
                    Reset counter: 21
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 69     3305
   Revision: 00H22000
   VCID: 372B2E5683414A33A39-8062
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0515
   Revision: 14110009    Serial number: 0006580810
   Coding: 0013F6
   VCID: 1D67DCFE0D3D0063595-8048
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 703 B    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  008 1508
   Serial number: 00000007717733
   Coding: 0002D0
                    Reset counter: 21
                    Reset counter: 21
   Component: AFS-ECU       H04 0111
   Coding: 021200000B000200
   Shop #: WSC 05311 115 00000
   VCID: 372B2E568FC14A33A39-8062
   Subsystem 1 - Part No: 5N0 941 329   Labels: 3D0-941-329.CLB
   Subsystem 2 - Part No: 5N0 941 329   Labels: 3D0-941-329.CLB
9 Faults Found:
          U1014 00 [137] - -
          [Steuergeraet falsch kodiert]
                    Reset counter: 236
5276145 - Power Output Module for Left Headlamp
          C1081 F1 [137] - Incorrectly Coded
                    Reset counter: 236
5276401 - Power Output Module for Right Headlamp
          C1082 F1 [137] - Incorrectly Coded
                    Reset counter: 236
                    Reset counter: 21
                    Mileage: 136433 km
                    Date: 2020.08.18
                    Time: 00:03:05
13678592 - Local Data Bus
          U10B8 00 [008] - Defective
                    Reset counter: 95
13679104 - Local Data Bus
          U10BA 00 [008] - No Communication
                    Fault Frequency: 111
                    Reset counter: 21
5275926 - Power Output Module for Left Headlamp
          C1081 16 [008] - Voltage Too Low
                    Reset counter: 21
                    Mileage: 136433 km
                    Date: 2020.08.18
                    Time: 01:33:18
5276182 - Power Output Module for Right Headlamp
          C1082 16 [008] - Voltage Too Low
                    Reset counter: 21
                    Mileage: 136433 km
                    Date: 2020.08.18
                    Time: 01:33:18
13705475 - Databus
          [Timeout mMotor_1]
                    Reset counter: 21
   Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
   Component: Radio         541 5515
   Revision: --------    Serial number: VWZZZ4P5100132
   Coding: 16000440040000
   VCID: 46D55392F8AB23BB28F-8012
00856 - Radio Antenna
                    Fault Status: 01100111
                    Reset counter: 209
                    Mileage: 135991 km
                    Date: 2014.11.17
                    Time: 20:33:47
                    Reset counter: 21
   Part No SW: 7P6 035 730 J    HW: 7P6 035 730 J
   Revision: 1B001001    Serial number: 00007664342464
   Coding: 0A01000000010101
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 392F286EB9D55C4355D-806C
          B104F 13 [009] - Short to GND
                    Reset counter: 151
                    Mileage: 134753 km
                    Date: 2020.04.11
                    Time: 11:35:09
          B104E 13 [009] - Short to GND
                    Reset counter: 151
                    Mileage: 134753 km
                    Date: 2020.04.11
                    Time: 11:35:09
          [Klemme 30: unterer Grenzwert unterschritten]
                    Reset counter: 21
                    Mileage: 136433 km
                    Date: 2020.08.18
                    Time: 00:05:13
          U1400 00 [008] - -
                    Reset counter: 21
                    Mileage: 136433 km
                    Date: 2020.08.18
                    Time: 00:01:06
End----(Elapsed Time: 01:24, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
Although I am not certain that this module is compatible with the car, I would start by changing the first byte of the coding from Passat to Jetta and see where that gets you. Use Long Coding Helper for this.
DoubleXDeezy
Australia
C?ID=406852
I get the uninitialized control module message and Coding Rejected, error 31 request out of range
downtime
Finland
C?ID=280813
I think this same solution applies to you as well : https://forums.ross-tech.com/index.php?threads/15665/
And according to ETKA no difference in US, RoW, AU or CDN cars on headlight range control module. So you should be safe to buy it even it's from US Jetta.
