P2015 and P2004 on my 2013 VW Tiguan
rocket
Arlington Heights, IL
C?ID=418047
Hello, I installed a new intake manifold on my 2013 VW Tiguan 2.0 FWD and ever since I did, I have had the P2015 code. I recently purchased VCDS to do the relearn procedure for the intake manifold runner position sensor. But after I completed it, I gained the code P2004 (intake manifold flap, bank 1 stuck open). When I replaced my intake manifold I just swapped over the sensor from the old one. At this point I believe the issue is related to the sensor/sensor wiring. When performing the relearn procedure the result is ERROR. After clearing the codes, they both immediately come back. I have checked for vacuum leaks, none to be found. Anyone have any idea what I should do next? Here is the scan data from today;
Sunday,20,September,2020,13:00:54:29554
VCDS Version: 20.4.2.0 (x64)  HEX-NET2 CB: 0.4527.4
VIN: WVGAV7AX6DW548674   License Plate:
Chassis Type: AX-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 4C 4F
          52 53 55 56 62 69 6C 72
VIN: WVGAV7AX6DW548674   Mileage: 108920km-67679miles
37-Navigation -- Status: Cannot be reached 1100
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 906 027 FB    HW: 06J 907 309 A
   Component: MED17.5.2 TFSI 2 06 8221
   Revision: P3H07---    Serial number:
   Coding: 0423010A19070160
   Shop #: WSC 13360 153 427622
   VCID: 70B2BBBB46A424ABA23-8024
008196 - Intake Manifold Flap; Bank 1
               P2004 - 000 - Stuck Open - MIL ON
                    Fault Status: 11100000
                    Mileage: 108926 km
                    Date: 2015.02.11
                    Time: 12:57:47
                    RPM: 705 /min
                    Load: 20.0 %
                    Temperature: 51.0�C
                    Temperature: 21.0�C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.843 V
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 000 - Implausible Signal - MIL ON
                    Mileage: 108926 km
                    Date: 2015.02.11
                    Time: 12:57:49
                    RPM: 695 /min
                    Load: 20.4 %
                    Temperature: 52.0�C
                    Temperature: 21.0�C
                    Voltage: 13.970 V
Readiness: 1110 0101
   Part No SW: 09G 927 750 NK    HW: 09G 927 750 NK
   Component: AQ 250 6F           2253
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 0740F067532A0313139-8052
   Part No SW: 5N0 614 109 AR    HW: 5N0 614 109 AR
   Component: J104   C6 450M VDC9 0006
   Revision: --H07---    Serial number: 00000006249109
   Coding: 0005158
   VCID: 7BA89C971FE257F3071-802E
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Revision: 00086000    Serial number: 0186633923
   Coding: 030C0C
   VCID: 343A77AB7EBC588B86B-8060
10487040 - invalid data record
          B2005 00 [008] - -
          [Kein g�ltiger Datensatz]
                    Date: 2012.10.09
                    Time: 00:04:44
   Part No SW: 3AA 907 044 AN    HW: 3AA 907 044 AN
   Component: Climatronic   H03 0303
   Revision: 00001K02
   Coding: 0010001002
   VCID: 7CAA9F8B166C50CB0EB-8028
   Part No SW: 5K0 937 086 N    HW: 5K0 937 086 N
   Component: BCM PQ35 M    021 0068
   Revision: BJ021001
   Coding: 6F180A1B8C232EC4008800C134000D444855AE06576D8DF0E4840000A040
   Shop #: WSC 33361 790 00999
   VCID: 3FD02887477A8BD36B9-806A
   Subsystem 1 - Part No: 5N1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS 190912 03  32  0010
   Coding: 009795
   Component: RLS 290912 05  54  0403
   Coding: 02304D
   Part No SW: 5N0 959 655 S    HW: 5N0 959 655 S
   Component: J234__2VB VW10 HI   2118
   Revision: 24017000    Serial number: 003L6PL2D1W
   Coding: 0022082
   VCID: 4DCC024FF1D62943E95-8018
   Subsystem 1 - Part No: 5N0 959 339 B
   Subsystem 2 - Serial number: 0000000000A281
   Subsystem 3 - Serial number: 0011.07.120000300000640005��63
   Subsystem 4 - Serial number: 640005��6332MTS602972522 ��63
   Subsystem 5 - Serial number: 72522 ��6342MTS644382512 ��63
   Subsystem 6 - Serial number: 82512 ��6351HTS6JJ88EBKR ��63
   Subsystem 7 - Serial number: 8EBKR ��6361HTS6B9GHDBKR ��63
   Subsystem 8 - Serial number: HDBKR ��63727TS6JLI6EBKR ��63
   Subsystem 9 - Serial number: 6EBKR ��63827TS64NMFBBKR �
   Subsystem 10 - Serial number: FBBKR �
   Part No SW: 5K0 953 501 BL    HW: 5K0 953 569 L
   Revision: FF010041    Serial number: 20120926301721
   Coding: 110A140000
   VCID: 75BC8AAF35460183715-8020
   Component: E221__MFL-TAS  H31 0033
   Coding: 820000
   Part No SW: 5N0 920 973 B    HW: 5N0 920 973 B
   Component: KOMBI         H05 0705
   Coding: 211F01
   VCID: 333874B77BB25FB39F1-8066
   Part No SW: 7N0 907 530 AD    HW: 7N0 907 530 AD
   Component: J533  Gateway H45 1633
   Revision:   H45       Serial number: 020912F1001869
   Coding: 356002
   VCID: 72B6B1B344A816BB547-8026
                    Reset counter: 201
                    Mileage: 108926 km
                    Date: 2015.02.11
                    Time: 12:58:38
   Component: IMMO          H05 0705
   Coding: 000007
   Shop #: WSC 30400 002 1048576
   VCID: 6A86A9D36CF8DE7BEC7-803E
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 12000220134004
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X_VW31.rod
   VCID: 2F3078C7979A7B53FB9-807A
   Revision: A1001003    Serial number: 7663537781
   Coding: 020100
   VCID: 2A0669D3ACF81E7B2C7-807E
00464 - Control Module with Display for Radio and Navigation (J503)
                    Reset counter: 201
   Part No SW: 561 959 760 A    HW: 561 959 760 A
   Component: MEM-FS        H04 0181
   Revision: AA000000    Serial number: 00000037212661
   Coding: 00581B0000000000000001010101202020202121202020
   VCID: 21148EFFD1CEDD237DD-8074
Address 37: Navigation
   Part No SW: 5N0 959 701 G    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0503
   Revision: 12110009    Serial number: 0005748547
   Coding: 0015BE
   VCID: 3924469F59DEA5E355D-806C
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 703 G    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  008 1504
   Serial number: 00000007253595
   Coding: 000490
   Part No SW: 5N1 909 144 N    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.286 1101
   Revision: 1AH03837    Serial number: 00122560073901
   Coding: 0000258
   VCID: 3D2C528F417699C3795-8068
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AD
   Component: EZE_2         H45 1633
   Coding: 050B0500
   VCID: 6FB0B8C7579A3B53BB9-803A
   Component: J245EE20SKB13  H03 0220
   Component: J394EE20SKB13  H03 0220
   Part No SW: 5N0 959 702 G    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0503
   Revision: 14110009    Serial number: 0005750180
   Coding: 0015BE
   VCID: 3A2659935CD8AEFB5C7-806E
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  008 1504
   Serial number: 00000007256545
   Coding: 000490
   Revision:   H19       Serial number: 00000000466779
   Coding: 0026156
   VCID: 363E4DA364404A9BB8F-8062
   Component: AFS-ECU       H04 0111
   Coding: 041200010B000400
   VCID: 372040A76FCAB393A39-8062
   Subsystem 1 - Part No: 4H0 941 329   Labels: 3D0-941-329.CLB
   Subsystem 2 - Part No: 4H0 941 329   Labels: 3D0-941-329.CLB
Address 56: Radio
   Revision: 3A001001    Serial number: 00008030191228
   Coding: 420D000100000000
   VCID: 30327BBB8A2464ABE23-8064
   Part No SW: 5N0 907 441 A    HW: 5N0 907 441 A
   Revision: 00H11000    Serial number: 525PA8-J290261
   Coding: 0110010
   Shop #: WSC 00000 000 08192
   VCID: 2D0C62CF91160943C95-8078
02203 - Audio / Video Input 1
                    Reset counter: 201
                    Mileage: 108926 km
                    Date: 2015.02.11
                    Time: 12:58:32
                        Reverse OFF
                    Count: 3
End----------(Elapsed Time: 01:44, VBatt start/end: 13.9V/13.8V)-----------
NostraJackAss
Did you reverse the air motor connection to vacuum switch solenoid? :rolleyes:
Isn't that intake under CARB/EPA useful life warranty and recall campaign at NHTSA?
rocket
C?ID=418047
Is this the correct connection? Or did I reverse it?
NostraJackAss
What does RTFB say?
Did you check switch function of solenoid is proper with mighty vac and VCDS outputs?
rocket
C?ID=418047
What does RTFB say?
I have found some diagrams in the repair manual. I believe the vacuum lines are in the correct spots. Under what part of VCDS can I view the outputs?
rocket
C?ID=418047
The vacuum solenoid appears to be working correctly after the active test. Though I've noticed over the past week when cold starting the vehicle, the RPMs fluctuate for about 5 seconds. Then return to normal cold start idle. Last night leaving work it was around 46 degrees Fahrenheit, the coldest it has been since this problem occurred. Upon cold start the RPM fluctuations were a little more aggressive than "normal" and the check engine light started to blink. Right as I was going to turn off the vehicle it stopped blinking and went down to normal idle. Today I scanned the vehicle and the P2015 and P2004 codes are still there, but I had also gotten Random/Multiple Cylinder Misfires (Intermittent) on all 4 cylinders. I assume this and the cold start issue are related. I've attached the code to view as well. I have not gotten around to testing the intake manifold runner position sensor yet. Would all of these symptoms relate to a "bad" sensor or a problem in the sensor circuit? I believe that is the last thing to test relating to the intake manifold components. If not, any suggestions on where to look next?
Wednesday,30,September,2020,10:59:36:29554
VIN: WVGAV7AX6DW548674   Mileage: 109480km-68027miles
7 Faults Found:
                    Mileage: 108926 km
                    Date: 2015.02.11
                    Time: 12:57:47
                    RPM: 705 /min
                    Load: 20.0 %
                    Temperature: 51.0�C
                    Temperature: 21.0�C
                    Voltage: 13.843 V
                    Mileage: 108926 km
                    Date: 2015.02.11
                    Time: 12:57:49
                    RPM: 695 /min
                    Load: 20.4 %
                    Temperature: 52.0�C
                    Temperature: 21.0�C
                    Voltage: 13.970 V
               P0300 - 000 -  - Intermittent - MIL ON
                    Fault Status: 10100000
                    Mileage: 108950 km
                    Date: 2015.02.13
                    Time: 19:01:58
                    RPM: 1256 /min
                    Load: 67.4 %
                    Temperature: 21.0�C
                    Temperature: 24.0�C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 14.224 V
000771 - Cylinder 3
               P0303 - 000 - Misfire Detected - Intermittent
                    Mileage: 108950 km
                    Date: 2015.02.13
                    Time: 19:02:37
                    RPM: 777 /min
                    Load: 23.9 %
                    Speed: 17.0 km/h
                    Temperature: 33.0�C
                    Temperature: 25.0�C
                    Voltage: 13.970 V
000772 - Cylinder 4
               P0304 - 000 - Misfire Detected - Intermittent
                    Mileage: 108950 km
                    Date: 2015.02.13
                    Time: 19:02:37
                    RPM: 777 /min
                    Load: 23.9 %
                    Speed: 17.0 km/h
                    Temperature: 33.0�C
                    Temperature: 25.0�C
                    Voltage: 13.970 V
000770 - Cylinder 2
               P0302 - 000 - Misfire Detected - Intermittent - MIL ON
                    Mileage: 108950 km
                    Date: 2015.02.13
                    Time: 19:02:37
                    RPM: 777 /min
                    Load: 23.9 %
                    Speed: 17.0 km/h
                    Temperature: 33.0�C
                    Temperature: 25.0�C
                    Voltage: 13.970 V
000769 - Cylinder 1
               P0301 - 000 - Misfire Detected - Intermittent
                    Mileage: 109209 km
                    Date: 2015.02.16
                    Time: 10:06:36
                    RPM: 1213 /min
                    Load: 32.1 %
                    Temperature: 28.0�C
                    Temperature: 23.0�C
                    Voltage: 13.970 V
   Coding: 0000840
   Component: J104   C6 450M VDE3 0006
   Coding: 0005158
   Coding: 030C0C
          B2005 00 [008] - -
                    Date: 2012.10.09
                    Time: 00:04:44
   Revision: 00001K02
   Coding: 0010001002
   Coding: 0022082
   Coding: 110A140000
   Coding: 820000
   Coding: 211F01
   Coding: 356002
                    Reset counter: 201
                    Mileage: 108926 km
                    Date: 2015.02.11
                    Time: 12:58:38
01304 - Radio
                    Fault Frequency: 39
                    Reset counter: 11
                    Mileage: 108926 km
                    Date: 2015.02.11
                    Time: 13:04:28
   Coding: 000007
   Coding: 020100
                    Reset counter: 201
   Coding: 0015BE
   Slave Driver:
   Coding: 000490
   Coding: 0000258
Address 46: Central Conv.
   Coding: 050B0500
   Coding: 0015BE
   Slave Passenger:
   Coding: 000490
   Coding: 0026156
Address 56: Radio
   Coding: 0110010
                    Reset counter: 201
                    Mileage: 108926 km
                    Date: 2015.02.11
                    Time: 12:58:32
                        Reverse OFF
                    Count: 3
End----------(Elapsed Time: 01:34, VBatt start/end: 14.1V/14.3V)-----------
