IDE equivalent to Measuring Blocks
Gazdok
HUC-NRRT
I am looking for the IDE code in advanced measuring values to the "old" measuring block 011. I have a 2014 CFBG 2L TDI 170 and had a limp mode situation and the DTCs 9126 and 9127.
Tuesday,01,September,2020,15:09:22:20809
VCDS Version: Release 20.4.2 (x64) Running on Windows 10 x64
                Address 01: Engine       Labels: 03L-906-018-CFF.clb
Control Module Part Number: 03L 906 018 RS    HW: 03L 906 018 MH
  Component and/or Version: R4 2,0L EDC   H28 5357
           Software Coding: 001D0032042701080000
            Work Shop Code: WSC 33361 790 00999
              ASAM Dataset: EV_ECM20TDI01103L906018RS 003003 (SK46)
                       ROD: EV_ECM20TDI01103L906018RQ.rod
                      VCID: 0C17C779A71A1EE67F-8058
9126 - Actuator Module for Turbocharger 1
          P00AF 00 [096] - Stuck
                    Mileage: 87089 km
                    Date: 2020.08.24
                    Time: 12:55:09
                    Engine speed: 2367.00 /min
                    Normed load value: 39.2 %
                    Vehicle speed: 119 km/h
                    Coolant temperature: 90 °C
                    Intake air temperature: 25 °C
                    Voltage terminal 30: 14.840 V
                    Charge Pressure Actuator: activation: 5.00 %
                    Charge Pressure Actuator: acknowledgment: 45.94 %
                    Turbocharger boost control: offset closed: -0.06 %
                    High press turbocharger actuator: status-Bits 0-7: 0
                    High press turbocharger actuator: status-Bits 0-7: 55
                    High press turbocharger actuator: status-Bits 0-7: 4
                    High press turbocharger actuator: actual uncond volt value: 2482.6 mV
9127 - Actuator Module for Turbocharger 1
                    Mileage: 87116 km
                    Date: 2020.08.24
                    Time: 13:09:43
                    Engine speed: 1668.50 /min
                    Vehicle speed: 85 km/h
                    Coolant temperature: 89 °C
                    Intake air temperature: 23 °C
                    Voltage terminal 30: 14.760 V
                    Charge Pressure Actuator: activation: 10.00 %
                    Charge Pressure Actuator: acknowledgment: 17.00 %
                    High press turbocharger actuator: actual uncond volt value: 3408.4 mV
I tried to access the measuring block 011 to check the actuator, but I cannot access it - greyed out.
What would be the equivalent advanced measuring value to this?
Tuesday,01,September,2020,15:06:01:20809
VCDS Version: 20.4.2.0 (x64)
VIN: TMBMF73T3E9034631   License Plate:
Mileage: 87300km-54245mi   Repair Order:
Chassis Type: 3T-SK46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 20 22 25 36 37 42 44 46 47 4F
          52 55 56 57 61 62 6C 72 77
VIN: TMBMF73T3E9034631   Mileage: 87300km-54245miles
Address 01: Engine (J623-CFGB)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 RS    HW: 03L 906 018 MH
   Component: R4 2,0L EDC   H28 5357
   Revision: 41H28---    Serial number:
   Shop #: WSC 33361 790 00999
                    Mileage: 87089 km
                    Date: 2020.08.24
                    Time: 12:55:09
                    Mileage: 87116 km
                    Date: 2020.08.24
                    Time: 13:09:43
   Part No SW: 02E 300 016 D    HW: 02E 927 770 AL
   Component: GSG DSG AG6     521 4013
   Revision: 05652104    Serial number: 00001311100185
   VCID: 1521A21D3CD0DF2ED0-8040
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: 863D6016092500FE611106E7901A0092A1095023
   Shop #: WSC 33361 790 00085
   VCID: 7EF39DB1E9A63C7661-802A
   Part No SW: 3T0 907 044 CJ    HW: 3T0 907 044 CJ
   Component: Climatronic   H19 0709
   Revision: 00001009
   Coding: 0010100003
   Shop #: WSC 00123 123 12345
   ROD: EV_ClimaAutoBasis_SK46.rod
   VCID: 7CF797B9F7BA2E664F-8028
   Part No SW: 1K0 937 087 AN    HW: 1K0 937 087 AN
   Component: BCM PQ35  H+  112 0771
   Revision: AF112771
   Coding: 40010ABFE849F1C0400800C8710089EC48790046617D876099C5EF840041
   VCID: 7DF19ABDE4A0276E78-8028
   Subsystem 1 - Part No: 3T2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 13101  26  0700
   Coding: 00DFB7
   Component: RLS 221113 05  54  0403
   Coding: 0730CD
   Subsystem 3 - Part No: 7N0 951 171 A
   Component: DWA-Sensor 00  002 0206
Address 10: Park/Steer Assist (J791)       Labels:| 3T0-919-475-V2.clb
   Part No SW: 3T0 919 475 D    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0005
   Revision: --------    Serial number: 56261330201000
   Coding: 341305
   ASAM Dataset: EV_EPHVA2CAS46X0000 001003
   ROD: EV_EPHVA2CAS46X0000_001.rod
   VCID: 3E735DB1A126FC7621-806A
   Part No SW: 3T0 959 655 D    HW: 3T0 959 655 D
   Component: J234__LDM VW10 HI   2518
   Revision: 25019000    Serial number: 003LEPPNRSD7
   Coding: 0017485
   VCID: 428B29411DDE989645-8016
   Subsystem 1 - Serial number: 6332MTS658493123
   Subsystem 2 - Serial number: 6342MTS658373123
   Subsystem 3 - Serial number: 6351HTS6C0AIFCKR
   Subsystem 4 - Serial number: 6361HTS63TDJFCKR
   Subsystem 5 - Serial number: 63727TS6IRG7CCKR
   Part No SW: 5K0 953 521 DD    HW: 5K0 953 569 AE
   Revision: FF010042    Serial number: 20131120201487
   Coding: 1882140002
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 71E9B68DA0F8530EEC-8024
   Subsystem 1 - Part No SW: 5E0 919 719 F    HW: 5E0 919 719 F
   Component: E221__MFL-PR6  H04 0120
   Coding: 820000
   Part No SW: 3T2 920 941 M    HW: 3T2 920 941 M
   Component: KOMBI         H07 0811
   Coding: 111C01
   Shop #: WSC 12055 002 104857
   VCID: 3F8D20B5A62CF57E2A-806A
   Part No SW: 7N0 907 530 BF    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1674
   Revision:   H55       Serial number: 250913F1003440
   Coding: 359303
   VCID: 75E1829DDC907F2E30-8020
   Part No SW: 5K0 857 511 C    HW: 8P0 857 511 C
   Component: FLA           H04 0012
   Revision: AA001002
   Coding: 0202826B74745D545420363E00
   Shop #: WSC 01324 784 00200
   VCID: 2E536DF179460CF6B1-807A
   Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
   Component: Haldex 4Motion      3018
   Coding: 0000005
   VCID: 4581325D0CF0AFAE60-8010
   Component: IMMO          H07 0811
   Coding: 000002
   VCID: 6ADBA1E18D2EA0D6AD-803E
   Part No SW: 3C8 959 760 E    HW: 3C8 959 760 E
   Component: Sitzmemory    H05 3101
   Revision: 00H05000
   Coding: 00003B
   Shop #: WSC 12336 024 394758
   VCID: 377D4895861CCD3EE2-8062
                    Reset counter: 178
                    Mileage: 87187 km
                    Date: 2015.01.19
                    Time: 09:15:18
   Part No SW: 3T0 035 686 H    HW: 3T0 035 686 H
   Component: RNS-MID       H21 6276
   Revision: AB001001    Serial number: SKZ6Z7N9325044
   Coding: 04040002020100801000
   VCID: 3B7554A5BA34E95E06-806E
   Subsystem 1 - Part No: tbd
8557
   Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
   Component: TSG FA        H10 0415
   Coding: 011D0220DE01001000
   VCID: 52AB19010DBE0816F5-8006
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 194    3501
   Revision: 00H22000
   VCID: 39794EAD7008DB4E14-806C
   Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
   Component: KonzernAmp10K H08 6815
   Revision: --------    Serial number: EAA098A0099997
   ASAM Dataset: EV_AudioVerst10KanalBNO1 A01003
   ROD: EV_AudioVerst10KanalBNO1_VW32.rod
   VCID: 264395D159B644B649-8072
   Component: EZE_2         H55 1674
   Coding: 050B0100
   VCID: 6FEDB0F5BECC45FEFA-803A
   Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H03 0090
   Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H03 0090
   Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
   Component: TSG BF        H10 0415
   VCID: 51A9160D08B8730ECC-8004
   Component: AFS-ECU       H04 0111
   Coding: 01CE00003F000000
   ROD: EV_HeadlRegulVWAFSPt_VW46.rod
   VCID: 377D48958E1CCD3EE2-8062
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0003
   Coding: 8E0000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0003
   Coding: 8E0000
8557
Address 57: TV Tuner        Labels: 7L6-919-148.clb
   Part No SW: 7L6 919 148 A    HW: 7L6 919 148
   Component: R0078 TVhybridDVB   0150
   Revision: R0H21000    Serial number: 93900501272701
   Coding: 0000003
   VCID: 3A7B51A1750ED0561D-806E
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AM
   Component: Batt.regelung H55 1674
   Coding: 030F185A
   VCID: 71E9B68DA8F8530EEC-8024
   Component: J367-BDM  H07 0180
   Serial number: 40317811471491428949
Address 62: Door, Rear Left (J388)       Labels:. 8X0-959-795.clb
   Part No SW: 8X0 959 795 D    HW: 8X0 959 795 D
   Component: TSG HL        H07 0415
   Coding: 010C00200001001000
   VCID: 50AF130903B27A06C3-8004
   Part No SW: 7N0 907 441     HW: 7N0 907 441
   Component: J772__Rearview      0020
   Revision: 00H11000    Serial number: 525 PA8J264823
   Coding: 0020011
   Shop #: WSC 00020 790 00000
   VCID: 6ED3ADF179C64CF6F1-803A
Address 72: Door, Rear Right (J389)       Labels:. 8X0-959-795.clb
   Component: TSG HR        H07 0415
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 D    HW: 3C8 035 730 D
   Component: Telefon       022 0982
   Revision: --------    Serial number: 35502105078894
   Coding: 020000000100010000000101
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi.rod
   VCID: 24478FD92F8AB6A657-8070
End-------------------------(Elapsed Time: 04:18)--------------------------
                    Mileage: 87089 km
                    Date: 2020.08.24
                    Time: 12:55:09
                    Mileage: 87116 km
                    Date: 2020.08.24
                    Time: 13:09:43
Address 01: DTCs cleared
Address 36: DTCs cleared
Address 17,3T2 920 941 M,channel IDE00511-ESI: time from inspection,adapted from,40 d,to,90 d,
Address 17,3T2 920 941 M,channel IDE03346-MAS01456-Units adjusted-Speed,adapted from,Miles per hour ,to,Kilometers per hour ,
Address 17,3T2 920 941 M,channel IDE03346-MAS01456-Units adjusted-Speed,adapted from,Kilometers per hour ,to,Miles per hour ,
Address 17,3T2 920 941 M,channel IDE05930-Service notification in days,adapted from,21 d,to,14 d,
Address 17,3T2 920 941 M,channel IDE03352-FIX: Time since last time-dependent inspection,adapted from,41 d,to,0 d,
Address 17,3T2 920 941 M,channel IDE00511-ESI: time from inspection,adapted from,90 d,to,0 d,
Address 17,3T2 920 941 M,channel IDE00342-ESI: Resetting ESI,adapted from,Warning active ,to,Reset ,
You mean like these?
IDE00190 -- Charge air pressure specified value
IDE00191 -- Charge air pressure: actual value
IDE00362 -- Charge Pressure Actuator: activation
PS: Since your question does seem to involve VCDS, moving from General VW/Audi Repair to New User section.
PPS: You should Get Verified.
