A4 B9 problem retrofit Virtual Cockpit help
krisuumax
Poland
C?ID=396010 (?)
Hi. I have A4 B9 from 2016. I changed the counter to a virtual cockpit. Component protection has been removed, I entered the encoding from the old one, the errors are gone, but I have 2 constants. (LVDS I know it, because the cable is not connected yet) the second is the U112200 Data Bus error, unreliable information. In addition, after turning the ignition, the electrical installation, fault! Appears immediately on virtual. Park your car safely. I will add that I put the old counter, it works without a problem. Please help
Westbury, UK
We'll need to see a full unedited VCDS Auto-Scan so we can see how your car is equipped (hardware & software versions of modules is important).
krisuumax
Poland
C?ID=396010 (?)
Adres: 0017 Nazwa systemu: 17 - zestaw wskaźników Wersja protokołu: UDS / ISOTP (Ereignisse: 6)
-Identyfikacja:
Źródło danych:Pojazd
Numer katalogowy sprzętu:8W5920790E
Numer części:8W5920790E
Numer wersji sprzętu:H19
Numer wersji oprogramowania:0417
Dane produkcji:30.06.2019
Kod:
Kod:05A441C6A88000080723E9601000000000000000
Możliwość wykonania aktualizacji flash:nieznane
Oznaczenie systemu:FBenRDW
Wersja podstawowa ASAM:BV_DashBoardUDS
ASAM 2D / zestaw danych ODX:EV_DashBoardAU736
ASAM 2D / wersja zestawu danych ODX:001032
Zastosować ASAM / wersja sterownika ODX:EV_DashBoardAU736_001
Docelowy zasobnik danych:8W2909525D
Wersja zasobnika danych:0026
Kod wyposażenia:00 00 00 00 00 00 00 00 00 00 00 00
Skrót systemu:J285
Westbury, UK
To make it easier for all, I've attached the scan between code tags below BUT very few of us read Polish so we always ask for Auto-Scans posted here to be made using the English version of VCDS - which can be downloaded from the Ross-Tech website and will install happily alongside your Polish version.
Niedziela,20,Wrzesieñ,2020,10:27:59:49592
VCDS -- Emulator VAG/VAS pracuj¹cy w œrodowisku Windows, uruchomiony na Windows 7 x64
Wersja VCDS: AKP 20.4.1.1  HEX-NET CB: 0.4508.4
Wersja danych: 20200629 DS317.0
www.vcds.pl
VIN: WAUZZZF45GA088279   Numer rejestracyjny: DDWW23
Przebieg: 193332km   Numer naprawy:
Typ podwozia: F4-AU49 (4M2)
Skanowanie: 01 02 03 08 09 15 16 17 19 29 39 42 44 46 52 5F 6C 74 81 A5
          BB BC D6 D7
VIN: WAUZZZF45GA088279   Przebieg: 193332km
01-Silnik -- Stan: OK 0000
02-Skrzynia biegów -- Stan: OK 0000
03-ABS/hamulce -- Stan: OK 0000
08-Klimatyzacja -- Stan: Usterka 0010
09-Centr.zesp.elektr. -- Stan: OK 0000
15-Airbag -- Stan: OK 0000
16-Ko³o kierownicy -- Stan: OK 0000
17-Zest.wskaŸników -- Stan: OK 0000
19-CAN Gateway -- Stan: OK 0000
29-Œwiat³a -lewa str. -- Stan: OK 0000
39-Œwiat³a -prawa str. -- Stan: OK 0000
42-Elektr.drzwi kier. -- Stan: OK 0000
44-Wsp.kierownicy -- Stan: OK 0000
46-Modu³ komfortu -- Stan: OK 0000
52-Elektr.drzwi pas. -- Stan: OK 0000
5F-Elektr.informacji -- Stan: OK 0000
6C-Kamera wsteczna -- Stan: OK 0000
74-Kontrola podwozia -- Stan: OK 0000
81-Zmiana biegów -- Stan: OK 0000
A5-Czujniki asyst.j.-p. -- Stan: OK 0000
BB-Drzwi tylne s.kier. -- Stan: OK 0000
BC-Drzwi tylne s.pas. -- Stan: OK 0000
D6-Sterow.LED lewy 2 -- Stan: OK 0000
D7-Sterow.LED prawy 2 -- Stan: OK 0000
Adres 01: Silnik (J623-CYRB)       Plik etykiet:. 06L-907-115-V1.clb
   Oznaczenie elementu SW: 8W0 906 259     HW: 06L 907 425
   Komponent: 2.0l R4 TFSI  H13 0005
   Weryfikacja: --H13---
   Kodowanie: 0A2500322326050B34000000000000000000000000000000
   Kod serwisu: WSC 06314 790 00001
   Zbiór danych ASAM: EV_ECM20TFS0208W0906259 001007
   ROD: EV_ECM20TFS0208W0906259.rod
   VCID: FEB058A061364D76F8-80AA
Nie znaleziono b³êdów.
Kody gotowoœci: 0010 0001
Adres 02: Skrzynia biegów (J217)       Plik etykiet:| 0CJ-927-156.clb
   Oznaczenie elementu SW: 8W1 927 155 M    HW: 0CJ 927 156
   Komponent: 0CL 20TFSIRdW H03 0009
   Weryfikacja: --H03---    Numer seryjny: 0000001288
   Kodowanie: 000001
   Kod serwisu: WSC 00000 000 00000
   Zbiór danych ASAM: EV_TCMDL382021 002024
   ROD: EV_TCMDL382021_AU49.rod
   VCID: CAD8C4706D7E31D614-809E
   Pompa MTF:
   Podsystem 1 - Oznaczenie elementu SW: 0CK 927 152 AA    HW: 0CK 321 281 K
   Komponent: V553 MTFP  002 0572
   Numer seryjny: 75117071160335002380
Adres 03: ABS/hamulce (J104)       Plik etykiet: 8W0-907-379-PLU-V1.clb
   Oznaczenie elementu SW: 8W0 907 379 E    HW: 8W0 907 379 J
   Komponent: ESP9 Plus     H06 0593
   Kodowanie: 14AA409928AA0A9E15A0489800865292E6A5D228021450A812004A4967A54B
   Kod serwisu: WSC 41472 002 1048576
   Zbiór danych ASAM: EV_ESP9BOSCHAU49X 012014
   ROD: EV_ESP9BOSCHAU49X_012.rod
   VCID: C7DEFD447E6CCCBE0B-8092
Adres 08: Klimatyzacja (E87)       Plik etykiet:* Przekier.nieudane!
   Oznaczenie elementu SW: 8W0 820 043 T    HW: 8W0 820 043 T
   Komponent: Klima Zone 3  H55 0210
   Kodowanie: 140800085144000500000100000000000000000000000000000000000000
   Kod serwisu: WSC 06335 790 00001
   Zbiór danych ASAM: EV_AirCondiBHTCAU491 001013
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: C4C4EA484F5AE7A6EE-8090
   Sterownik dmuchawy œwie¿ego powietrza (z przodu):
   Podsystem 1 - Oznaczenie elementu SW: 4M1 820 021     HW: 4M1 820 021
   Komponent: J216 FLuftV  H05 0001
   Numer seryjny: 00000000000000800983
   Czujnik wilgotnoœci powietrza na zewn¹trz:
   Podsystem 2 - Oznaczenie elementu SW: 4G0 907 658 B    HW: 4G0 907 658 B
   Komponent: Humidity_Sens  H01 0003
   Numer seryjny: DB188D18000000000001
   Panel obs³ugi uk³adu klimatyzacji z ty³u:
   Podsystem 3 - Oznaczenie elementu SW: 8W0 919 158     HW: 8W0 919 158
   Komponent: E265 Kli Fond  H40 0080
12 - iloœæ znalezionych b³êdów. Oto one:
196864 - Czujnik temperatury przedniego lewego nawiewu na tu³ów
          B10DD 01 [009] - B³¹d elektryczny
          Potwierdzony - Testowany od skasowania kodów b³êdów
             Ramka zamro¿ona:
                    Stan b³êdu: 00000001
                    Priorytet b³êdu: 5
                    Czêstoœæ b³êdu: 1
                    Wew.licznik b³êdów: 106
                    Przebieg: 193326 km
                    Data: 2020.09.19
                    Czas: 19:09:09
                    Napiêcie zacisku 30: 13.63 V
                    Temperatura zewnêtrzna: 25.00 °C
                    Prêdkoœæ pojazdu: 0 km/h
196865 - Czujnik temperatury przedniego prawego nawiewu na tu³ów
          B10DE 01 [009] - B³¹d elektryczny
             Ramka zamro¿ona:
                    Priorytet b³êdu: 5
                    Czêstoœæ b³êdu: 1
                    Przebieg: 193326 km
                    Data: 2020.09.19
                    Czas: 19:09:09
196896 - Nieznany kod b³êdu
          B1451 01 [009] - B³¹d elektryczny
             Ramka zamro¿ona:
                    Priorytet b³êdu: 5
                    Czêstoœæ b³êdu: 1
                    Przebieg: 193326 km
                    Data: 2020.09.19
                    Czas: 19:09:09
327956 - Silnik nastawczy klapy temperatury z prawej strony
          B108D 31 [009] - Brak sygna³u
             Ramka zamro¿ona:
                    Priorytet b³êdu: 5
                    Czêstoœæ b³êdu: 1
                    Przebieg: 193326 km
                    Data: 2020.09.19
                    Czas: 19:09:08
                    WartoϾ wymagana silnika nastawczego prawej klapy temperatury: 65535
                    Czas pracy systemu-Czas pracy silnika: 471 s
                    Czas pracy systemu-Zacisk 15 ON: 474 s
                    Silnik nastawczy prawej klapy temperatury: diagnoza-Ostatni tryb pracy: Brak uruchomionej procedury
                    Silnik nastawczy prawej klapy temperatury: diagnoza-Stan pracy: Brak uruchomionej procedury
327972 - Silnik nastawczy klapy œwie¿ego powietrza
          B11AF 31 [009] - Brak sygna³u
             Ramka zamro¿ona:
                    Priorytet b³êdu: 5
                    Czêstoœæ b³êdu: 1
                    Przebieg: 193326 km
                    Data: 2020.09.19
                    Czas: 19:09:08
                    Wartoœæ wymagana silnika nastawczego klapy œwie¿ego powietrza: 65535
                    Silnik nastawczy klapy œwie¿ego powietrza: diagnoza-Ostatni tryb pracy: Brak uruchomionej procedury
                    Silnik nastawczy klapy œwie¿ego powietrza: diagnoza-Stan pracy: Brak uruchomionej procedury
327987 - Silnik nastawczy klapy rozmra¿ania
          B1090 07 [009] - Usterka mechaniczna
             Ramka zamro¿ona:
                    Priorytet b³êdu: 5
                    Czêstoœæ b³êdu: 1
                    Przebieg: 193327 km
                    Data: 2020.09.19
                    Czas: 19:59:40
                    Wartoœæ wymagana silnika nastawczego klapy rozmra¿ania: 9699
                    Silnik nastawczy klapy rozmra¿ania: wartoœæ rzeczywista: 10272
                    Czas pracy systemu-Czas pracy silnika: 22 s
                    Czas pracy systemu-Zacisk 15 ON: 23 s
                    Silnik nastawczy klapy rozmra¿ania: diagnoza-Ostatni tryb pracy: Brak uruchomionej procedury
                    Silnik nastawczy klapy rozmra¿ania: diagnoza-Stan pracy: Obs³uga blokowania
                    Napiêcie zacisku 30: 14.01 V
                    Temperatura zewnêtrzna: 27.50 °C
328004 - Silnik nastawczy klapy zamkniêtego obiegu powietrza
          B1092 31 [009] - Brak sygna³u
             Ramka zamro¿ona:
                    Priorytet b³êdu: 5
                    Czêstoœæ b³êdu: 1
                    Przebieg: 193326 km
                    Data: 2020.09.19
                    Czas: 19:09:08
                    WartoϾ wymagana silnika nast. klapy zamkn. obiegu powietrza: 65535
                    Silnik nastawczy klapy zamkniêtego obiegu powietrza: diagnoza-Ostatni tryb pracy: Brak uruchomionej procedury
                    Silnik nastawczy klapy zamkniêtego obiegu powietrza: diagnoza-Stan pracy: Brak uruchomionej procedury
328037 - Silnik nastawczy lewego nawiewu bocznego
          B10C9 29 [009] - Nieprawid³owy sygna³
             Ramka zamro¿ona:
                    Priorytet b³êdu: 5
                    Czêstoœæ b³êdu: 1
                    Przebieg: 193326 km
                    Data: 2020.09.19
                    Czas: 19:09:10
                    Silnik nastawczy lewego nawiewu bocznego: wartoϾ wymagana: 10000
                    Silnik nastawczy lewego nawiewu bocznego: wartoϾ rzeczywista: 10000
                    Czas pracy systemu-Czas pracy silnika: 473 s
                    Czas pracy systemu-Zacisk 15 ON: 476 s
                    Silnik nastawczy lewego nawiewu bocznego: diagnoza-Ostatni tryb pracy: Brak uruchomionej procedury
                    Silnik nastawczy lewego nawiewu bocznego: diagnoza-Stan pracy: Brak uruchomionej procedury
328051 - Silnik nastawczy prawego nawiewu bocznego
          B10CA 07 [009] - Usterka mechaniczna
             Ramka zamro¿ona:
                    Priorytet b³êdu: 5
                    Czêstoœæ b³êdu: 1
                    Przebieg: 193330 km
                    Data: 2020.09.19
                    Czas: 23:32:49
                    Silnik nastawczy prawego nawiewu bocznego: wartoϾ wymagana: 13028
                    Silnik nastawczy prawego nawiewu bocznego: wartoϾ rzeczywista: 11573
                    Czas pracy systemu-Czas pracy silnika: 30 s
                    Czas pracy systemu-Zacisk 15 ON: 31 s
                    Silnik nastawczy prawego nawiewu bocznego: diagnoza-Ostatni tryb pracy: Brak uruchomionej procedury
                    Silnik nastawczy prawego nawiewu bocznego: diagnoza-Stan pracy: Obs³uga blokowania
                    Napiêcie zacisku 30: 13.96 V
                    Temperatura zewnêtrzna: 16.00 °C
328053 - Silnik nastawczy prawego nawiewu bocznego
          B10CA 29 [009] - Nieprawid³owy sygna³
             Ramka zamro¿ona:
                    Priorytet b³êdu: 5
                    Czêstoœæ b³êdu: 1
                    Przebieg: 193326 km
                    Data: 2020.09.19
                    Czas: 19:09:10
                    Silnik nastawczy prawego nawiewu bocznego: wartoϾ wymagana: 10000
                    Silnik nastawczy prawego nawiewu bocznego: wartoϾ rzeczywista: 10000
                    Silnik nastawczy prawego nawiewu bocznego: diagnoza-Stan pracy: Brak uruchomionej procedury
                    Napiêcie zacisku 30: 13.61 V
328180 - Silnik nastawczy klapy rozdzia³u powietrza z ty³u
          B1093 31 [009] - Brak sygna³u
             Ramka zamro¿ona:
                    Priorytet b³êdu: 5
                    Czêstoœæ b³êdu: 1
                    Przebieg: 193326 km
                    Data: 2020.09.19
                    Czas: 19:09:08
                    Silnik nastawczy klapy rozdzia³u powietrza: ty³: wart.wymagana: 65535
                    Silnik nastawczy klapy rozdzia³u powietrza z ty³u: diagnoza-Ostatni tryb pracy: Brak uruchomionej procedury
                    Silnik nastawczy klapy rozdzia³u powietrza z ty³u: diagnoza-Stan pracy: Brak uruchomionej procedury
196914 - Nieznany kod b³êdu
          B1486 01 [009] - B³¹d elektryczny
             Ramka zamro¿ona:
                    Priorytet b³êdu: 5
                    Czêstoœæ b³êdu: 1
                    Przebieg: 193326 km
                    Data: 2020.09.19
                    Czas: 19:09:09
Adres 09: Centr.zesp.elektr. (J519)       Plik etykiet:* Brak
   Oznaczenie elementu SW: 8W0 907 063 AG    HW: 8W0 907 063 G
   Komponent: BCM1 MLBevo   H12 0228
   Kodowanie: 07501143E17900CD01155118182C00F9110331000000000000000000200016010A440123025605
   Kod serwisu: WSC 06325 790 00001
   Zbiór danych ASAM: EV_BCM1BOSCHAU736 015005
   ROD: EV_BCM1BOSCHAU736_015.rod
   VCID: 804C26581BC23B868A-80D4
   Sterownik silnika wycieraczek:
   Podsystem 1 - Oznaczenie elementu SW: 8W1 955 119     HW: 8V1 955 119 A  Plik etykiet: 1KX-955-119.CLB
   Komponent: WWS491 160305  043 0813
   Numer seryjny: 894353?0301606500861
   Kodowanie: 5BC7F7
   Czujnik rozpoznawania deszczu i œwiat³a:
   Podsystem 2 - Oznaczenie elementu SW: 8U0 955 559 C    HW: 8U0 955 559 B  Plik etykiet: 8U0-955-559.CLB
   Komponent: G397_RLFS  H06 0004
   Numer seryjny: 61569558
   Kodowanie: 02005D
   Prze³¹cznik œwiate³:
   Podsystem 3 - Oznaczenie elementu SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
   Komponent: E1 - LDS  H06 0008
   Numer seryjny: 17 01 2016  00214524
   Automatycznie przyciemniane lusterko wewnêtrzne:
   Podsystem 4 - Oznaczenie elementu SW: 8W0 857 511     HW: 8W0 857 511
   Komponent: Y7_Innenspieg  H09 0002
   Numer seryjny: GX1CE121011611520968
   Kodowanie: 010000
   Modu³ oœwietlenia wnêtrza:
   Podsystem 5 - Oznaczenie elementu SW: 8W0 947 135 D    HW: 8W0 947 135
   Komponent: J528-Dachele  H13 0082
   Numer seryjny: Q00108047
   Jednostka obs³ugi funkcji jazdy i funkcji komfortowych:
   Podsystem 6 - Oznaczenie elementu SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
   Komponent: SL-B9/Q5NF  H15 0010
   Numer seryjny: 2615000143588003
   Kodowanie: 000000
Adres 15: Airbag (J234)       Plik etykiet:| 8W0-959-655.clb
   Oznaczenie elementu SW: 8W0 959 655     HW: 8W0 959 655
   Komponent: Airbag10.44   H72 0086
   Numer seryjny: 003M6002RJXQ
   Kodowanie: AECCF0C00C800000585400F3C00C00000000
   Zbiór danych ASAM: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
   VCID: 8640304039E615B6B0-80D2
   Czujnik zderzenia bocznej poduszki bezp.po stronie kierowcy:
   Podsystem 1 - Oznaczenie elementu SW: -----------    HW: 442 061 103 16
   Komponent: SideSensor_Df  1E2 0887
   Numer seryjny: 3577Y00B31C5CD42C29D
   Kodowanie: 2D2D2D
   Czujnik zderzenia bocznej poduszki bezp.po stronie pasa¿era:
   Podsystem 2 - Oznaczenie elementu SW: -----------    HW: 442 061 103 16
   Komponent: SideSensor_Pf  1E2 0887
   Numer seryjny: 3587Y00B31C5CD414385
   Kodowanie: 2D2D2D
   Czujnik zderzenia bocznej poduszki bezp.z ty³u po str.kierowcy:
   Podsystem 3 - Oznaczenie elementu SW: -----------    HW: 442 0B1 603 16
   Komponent: SideSensor_Dr  1C7 0148
   Numer seryjny: 3517700C11F88774839K
   Kodowanie: 2D2D2D
   Czujnik zderz.bocznej poduszki bezp.z ty³u po str.przedn.pasa¿.:
   Podsystem 4 - Oznaczenie elementu SW: -----------    HW: 442 0B1 603 16
   Komponent: SideSensor_Pr  1C7 0148
   Numer seryjny: 3527700C11F9D2702213
   Kodowanie: 2D2D2D
   Czujnik zderzenia przedniej poduszki bezp.po stronie kierowcy:
   Podsystem 5 - Oznaczenie elementu SW: -----------    HW: 442 0C1 803 16
   Komponent: FrontSensor_D  1C5 014A
   Numer seryjny: 3557500A71FE78C5231O
   Kodowanie: 2D2D2D
   Czujnik zderzenia przedniej poduszki bezp.po str.przed.pasa¿era:
   Podsystem 6 - Oznaczenie elementu SW: -----------    HW: 442 0C1 803 16
   Komponent: FrontSensor_P  1C5 014A
   Numer seryjny: 3567500A91FE78C582D1
   Kodowanie: 2D2D2D
   Czujnik zderzenia uk³adu ochrony pieszych na œrodku:
   Podsystem 7 - Oznaczenie elementu SW: -----------    HW: 442 0C1 703 16
   Komponent: PedP_Sensor_C  1C5 014A
   Numer seryjny: 2307500A51FACC8243FS
   Kodowanie: 2D2D2D
   Czujnik zderzenia uk³adu ochrony pieszych po stronie kierowcy 2:
   Podsystem 8 - Oznaczenie elementu SW: -----------    HW: 442 431 702 16
   Komponent: PedPSensor_D2  256 0887
   Numer seryjny: I0M9M00B71B1C0F5127F
   Kodowanie: 2D2D2D
   Czujnik zderzenia uk³adu ochrony pieszych po str.przedn.pasa¿.2:
   Podsystem 9 - Oznaczenie elementu SW: -----------    HW: 442 431 702 16
   Komponent: PedPSensor_P2  256 0887
   Numer seryjny: I0N9M00C31B1C0F0917F
   Kodowanie: 2D2D2D
Adres 16: Ko³o kierownicy (J527)       Plik etykiet: 4M0-907-129.clb
   Oznaczenie elementu SW: 4N0 907 129 AE    HW: 4N0 907 129 AE
   Komponent: Lenks.Modul   H03 0005
   Zbiór danych ASAM: EV_SMLSKLOAU736 007012
   VCID: F4A47A885F7A17269E-80A0
Adres 17: Zest.wskaŸników (J285)       Plik etykiet:* Przekier.nieudane!-SRI2
   Oznaczenie elementu SW: 8W5 920 770 A    HW: 8W5 920 770 A
   Komponent: MM--T--BENRW- H12 0267
   Weryfikacja: 0264v1      Numer seryjny:    LK4DPMR3S
   Kodowanie: 05AF51C078840008072368621000400000000000
   Kod serwisu: WSC 00046 123 12345
   Zbiór danych ASAM: EV_DashBoardAU736 001022
   VCID: BE3098A021B68D76B8-80EA
Adres 19: CAN Gateway (J533)       Plik etykiet:* Brak
   Oznaczenie elementu SW: 4M2 907 468 A    HW: 4M2 907 468 A
   Komponent: Gateway       H13 1079
   Weryfikacja: 3C060055    Numer seryjny: 5543C025F16220
   Kodowanie: 0301000100000F402900000000590012C8900007000000010100000000000000
   Zbiór danych ASAM: EV_GatewCONTIAU736 002040
   ROD: EV_GatewCONTIAU736_002_AU49.rod
   VCID: B62080800986453660-80E2
   Sterownik kierownicy wielofunkcyjnej:
   Podsystem 1 - Oznaczenie elementu SW: 4M0 951 523     HW: 4M0 951 523
   Komponent: J453 MFL  H06 0002
   Numer seryjny: 20160504233346 02961
   Sterownik uk³adu kontroli akumulatora:
   Podsystem 2 - Oznaczenie elementu SW: 8S0 915 181     HW: 8S0 915 181
   Komponent: J367-BDMHella  H10 9052
   Numer seryjny: 4848249703
Adres 29: Œwiat³a -lewa str. (J1018)       Plik etykiet: 4M0-907-397.clb
   Oznaczenie elementu SW: 4M0 907 397 AC    HW: 4M0 907 397 C
   Komponent: LCM_MLBevoH05 0023
   Zbiór danych ASAM: EV_LCMLeftHELLAAU736 001012
   VCID: F8BC4EB843127346B2-80AC
Adres 39: Œwiat³a -prawa str. (J1023)       Plik etykiet: 4M0-907-397.clb
   Oznaczenie elementu SW: 4M0 907 397 AD    HW: 4M0 907 397 D
   Komponent: LCM_MLBevoH05 0024
   Zbiór danych ASAM: EV_LCMRightHELLAAU736 001012
   VCID: F9BA4BBC78186A4ECD-80AC
Adres 42: Elektr.drzwi kier. (J386)       Plik etykiet:* Brak
   Oznaczenie elementu SW: 4M0 959 793 E    HW: 4M0 959 793 C
   Komponent: TSG FS        009 0057
   Numer seryjny: 0000229251620
   Kodowanie: 001D9A215000000000001082
   Zbiór danych ASAM: EV_DCU2DriveSideMAXHCONT 001005
   VCID: C0CCE6585B42FB86CA-8094
Adres 44: Wsp.kierownicy (J500)       Plik etykiet:* Brak
   Oznaczenie elementu SW: 8W0 909 144 F    HW: 8W0 909 144 B
   Komponent: EPS_MLBEVO_ZF H08 0407
   Kodowanie: 09008380008000
   Kod serwisu: WSC 06324 790 00001
   Zbiór danych ASAM: EV_EPSZFAU49X 002015
   ROD: EV_EPSZFAU49X_002.rod
Adres 46: Modu³ komfortu (J393)       Plik etykiet:* Brak
   Oznaczenie elementu SW: 8W0 907 064 CC    HW: 8W0 907 064 C
   Komponent: BCM2 MLBevo   016 0344
   Kodowanie: 013400000F100020630980000E00000033004000104302502F0400000104803F001F0001000000
   Zbiór danych ASAM: EV_BCM2HellaAU736 012013
   ROD: EV_BCM2HellaAU736_012_AU49.rod
   VCID: FF4EA5A4663C447EF3-80AA
   Czujnik uk³adu alarmowego:
   Podsystem 1 - Oznaczenie elementu SW: 5Q0 951 177     HW: 5Q0 951 172
   Komponent: Sensor, DWA  005 0316
   Numer seryjny: 000000000ZY160263NFU
   Syrena uk³adu alarmowego:
   Podsystem 2 - Oznaczenie elementu SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Komponent: Sirene, DWA  005 0313
   Numer seryjny: 00000000000035042507
   Sterownik otwierania pokrywy tylnej:
   Podsystem 3 - Oznaczenie elementu SW: 3AA 962 243 F    HW: 3AA 962 243 F
   Komponent: GEB.F.Heckoef  H16 0816
   Numer seryjny: 94288572
Adres 52: Elektr.drzwi pas. (J387)       Plik etykiet:* Brak
   Oznaczenie elementu SW: 4M0 959 792 E    HW: 4M0 959 792 C
   Komponent: TSG BFS       009 0057
   Numer seryjny: 0000229278818
   Kodowanie: 001D9A217C00000000001080
   Zbiór danych ASAM: EV_DCU2PasseSideMAXHCONT 001005
   VCID: BFCEE5A426BC847EB3-80EA
Adres 5F: Elektr.informacji (J794)       Plik etykiet:* Brak
   Oznaczenie elementu SW: 8W0 035 036 F    HW: 8W0 035 036 A
   Komponent: MU-P-LN-EU    050 0976
   Numer seryjny: A667K0F7504562
   Kodowanie: 01940101FF00000013110001000A00102F0002E5417081001E
   Zbiór danych ASAM: EV_MUHig6C3Gen2HBAS 001115
   Naklejka z danymi:
   Podsystem 1 - Oznaczenie elementu SW: V03 959 802 TL    HW: -----------
   Komponent: ECE 2020/2021  --- 0187
   Numer seryjny: --------------------
   Jednostka wskazañ 1 systemu Multimedia:
   Podsystem 2 - Oznaczenie elementu SW: 8W1 919 605     HW: 8W1 919 605
   Komponent: DU High AU49x  H32 0170
   Numer seryjny: TPO00127051900820065
   Jednostka obs³ugi systemu Multimedia:
   Podsystem 3 - Oznaczenie elementu SW: 8W0 919 614 T    HW: 8W0 919 614 T
   Komponent: ControlUnit_H  H30 0206
   Numer seryjny: APVAK116061700040615
   Baza danych Compact Disc:
   Podsystem 4 - Oznaczenie elementu SW: V03 959 800 EG    HW: -----------
   Komponent: Gracenote2  --- 1011
Adres 6C: Kamera wsteczna (J772)       Plik etykiet:* Przekier.nieudane!
   Oznaczenie elementu SW: 4M0 980 556 A    HW: 4M0 980 556 A
   Komponent: RVC Compact   H12 0240
   Kodowanie: 0237060102002001000040
   Kod serwisu: WSC 12345 123 12345
   Zbiór danych ASAM: EV_CamSysRVRVCPANAMLBEv 005010
   ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
   VCID: B326B9941AF4501E47-80E6
Adres 74: Kontrola podwozia (J775)       Plik etykiet:* Brak
   Oznaczenie elementu SW: 8W0 907 777 C    HW: 8W0 907 777 C
   Komponent: Fahrwerk-SG   H34 1203
   Numer seryjny: 2202160059
   Kodowanie: 1050303958
   Zbiór danych ASAM: EV_ChassContrContiAU426 001001
   ROD: EV_ChassContrContiAU426.rod
Adres 81: Zmiana biegów (J587)       Plik etykiet: 4MX-713-041-81.clb
   Oznaczenie elementu SW: 8W1 713 041 E    HW: 8W1 713 041 E
   Komponent: GSM-LL        H07 0068
   Weryfikacja: 0L0D5012    Numer seryjny: 20160317000816
   Zbiór danych ASAM: EV_GSMWaehlZFAU736 001013
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: B522878C14804E2E69-80E0
Adres A5: Czujniki asyst.j.-p. (R242)       Plik etykiet:* Przekier.nieudane!
   Oznaczenie elementu SW: 8W0 907 217 A    HW: 8W0 907 217
   Komponent: BVS           H14 0030
   Kodowanie: 0404090100000404022021A0AC0000FED0F0C0200020
   Zbiór danych ASAM: EV_BVSMLBevKOSTAAU736 002022
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
   VCID: BA3894B03D9EA15684-80EE
Adres BB: Drzwi tylne s.kier. (J388)       Plik etykiet:* Brak
   Oznaczenie elementu SW: 8W0 959 595 G    HW: 8W0 959 595
   Komponent: TSG HFS       005 0052
   Numer seryjny: 0000191071861
   Kodowanie: 000D98210000000000001080
   Zbiór danych ASAM: EV_DCU2RearDriveMAXHCONT 001005
   VCID: D0ECD6188B220B065A-8084
Adres BC: Drzwi tylne s.pas. (J389)       Plik etykiet:* Brak
   Komponent: TSG HBFS      005 0052
   Numer seryjny: 0000191071864
   Zbiór danych ASAM: EV_DCU2RearPasseMAXHCONT 001005
   ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
Adres D6: Sterow.LED lewy 2 (A31)       Plik etykiet: 7PP-941-572.clb
   Oznaczenie elementu SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Komponent: LED1L         H09 0003
   Zbiór danych ASAM: EV_LEDModLeftMELCOAU736 001004
   ROD: EV_LEDModLeftMELCOAU736_AU37.rod
   VCID: 966060006946A53640-80C2
Adres D7: Sterow.LED prawy 2 (A27)       Plik etykiet: 7PP-941-572.clb
   Komponent: LED1R         H09 0003
   Zbiór danych ASAM: EV_LEDModRightMELCOAU736 001004
Koniec (Skanowanie trwa³o: 01:51, Napiêcie akumulatora - na pocz¹tku skanowania / przy koñcu skanowania: 14.7V/14.7V)
