Function Fail in Session
morris39
Canada
C?ID=395084
Tosayu after successfully saving 1 Adpmap and one Blockmap I tried to access Module 01 for logging but could not get any funcions, all greyed out, but Testand Config still OK . I tried Select, Applications, Autoscan, all very slow then " Module cannot be accesssed"
Conditions: Car running, laptop battery 93%, no internet, several attempts, car OK
At home I can accesss Logs and Scansbut there is a "funny log which I did not ask for and includes data from a previous session during which I did get an Autoscan (no DTCs)
The odd Log below
I suspect the program is corrupt and I will need to load a new copy. Ideas ? So my Logs & Scans would be lost? A way around that?
Friday,14,August,2020,15:21:50:47231
VIN: WAUFFRFF8F1141715   License Plate:
                Address 22: AWD  (0CQ 907 554 D)
15:21:42
  IDE05708   Haldex clutch pump PWM signal 0 %
Saturday,15,August,2020,15:10:38:47231
                Address 01: Engine  (8V0 906 259 H)
15:10:20
  IDE00182   Camshaft adaptation intake bank 1: phase position -0.3 °
  IDE00184   Camshaft adaptation exhaust bank 1: phase position -3.0 °
  IDE03711   Mass flow through throttle valve 9 kg/h
  ENG104044   Engine load 16.796875 %
  ENG101741   Intake air temperature 48.75 °C
15:23:12
  IDE00920   Front left wheel speed 0.0 km/h
  IDE00921   Front right wheel speed 0.0 km/h
  IDE00922   Left rear wheel speed 0.0 km/h
  IDE00923   Right rear wheel speed 0.0 km/h
  IDE01617   Clutch temperature 47.60 °C
  IDE05707   Haldex clutch pump current 0.009 A
  IDE06111   Axle speed deltas 0.0 km/h
15:23:25
  IDE05707   Haldex clutch pump current 0.005 A
Sunday,23,August,2020,09:02:52:47231
09:02:47
  IDE00075   Vehicle speed 0 km/h
  IDE00085   Normed load value 20.8 %
  IDE00190   Charge air pressure specified value 0.965 bar
  IDE00191   Charge air pressure: actual value 0.964 bar
  IDE00195   Coolant temperature difference between engine and radiator 65.2 °C
  IDE00556   Outside air temperature 21 °C
Sunday,23,August,2020,15:13:06:47231
Mode 01 - PID 01 : Readiness  --  Address 7E8
Number of DTCs stored: 0  --  MIL Status: MIL OFF
Misfire monitoring:  Passed
Fuel System:  Passed
Comprehensive Components:  Passed
Catalyst monitoring:  Passed
Heated catalyst monitoring: Not installed.
Evaporative system monitoring:  Passed
Secondary air system monitoring: Not installed.
A/C system refrigerant monitoring: Not installed.
Oxygen sensor monitoring:  Passed
Oxygen sensor heater monitoring:  Passed
Exhaust Gas Recirculation:  Passed
15:25:19
  IDE00085   Normed load value 22.7 %
  IDE00190   Charge air pressure specified value 0.962 bar
  IDE00191   Charge air pressure: actual value 0.966 bar
  IDE00195   Coolant temperature difference between engine and radiator 60.7 °C
15:43:12
  IDE00085   Normed load value 23.5 %
  IDE00190   Charge air pressure specified value 0.950 bar
  IDE00191   Charge air pressure: actual value 0.953 bar
  IDE00195   Coolant temperature difference between engine and radiator 63.7 °C
Sunday,30,August,2020,08:27:33:47231
                Address 02: Auto Trans  (0D9 300 012 L)
08:27:23
  IDE00024   Transmission fluid temperature 28 °C
Friday,18,September,2020,14:45:35:47231
14:45:26
  IDE00021   Engine speed N/A
  IDE00085   Normed load value N/A
  IDE03711   Mass flow through throttle valve N/A
  ENG109006-ENG100882   Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX N/A
  ENG109007-ENG99938   Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX N/A
Saturday,19,September,2020,15:17:52:47231
UDS Adaptation Channel (246/2473): IDE05145-ENG115943-Light configuration-Dimming Direction EF 3
Stored value maximize
morris39
Canada
C?ID=395084
The odd Log below
15:21:42
15:10:20
15:23:12
15:23:25
09:02:47
Fuel System:  Passed
15:25:19
15:43:12
08:27:23
14:45:26
I forgot to mention that for the last 2-3 sessions the Options/Config menu does not allow screen size adjustment but goes to 16 automatically. So to see the bottom of the screen which contains the Save command I use Windows to reduce the size. The laptop is a newish Dell 13XPS.
Laptop specs? Make, model, CPU, RAM, version of Windows? What "nannyware" do you have running on it? Is USB Selective Suspend on?
Pay attention to the file names. If you do a new log and the file name is the same, it will be appended to the existing data in that file.
I doubt it that there's anything wrong with the install. Re-installing should not affect existing logs and scans, but if you want to be doubly sure, just make a backup copy of your Logs and Scans sub-folders somewhere else.
Window size setting is saved. If you've made it too big for your screen, start VCDS, click the "skateboard" icon on the left end of the title bar. From the the menu that appears, select "Delete config file and close". Then re-start VCDS and make window size changes more incrementally.
morris39
Canada
C?ID=395084
Thanks Uwe. Tested function today using old laptop which also failed but pop up said "Firmware UIpdate needed". That msg did not appear on the std laptop, So I updated the interfdace on the old computer and it works. The only part that is not identical between the 2 trials besides the laptop is the USB A to C adapterfor the new computor.
New laptop is Dell XPS, 8GB memory, SSD HD, Intel i5-1021U core, Win10 OS, no 3rd party antivirus, Dell Support nanny but usually asks.
No time for today for further testing.
If I do have to load new version of the program so I not have to delete the existing and so also deletemy saved files>
South Molton, UK
You don't have to delete the old version of VCDS to update to a new version, it happily installs over the top without deleting your saved logs, etc.
morris39
Canada
C?ID=395084
Update. Hex-V2 works now on std. computor without reloading the program. Problem was with the interface which needed to be updated. Why that appeared during a working session is still a mystery to me. VCDS screen image size adjusted successfuly. Uwe gave instruction for that. Is that info found elsewhere , say the Q&As? I had not seen it.
Thanks Uwe and PetrolDave
