General question coding Fog lights
DanF
Denmark
C?ID=388943
Hey.
I am new in this world, and have so much to learn.
I have a general question about coding in VCDS.
Can an Adaption change anything in other settings without me noticing?
Example:
I have a Skoda Octavia 1.4TSI DSG 2018. There are original full LED headlights with static cornering light mounted.
If I want to get my fog lights as corner lights at the same time.
Can there be a conflict in the codes?
so when I code the fog lights, can the original coding for my headlights be changed without me noticing?
I want to code my fog lights with several things.
-Corner light when low beam is on
-As DRL simultaneously with original DRL
-Works simultaneously with high beam
-Turned on in reverse.
Someone who can help with Adaption to it (I do not have Long Coding Helper)
Tuesday,08,September,2020,15:39:45:49496
VIN: TMBJC9NE0J0132343   License Plate: CM94732
Mileage: 73032km-45379mi   Repair Order:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 20 42 44 4B 52 5F 69 D6 D7
VIN: TMBJC9NE0J0132343   Mileage: 73032km-45379miles
Address 01: Engine (J623-CZDA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HD    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H26 3742
   Revision: R7H26---
   Coding: 01250032247419080000
   ASAM Dataset: EV_ECM14TFS01104E906027HD 001007
   ROD: EV_ECM14TFS01104E906027HD.rod
   VCID: 6D87CE06FD1DEBE3895-8038
   CAN Converter 01:
Readiness: 0010 0001
   Part No SW: 0CW 300 043 T    HW: 0AM 927 769 E
   Component: TVS DQ200G2_M H05 9999
   Revision: 00005026    Serial number: CU501707095696
   Shop #: WSC 46777 002 1048576
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 48C95F92B23FEECBDA3-801C
   Revision: 00000000    Serial number: 62057000000875
   Coding: 25076A912423216E407A060440C624A456248402600224723621F070C002430000000012121212B8586C384E4484EE
   Shop #: WSC 73430 031 00000
   ROD: EV_Brake1UDSContiMK100IPB_036_SK37.rod
   VCID: 77ABEC6E8F415133639-8022
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 55
                    Mileage: 72190 km
                    Date: 2020.07.22
                    Time: 12:44:41
   Part No SW: 5E0 907 044 AQ    HW: 5E0 907 044 AQ
   Component: Climatronic   H04 2001
   Revision: 00001K00
   Coding: 02010004000110011005000800101022
   Shop #: WSC 73430 031 00063
   ROD: EV_ACClimaBHBVW37X_006_SK37.rod
   VCID: 74B1DB629E373A2B46B-8020
   Air quality sensor:
   Part No SW: 5Q0 937 086 BM    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 034 0242
   Revision: --------    Serial number: 865811071701WS
   Shop #: WSC 73430 790 00000
   ROD: EV_BCMBOSCH_018.rod
   VCID: 065591AAF8AB38BB68F-8052
   Subsystem 1 - Part No SW: 5E1 955 119 A    HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 170621  051 0915
   Serial number: 887353F0401717200729
   Coding: 164DDD
   Component: RLHS  042 0105
   Serial number: S5Y17M08D01H06M48S33
   Coding: 00885D
   Part No SW: 5QA 919 294 A    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0038
   Serial number: 000308418617125
   Coding: 0471051911
   ASAM Dataset: EV_EPHVA18AU3700000 009031
   VCID: 4ACD659AAC331CDBCC7-801E
12658704 - Databus
          [Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
                    Reset counter: 0
                    Mileage: 71611 km
                    Date: 2020.07.15
                    Time: 08:15:10
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 3300600941FFC728949C810520400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: 3E25394AE0FBA07B60F-806A
   Part No SW: 3Q0 959 655 BK    HW: 3Q0 959 655 BK
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W6PEKE81.
   Coding: 98FCC000000000005C5400CC000800000065
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 08499F92F2BF2ECB1A3-805C
   Belt Pretensioner left:
   Serial number: 34169593D02081750061
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169592D30071740129
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 454 000 607 17
   Serial number: 35700000000B546CC72V
   Subsystem 4 - Part No SW: -----------    HW: 454 001 307 17
   Serial number: 35800000000ECC1C472.
   Subsystem 5 - Part No SW: -----------    HW: 454 801 807 17
   Serial number: 3510009C23C100000005
   Subsystem 6 - Part No SW: -----------    HW: 454 801 207 17
   Serial number: 3520065109910000000+
   Subsystem 7 - Part No SW: -----------    HW: 454 801 906 17
   Serial number: 35500BF8B0210000000I
   Part No SW: 5Q0 953 507 HB    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 02081704401308
   Coding: 6410
   VCID: 7DA7FE46AD7D7B63395-8028
617752 - Selector Lever Park Position Lock Switch
          B1162 29 [024] - Signal Implausible
                    Reset counter: 85
                    Mileage: 73006 km
                    Date: 2020.09.05
                    Time: 15:03:21
                    Operating time: 95369 min
                    Supply voltage: Terminal 30: 12.8 V
                    Vehicle speed: 66 km/h
                    Voltage at switch: 4.98 V
                    Terminal 15 status: active
                    System status: 30
   Part No SW: 5E0 920 750 E    HW: 5E0 920 750 E
   Component: KOMBI         303 0310
   Coding: 07A40A082D80000801886A011001000000000000
   VCID: 2615F12A186B18BB08F-8072
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   433 4303
   Revision: --------    Serial number: 0006629722
   Coding: 030100347F085700EB00025E1C0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 3333187EDBB97D139F1-8066
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Serial number: 000000000C2734270617
   Serial number: 75886000001707170960
Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
   Part No SW: 3G0 857 511 G    HW: 3G0 857 511 G
   Component: FLA           H10 0003
   Revision: AA001001
   Coding: 0404000700000000000000
   ASAM Dataset: EV_HighBeamAssisAU33X 001017
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   VCID: 2C010302068722EBDEB-8078
   Serial number: 0000268997317
   Coding: 001D0120D000048000001100
   VCID: 47CB5CAEBF21E1B3D39-8012
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  005 0007
   Serial number: 00000000000015571714
   Coding: 010200
   Component: EPS_MQB_ZFLS  129 1072
   Coding: 0107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45D756A6852DF3A3215-8010
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 30071710801380
   Coding: 000000070100046200003D01010000000000000000000000000000000000
   Shop #: WSC 73430 790 00063
   VCID: 72BDDD7AE423341B547-8026
   Serial number: 0000268639114
   VCID: 46D551AAB82BF8BB28F-8012
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  005 0007
   Serial number: 00000000000014504483
   Coding: 190200
   Part No SW: 5Q0 035 864 C    HW: 5Q0 035 864 C
   Component: MU-S-N-ER     H41 0456
   Serial number: SKZAZ2T5297506
   Coding: 03730201FF00000051110001000802002F0208C401200500CF
   ROD: EV_MUStd4CTSAT_VW37.rod
   Subsystem 1 - Part No SW: 5E0 919 605 M    HW: 5E0 919 605 M
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: SKZ6ZHT2113922
   Subsystem 2 - Part No SW: 5L0 051 236 P    HW: -----------
   Component: ECE1 2017  --- 0730
   Part No SW: 5Q0 907 383 L    HW: 5Q0 907 383 L
   Component: Anhaenger     H27 0260
   Revision: 8C001004    Serial number: 0452481141
   Coding: 0100000202000000
   VCID: 40D947B29A0FD68B123-8014
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
   VCID: 7EA5F94AA07B607B20F-802A
   ROD: EV_LED_PLUS_R_KEBODAVW416_VW41.rod
End----(Elapsed Time: 01:45, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)-----
TBAx
DE
C?ID=287144
Should be no big deal to code them according to your requirements.
However you state, that static cornering light is already present, so I wonder why you put options on your "wishlist", that are already there by default.
DanF
Denmark
C?ID=388943
Please post an admap of module 09 between CODE tags. How-to: https://www.ross-tech.com/vcds/tour/controller-channels-map.php
okay, look at it tomorrow, I think I can figure out how. i hope
You ask me why, with cornering light in fog light. Just for fun and because I think it looks good, and to begin with a little experience, have never coded anything before.
so when you write "no big deal" for me it is because as I said I have never coded anything before.
What about those conflicts i ask about, is it something I need to worry about, or is it just getting started?
TBAx
DE
C?ID=287144
I don‘t see any obvious conflicts.
The bold marked features should already be present in your car. Can you confirm? Please be aware, that the static cornering lights are only available in the LDS (rotary light switch) „AUTO“ position.
DanF
Denmark
C?ID=388943
Hello again.
No I do not have any of the features in my car.
I think it's because I have static LED headlights, the factory probably does not think it is necessary to have it in headlights and fog lights at the same time. but I want.:D
Did I understand correctly that AdMap file can be used as a backup of a control box?
So good idea to make an AdMap file before I start coding anything?
What file type is best to create that file in, Pre-label, CSV or Raw Hex? Or should I make one in all file types?
siLc
Tallinn, Estonia
C?ID=330192
Since 2017 models there is no coding in the BCM, the lighting features are modified using adaptation channels. To even start to suggest what to change, we need to see the adaptation map. And yes, you can use the output as a backup.
DanF
Denmark
C?ID=388943
Yes I know it has to be done in the adaptation channel, therefore I want to be confident in what I do and understand it.
Have also made an excel program where I enter what I change in Adaption.
How do I paste that AdMap file as an attachment or text?
Previously asked what file type I should make the AdMap in.
DanF
Denmark
C?ID=388943
I have made the AdpMap, but need a bit help, how can i attach in here, as an CVS file.
South Molton, UK
CVS is just a fancy text file, open it in Notepad then Select All and Copy - then paste it here between code tags (use the </> icon).
DanF
Denmark
C?ID=388943
Here it come, only 09-Cent. Elect.AdpMap. Hope some of you can see something.
SW:5Q0-937-086-BM   HW:5Q0-937-086-BH ---  Cent. Elect.
    Component:BCM PQ37BOSCH 034 0242, Coding:
    EV_BodyContrModul1UDSBosc,018001,EV_BCMBOSCH_018.rod
    Sunday,20,September,2020,12:30:55:49496
    VCDS Version: Release 20.4.2 (x64)  Data version: 20200730 DS317.0
IDE01550-Service position,157.999843 °,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,not active ,10
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,active ,8
IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen,not active ,8
IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1,8 s,8
IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,16 s,8
IDE02711-ENG112304-Rear Window Wiper-Heckwischer,logikgesteuert ,8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer,Keine_Spannungsanforderung ,8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,not active ,8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck,0 ms,8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-0.3 °,16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,0.0 %/s,16
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides ,16
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h,16
IDE03638-ENG116682-static AFS light-Maximaltemperatur,0.0 °C,16
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,0.0 °C,16
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,65 °,16
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,0.0 °C,16
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,40 °,16
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,16
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,16
IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht,15 min,16
IDE04927-IDE01446-Window heater-Running time of heated front window,600 s,11
IDE04927-ENG126845-Window heater-FSH Automatik,active ,11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,not active ,11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,not active ,11
IDE04927-ENG141962-Window heater-Waschduesenheizung,not installed ,11
IDE04928-MAS01577-Anti-theft device-Parking heater,not installed ,8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,8
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,not active ,8
IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick,not_active ,8
IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI,not_active ,8
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,8
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,not installed ,8
IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor,not installed ,8
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
IDE04928-ENG142249-Anti-theft device-OBD Alarm,activ ,8
IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm,not_active ,8
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung,No ,8
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,8
IDE04928-ENG142008-Anti-theft device-tilt_sensor,No ,8
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active ,8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,2 sekunden verzoegerung ,8
IDE05143-MAS02985-Writing parameter-Value,130 ,5
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00 ,5
IDE05144-Read parameter address,FE 00 00 ,3
IDE05145-Light configuration,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00 05 44 00 4B 46 08 7F 0A 00 7F 00 00 00 00 00 00 05 3A 00 49 46 08 7F 09 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 00 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 00 64 00 00 00 00 00 00 00 00 00 ,224
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,30 s,30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,1.10 °C,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,33.00 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,32.00 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,33.00 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,32.00 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,37.50 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,36.50 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,37.50 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,36.50 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,41.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,40.00 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,41.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,40.00 °C,30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Keine_Spannungsanforderung ,30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.0 V,30
IDE06507-MAS13132-Button in center console-Function of button 3,NOT-DEFINED ,8
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich,not active ,8
IDE07007-ENG142252-A/C heater function via remote control-Abbruch_Hupen_RSt,not active ,8
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige,not active ,8
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik,not active ,8
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,not active ,8
IDE07007-ENG115720-A/C heater function via remote control-Remote Start,not installed ,8
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung,not active ,8
IDE07356-Position during interval mode,16.999983 °,2
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,not active ,6
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active ,9
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor,not installed ,9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,0 ,19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,active ,19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,active ,19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.50 s,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,1 ,19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,4 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,5 ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,4 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,20 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,30 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,0 %,19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,not active ,19
IDE09731-ENG98648-Int. light: 2nd generation-Interior light,Keine_Spannungsanforderung ,19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active ,19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,active ,19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,1 ,5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,active ,5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,active ,5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,5
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,30 %,17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,30 %,17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,50 %,17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,50 %,17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,50 %,17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,50 %,17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,50 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,50 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,70 %,17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,70 %,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,installed ,17
IDE10298-Alternating park position 1,0.000000 °,2
IDE10299-Alternating park position 2,13.999986 °,2
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,0.00 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,1.00 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.37 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000011  ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00110000  ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00001100  ,256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00011001  ,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,0 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,0 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,0 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,0 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,0 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,100 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,0 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,100 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,0 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,40 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,37 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,0 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,0 %,256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,125 %,256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,125 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,0 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,0 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,125 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,125 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,0 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,100 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,0 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,40 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,37 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,0 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,40 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,37 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,0 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,40 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,37 %,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,1.0 s,256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,235 ,30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,57 ,30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,5 ,30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,55 ,30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,40 ,30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,240 ,30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,222 ,30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7,255 ,30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,255 ,30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,221 ,30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,255 ,30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,172 ,30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,108 ,30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,116 ,30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,76 ,30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,102 ,30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,192 ,30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,204 ,30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,217 ,30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,182 ,30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,255 ,30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,253 ,30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,242 ,30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,252 ,30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,132 ,30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,1 ,30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung,not installed ,3
IDE11944-ENG141948-Keyless access and start authorization-Kessy,not installed ,3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,active ,3
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin,71 ,30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,6 ,30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,2 ,30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,106 ,30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,182 ,30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin,254 ,30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin,153 ,30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin,4 ,30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin,231 ,30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin,132 ,30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,200 ,30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,73 ,30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,9 ,30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,134 ,30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,140 ,30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,110 ,30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,255 ,30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin,245 ,30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,120 ,30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin,57 ,30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,255 ,30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin,173 ,30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,255 ,30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,255 ,30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,106 ,30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,29 ,30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin,58 ,30
MAS05055-lower turn position,16.999983 °,2
MAS05056-upper turn position,157.999843 °,2
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,59395 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,50 00 ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,2000 lx,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,37905 mV,24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,225300 lx,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,53255 mV,24
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,active ,4
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1,multicolor ,30
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,1 ,60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,2 ,60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,3 ,60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,4 ,60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,04 ,60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,8 ,60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,12 ,60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,16 ,60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,installed ,60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,installed ,60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,installed ,60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,installed ,60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Keine_Spannungsanforderung ,23
ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0,0 ,23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,0 ,23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,0 ,23
ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11,0 ,23
ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12,0 ,23
ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13,0 ,23
ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14,0 ,23
ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15,0 ,23
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2,0 ,23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,0 ,23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,0 ,23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,0 ,23
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6,0 ,23
ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7,0 ,23
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8,0 ,23
ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9,0 ,23
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,not active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,not active ,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,not active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,not active ,10
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze,50 km/h,9
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze,50 km/h,9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,active ,9
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,9
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights,not installed ,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active ,18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light,Keine_Spannungsanforderung ,18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,46400 lx,18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,10 seconds ,18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal,Keine_Spannungsanforderung ,18
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: FLA: Fernlicht ueber AFS ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,present ,6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay,0 ms,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,active ,6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus,active ,6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active ,6
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,100.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,83.00 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,67.00 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,50.00 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,33.00 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,17.00 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,-0.00 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,-0.00 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,-0.00 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-0.00 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,44.0 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,38.0 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,33.0 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,28.0 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,24.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,17.0 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,10.0 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,10.0 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,10.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,10.0 %,30
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,00 ,16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15,36 - LED Kleinleistung ,16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Unknown (76),16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,27 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,3F ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,43 - allgemeine LED ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,Parking light right ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,127 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,26 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,35 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,43 - allgemeine LED ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,12 - Blinkleuchten ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,12 - Blinkleuchten ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,0 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,00 ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,not active ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,not active ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake light ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake light ,16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,34 - LED Bremsleuchten ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,100 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,100 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,32 - allgemeine LED bis 12W ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Coming Home oder Leaving Home aktiv ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,100 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,100 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,32 - allgemeine LED bis 12W ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Coming Home oder Leaving Home aktiv ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,100 ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,32 - allgemeine LED bis 12W ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,2F ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1C ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,not active ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100 ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,0 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,not active ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,not active ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,20 - 4* 5W ,16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,Ambientelicht 2 ,16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,Ambientelicht 3 ,16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,Ambientelicht 4 ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,0 ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,not active ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,not active ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,0 ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,not active ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,not active ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,0 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,not active ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,not active ,16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,4B ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,44 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,5 - LED Abblendlicht ,16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Parking light right ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,49 ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,3A ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,5 - LED Abblendlicht ,16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,0C 08 00 16 02 00 64 00 00 00 00 00 00 00 00 00 0C 18 00 18 04 00 64 00 00 00 00 00 00 00 00 00 22 09 00 2B 18 00 64 00 00 00 00 00 00 00 00 00 22 19 00 2D 18 00 64 00 00 00 00 00 00 00 00 00 22 29 00 2C 18 00 64 00 00 00 00 00 00 00 00 00 20 0A 00 29 08 09 64 1E 00 64 00 00 00 00 00 00 20 1A 00 2A 08 0A 64 1E 00 64 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 20 0C 00 2E 1A 00 64 00 00 00 00 00 00 00 00 00 00 1C 00 2F 00 00 00 00 00 00 00 00 00 00 00 00 09 0B 00 31 19 00 64 00 00 00 00 00 00 00 00 00 09 1B 00 32 19 00 64 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,2B 3F 00 27 08 0A 7F 00 00 00 00 00 00 00 00 00 2B 35 00 26 08 09 7F 00 00 00 00 00 00 00 00 00 14 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 03 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 2F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 30 00 00 00 00 00 00 00 00 00 00 00 24 00 00 00 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,2700 mm,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,100.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,0.0 %,62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-114.3 ms,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,5.00 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,5.00 mm/%,62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,5.00 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,3.00 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,3.00 mm/%,62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,3.00 mm/%,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,44.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.03 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,Inverted ,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,255 km/h,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.03 Hz,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,Rear ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,active ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,0.0 %,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,1000.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,0.0 %,62
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-3.71 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-2.96 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-2.04 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-1.48 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-0.37 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-0.20 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-0.10 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-0.05 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-0.01 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-0.00 ,20
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet,installed ,8
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,4 ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_inactive ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Schluessel ,16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,not active ,16
ENG141646-MAS01065-Querschnitts_funktionen-Brand,Skoda ,5
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,not active ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Keine_Spannungsanforderung ,5
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,installed ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,2000 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,600 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,600 ms,10
ENG141684-SFT271873-Slave_systems_identification-Control Unit For Wiper Motor,Not available ,6
ENG141684-SFT271874-Slave_systems_identification-Rain Light Recognition Sensor,Not available ,6
ENG141684-SFT271877-Slave_systems_identification-Garage Door Opener Operating Unit,Not available ,6
ENG141684-SFT271894-Slave_systems_identification-Sensor For Anti Theft Alarm System,Not available ,6
ENG141684-SFT271904-Slave_systems_identification-Sun Roof,Not available ,6
ENG141684-SFT271910-Slave_systems_identification-Ceiling Light Module,Not available ,6
ENG141684-SFT271928-Slave_systems_identification-Roof Blind,Not available ,6
ENG141684-SFT271947-Slave_systems_identification-Relative Air Humidity Interior Sender,Not available ,6
ENG141684-SFT271966-Slave_systems_identification-Neck Heating Left,Not available ,6
ENG141684-SFT271967-Slave_systems_identification-Neck Heating Right,Not available ,6
ENG141684-SFT272065-Slave_systems_identification-Seat Backrest Fan 1 Front Left,Not available ,6
ENG141684-SFT272067-Slave_systems_identification-Seat Cushion Fan 1 Front Left,Not available ,6
ENG141684-SFT272069-Slave_systems_identification-Seat Backrest Fan 1 Front Right,Not available ,6
ENG141684-SFT272071-Slave_systems_identification-Seat Cushion Fan 1 Front Right,Not available ,6
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung,not active ,5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,active ,5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt,not active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,active ,5
ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt,25 ,10
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,CAN ,10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,10.0 min,10
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1,72.0 %,22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2,48.0 %,22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3,33.0 %,22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4,18.0 %,22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5,12.0 %,22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6,8.0 %,22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7,6.0 %,22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8,4.0 %,22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9,2.0 %,22
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,0.0 s,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,0 ,21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,60 %,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,20.0 %,21
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3,510 lx,8
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,50 ,12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,100 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,2.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,2.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,6.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,10.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,80.0 %,12
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,not active ,4
ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba,not active ,9
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein,not active ,7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt,installed ,7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster,installed ,7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,installed ,7
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,active ,4
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,not installed ,7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste,No ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Pulse control ,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,active ,8
Elapsed Time: 02:07
@DanF : To make the fogs do all the wants in your first post - maybe something like this, perhaps:
Left front fog light
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12 > maximize
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12 > maximize
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12 > maximize
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12 > 100
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12 > 100
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12 > 100
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12 > 0
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12 > 22
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12 > 38
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12 > 10 - allgemeine Scheinwerfer
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12 > Always
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12 > Nebellicht links
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12 > Abbiegelicht links
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12 > Left high beam
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12 > Lichthupe generell
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12 > Daytime running lights
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12 > not active
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12 > not active
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12 > not active
Right front fog light
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13 > maximize
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13 > maximize
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13 > maximize
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13 > 100
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13 > 100
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13 > 100
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13 > 0
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13 > 23
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13 > 42
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13 > 10 - allgemeine Scheinwerfer
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13 > Always
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13 > Nebellicht rechts
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13 > Abbiegelicht rechts
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13 > Right high beam
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13 > Lichthupe generell
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13 > Daytime running lights
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13 > not active
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13 > not active
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13 > not active
Because IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt is already set to both sides, your fogs and your LED static corning lights should illuminate when reversing with the above changes- I think.
PS: I've included both High-beam ON and High-beam flash in the table - please advise if you didn't want the latter
PPS: when selecting the Daytime running lights setting, use the version marked 1A in the picture below (don't use 2A)
DanF
Denmark
C?ID=388943
wow, a great job, say thank you very much. I will try it as soon as possible.
What you write about light in reverse. Do you mean that I already have the fog light on in reverse? Or do I misunderstand?
Since I am brand new an this world and I would like to learn and understand what I do with this coding.
So if it's not too much to ask you? If you want to split the codes so that I can code it individually, then I have a better opportunity to follow what I do. If it is possible
I'm really just aping @TBAx comment which is confirmed by the admap setting of IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt (which is broadly translated in English as "AFS light - when driving backwards").
So, as your BCM is currently programmed, the LED static cornering lights should already illuminate when the car is in reverse. After you add Abbiegelicht links/rechts command as in my table - this facility should be extended to the front fog lights.
hmm......... not sure if you want to learn about Leuchte programming, or if you just want a more detailed instruction set as to how to proceed.
If the former, I'm happy to oblige - but @TBAx is the real expert on this stuff (I learned from his early work on Leuchte-sets).
If the latter, try this:
  1. Fire-up VCDS software and navigate to the screen below and press Select:
  2. Select 09-Cent. Elect. on the screen below:
  3. Select Security Access -16 on the screen below:
  4. Click in the dialogue box on the screen below and the balloon shown should appear. As indicated in the balloon, enter the magic number 31347 and click Do it!!.
  5. Back on the screen in Step 3 above, click on Adaptation-10.
  6. Click in the dialogue box under "Search" in the screen below and enter ENG116948 (instead of "ha59" - I used the screen below for another purpose originally).
    Then click on the down-arrow in the screen below (i.e. "2") and you will see a list of the 19 x adaptation channels for the Left front fog light as per the upper part of the table in my post above.
  7. select the first of the channels from the down-arrow list and click on the box under New value in the screen below (ignore the values shown in the screen - I developed the picture for another purpose originally)
  8. Select the value shown in my table above for the first adaptation channel and press Do it! to enable the change
  9. Repeat Step 7 & Step 8 above for the remaining 18 x channels in the Left front fog light
  10. Back on Step 6 , click in the dialogue box under "Search" in the screen and enter ENG116949 to access the 19 x adaptation channels for the Right front fog light - as per the lower part of the table in my post above.
  11. Repeat Step 7, Step 8 and Step 9 above for the 19 x adaptation channels for the Right front fog light
  12. Exit VCDS software and try the new front fog light functions
PS: There are a total of 38 x adaptation channels involved in this tweak - proceed carefully and be very sure that the change is correct in every instance before you click Do it!
DanF
Denmark
C?ID=388943
Sorry i give you all that work :rolleyes:
Oh okay that way, yes I have static corner light in the headlights, so yes it is already active.
Sorry, think you misunderstood or I did not explain myself correctly. I know a little about how to use and code in VCDS.:D
The codes you have sent to me, yes I can just type them in and use them, but do not know more exactly what codes there are for what, of course something I can guess.
So what I meant and asked you about. If you have the opportunity to splitting the codes up, then one chapter is only for fog lights + high beam, and one is only for fog lights as DRL. Can you follow me?
Then I can more easily make documentation of what has changed if I later only want to remove one of the Adaptations.
Dan:thank you - but no need for contrition. Uwe pays ALL forum members for each letter that they type on this forum. So - feel free to be as prolific as possible and you can expect a big juicy Ross-Tech cheque in the mail. I've received many such cheques over the years - but they all seem to be made of rubber (i.e. they bounce)!! :facepalm:
OK - let's try this another way!
First, allow me to introduce you to the concept of a "Leuchte-set". On MQB platform vehicles like your Skoda, each of the 35 x exterior lights are controlled by individual Leuchte-sets. A Leuchte-set is a group of 19 x adaptation channels that live in the BCM. Ignoring the TAG numbers, the first part of the name for each of these 19 x channels is common and it starts with the term "Leuchte". Look at the channels in my table above to see this pattern.
The second part of the name of these 19 x channels establishes the the structure of a Leuchte-set and this structure is the same for each of the 35 x Leuchte-sets. I can best explain this by re-organizing the channels in my first respone by the second part of their names like this:
Ignoring the "4" (I developed the picture for another purpose) - I hope that you can see how the 19 x channels in a Leuchte-set in my first response can be re-ordered as in the picture.
As indicated in the picture, the first 3 x channels in a Leuchte-set define the lamp set-up and how the light will be monitored by the BCM for faults. Of more importance for your task however, notice how the rest of the structure of a Leuchte-set is just 4 x repeats of what I've called an "Alpha-pair" - each of which contains 4 x channels. The relevance of an Alpha-pair to your task is that each Leuchte-set permits a lamp to operate in up to 4 x different modes with each "mode" allowing 2 x lighting functions. So, in total, a Leuchte-set can be programmed to operate each lamp with up to 8 x lighting functions - which I reckon is pretty amazing!!
hopefully, you are still awake (well.....not comotose, at least) and following! If I strip-off the non essential part of the channel names in my first response and if I re-order the channels as per my picture above, this is what results:
Leuchte12NL LB45: left-side fog-lightSettingComment
Lasttyp 1210 - allgemeine Scheinwerfer
Lampendefektbitposition 1238
Fehlerort mittleres Byte DTC-DFCC 1222
Lichtfunktion A 12Nebellicht linksleft-side fog-Light
Lichtfunktion B 12Abbiegelicht linksleft-side cornering-light
Dimmwert AB 12100full illumination
Lichtansteuerung HD AB 12Always
Lichtfunktion C 12Left high beamleft-side high-beam
Lichtfunktion D 12Lichthupe generellhigh-beam flash
Dimmwert CD 12100full illumination
Dimming Direction CD 12maximize
Lichtfunktion E 12Daytime running lightsDRL
Lichtfunktion F 12not active
Dimmwert EF 12100full illumination
Dimming Direction EF 12maximize
Lichtfunktion G 12not active
Lichtfunktion H 12not active
Dimmwert GH 120
Dimming Direction GH 12maximize
Leuchte13NL RB5: right-side fog-lightSettingComment
Lasttyp 1310 - allgemeine Scheinwerfer
Lampendefektbitposition 1342
Fehlerort mittleres Byte DTC-DFCC 1323
Lichtfunktion A 13Nebellicht rechtsright-side fog-Light
Lichtfunktion B 13Abbiegelicht rechtsright-side cornerning-light
Dimmwert AB 13100full illumination
Lichtansteuerung HD AB 13Always
Lichtfunktion C 13Right high beamright-side high-beam
Lichtfunktion D 13Lichthupe generellhigh-beam flash
Dimmwert CD 13100full illumination
Dimming Direction CD 13maximize
Lichtfunktion E 13Daytime running lightsDRL
Lichtfunktion F 13not active
Dimmwert EF 13100full illumination
Dimming Direction EF 13maximize
Lichtfunktion G 13not active
Lichtfunktion H 13not active
Dimmwert GH 130
Dimming Direction GH 13maximize
So, bottom line (both figuratively and physically) - that's how each of my suggested changes translates into your stated wants . QED!!
Don (looking forward to my next rubber cheque)
DanF
Denmark
C?ID=388943
I work in shift and on night shift at the moment :banghead:
Seems to have understood some of it.
So once I've made those changes, is it actually still possible for 2 more tweaks on channel G and H?
Dimmwert AB means that I control the brightness of 2 channels at the same time, in this case channel A and B?
So if I want less light on my DRL in the fog lights, then I need to change the Dimmwert EF 12 from 100 to 75 maybe, both sides of course, Did I understand correctly?
Dimming Direction, what does it do?
If I want to turn off fog lights plus high beams, but want to keep it with Flash, then I have to switch Light function C 12 to not active, and nothing else?
Lastype
Fehlerort Mittleres Byte
These 3 are not someone you change once the lamp is made active?
Is the same method on all lamps?
Is there a list of what the lamps are called / have by number?
