Predictive ACC Coding
nibose
Perth, Australia
C?ID=371170
Not possible with your radar afaik. 2Q0 or 3QF. MRREvo14f.
and not possible with just coding. pACC is once more under our friend SWaP and needs proper FeC to be enabled.
Hi, Yes, I'm aware that I need a new radar. Before ordering the radar (before spending money), i need to know if I can have pacc. The main reason is that traffic sign recognition does not currently work in fusion mode. I'd updated the firmware in A5 but to no avail.
How can I get TSR to work in fusion mode?
Dont think pacc will work properly without fusion mode.
   #22
downtime
Finland
C?ID=280813
What do you mean it does not work in fusion mode? How is it visible? In which part of the world you live? Some areas like south America do not have all the features of the map data available.
   #24
According to nibose' profile he is in Perth, Western Australia.
"WA" wasn't really clear and could easily be confused with the US State of Washington. I just changed it to, "Perth, Australia", which is pretty unambiguous.
nibose
Perth, Australia
C?ID=371170
Hi Everyone,
I'm from Perth, Western Australia.
I tried setting TSR to fusion mode but then no signs are displayed. It works well in "traffic sign recognition mode" though.
Which makes me wonder if upgrading the dataset will enable fusion mode.
   #26
downtime
Finland
C?ID=280813
No, it means it cannot read the traffic signs from the map data. So something either not correctly coded or no traffic signs in map data at all.
Can you put your A5 coding and adaptation map here?
   #27
Mrclopec
Nipomo, CA, USA
C?ID=149231
No TSR, w/ Signs showing from Map Data - Normal
TSR w/ Signs from camera and not from map data - Normal
TSR w/ Fusion and no signs showing - This anomaly is interesting...
Makes you wonder if the lack of PSD in the navigation data overrides the ability of the system to display traffic signs solely identified by A5 in fusion mode. That would be lame...
   #28
downtime
Finland
C?ID=280813
^ Exactly. That's why the coding and adaptations from A5 would be interesting to see. Especially what has been coded in A5 as the map data. It should be PSD1.5.
If TSR is enabled and no map data, signs are recognized and the restricted message appears at some point once in each start. But TSR still works.
   #29
nibose
Perth, Australia
C?ID=371170
Here is the admap of the A5 module:
;SW:3Q0-980-654-L   HW:3Q0-980-654-A ---  Frt Sens. Drv. Assist
;Component:MQB_B_MFK     H09 0610     Coding:000408010000010100022346C150890094000E30004000
;EV_MFKBoschMQBB    2041    EV_MFKBoschMQBB_002.rod
;Thursday    3    June    2021    20:33:59:34260
;VCDS Version: Release 21.3.0 (x64)  Data version: 20210226 DS325.0
;VCID: 40D941F37A0B9E4BCF3-8014
IDE00001-Production mode    Deactivating     3
IDE00820-ENG130919-Activating and deactivating all development messages-Activation_of_development_messages_EHR    not activated     1
IDE00820-ENG130920-Activating and deactivating all development messages-Activation_of_development_messages_HCA_lane    not activated     1
IDE00820-ENG130921-Activating and deactivating all development messages-Activation_of_development_messages_HCA_state    not activated     1
IDE00820-ENG130922-Activating and deactivating all development messages-Activation_of_development_messages_internal    not activated     1
IDE00820-ENG130916-Activating and deactivating all development messages-Activation_of_development_messages_lane    not activated     1
IDE00820-ENG130915-Activating and deactivating all development messages-Activation_of_development_messages_reserved    not activated     1
IDE00820-ENG130918-Activating and deactivating all development messages-Activation_of_development_messages_VZF/TSR    not activated     1
IDE00820-ENG130917-Activating and deactivating all development messages-Activation_of_development_messages_WLA    not activated     1
IDE02332-Deactivate production mode    0    3
IDE04160-Direct. stab. assist speed threshold during towing mode    300 km/h    2
IDE04733-Road sign detection fusion mode    Traffic sign detection     1
IDE06425-Dynamometer mode: functional    not activated     1
IDE07358-Distance to calibration field    1500 mm    2
IDE09375-IDE05717-Axle offset-Front axle transverse position    6.80001 mm    4
IDE09375-IDE05718-Axle offset-Rear axle transverse position    5.90001 mm    4
IDE09376-IDE02001-Body height wheel house edge-Body height left front wheel house edge    701 mm    8
IDE09376-IDE02002-Body height wheel house edge-Body height right front wheel house edge    701 mm    8
IDE09376-IDE02003-Body height wheel house edge-Body height left rear wheel house edge    696.75 mm    8
IDE09376-IDE02004-Body height wheel house edge-Body height right rear wheel house edge    698.25 mm    8
IDE09391-MAS08824-Calibration target position-Target 1: calibration mark 1: x-coordinate    2400 mm    24
IDE09391-MAS08825-Calibration target position-Target 1: calibration mark 1: y-coordinate    735 mm    24
IDE09391-MAS08826-Calibration target position-Target 1: calibration mark 1: z-coordinate    1494 mm    24
IDE09391-MAS08827-Calibration target position-Target 1: calibration mark 2: x-coordinate    2400 mm    24
IDE09391-MAS08828-Calibration target position-Target 1: calibration mark 2: y-coordinate    -735 mm    24
IDE09391-MAS08829-Calibration target position-Target 1: calibration mark 2: z-coordinate    1494 mm    24
IDE09391-MAS08830-Calibration target position-Target 1: calibration mark 3: x-coordinate    2400 mm    24
IDE09391-MAS08831-Calibration target position-Target 1: calibration mark 3: y-coordinate    735 mm    24
IDE09391-MAS08832-Calibration target position-Target 1: calibration mark 3: z-coordinate    906 mm    24
IDE09391-MAS08833-Calibration target position-Target 1: calibration mark 4: x-coordinate    2400 mm    24
IDE09391-MAS08834-Calibration target position-Target 1: calibration mark 4: y-coordinate    -735 mm    24
IDE09391-MAS08835-Calibration target position-Target 1: calibration mark 4: z-coordinate    906 mm    24
IDE10407-Personalization of intervention moment at T. 15 on    Early     1
IDE10870-Switch-on condition: lane depart. warn.    on (setting via menu)     1
IDE10872-Warning intensity: lane depart. warning    Medium     1
IDE10873-BAP personalization    activated     1
IDE10924-MAS02479-Initial calibration: result-Yaw angle    -0.274 ∞    8
IDE10924-MAS05286-Initial calibration: result-Roll angle    0.148 ∞    8
IDE10924-MAS05287-Initial calibration: result-Pitch angle    0.320 ∞    8
IDE10924-MAS10678-Initial calibration: result-Camera height    1310 mm    8
ENG130776-ENG130840-Adaptation_tsr-Par_country_code_RSR    0    3
ENG130776-ENG130841-Adaptation_tsr-Par_country_code_VZF    0    3
ENG130776-ENG130838-Adaptation_tsr-Par_country_mode    automatic     3
ENG130776-ENG130839-Adaptation_tsr-Par_relevance_mode    Enabled     3
ENG120319-Mask_error_reactions_for_development    not activated     1
ENG107577-Masked_fault_classes-    255    4
ENG130777-standstill_mode    not activated     1
ENG130781-ENG130836-WLA_adjustment-BrightnessThreshold_active    1    5
ENG130781-ENG130837-WLA_adjustment-BrightnessThreshold_passive    20    5
ENG130779-Xcp_interface    not activated     1
   #30
nibose
Perth, Australia
C?ID=371170
I dont see any info on PSD on the A5 admap.
Do go through and let me know what could be missing.
   #31
downtime
Finland
C?ID=280813
Its’s in A5 coding, not adaptations
   #32
downtime
Finland
C?ID=280813
Coding for the A5 seems to be correct. Do you get the dynamic traffic sign restricted when the fusion mode is set to traffic sign detection?
   #33
nibose
Perth, Australia
C?ID=371170
Yes, I do get the message in (Traffic Sign Detection Mode) for a few seconds and then goes away. The traffic signs are then detected through camera and displayed on virtual cockpit.
There is nothing displayed when in fusion mode, not even errors.
   #34
nibose
Perth, Australia
C?ID=371170
Anybody online to assist me?
Keen to know why TSR does not work for me in fusion mode
   #35
k0mpresd
NC, USA
C?ID=358992
hi, reading this thread, i am in usa, north carolina.
i have coded the TSR inside the modules and it does display correctly.
however, it works exactly as described above.
no tsr when coded to fusion mode and error code display.
with tsr coded to detection mode, the error displays as a passive error, no sound, only display, and then TSR works correctly.
full autoscan posted below.
Tuesday,24,August,2021,15:20:44:55877
VCDS Version: 21.8.0.0 (x64)  HEX-NET CB: 0.4553.4
Data version: 20210731 DS330.0
VIN: WVWPR7AU2KW910599   License Plate:
Mileage: 1087km-675mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 05 08 09 10 13 15 17 19 23 29 2B 39 3C 42 44 4B 51 52
          5F 75 8C A5 BD C0 C5 C6 D6 D7
VIN: WVWPR7AU2KW910599   Mileage: 1087km-675miles
BD-Hi Volt. Batt. Charg. -- Status: OK 0000
C5-Therm. mgt. -- Status: OK 0000
Address 01: Engine (J623-EAZA)       Labels:. 0EA-907-309-V1.clb
   Part No SW: 0EA 906 016 F    HW: 0EA 907 309 A
   Component: E-Vehicle     H24 5002
   Revision: WMH24---    CVN: C3D5AD29
   Coding: 000D0016006400003000
   ASAM Dataset: EV_VCU00XXX0110EA906016F 004006
   ROD: EV_VCU00XXX0110EA906016F_004.rod
   VCID: 3228183A65F52419C5-8066
   VINID: 9E69E088746509B9C90401492408B1C2D9
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 614 517 DB    HW: 5Q0 614 517 AH
   Component: ESC           H62 0856
   Revision: 00000000    Serial number: 60279000000490 CVN: E2304CF2
   Coding: 01FA40A12C21216C857C0209A1CC2980023484A14085943238915058C2E203
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
   ROD: EV_Brake1UDSContiMK100OMG_003.rod
   VCID: 74A4DE22DF616A2917-8020
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 6097250984
   Coding: 132C0C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   VCID: 43C64DFECA4F9D915E-8016
   Part No SW: 5GE 907 044 AN    HW: 5GE 907 044 AN
   Component: Climatronic   H04 1702
   Revision: 00001K01
   Coding: 0002220020011001050500421211140B
   VCID: 085C9AD2B3E97EC94B-805C
   Air quality sensor:
   Part No SW: 5Q0 937 085 BS    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H38 0273
   Serial number: 00001903800196
   ROD: EV_BCMBOSCH_019.rod
   VCID: 0B56A5DEA29F15D166-805E
   Component: WWS    190106  043 0551
   Serial number:         190129054919
   Component: RLHS  052 0107
   Serial number: SAY19M02D06H22M19S10
   Coding: 06A8DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 507 M    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0060
   Serial number: 00000018011904401364
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417319037
   Coding: 2271167811
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 51EA77B600337F01DC-8004
   Part No SW: 5Q0 907 572 P    HW: 5Q0 907 572 J
   Coding: 7D0000C159FFC728949C810580401600000000000000000004
   VCID: 44C44EE2CF419AA967-8010
   Serial number: 003GCR0B8P0G
   Coding: 8CCCFC00002000005000001AC20800000065
   VCID: 47DE59EEFE77B1B182-8012
   Serial number: IBH00000000000AT981H
   Coding: 303139
   Subsystem 2 - Part No SW: -----------    HW: 480 000 402 19
   Serial number: 357000000001D429C83O
   Subsystem 3 - Part No SW: -----------    HW: 480 000 502 19
   Serial number: 35800000000F3CF0193V
   Subsystem 4 - Part No SW: -----------    HW: 480 400 102 19
   Component: SideSensor_Dr  004 6149
   Serial number: 35100011A2B76D05A650
   Subsystem 5 - Part No SW: -----------    HW: 480 400 102 19
   Component: SideSensor_Pr  004 6149
   Serial number: 3520001162B76D01D6B2
   Subsystem 6 - Part No SW: -----------    HW: 480 400 602 19
   Serial number: 35500011A2B7F1C40270
   Subsystem 7 - Part No SW: -----------    HW: 480 400 602 19
   Component: FrontSensor_P  004 6149
   Serial number: 35600011A2B7F1C4B75F
   Part No SW: 5G1 920 895 B    HW: 5G1 920 895 B
   Component: KOMBI         403 4191
   Coding: 0BB4701A6F8CCF050288690B5701032080000000
   VCID: 302C12326BF91609B3-8064
   Part No SW: 3Q0 907 530 AB    HW: 3Q0 907 530 D
   Component: GW MQB EV     621 6366
   Serial number: 29011910800336
   Coding: 0201001704F81000FB001210081D00000001070100070000000300000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6FAED14EB64749F1EA-803A
   Subsystem 1 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0052
   Serial number: 23190000082990099034
   Coding: 2CFFFF
   Subsystem 2 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Serial number: 5758090405
   Part No SW: 5QE 909 059 H    HW: 5QE 909 059 B
   Component: EBKV          H14 0230
   Serial number:   085460012503
   Coding: 06720100321A00010002000500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 005002
   ROD: EV_BrakeBoostBoschMQBOMG_005_VW37.rod
   VCID: 53E67DBE3A2F0D11EE-8006
   Brake pressure reservoir:
   Subsystem 1 - Part No SW: 5QE 909 057 D    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0155
   Serial number: 05802861170119091521
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000010072013
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 312A173660F31F01BC-8064
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Serial number: 0506197877
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D323B06ACABEB6128-8068
   Component: HRE_Slave  H12 0081
   Serial number: 0506635659
   Coding: 020111
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YE007SAO19811
   Coding: 003E13208000040000000000
   ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000027335897
   Coding: 111000
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1082
   Coding: D3020000
   ROD: EV_SteerAssisMQB_015.rod
   Component: FCM MQB Low   002 0345
   Serial number: 30011911600064
   Coding: 000000050900054A00310F01040000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 35222326949B3321E0-8060
   Part No SW: 5QE 907 080 K    HW: 5QE 907 080 K
   Component: LE Gen 3.3H16 2052
   Revision: 00H16000    CVN: 89FB0C7E
   Coding: 40020000000000000000
   ASAM Dataset: EV_DMCM10030115QE907080K 001008
   ROD: EV_DMCM10030115QE907080K.rod
   VCID: 4ED06CCA110D60F9C1-801A
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS001 0287
   Serial number: YE007RLJ14592
   Coding: 003E13208C00040000000000
   ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000027013351
   Coding: 091000
   Part No SW: 5NA 035 047 D    HW: 5NA 035 047
   Component: MU-H-NS-US    H55 1418
   Serial number: A852A0KS002102
   Coding: 02738002FF00000041220001041C08009F0105B401200405DE
   VCID: 3B36351EB2BFE55116-806E
   Subsystem 1 - Part No SW: 5G6 919 606 B    HW: 5G6 919 606 B
   Component: ABT_High-2  H52 9130
   Serial number: VWZ6ZJW0181599
   Subsystem 2 - Part No SW: V03 959 806 CD    HW: -----------
   Component: NAR 2018/2019  --- 0066
   Compact disc data bank:
   Component: Gracenote2  --- 3013
   Component: OCULowMQBUS   009 0570
   Coding: 02737002C2829A017FFE06000000
   ROD: EV_OCULowMQB.rod
Address 8C: HV Battery (J840)       Labels: None
   Part No SW: 5GE 915 225 B    HW: 5GE 915 225 B
   Component: K8C           005 0400
   Serial number: 16011901010197 CVN: 624110320000000028B0002C972676B7972676B7972676B7972676B7972676B7
   ASAM Dataset: EV_BECM08820215GE915225B 001004
   ROD: EV_BECM08820215GE915225B.rod
   Battery interrupt switch:
   Subsystem 1 - Part No SW: 5GE 915 316 B    HW: 5GE 915 316 B
   Component: A2 HVSMBJBECU  011 0311
   Serial number: 00000025011901010029
   Cell module control module 1:
   Subsystem 2 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J991Battmod1  H08 0322
   Serial number: 18B07Y18AH0803228665
   Cell module control module 2:
   Subsystem 3 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J992Battmod2  H08 0322
   Serial number: 18B08Y18AH0803226397
   Cell module control module 3:
   Subsystem 4 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J993Battmod3  H08 0322
   Serial number: 18B08Y18AH0803226122
   Cell module control module 4:
   Subsystem 5 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J994Battmod4  H08 0322
   Serial number: 18B08Y18AH0803226146
   Cell module control module 5:
   Subsystem 6 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J995Battmod5  H08 0322
   Serial number: 18B08Y18AH0803226299
   Cell module control module 6:
   Subsystem 7 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J996Battmod6  H08 0322
   Serial number: 18B07Y18AH0803228596
   Cell module control module 7:
   Subsystem 8 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J997Battmod7  H08 0322
   Serial number: 18B11Y18AH0803227201
   Cell module control module 8:
   Subsystem 9 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J998Battmod8  H08 0322
   Serial number: 18B08Y18AH0803222757
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 0272
   Serial number: 07111815K21328
   Coding: 000307000000020100222354C150890094000E200120
   VCID: 3C343602B7B1E2691F-8068
Address BD: Hi Volt. Batt. Charg. (J966)       Labels:| 5QE-915-022-V2.clb
   Part No SW: 5QE 915 022 AP    HW: 12E 915 022 H
   Component: LMSG          H20 1096
   Serial number: 01148090550010
   Coding: 4A4914040400
   ASAM Dataset: EV_HVChargManagVWMQB 003004
   ROD: EV_HVChargManagVWMQB.rod
   VCID: 0F6EB1CED68729F18A-805A
Address C0: Act. for Ext. Noise (----)       Labels:| 5QE-035-335.clb
   Part No SW: 5QE 035 335 M    HW: 5QE 035 335 B
   Component: E_SOUND_SG    H10 0223
   Serial number: EN190444590000
   Coding: 04
   ASAM Dataset: EV_ENoiseS1NNVW3707 007015
   ROD: EV_ENoiseS1NNVW3707_007.rod
   VCID: 4BD665DEE21F55D1A6-801E
Address C5: Therm. mgt. (J1024)       Labels:* None
   Part No SW: 5GE 907 458 C    HW: 5GE 907 458
   Component: TME-Min       H20 0203
   Serial number: 0100842
   Coding: 02
   ASAM Dataset: EV_ThermContrVISAU49X 001021
   ROD: EV_ThermContrVISAU49X_VW37.rod
   VCID: 45C253E6C47BA3A170-8010
   Subsystem 1 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G395 pT-Sens1  H11 0010
   Subsystem 2 - Part No SW: 12E 963 231 G    HW: 12E 963 231 G
   Component: J848 HV-PTC  H09 0208
   Serial number: LR190383003810000319
   A/C compressor sub:
   Subsystem 3 - Part No SW: 5QE 816 803 E    HW: 5QE 816 803 E
   Component: J842 eKK  H03 0010
   A/C pressure/coolant temperature sensor 2:
   Subsystem 4 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G826 pT-Sens2  H11 0010
   A/C pressure/coolant temperature sensor 3:
   Subsystem 5 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G827 pT-Sens3  H11 0010
   A/C pressure/coolant temperature sensor 4:
   Subsystem 6 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G828 pT-Sens4  H11 0010
   A/C pressure/coolant temperature sensor 5:
   Subsystem 7 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G829 pT-Sens5  H11 0010
   Expansion valve 1 for refrigerant:
   Subsystem 8 - Part No SW: 4M0 816 682 D    HW: 4M0 816 682 D
   Component: N636 EV1_KaMi  H12 0102
   Serial number: 00000000000120611681
   Expansion valve 2 for refrigerant:
   Subsystem 9 - Part No SW: 4M0 816 682 D    HW: 4M0 816 682 D
   Component: N637 EV2_KaMi  H12 0102
   Serial number: 00000000000120611727
   Expansion valve 3 for refrigerant:
   Subsystem 10 - Part No SW: 4M0 816 682 D    HW: 4M0 816 682 D
   Component: N638 EV3_KaMi  H12 0102
   Serial number: 00000000000120611745
   Shut-off valve 1 for refrigerant:
   Subsystem 11 - Part No SW: 4M0 816 703 B    HW: 4M0 816 703 B
   Component: V424 AV1_KaMi  H12 0102
   Serial number: 00000000000140638175
   Shut-off valve 4 for refrigerant:
   Subsystem 12 - Part No SW: 4M0 816 703 B    HW: 4M0 816 703 B
   Component: N642 AV4_KaMi  H12 0102
   Serial number: 00000000000140638223
   Shut-off valve 5 for refrigerant:
   Subsystem 13 - Part No SW: 4M0 816 703 B    HW: 4M0 816 703 B
   Component: N643 AV5_KaMi  H12 0102
   Serial number: 00000000000140554976
Address C6: Batt. Chrg. (J1050)       Labels: 5QE-915-681.clb
   Part No SW: 5QE 915 681 B    HW: 5QE 915 681 B
   Component: OBC Delta-ES  H59 1560
   ASAM Dataset: EV_OBCTwoPhaseDT2VW3707 003009
   ROD: EV_OBCTwoPhaseDT2VW3707.rod
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 393A2F16B883D74104-806C
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 02:00, VBatt start/end: 13.2V/13.2V)-----------
downtime
Finland
C?ID=280813
Any chance to post adaptation map from 5F unit as well? Just want to check that the PSD data is enabled correctly there. Could be that 5F is not transmitting this info now as it should.
And I can help to enable pACC as well. For your current radar it's doable. Time goes by, knowledge increases :D
   #37
stefan147
Greece
C?ID=361962
Not sure I want it (the pACC that is) but I sure want to know how it's done!:D
   #38
downtime
Finland
C?ID=280813
Not for the faint of heart I can tell you that :D
   #39
stefan147
Greece
C?ID=361962
Really??? Is it that of a pita?
   #40
k0mpresd
NC, USA
C?ID=358992
hi, i think you mean to quote my post and ask for adaptations as the user you quoted had already posted theirs.
anyway, here is adaptations from 5f.
;SW:3Q0-980-654-H   HW:3Q0-980-654-A ---  Frt Sens. Drv. Assist
;Component:MQB_B_MFK     H09 0272, Coding:000307000000020100222354C150890094000E200120
;EV_MFKBoschMQBB,001001,EV_MFKBoschMQBB_001_VW36.rod
;Wednesday,25,August,2021,08:15:45:55877
;VCDS Version: Beta 21.8.0 (x64)  Data version: 20210731 DS330.0
;VCID: 3C343602B7B1E2691F-8068
IDE00820-ENG130919-Activating and deactivating all development messages-Activation_of_development_messages_EHR,not activated ,1
IDE00820-ENG130920-Activating and deactivating all development messages-Activation_of_development_messages_HCA_lane,not activated ,1
IDE00820-ENG130921-Activating and deactivating all development messages-Activation_of_development_messages_HCA_state,not activated ,1
IDE00820-ENG130922-Activating and deactivating all development messages-Activation_of_development_messages_internal,not activated ,1
IDE00820-ENG130916-Activating and deactivating all development messages-Activation_of_development_messages_lane,not activated ,1
IDE00820-ENG130915-Activating and deactivating all development messages-Activation_of_development_messages_reserved,not activated ,1
IDE00820-ENG130918-Activating and deactivating all development messages-Activation_of_development_messages_VZF/TSR,not activated ,1
IDE00820-ENG130917-Activating and deactivating all development messages-Activation_of_development_messages_WLA,not activated ,1
IDE04160-Direct. stab. assist speed threshold during towing mode,300 km/h,2
IDE04733-Road sign detection fusion mode,Traffic sign detection ,1
IDE07358-Distance to calibration field,1500 mm,2
IDE09375-IDE05717-Axle offset-Front axle transverse position,-9.99999 mm,4
IDE09375-IDE05718-Axle offset-Rear axle transverse position,-8.99999 mm,4
IDE09376-IDE02001-Body height wheel house edge-Body height left front wheel house edge,683 mm,8
IDE09376-IDE02002-Body height wheel house edge-Body height right front wheel house edge,682 mm,8
IDE09376-IDE02003-Body height wheel house edge-Body height left rear wheel house edge,684 mm,8
IDE09376-IDE02004-Body height wheel house edge-Body height right rear wheel house edge,681 mm,8
IDE09391-MAS08824-Calibration target position-Target 1: calibration mark 1: x-coordinate,2460 mm,24
IDE09391-MAS08825-Calibration target position-Target 1: calibration mark 1: y-coordinate,742 mm,24
IDE09391-MAS08826-Calibration target position-Target 1: calibration mark 1: z-coordinate,1397 mm,24
IDE09391-MAS08827-Calibration target position-Target 1: calibration mark 2: x-coordinate,2460 mm,24
IDE09391-MAS08828-Calibration target position-Target 1: calibration mark 2: y-coordinate,-742 mm,24
IDE09391-MAS08829-Calibration target position-Target 1: calibration mark 2: z-coordinate,1397 mm,24
IDE09391-MAS08830-Calibration target position-Target 1: calibration mark 3: x-coordinate,2460 mm,24
IDE09391-MAS08831-Calibration target position-Target 1: calibration mark 3: y-coordinate,742 mm,24
IDE09391-MAS08832-Calibration target position-Target 1: calibration mark 3: z-coordinate,803 mm,24
IDE09391-MAS08833-Calibration target position-Target 1: calibration mark 4: x-coordinate,2460 mm,24
IDE09391-MAS08834-Calibration target position-Target 1: calibration mark 4: y-coordinate,-742 mm,24
IDE09391-MAS08835-Calibration target position-Target 1: calibration mark 4: z-coordinate,803 mm,24
IDE10407-Personalization of intervention moment at T. 15 on,Last setting ,1
IDE10870-Switch-on condition: lane depart. warn.,on (setting via menu) ,1
IDE10872-Warning intensity: lane depart. warning,Medium ,1
IDE10873-BAP personalization,activated ,1
IDE10924-MAS02479-Initial calibration: result-Yaw angle,-0.023 °,8
IDE10924-MAS05286-Initial calibration: result-Roll angle,-0.022 °,8
IDE10924-MAS05287-Initial calibration: result-Pitch angle,0.379 °,8
IDE10924-MAS10678-Initial calibration: result-Camera height,1328 mm,8
ENG130776-ENG130840-Adaptation_tsr-Par_country_code_RSR,0 ,3
ENG130776-ENG130841-Adaptation_tsr-Par_country_code_VZF,0 ,3
ENG130776-ENG130838-Adaptation_tsr-Par_country_mode,automatic ,3
ENG130776-ENG130839-Adaptation_tsr-Par_relevance_mode,Enabled ,3
ENG120319-Mask_error_reactions_for_development,not activated ,1
ENG107577-Masked_fault_classes-,255 ,4
ENG130777-standstill_mode,not activated ,1
ENG130781-ENG130836-WLA_adjustment-BrightnessThreshold_active,1 ,5
ENG130781-ENG130837-WLA_adjustment-BrightnessThreshold_passive,20 ,5
ENG130779-Xcp_interface,not activated ,1
Elapsed Time: 00:07
