Predictive ACC Coding
peekay34
Australia
C?ID=137150
Hi All wonder if someone can help me. I am looking for coding for predictive ACC and enabling it.
I have a brand new 2020 Karoq (yes I have the HEX2 Cable) which has all the bells an whistles on it (except for 360 Camera which is not an option in AU).
I have managed to code speed sign recognition and its all working great, but would love to enable this feature as well.
Can anyone help please.
downtime
Finland
C?ID=280813
Could you please provide a full unedited autoscan?
But to my knowledge pACC is behind SwAP again and requires a proper FeC code to be enabled. That is not officially possible and not possible with VCDS.
peekay34
Australia
C?ID=137150
May be better explain I have ACC which brakes and accelerates I understand that the option for slowing down in corners while in cruise control on.... just wanted if there was a way to code that.....
peekay34
Australia
C?ID=137150
Tuesday,22,September,2020,11:27:47:41284
VIN: TMBME7NU9L5036946   License Plate: LCY888
Mileage: 583km-362mi   Repair Order:
Chassis Type: NU-SK37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 2B 3C 42 44 47 4B 52
          5F 6D A5 A9 BB BC CA D6 D7
VIN: TMBME7NU9L5036946   Mileage: 583km-362miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DKZA)       Labels: None
   Part No SW: 81A 907 115 A    HW: 06K 907 309 B
   Component: R4 2.0l TFSI  H61 0002
   Revision: O1H61000
   Coding: 042540322466050B34100000000000000000000000000000
   Shop #: WSC 00033 790 00063
   ASAM Dataset: EV_ECM20TFS01181A907115A 001004
   ROD: EV_ECM20TFS011_VW37.rod
   VCID: 221DED054445E55B647-8076
17165 - Databus
          U1123 00 [040] - Received Error Message
                    Mileage: 10 km
                    Date: 2020.06.16
                    Time: 04:27:11
                    Engine speed: 0.00 /min
                    Coolant temperature: 28 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 11.820 V
                    Unlearning counter according OBD: 14
                    ACC variants-Bits 0-7: 2
                    CCS Switch-Bits 0-7: 2
                    Cruise control switch actuation-Bits 0-7: 32
                    Cruise control switch actuation-Bits 0-7: 128
                    ACC variants (coding)-Bits 0-7: 3
17166 - Cruise Control Switch (E45)
          P0568 00 [040] - Implausible Signal
                    Fault Frequency: 11
                    Mileage: 10 km
                    Date: 2020.06.16
                    Time: 04:25:47
                    Voltage terminal 30: 11.860 V
                    Cruise control switch actuation-Bits 0-7: 33
   Part No SW: 0GC 300 013 N    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2405
   Revision: 00H06V11
   ROD: EV_TCMDQ381061.rod
   VCID: 2F3B143107975833FB9-807A
   Part No SW: 5Q0 614 517 DP    HW: 5Q0 614 517 BS
   Component: ESC           H82 0113
   Revision: 00000000    Serial number: 60350000000132
   Coding: 1F078AA1A02324724780070462C929F8510524E2E0469475384150B8F2A94A0B00400C6212120B095A35351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
   ROD: EV_Brake1UDSContiMK100IPB_049_SK37.rod
   VCID: 025D8D85E485055B447-8056
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0541952777
   Coding: 032C0C0723
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 45D75699B52BF263215-8010
   Subsystem 1 - Part No SW: 3G0 962 243 B    HW: 3G0 962 243 B
   Component: GEB.F.Heckoef  H17 0904
   Serial number: 58694671
   Part No SW: 565 907 044 CL    HW: 565 907 044 CL
   Component: Climatronic   H04 2202
   Revision: 00001K00
   Coding: 0611000400010401110500480010102A
   Shop #: WSC 00033 790 00119
   ASAM Dataset: EV_ACClimaBHBVW37X 006150
   ROD: EV_ACClimaBHBVW37X_006_SK37.rod
   VCID: 678BBC11EFE7C073F39-8032
   Air quality sensor:
   Subsystem 3 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
   Component: G238 _AQS  H31 0120
   Serial number: 105364114
   Part No SW: 5Q0 937 084 DH    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H42 0312
   Serial number: 02002004901022
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020.rod
   VCID: 015F8289E1831E435DD-8054
   Subsystem 1 - Part No SW: 81A 955 555 A    HW: 81A 955 555
   Component: G397_RLFSS  H06  0002
   Serial number: 24338724X81A955555A0
   Coding: 80006E
   Component: Sensor, DWA  005  0316
   Serial number: 000000000ZY200200D5C
   Subsystem 3 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004  0007
   Serial number: 00000000000000916303
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 521 AG    HW: 5Q1 953 569 A
   Component: Lenks.Modul  H13  0170
   Serial number: 0100160220200C205938
534549 - Databus
          [FLA_01 Datenbus fehlende Botschaft]
                    Reset counter: 62
                    Mileage: 466 km
                    Date: 2020.08.12
                    Time: 13:05:12
549652 - Databus
          [TSG_BT_01 Datenbus empfangener Fehlerwert]
                    Reset counter: 62
                    Mileage: 466 km
                    Date: 2020.07.27
                    Time: 13:15:46
797955 - Steering Column Control Module
          B105D 07 [008] - Mechanical Failure
          [Schaltermodul Lenksäule (SMLS)->mechanischer Fehler]
                    Fault Frequency: 9
                    Reset counter: 43
                    Mileage: 10 km
                    Date: 2020.06.16
                    Time: 04:29:38
   Part No SW: 5QA 919 298 H    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H08 0061
   Serial number: 000150057220044
   Coding: 0371167851
   ASAM Dataset: EV_EPHVA2CAU3700000 009048
   VCID: 55F786D9458B42E3515-8000
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Coding: 320467D35CFF8428749C814530308700000000000000000004
   ROD: EV_ACCMRRCONTIVW376_003_SK37.rod
   VCID: 43D34881BB1FCC530F1-8016
1076 - Databus
          [FAULT_TIMEOUT_GRA_ACC_01]
                    Reset counter: 63
                    Mileage: 461 km
                    Date: 2020.07.23
                    Time: 15:01:26
                    Voltage terminal 15: 14.8 V
                    Control Module temperature: 57 °C
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.00 m/s²
                    Adaptive distance regulation: status: ACC_StandBy
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Fault Frequency: 30
                    Reset counter: 43
                    Mileage: 10 km
                    Date: 2020.06.16
                    Time: 04:26:07
                    Voltage terminal 15: 11.8 V
                    Control Module temperature: 28 °C
                    Adaptive distance regulation: status: ACC_irreversible error
1116 - Databus
          [FAULT_TSK_CODING_IN_PLAUS_PHASE_FAIL]
                    Mileage: 10 km
                    Date: 2020.06.16
                    Time: 04:30:05
                    Control Module temperature: 30 °C
2127 - Databus
          [FAULT_OP_FAIL]
                    Reset counter: 43
                    Mileage: 10 km
                    Date: 2020.06.16
                    Time: 04:27:11
                    Control Module temperature: 31 °C
   Serial number: 02022041350446
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 38292F6DF2D99F8BAA3-806C
   Part No SW: 3Q0 959 655 CM    HW: 3Q0 959 655 CM
   Component: Airbag VW21   006 0720
   Revision: --------    Serial number: 003Z2P198MQ2
   Coding: 98CCC0C0000000005C540000008800000065
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 0B43A0A1D3CF4413371-805E
   Subsystem 1 - Part No SW: -----------    HW: 454 001 301 20
   Serial number: 357000000000EC10A44H
   Subsystem 2 - Part No SW: -----------    HW: 454 001 401 20
   Serial number: 35800000000A58C0A44Q
   Subsystem 3 - Part No SW: -----------    HW: 454 801 501 20
   Serial number: 351005540B81A000000A
   Subsystem 4 - Part No SW: -----------    HW: 454 801 501 20
   Serial number: 35200324DB81A000000J
   Subsystem 5 - Part No SW: -----------    HW: 454 801 312 19
   Serial number: 35500F9A5A21A000000W
   Part No SW: 565 920 790 C    HW: 565 920 790 C
   Component: KOMBI         503 4194
   Coding: 24AC0A1EFF8C0008018D630B1001000080000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001042
   ROD: EV_DashBoardVDDMQBA0_VW37.rod
   VCID: 1E65D9F5703DC1BB40F-804A
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 24022010520457
   Coding: 030100047F085900A90322FA9E0F00010001070000000000000000000000
   Shop #: WSC 00033 790 00114
   ROD: EV_GatewNF_VW37.rod
   VCID: 70B9D74DDA2907CBA23-8024
   Component: 4-01-13-01-04
   Subsystem 2 - Part No SW: 3V0 919 719 F    HW: 3V0 919 719 F
   Component: E221__MFL-PR6  H03 0180
   Serial number: 000000000D2511170220
   Serial number: 75886003002002190D72
8531970 - Quiescent Current
          U1406 00 [008] - Too High
          [Ruhestrom oberer Grenzwert überschritten]
                    Fault Frequency: 24
                    Reset counter: 69
                    Mileage: 314 km
                    Date: 2020.07.04
                    Time: 23:03:11
                    Supply voltage: Terminal 30: 12.4 V
                    Terminal 15: OFF
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00008.01.20
   Coding: 0001
   VCID: 4CC163BD9641032BFEB-8018
   Serial number: 20000020731001
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_AU37.rod
   VCID: 33331841EBBF7CD39F1-8066
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0150
   Serial number: 00000540349141
   Coding: 92954640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15.rod
   VCID: 392F2A69C9D3868355D-806C
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q4 959 593 K    HW: 5Q4 959 593 K
   Component: TSG FS        007 0485
   Serial number: 0000405313494
   Coding: 00158820D001020000001100
   VCID: 4DC76EB96D5B0A23E95-8018
196630 - Heated Exterior Mirror
          B11F8 14 [008] - Open or Short to Ground
                    Reset counter: 62
                    Mileage: 466 km
                    Date: 2020.07.27
                    Time: 12:11:06
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Coding: 93170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C21337DC6E1B3AB4EB-8068
   Part No SW: 81A 035 223     HW: 81A 035 223
   Component: MIB2_amp_P_SK H10 0410
   Revision: 00000001    Serial number: SKZ8Z1KJE09H865
   Coding: 0323060000AA002AAA0000000000
   ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001001
   ROD: EV_AMPMst16C4Gen2ALPI.rod
   VCID: 59EF8AE92993668375D-800C
0522 - Front Left Treble Speaker
          B1061 13 [008] - Open Circuit
          [Tieftonlautsprecher Kanal 3: Unterbrechung (DC-Diagnose)]
                    Reset counter: 69
                    Mileage: 314 km
                    Date: 2020.07.04
                    Time: 13:23:42
                    Voltage terminal 30: 12.0 V
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 17022010523938
   Coding: 000000070900057606003D01190000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_003_VW27.rod
   VCID: 372B2C51FFC790F3A39-8062
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 5Q4 959 592 K    HW: 5Q4 959 592 K
   Component: TSG BFS       007 0485
   Serial number: 0000405284813
   Coding: 00158020DC01020000001100
                    Reset counter: 62
                    Mileage: 466 km
                    Date: 2020.07.27
                    Time: 13:15:37
196673 - Position Sensor for Mirror Adjustment
          B11FA 29 [009] - Signal Implausible
                    Reset counter: 22
                    Mileage: 461 km
                    Date: 2020.07.24
                    Time: 13:52:20
196722 - Turn Signal in Exterior Mirror
          B11FD 13 [008] - Open Circuit
                    Reset counter: 62
                    Mileage: 466 km
                    Date: 2020.07.27
                    Time: 13:15:49
   Part No SW: 565 035 019 E    HW: 565 035 019
   Component: MU-H-LND-RW   H55 1440
   Serial number: A890K0KP000105
   Coding: 032306080000000001510202008908312F0108F601208400FF
   VCID: 176BCCD19F07B0F3839-8042
   Subsystem 1 - Part No SW: 565 919 606 D    HW: 565 919 606 D
   Component: ABT_High-2  H53 9130
   Serial number: SKZ6ZHX0535905
   Subsystem 2 - Part No SW: V03 959 806 GS    HW: -----------
   Component: ROW 2020/2021  --- 0088
   Compact Disc Database:
   Component: Gracenote2  --- 4013
          B201A 00 [009] - -
                    Fault Frequency: 29
                    Reset counter: 29
                    Mileage: 170 km
                    Date: 2020.06.30
                    Time: 22:08:04
                    Voltage terminal 30: 12.8 V
                    Status_Software_Version_Management-module_name: MDUK621/Main
6667 - Optical Data Bus for Information Electronics 1
          U10CA 00 [008] - Intermittent Disruption
          [Optical data bus: sporadic open circuit in central processor]
                    Reset counter: 48
                    Mileage: 170 km
                    Date: 2020.06.30
                    Time: 22:07:40
                    Temperature of MOST transceiver-max.value: -50 °C
                    Temperature of MOST transceiver-min.value: -3 °C
                    Temperature of MOST transceiver-Current: 45 °C
6678 - Digital sound System control module
          U106A 00 [008] - No Communication
          [Control module for sound system: no communication]
                    Reset counter: 48
                    Mileage: 170 km
                    Date: 2020.06.30
                    Time: 21:30:22
                    Voltage terminal 30: 12.6 V
7201 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Road sign display (0x21) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 62
                    Mileage: 466 km
                    Date: 2020.08.12
                    Time: 17:55:22
                    Voltage terminal 30: 13.5 V
                    BAP-BAP_Function_ID: 02
   Part No SW: 5Q0 959 107 S    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0271
   Revision: --------    Serial number: A2-C737-6291-8
   Coding: 1808
   VCID: 48C95FAD8239EF0BDA3-801C
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H13 0610
   Serial number: 18022015P11412
   Coding: 020307080000010100022346C150A90098000E20002000
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40D9478DAA09D74B123-8014
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 57A 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 191017201308
   VCID: 6C81C33DF601E32B9EB-8038
   Part No SW: 8W0 959 595 M    HW: 8W0 959 595 J
   Component: TSG HFS       010 0384
   Serial number: 0000405598586
   Coding: 000080200001020000001100
   VCID: 56F581D5588D49FB58F-8002
   Component: TSG HBFS      010 0384
   Serial number: 0000405803949
   ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
   Coding: 508040632602
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   VCID: 75B7E659A54B22E3715-8020
   Part No SW: 7P5 941 591 AJ    HW: 7P5 941 591 A
   Component: LED1L         H07 0011
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
   VCID: 04518B9DFE910B6B76B-8050
   Component: LED1R         H07 0011
   ROD: EV_LED_PLUS_R_KEBODAVW416_VW41.rod
End----------(Elapsed Time: 02:12, VBatt start/end: 14.5V/14.5V)-----------
downtime
Finland
C?ID=280813
I know what pACC is. And again, it is not something that can be coded, it is a SwAP function, not something you can code. Another thing is that I don't think your radar support pACC. It needs a Bosch radar like 3QF.
AINils
Germany (AIB)
C?ID=56975
For 3Q0 (3QF) it's easy to activate FEC in ACC, but 2Q0 is not easy. Actually it's only 1 Person who can do it
downtime
Finland
C?ID=280813
This is my understanding as well. Luckily the 3QF radars are quite cheap from Aliexpress :)
peekay34
Australia
C?ID=137150
So If I replace the 2Q0 907 572 R with as an example......
FOR 3QF 907 561 D ACC Adaptive Cruise Control radar sensor 3QF907561D
5.0(1 votes)Store: Aidu Auto Technology CO., LTD
AU $126.72
I assume that this will have component protection which will have to be recoded but what other coding will be required.
downtime
Finland
C?ID=280813
You need FeC enabled for the features and that cannot be done with VCDS nor it cannot be done through the dealer either. I know there are people who can help you remotely. Facebook & maybe AINils can point you to the right direction.
AINils
Germany (AIB)
C?ID=56975
AU $126.72
No it won`t work as Cars came from factory with 2Q0 or 5Q0 (5QF), but if you don`t have valid dataset it won`t work
Hawkeye9723
C?ID=389466
AINils
Germany (AIB)
C?ID=56975
Hawkeye9723
C?ID=389466
Thanks for the info. Figured it was a long shot.
nibose
Perth, Australia
C?ID=371170
Hi,
My car has the 3Q0 module (Part No SW: 3Q0 907 572 C HW: 3Q0 907 572 C), please let me know how I can enable PaCC.
Many thanks,
Nitin
downtime
Finland
C?ID=280813
Hi,
Many thanks,
Nitin
Officially not in any way, unofficially. Well, facebook groups etc. And I'm quite sure 3Q0 radar does not support pACC. You would need either 2Q0 or 3QF.
kreativ
Hidden
C?ID=108852
Hi,
Many thanks,
Nitin
You need to change to 3QF907561 for pACC support, i can help you with activation in radar, just send me PM.
AINils
Germany (AIB)
C?ID=56975
Hi,
Many thanks,
Nitin
It was a typo, mean 5Q0 (3QF) is easy. 3Q0 is not possible as Downtime wrote. You can trust @kreativ he has best solution ;-)
It`s possible on 5Q0 and 2Q0 easily
nibose
Perth, Australia
C?ID=371170
Hi Everyone,
I am trying to see if Pacc is possible in my vehicle.
As the first step, I flashed A5 module but traffic sign recognition is still not working in fusion mode.
Am I missing something?
Sunday,25,April,2021,12:46:04:34260
VIN:   License Plate:
Mileage: 25148km-15626mi   Repair Order:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 36 3C 42 44 4B 52 5F 6C
          A5 BB BC CA CF D6 D7
VIN: WVWZZZ3CZKE054334   Mileage: 25148km-15626miles
Address 01: Engine (J623-CJSA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 3G0 906 264     HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0004
   Revision: --H13---
   Coding: 092500322464050B3000
   Shop #: WSC 05311 115 00311
   ASAM Dataset: EV_ECM18TFS0203G0906264 001007
   ROD: EV_ECM18TFS020_VW48.rod
   VCID: 6597B067C5E99B631C5-8030
   Part No SW: 0CW 300 043 H    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1601
   Revision: 00005008    Serial number: CU501811136031
   Shop #: WSC 05311 115 00086
   ROD: EV_TCMDQ200021_VW48.rod
   VCID: 3C21350316E3FAAB93B-8068
   Part No SW: 5Q0 614 517 DH    HW: 5Q0 614 517 AH
   Component: ESC           H62 0754
   Revision: 00000000    Serial number: 63258000001330
   Coding: 0EEC928F34252370477A060360C74970492CC4E2600692753842F038C2A9420B00000012121212B835351919323200
   Shop #: WSC 00015 115 08193
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 7AADF31B5C57049BC17-802E
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0499916047
   Coding: 1F20000723
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   VCID: 43D34EFF6B1D8553D21-8016
   Part No SW: 5G0 907 044 DP    HW: 5G0 907 044 DP
   Component: Climatronic   H04 2001
   Revision: 00001K10
   Coding: 1112001420010000111510401210182A
   VCID: 78A9E913625B168BB73-802C
   Air quality sensor:
   Humidity sensor: exterior:
   Part No SW: 5Q0 937 086 BQ    HW: 5Q0 937 086 BQ
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: 8658081118000S
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019.rod
   VCID: 0A4DA3DB0CB7141BD17-805E
   Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    181104  043 0607
   Serial number:         181115102536
   Component: RLHS  052 0107
   Serial number: S7Y18M11D29H15M50S54
   Coding: 00A8DD
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Serial number: 25 09 2018  10000464
   Humidity sensor: interior:
   Subsystem 5 - Part No SW: 5Q1 953 521 AS    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0100241120180C301643
   Part No SW: 5QA 919 298 F    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0453
   Serial number: 000308417618311
   Coding: 0371167851
   ASAM Dataset: EV_EPHVA2CAU3700000 009037
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 53F37EBF9B7D15D3621-8006
   Component: ACC BOSCH MQB H05 0196
   Coding: 320467D359FFC428949C8045
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3537202735C92BE36C5-8060
   Part No SW: 3Q0 959 655 BJ    HW: 3Q0 959 655 BJ
   Component: Airbag VW21   006 0712
   Revision: --------    Serial number: 003W5PN9QTH/
   Coding: 98FCC0C0000000005C540000008800000065
   Shop #: WSC 05311 000 08193
   VCID: 074B9AEF1FA56973CE9-8052
   Subsystem 1 - Part No SW: -----------    HW: 454 000 611 18
   Serial number: 35700000000162717231
   Subsystem 2 - Part No SW: -----------    HW: 454 000 611 18
   Serial number: 35800000000B5271723B
   Subsystem 3 - Part No SW: -----------    HW: 454 800 810 18
   Serial number: 35100F6C57A16000000S
   Subsystem 4 - Part No SW: -----------    HW: 454 801 211 18
   Serial number: 35200E660D916000000M
   Subsystem 5 - Part No SW: -----------    HW: 454 802 510 18
   Serial number: 35500E5619C16000000O
   Part No SW: 3G0 920 791 D    HW: 3G0 920 791 D
   Component: KOMBI         403 4191
   Coding: 27A501186F8C000801887B0B1001000080000000
   VCID: 2A0D035BEC77741BF17-807E
   Serial number: 29111810804595
   Coding: 030300347F085900FB00025A1C0F00010001070000000000000000000000
   VCID: 6E85CF4B101F583B6DF-803A
   Generator:
   Component: 0-00-03-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0052
   Serial number: 29180002805690098475
   Coding: 2DFFFF
   Serial number: 75886002001811091A89
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  111 1004
   Serial number: 1311201800010362
   Serial number: 18000349925013
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 33331E3F3BBD35D3421-8066
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 3Q0 959 760 D    HW: 3Q0 959 760 D
   Component: Sitzmemory    H06 0024
   Serial number: Y0006RKR13119
   Coding: 001400020000050081C280808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   Part No SW: 3Q0 907 566 G    HW: 3Q0 907 566
   Component: MRR1Rear      H23 0530
   Revision: --------
   Coding: 44C002
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YE007RKG05581
   Coding: 003F1B20D201020000000000
   VCID: 44D14DE36E13826BEBB-8010
   Coding: 93170000
   Shop #: WSC 00015 115 00311
   Component: FCM MQB Low   002 0345
   Serial number: 23111810521586
   Coding: 000000060900034E01004F05020000040000000000000000000000000000
   Shop #: WSC 05311 123 08193
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW41.rod
   Subsystem 1 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: Leimo links  H02 0003
   Coding: E02400
   Subsystem 2 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: Leimo rechts  H02 0003
   Coding: E02400
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS001 0287
   Serial number: YE007RKG17817
   Coding: 003F1120DE01020000000000
   Part No SW: 5NA 035 045 C    HW: 5NA 035 045
   Component: MU-H-N-RW     H55 1161
   Serial number: A849K0JS036922
   Coding: 02840108FF00000051510001000808001F0106E601200402DF
   VCID: 3829291322DBD68B773-806C
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H52 9130
   Serial number: VWZ6ZJV3280358
   Subsystem 2 - Part No SW: V03 959 806 ND    HW: -----------
   Component: ROW 2021  --- 0090
   Compact disc data bank:
   Coding: 0184010162002017000040
   VCID: 392F2C1719D1CF8388D-806C
   Component: MQB_B_MFK     H09 0272
   Serial number: 20081815P12294
   Coding: 000408010000010100022346C150A90094000E300040
   Part No SW: 8W1 959 595 D    HW: 8W1 959 595 D
   Component: TSG HFS003 0187
   Serial number: YE007RKD22815
   Coding: 000E11200101020000000000
   ROD: EV_DCU2RearDriveMAXHCONT_VW41.rod
   VCID: 4EC56FCBB05F783B4DF-801A
   Component: TSG HBFS003 0187
   Serial number: YE007RKD22811
   ROD: EV_DCU2RearPasseMAXHKLO_VW37.rod
   Part No SW: 4M0 907 594 K    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Coding: 508000748101
   ROD: EV_SunRoofCONTIAU736_006.rod
   VCID: 3E253F0B00FFE8BBBDF-806A
   Part No SW: 3Q0 907 590 G    HW: 3Q0 907 590
   Revision: --------
   Coding: 44C002
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 1675C7AB480FC0FB45F-8042
   Component: LED1R         H09 0003
End----(Elapsed Time: 02:10, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
downtime
Finland
C?ID=280813
Not possible with your radar afaik. 2Q0 or 3QF. MRREvo14f.
and not possible with just coding. pACC is once more under our friend SWaP and needs proper FeC to be enabled.
