2008 VW Golf BMN P2002 wont clear
fastlane
Australia
C?ID=302768
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: WVWZZZ1KZ8U028342   Mileage: 197120km-122484miles
Address 01: Engine        Labels: 03G-906-018-BMN.clb
   Part No SW: 03G 906 018 FC    HW: 03G 906 018 FC
   Component: R4 2.0l PPD1.2 G    1879
   Revision: --H52---    Serial number: VWX7Z0H23N37V7
   Coding: 0000072
   Shop #: WSC 00999 444 64523
   VCID: 6B961A374ABE77DED6-803E
008194 - Particulate Trap Bank 1
               P2002 - 006 - Efficiency Below Threshold
                    Fault Status: 11010001
                    Mileage: 197123 km
                    Time: 08:48:31
                    Torque: 144.0 Nm
                    (no units): 3.0
                    Pressure: 0.0 mbar
                    Lambda: 19.8 %
                    Time: 4492.8 s
Readiness: N/A
   Revision: 00H11001
   Coding: 0023170
   Shop #: WSC 00046 412 00000
   VCID: 73A60257128EAF1E1E-8026
   Part No SW: 1K0 907 044 DE    HW: 1K0 907 044 DE
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   VCID: 6D92142F74AA79EEC8-8038
00229 - Refrigerant Pressure
            001 - Upper Limit Exceeded
   Revision: 00H54000    Serial number: 00000008237755
   Coding: E5898F2700041500471400001400000000087F075C000100000000000000
   VCID: 71AA085F68929D0EEC-8024
   Component: Wischer 160408 020  0501
   Coding: 00049109
   Shop #: WSC 00046
   Component: RLS     290308 046  0204
   Coding: 00208933
   Shop #: WSC 00046
   Component: 1P AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1PA4BE
   Coding: 0012624
   VCID: 3D32E46F644A296E38-8068
   Subsystem 1 - Serial number: 6332MSME2A0169302
   Subsystem 2 - Serial number: 6342MSME32704B7DJ
   Subsystem 3 - Serial number: 6352QSME4B081357G
   Subsystem 4 - Serial number: 6362QSME501734334
   Part No SW: 1K0 953 549 BP    HW: 1K0 953 549 BP
   Component: J0527           752 0100
   Coding: 0002022
   VCID: 014A589F58328D8E1C-8054
00576 - Terminal 15
00885 - Ignition Switch (D) Terminal 50
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
   Part No SW: 1K0 920 874 B    HW: 1K0 920 874 B
   Component: KOMBIINSTRUMENT VDD 2216
   Revision: V0002000    Serial number: VWX7Z0H23N37V7
   Coding: 0003103
   Shop #: WSC 02267 959 999999
   VCID: 2C14D92B8F30B0E69F-8078
   Component: J533__Gateway   H15 0180
   Revision:   H15       Serial number: 1400K082098282
   Coding: E9807F060006020083
   Shop #: WSC 20623 002 1048576
   VCID: 302CCD5BA318D406A3-8064
   Component: IMMO            VDD 2216
   Component: Tuer-SG         006 1210
   Coding: 0000692
   VCID: 383CF57B4B680C46EB-806C
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.069 H08 1901
   VCID: 3620FB43417CFA36F9-8062
   Coding: 809002005103087F2D04840560085F0380FC00
   Shop #: WSC 00046 000 00000
   VCID: 03465297422E9F9E0E-8056
   Coding: 0000692
   VCID: 393AF07F7062154E14-806C
   Part No: 1K0 035 186 AD
   Component: Radio GR0       034 0033
   Revision: 0003404S    Serial number: VWZ2Z2H5853748
   Coding: 0040400
   VCID: 689C653B5B485CC6BB-803C
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         006 1301
   Coding: 0000144
   Shop #: WSC 00046 412 1012544
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Coding: 0000144
Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
   Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
   Component: Telefon       H08 6900
   Revision: 00008000    Serial number: 00000A10144005
   Coding: 412220
   Shop #: WSC 00078 790 00189
   VCID: 2A18DF3345C4AED66D-807E
03426 - Left Audio Channel
                    Reset counter: 245
                    Mileage: 197120 km
End----------(Elapsed Time: 01:08, VBatt start/end: 12.8V/12.6V)-----------
                Address 01: Engine  (03G 906 018 FC)
08:56:00
  50.0°C   Coolant Temperature (G62)
  811 /min   Engine Speed (G28)
  250.1 mg/str   Mass Air Flow (actual)
  0 km   Soot Index
  63.9 %   Position (spec.) EGR-Actuator
  61.3 %   Position (act.) EGR-Actuator
  89.3°C   Temperatur in Particle Filter
  6.0 mbar   Press. Difference Particle Filter
  -1 mbar   Press. Difference Offset
  20.0 %   Particle Filter Load Coefficient
  7.00   Particle Filter Oil Ash Mass
  0.0 %   Oil Ash Mass Learned Value
Car has almost 200,000 km on it...
What values are you seeing from the differential pressure sensor in MVB 067.3, both key on, engine off, and with the engine idling?
How much carbon mass (ash) does it think it has accumulated in MVB 068.2?
fastlane
Australia
C?ID=302768
Is there a procedure for clearing this code as it will not clear with KOEO. I have tried adaptations and checked active data which appears to be good. Is there something I am overlooking?
Coding: 0000072
Mileage: 197123 km
                    Time: 08:48:31
Torque: 144.0 Nm
(no units): 3.0
Pressure: 0.0 mbar
Lambda: 19.8 %
                    Time: 4492.8 s
Readiness: N/A
Revision: 00H11001
Coding: 0023170
Coding: 00049109
   Shop #: WSC 00046
Coding: 00208933
   Shop #: WSC 00046
Coding: 0012624
Coding: 0002022
00576 - Terminal 15
Coding: 0003103
Coding: 0000692
Coding: 0000692
Coding: 0040400
Coding: 0000144
Coding: 0000144
Coding: 412220
Reset counter: 245
Mileage: 197120 km
08:56:00
0 km Soot Index
fastlane
Australia
C?ID=302768
Key on engine off reading is 0
Idle is 5.96mB
2000rpm is 21.5mB
Both old and new pressure sensors read the same.
Will check carbon mass tomorrow.
I tried particulate filter oil ash at 0, then set it to 7 as in scan data.
I would have thought I would be able to clear the code with KOEO but it resets straight away without starting engine.
avisonjohn
C?ID=403276
Surely a difference of 21.5mB indicates a partially blocked/full DPF at 122k miles?
fastlane
Australia
C?ID=302768
Although I dont work on a lot of these vehicles, believe these readings are right for a good/clean DPF.
fastlane
Australia
C?ID=302768
So all I would like to know is, with KOEO should I be able to clear this fault code, the code relogs straight away without starting engine, I want to determine whether there is a fault in the ECU or the ECU is wont reset due to an incorrect reading KOEO. The engine does not have to be started for it to log. Vehicle is always in limp mode.
09:26:30
847 /min Engine Speed (G28)
30.0°C Coolant Temperature (G62)
30.0°C Fuel Temperature (G81)
27.0°C Intake Air Temperature (G72)
297.8 mg/str Mass Air Flow (actual)
1013.5 mbar Atmospheric Pressure
1001.0 mbar Boost Pressure (actual)
115.2°C Temperature bef. Turbo Charger
58.4°C Temperatur in Particle Filter
6.5 mbar Press. Difference Particle Filter
Address 01,03G 906 018 FC,channel 12,adapted from,7,to,0,
Address 01: DTCs cleared
09:32:22
38.0°C Coolant Temperature (G62)
34.0°C Fuel Temperature (G81)
31.0°C Oil Temperature
29.0 mm Oil Level
64.5°C Temperatur in Particle Filter
0.00 Particle Filter Oil Ash Mass
4 h Time since Regeneration
