2010 Golf A/C help
18ME
C?ID=401654
The air con hasn’t worked on the car since buying a few months ago but thought it may just need re-gassing so after having an issue with the gateway module packing up and replacing it and then trying to code it I booked it in for a re-gas. They said that it didn’t work and could be the compressor. Before I take it to an air con specialist can someone look at the last auto scan I did to see if there is anything that I may need to code due to the old gateway module being replaced.
i am very much a novice and trying to learn but don’t fully understand how it all works.
Sunday,06,September,2020,16:02:25:34784
VCDS Version: 20.4.2.0 (x64)  HEX-NET CB: 0.4513.4
VIN: WVWZZZ1KZBW077109   License Plate: LS60MBU
Mileage: 209660km-130276mi   Repair Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 56 62 72 77
VIN: WVWZZZ1KZBW077109   Mileage: 209660km-130276miles
   Part No SW: 03L 906 018     HW: 03L 907 309 R
   Component: R4 2.0l TDI   H22 9978
   Revision: 42H22---    Serial number: 00000000000000
   Coding: 00190012042500080000
   Shop #: WSC 55695 001 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018 003014
   ROD: EV_ECM20TDI01103L906018_003_VW36.rod
   VCID: 679E93F19EEA34BEB2-8032
4638 - Engine Oil Temp. Sensor (G8)
          P0196 00 [040] - Implausible Signal
                    Mileage: 209599 km
                    Date: 2020.08.19
                    Time: 16:16:49
                    Engine speed: 780.50 /min
                    Normed load value: 41.2 %
                    Coolant temperature: 29 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 13.800 V
                    Unlearning counter according OBD: 34
                    Fuel consumption: 1.03 l/h
                    Engine oil temperature: 100.0 °C
                    Oil warning threshold: 27.724 mm
                    Control Module temperature: 19.8 °C
                    Oil fill level: 0.000 mm
                    Outside air temperature: 21.0 °C
                    Fuel temperature: 21.5 °C
10095 - Engine Control Unit Incorrectly Coded
          P0610 00 [040] - -
                    Fault Frequency: 8
                    Mileage: 209605 km
                    Date: 2020.08.31
                    Time: 08:10:33
                    Engine speed: 0.00 /min
                    Coolant temperature: 14 °C
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 11.560 V
                    Unlearning counter according OBD: 37
                    Zähler der Regenerationszeit des Partikelfilters: 0.00 s
                    Particle filter: kilometers since last regeneration: 158636 m
                    Particle filter: soot mass measured: 11.25 g
                    Particle filter: soot mass calculated: 19.66 g
                    Particle filter: differential pressure: dynamic offset: 0 hPa
   Part No SW: 1K0 907 379 AT    HW: 1K0 907 379 AT
   Component: ESP MK60EC1   H30 0105
   Revision: 00H30001
   Coding: 163B400D09290001680C02E490220082310000
   VCID: 0444A47D879CFFA637-8050
                    Reset counter: 199
                    Mileage: 209605 km
                    Date: 2020.08.31
                    Time: 08:10:32
                    Count: 2
                    Count: 20480
                    Count: 8192
                    Count: 41728
                    Count: 255
   Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
   Revision: 00009001
   Coding: 0000000002
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 6D92E1D9BC161EEEC8-8038
          U1111 00 [008] - -
          [Motorsteuergerät - kein Signal/Kommunikation]
                    Reset counter: 91
13701392 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Bremsensteuergerät - kein Signal/Kommunikation]
                    Reset counter: 91
13701408 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Diagnoseinterface für Datenbus - kein Signal/Kommunikation]
                    Fault Frequency: 117
                    Reset counter: 196
13701456 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
                    Fault Frequency: 116
                    Reset counter: 196
9481748 - High Pressure Sensor
          B10AE 14 [008] - Open or Short to Ground
                    Reset counter: 197
                    Mileage: 209599 km
                    Date: 2020.08.19
                    Time: 16:15:37
   Part No SW: 1K0 937 084 D    HW: 1K0 937 084 D
   Component: BCM PQ35  B   103 0615
   Revision: 00103 AD
   Coding: 48180A3A8825F1C040080080340000E443510088536D8160648000200040
   VCID: 2F2E3BD17E9AACFEBA-807A
   Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 12081  26  0512
   Coding: 009795
   Component: RLS 230810 05  54  0403
   Coding: 0330AD
   Component: LIN BACKUP HO  H11 9004
                    Reset counter: 157
                    Mileage: 209583 km
                    Date: 2020.07.01
                    Time: 03:51:45
                    Voltage: 11.65 V
                        Term 50 Off
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 196
                    Mileage: 209583 km
                    Date: 2020.07.01
                    Time: 03:51:45
                    Voltage: 11.65 V
                        Term 50 Off
                    Reset counter: 156
                    Mileage: 209583 km
                    Date: 2020.07.01
                    Time: 03:53:52
                        Term 15 Off
                    Voltage: 11.70 V
                        Term 50 Off
                    Reset counter: 198
                    Mileage: 209605 km
                    Date: 2020.08.31
                    Time: 08:51:11
                        Term 15 Off
                    Voltage: 11.70 V
                        Term 50 Off
                    Fault Frequency: 159
                    Reset counter: 198
                    Mileage: 209605 km
                    Date: 2020.08.31
                    Time: 08:51:12
                        Term 15 Off
                    Voltage: 11.70 V
                        Term 50 Off
   Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
   Component: AirbagVW10    037 0606
   Serial number: 003FKRABV693
   Coding: 00003133
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3B361F81B2E2405E06-806E
   Serial number: 3572MSME2C504555ZZZV
   Serial number: 3582MSME466F7556ZZZ5
   Serial number: 3512QSME180D6B6EZZZ7
   Serial number: 3522QSME08266A17ZZZW
   Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
   Component: Lenks.Modul   007 0080
   Revision: --------    Serial number:  90440JHC000AU
   Coding: 108A140000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 72A8F2A5A528C11615-8026
   Serial number: 50000000000000202462
   Coding: E20000
332564 - Databus
                    Fault Frequency: 53
                    Reset counter: 0
                    Mileage: 208253 km
                    Date: 2021.11.18
                    Time: 11:51:24
332580 - Databus
                    Fault Frequency: 21
                    Reset counter: 51
                    Mileage: 208253 km
                    Date: 2021.11.18
                    Time: 11:51:24
332596 - Databus
                    Fault Frequency: 8
                    Reset counter: 51
                    Mileage: 208253 km
                    Date: 2021.11.18
                    Time: 11:51:24
   Part No SW: 5K0 920 971 A    HW: 5K0 920 971 A
   Component: KOMBI         H03 0406
   Coding: 470B00
   VCID: 2D1221D97C96DEEE88-8078
10 Faults Found:
9453842 - Oil Level Thermal Sensor
          B1041 35 [008] - Signal high time > maximum
                    Reset counter: 197
                    Mileage: 209599 km
                    Date: 2020.08.19
                    Time: 16:16:44
12604928 - Combination / Chassis CAN Bus (SAE Bus D)
          U0056 00 [008] - Performance
          [Datenbus Kombi/Fahrwerk: keine Kommunikation]
                    Fault Frequency: 17
                    Reset counter: 196
12648448 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Motor: keine Kommunikation]
                    Reset counter: 91
12656896 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Bremse: keine Kommunikation]
                    Reset counter: 91
12664832 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für BCM / Bordnetz / el. ZE: keine Kommunikation]
                    Fault Frequency: 64
                    Reset counter: 196
12669184 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Airbag: keine Kommunikation]
                    Reset counter: 91
13638912 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Lenkhilfe: keine Kommunikation]
                    Reset counter: 91
12718592 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Lenksäulenelektronik: keine Kommunikation]
                    Fault Frequency: 19
                    Reset counter: 196
12666368 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Diagnose Interface: keine Kommunikation]
                    Fault Frequency: 31
                    Reset counter: 196
13631488 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Komfortsysteme: keine Kommunikation]
                    Fault Frequency: 16
                    Reset counter: 91
   Part No SW: 7N0 907 530 P    HW: 1K0 907 951
   Component: J533  Gateway H40 1623
   Revision:   H40       Serial number: 041211F6000926
   Coding: 350003
   Shop #: WSC 05314 000 00000
   VCID: 3D321199A4F64E6E38-8068
   Component: IMMO          H03 0406
   VCID: 6A98EAC58DF809D6AD-803E
   Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
   Revision: A1001003    Serial number: 7668505564
   VCID: 271ED3F1566AF4BE72-8072
                    Fault Frequency: 8
                    Reset counter: 196
                    Reset counter: 91
   Part No SW: 1T0 035 680 C    HW: 1T0 035 680 C
   Component: RNS-MID       H41 2720
   Revision: AB001001    Serial number: VWZ6Z7K4187106
   Coding: 060100020100009000
   Shop #: WSC 00020 790 00000
   VCID: 2E1026D57990A5F6B1-807A
00857 - CD Changer Unit (R41)
                    Fault Frequency: 28
                    Reset counter: 163
                    Mileage: 209624 km
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2120
   Coding: 0000692
   VCID: 312A3DA9A8AEBA0EAC-8064
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 70     3001
   Revision: 00H17000
                    Fault Frequency: 11
                    Reset counter: 196
                    Voltage: 13.75 V
                        DU
                    Temperature: 29.0°C
                    RPM: 781 /min
                    Voltage: 11.63 V
                        DU
                    Temperature: 23.0°C
                    RPM: 1498 /min
   Component: EZE_2         H40 1623
   Coding: 00000008
   VCID: 6FAEFBD1BE1AECFEFA-803A
02174 - Analog/Digital clock
                    Reset counter: 156
                    Mileage: 209583 km
                    Date: 2020.07.01
                    Time: 00:00:25
   Part No SW: 5K0 959 702 E    HW: 5K0 959 702 E
   Component: Tuer-SG         009 2152
   Coding: 0000948
   VCID: 352209B95CC6962EF0-8060
                    Fault Frequency: 29
                    Reset counter: 163
                    Mileage: 209624 km
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   Coding: 0000144
   VCID: 36200EB541C09D36F9-8062
   Part No SW: 7P6 035 730 B    HW: 7P6 035 730 B
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668483647
   Coding: 0A01000000010101
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
   VCID: 312A3DA960AEBA0EAC-8064
9455635 - Telephone Microphone
          B1048 13 [008] - Open Circuit
                    Reset counter: 65
                    Mileage: 208366 km
                    Date: 2021.11.28
                    Time: 11:38:51
12664832 - Body Control Module (Central Electric)
          U0140 00 [008] - No Communications
                    Reset counter: 91
13633792 - No Communication with Diagnostic Gateway
          U0146 00 [008] - -
          [Gateway: keine Kommunikation]
                    Reset counter: 91
                    Mileage: 209582 km
                    Date: 2022.01.30
                    Time: 16:53:17
End----------(Elapsed Time: 01:29, VBatt start/end: 12.2V/12.2V)-----------
All those faults are flagged "Intermittent". What comes back and under what circumstances when you clear them?
In Advanced Measuring Values, have a look at:
IDE00198-ENG100282 00 Refrigerant pressure
and
IDE00965 -- Compressor shut-off requirement
as well as:
IDE01419 .. IDE01421 (the last three compressor shut-off reasons).
18ME
C?ID=401654
Sorry, I hadn’t realised that I had a reply. I’ll go and have a look now.
18ME
C?ID=401654
I think I must have cleared all the fault codes before taking the car in for the a/c re-gas. There are no fault codes under 08-auto hvac but the air con still doesn’t work so an I assume that the compressor isn’t working? The guy at ATS who tried to regas it said that the revs usually rise or fall (can’t remember which) but when I press the a/c button the revs do stay the same.
I’ve just done this auto scan from my iPad so don’t know if it scans differently to when you plug it in to the laptap.
Sun,Sep,20,2020,12:44:51
VCDS Mobile 0.4513.0.4
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 56 62 72 76
     77
08-Auto HVAC -- Status: OK 16000
09-Cent. Elect. -- Status: Malfunction 16010
16-Steering wheel -- Status: OK 16000
17-Instruments -- Status: OK 16000
25-Immobilizer -- Status: OK 16000
42-Door Elect, Driver -- Status: OK 16000
46-Central Conv. -- Status: OK 16000
52-Door Elect, Pass. -- Status: OK 16000
62-Door, Rear Left -- Status: OK 16000
72-Door, Rear Right -- Status: OK 16000
76-Park Assist -- Status: Cannot be reached 17100
Address 01: Engine  (CFFB J)    Labels: 03L-906-018-CFF.clb
    Revision: 42H22---
    VCID: E791A89FEF43DC62201851-80B2
No fault codes found.
    Revision: 00H30001
    VCID: 844B9F13FE350F7AA53A0E-80D1
Address 08: Auto HVAC  (J301)    Labels: 3C8-907-336.clb
    Revision: 00009001
    Coding: 0000000002
    ROD: EV_Climatic_VW36.rod
    VCID: 6D9D5AB74DBF7632DA5413-8038
Address 09: Cent. Elect.  (J519)    Labels: 1K0-937-08x-09.clb
    Revision: 00103 AD
    VCID: 2F2180BF8733DC22A8C8A9-807A
    Subsystem 1 -     Part No SW: 1K2-955-119-F    Labels: 1Kx-955-119.clb
    Component: Wischer 1208126  0512
    Coding: 009795
    Subsystem 2 -     Part No SW: 1K0-955-559-AH    Labels: 1K0-955-559-AG.clb
    Component: RLS 230810 0554  0403
    Coding: 0330AD
    Subsystem 3 -     Part No SW: 1K8-951-171
    Component: DWA-Sensor 00001 0104
    Subsystem 4 -     Part No SW: 1K8-951-605-A
    Component: LIN BACKUP HOH11 9004
    000 -  -
Address 15: Airbags  (J234)    Labels: 5K0-959-655.clb
    Coding: 00003133
    VCID: 3B39A4EF434B288214402D-806E
    Subsystem 1 -     Part No SW: 5K0-959-354
    Component: S.Sens.Fahr.VH01 ----
    Serial Number: 3572MSME2C504555ZZZV
    Subsystem 2 -     Part No SW: 5K0-959-354
    Component: S.Sens.Beif.VH01 ----
    Serial Number: 3582MSME466F7556ZZZ5
    Subsystem 3 -     Component: S.Sens.Fahr.H--- ----
    Serial Number: 3512QSME180D6B6EZZZ7
    Subsystem 4 -     Component: S.Sens.Beif.H--- ----
    Serial Number: 3522QSME08266A17ZZZW
Address 16: Steering wheel  (J527)    Labels: 5K-16.lbl
    Revision: --------
    Coding: 108A140000
    VCID: 72A749CB5481A9CA076648-8027
Address 17: Instruments  (J285)    Labels: 5K0-920-xxx-17.clb
    Coding: 470B00
    ROD: EV_Kombi_UDS_VDD_RM09_A04_VW36.rod
    VCID: 2D1D9AB78D3FB6329AD453-8078
Address 19: CAN Gateway  (J533)    Labels: 7N0-907-530-V2.clb
    Revision:   H40
    Coding: 350003
    VCID: 3D3DAAF75D5F3EB22A7403-8068
01327 - Control Module for Parking Aid (J446)
Address 25: Immobilizer  (J334)    Labels: 5K0-920-xxx-25.clb
    ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
    VCID: EA97D1ABFC51E10A3F36B0-80BF
Address 2E: Media Player 3  (J650)    Labels: 5N0-035-342.lbl
    Revision: A1001003
    VCID: 2711689FAFC38462609811-8072
Address 37: Navigation  (J0506)    Labels: 1T0-035-680.clb
    Revision: AB001001
    Shop #: WSC 00020 790 12345
    VCID: 2E1F9DBB8039D52AA3DE5C-807B
Address 42: Door Elect, Driver    Labels: 1K0-959-701-MIN3.clb
    Part No SW: 5K0 959 701 B    HW: 5K0959701B
    Coding: 0000692
    VCID: 312586C791074AD2BEFCBF-8064
    Part No SW: 1K0 909 144 J
    Revision: 00H17000
Address 46: Failed to respond
Address 4F: Centr. Electr. II  (J520)    Labels: 1K0-907-532.clb
    Revision:   H40
    Coding: 00000008
    VCID: EFA1C0BFC7B31C226848E9-80BA
    Subsystem 1 -
Address 52: Door Elect, Pass.    Labels: 1K0-959-702-MAX3.clb
    Part No SW: 5K0 959 702 E    HW: 5K0959702E
    Coding: 0000948
    VCID: 352DB2D7656F66F2E204EB-8060
Address 56: Radio  (J0506)    Labels: 1T0-035-680.clb
    Revision: AB001001
Address 62: Door, Rear Left    Labels: 1K0-959-703-GEN3.clb
    Part No SW: 5K0 959 703 D    HW: 5K0959703D
    Coding: 0000144
Address 72: Door, Rear Right    Labels: 1K0-959-704-GEN3.clb
    Part No SW: 5K0 959 704 D    HW: 5K0959704D
    Coding: 0000144
    VCID: 362FB5DB78696DEAEB0EF4-8063
Address 76: Failed to respond
Address 77: Telephone  (J412)    Labels: 7P6-035-730.clb
    Revision: 1B001001
    ROD: UHVNA.rod
    VCID: 312586C79107D2D2BEFCBF-8064
18ME
C?ID=401654
Does anyone know if the compressor could possibly be the issue if there are no fault codes now showing?
Yes, that is absolutely possible. These HVAC systems have a very poor ability to detect problems with the compressor.
Note that "possible" doesn't mean this actually is the problem.
