Audi A4 B8 - P0651
toolbonsai
C?ID=384819
2014 Audi A4 Avant 2.0L 177BHP - Engine light came up few days ago with flashing glow plug light and traction control error, been attempting to diagnose the issue since, replaced the crank sensor already as was told by someone else its likely this, purchased VCDS but doesn't really seem to shed much light on the issue is there anything else I can do to try track down if a sensor is out on the 5v circuit or if its a wiring issue via VCDS? I can't even find which sensors are on the 5v circuit that it mentions.
Friday,18,September,2020,15:21:37:31266
VIN: WAUZZZ8K0FA*******   License Plate:
Mileage: 218730km-135912mi   Repair Order:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 6D 72
VIN: WAUZZZ8K0FA******   Mileage: 218730km-135912miles
Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 JG    HW: 03L 906 018 JL
   Component: R4 2.0l TDI   H25 9978
   Revision: 45H25---
   Coding: 12194012242401080000
   Shop #: WSC 07112 002 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018JG 003007
   ROD: EV_ECM20TDI01103L906018JG.rod
   VCID: 78A9EFB41254E9EB6A3-802C
          U1113 00 [047] - -
                    Fault Frequency: 11
                    Mileage: 218736 km
                    Date: 2020.09.18
                    Time: 13:23:13
                    Engine speed: 0.00 /min
                    Coolant temperature: 63 °C
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 12.040 V
                    Cruise Control System (CCS): switch position-Bits 0-7: 129
                    Cruise Control System (CCS): status-Bits 0-7: 232
                    Cruise control switch-off: irreversible-Bits 0-7: 4
                    Cruise control switch-off: reversible-Bits 0-7: 255
                    Cruise Control System: specified speed: 0.00 km/h
                    Engine control module reset status-Bits 0-7: 2
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 16
4124 - Sensor Reference Voltage B
          P0651 00 [175] - Open Circuit
                    Mileage: 218736 km
                    Date: 2020.09.18
                    Time: 13:23:13
                    Voltage terminal 30: 12.060 V
                    Exh.gas temp.sen 1: 15.0 °C
                    Exh.gas temp.sen 2: -0.0 °C
                    Exh.gas temp.sen 3: 75.8 °C
                    Exh.gas temp.sen 4: 41.8 °C
                    Shut-off timer: last engine shut-off time: 599 s
Readiness: 1 1 0 0 1
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CN    HW: 8K0 907 379 CN
   Component: ESP8 front    H09 0020
   Coding: 161DC401
   Shop #: WSC 06325 000 00000
   VCID: 074B9C486F2A9613139-8052
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 19
                    Mileage: 218736 km
                    Date: 2020.09.18
                    Time: 13:24:29
                    Hex Value: 0x0000
                    Hex Value: 0x07A2
                    Hex Value: 0x000B
                    Hex Value: 0x639D
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 JG    HW: 8K0 907 064 JG
   Component: BCM2 2.0      H14 0650
   Coding: 03B24040000000000000
   VCID: 7EA5F9AC30F0D7DB20F-802A
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0514000102434019
   Serial number: 0214000129044007
   Part No SW: 8K2 820 043 BA    HW: 8K2 820 043 BA
   Revision: D0000000    Serial number: 01160720140102
   Coding: 342402E000
   VCID: 698FBAF0597E4063E5D-803C
   Part No SW: 8K0 907 063 DC    HW: 8K0 907 063 DC
   Revision: 03016001    Serial number: 00000857854301
   Coding: 290000308034A7C00081000000001F1F001D060827080201000008004000020000000024000000
   VCID: 73B3D8980BB28AB35F1-8026
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 080714  H06 0080
   Serial number: SWF14077085034
   Coding: 00FD11
   Serial number: 22891811
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001107140087
   Serial number: 1E080B37000000000001
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Component: AirbagVW-AU10 H48 0610
   Serial number: 003KFDC2RXSO
   Coding: 30534435363030303030554A3052384B3053
   Shop #: WSC 34290 001 1048576
   VCID: 48C95F742234596BDA3-801C
   Serial number: 6334MSME47695864M
   Serial number: 6344MSME482C2524D
   Serial number: 6352QSME3E445368O
   Serial number: 6362QSME7D431076J
   Serial number: 63732SME7143567E3
   Serial number: 63832SME71434254U
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NGI000M9
   Coding: 000017
   VCID: 48C95F7422B4596BDA3-801C
   Part No SW: 8K0 920 983 G    HW: 8K0 920 983 G
   Component: KOMBIINSTR.   H35 0564
   Revision: 00100000    Serial number: ZAC72TG7F
   Coding: 33A4100003012600010000
   VCID: 392F2AB0695E30E355D-806C
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0060
   Revision: 1Y080030    Serial number: 3041Y147080688
   Coding: 80CF07FF00
   VCID: 4ACD657C3CB8AB7BCC7-801E
   Serial number: 4773093903
   Serial number: 14197002290011200181
   Part No SW: 8K0 959 793 S    HW: 8K0 959 793 Q
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000109913983
   Coding: 011002204001410001
   VCID: 50F97714DAE491AB823-8004
   Part No SW: 8K0 909 144 J    HW: 8K0 909 144 B
   Component: RCEPS         H41 0509
   Revision: 00001000    Serial number: 0007749884
   Coding: 100000000001
   Shop #: WSC 06324 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 38292FB452D429EBAA3-806C
   Revision: 00002001    Serial number: 0341432344
   Coding: 013B0622A0B930408320023680000047
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 19
                    Mileage: 218736 km
                    Date: 2020.09.18
                    Time: 13:27:11
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 19
                    Mileage: 218736 km
                    Date: 2020.09.18
                    Time: 13:28:12
   Part No SW: 8K0 959 792 S    HW: 8K0 959 792 Q
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000109934051
   VCID: 4FFB7468C7DA8E539B9-801A
02111 - Motor for Window Regulator
                    Fault Status: 00100101
                    Reset counter: 57
                    Mileage: 218690 km
                    Date: 2020.09.15
                    Time: 17:52:40
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 20000000481342
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A2D35BC6CD83BFB5C7-806E
464128 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FC_SIGNAL_MO_QBIT_FAHRPEDALWERTE_01_QBIT]
                    Reset counter: 19
                    Mileage: 218736 km
                    Date: 2020.09.18
                    Time: 13:23:23
                    Voltage terminal 30: 12.1 V
                    Internal Fault ID: 187
                    Function light in parking brake button: On
                    Red operating lamp: On
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: Set
                    Status ParkingBrake right: Set
464384 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
                    Reset counter: 19
                    Mileage: 218736 km
                    Date: 2020.09.18
                    Time: 13:23:23
                    Internal Fault ID: 188
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
   Part No SW: 4G0 035 061 N    HW: 4G0 035 061
   Component: Radio U DAB   H60 0139
   Revision: AB001007    Serial number: 109G40E7949902
   Coding: 010103020100000001
   VCID: 2809FFF482F4B96B3A3-807C
   Part No SW: 8R2 035 666 G    HW: 8R2 035 666 C
   Component: H-BN-EU       H47 0809
   Revision: --------    Serial number: 206G.0EB008562
   Coding: 0F0101010006A1ED01808B5E00000403E40000020000000000
   VCID: 3D273EA07D760CC3795-8068
   Subsystem 1 - Part No: 8R0 060 884 BT
   Component: EUR 2014  1903
   Component: DU7 High  H42 0104
   Serial number: A130G-0E3089735
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Serial number: 00000001929988
   Component: CD-Database  5950
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000110140271
   Coding: 010002204001210001
   VCID: 46D5514C28A04F1B28F-8012
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8K9 827 851 C    HW: 8K9 827 851 C
   Component: J605  Master  H53 0330
   Revision: --------    Serial number: 8K9827851C
   VCID: 3E2539AC707017DB60F-806A
   Subsystem 1 - Part No SW: 8K9 827 852 C    HW: 8K9 827 852 C
   Component: J756  Slave  H53 0330
   Serial number: 8K9827852C
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000110143565
End----------(Elapsed Time: 01:44, VBatt start/end: 12.6V/12.5V)-----------
Controller Software Versions:
ECU 1 = Engine 9978
ECU 2 = ABS Brakes 0020
ECU 3 = Acc/Start Auth. 0650
Sub ECU 3 > 1 = Acc/Start Auth. 0083
Sub ECU 3 > 2 = Acc/Start Auth. 0046
ECU 4 = Auto HVAC 0123
ECU 5 = Cent. Elect. 0103
Sub ECU 5 > 1 = Cent. Elect. 0080
Sub ECU 5 > 2 = Cent. Elect. 0002
Sub ECU 5 > 3 = Cent. Elect. 0031
Sub ECU 5 > 4 = Cent. Elect. 0003
ECU 6 = Airbags 0610
ECU 7 = Steering wheel 0003
Sub ECU 7 > 1 = Steering wheel 0004
ECU 8 = Instruments 0564
ECU 9 = CAN Gateway 0060
Sub ECU 9 > 1 = CAN Gateway 8041
Sub ECU 9 > 2 = CAN Gateway 0042
ECU 10 = Door Elect, Driver 0510
ECU 11 = Steering Assist 0509
ECU 12 = Central Conv. 0650
Sub ECU 12 > 1 = Central Conv. 0040
Sub ECU 12 > 2 = Central Conv. 1501
ECU 13 = Door Elect, Pass. 0510
ECU 14 = Parking Brake 0005
ECU 15 = Radio 0139
ECU 16 = Information Electr. 0809
Sub ECU 16 > 1 = Information Electr. 1903
Sub ECU 16 > 2 = Information Electr. 0104
Sub ECU 16 > 3 = Information Electr. 0030
Sub ECU 16 > 4 = Information Electr. 5950
ECU 17 = Door, Rear Left 0510
ECU 18 = Trunk Elect. 0330
Sub ECU 18 > 1 = Trunk Elect. 0330
ECU 19 = Door, Rear Right 0510
Reactions: Jef
I assume you've been here?
You're going to need a wiring diagram for your particular car/engine.
"Open Circuit" strikes me as most likely to be a wiring or connector fault. I believe the ECU monitors current being pulled from its 5V reference output(s) and would flag the fault that way if the current is zero.
NostraJackAss
In addition to his eminence's fine suggestion......
OP
Did you try unplugging the engine bay side connector and further measuring the 5 volt + voltage directly available at module output current tracks yet and does the aforementioned fault clear with only the one side plugged in and key on via scanner?
JPPSG all pages yet?
toolbonsai
C?ID=384819
Engine bay side connector you mean the two connectors which go to the ECU? I've just purchased the wiring diagrams to find which sensors are on this circuit and their pinouts
NostraJackAss
Indeed my caps lock key was stuck!
Time for a keyboard!
Yes the connectors at ECU, however, the one going to engine consumers should be unplugged to isolate if problem exists at ECU directly or forward to harness to engine sensors and load devices.
toolbonsai
C?ID=384819
Thank you, I will try this later today.
toolbonsai
C?ID=384819
So I've used the wiring diagram thanks for the links and tested the five sensors on that circuit, and they all read 1.8volt instead of what I believe should be 5v. I've found the source of the power pin 25 on the ECU and its also 1.8volt there. I have no idea where the ECU gets the 5 volts from, but I'm guessing this is a good indication that the ECU is at fault here?
Shade
South Africa
C?ID=291138
Did you check whether there is any sensor which may be pulling the 5V ref circuit to 1.8v. Please you must also check your powers and grounds to the ECU before you blame it.
toolbonsai
C?ID=384819
Hello yes each sensor was tested off the circuit to make sure one wasnt bringing the circuit down to 1.8. Going to check grounds and powers next!
Fixed the issue, wiring chaffed.
