Steering angle sensor
martinez
Florida, USA
C?ID=413973
First time posting anything. I have a 2004 7L Touareg v8 Trying to insure it is my (G85) and not possibly something else within kessy or ABS. Any guidance would be greatly appreciated. G85 sits at zero and shows no change if i move the wheel. drives fine all controls work on wheel except radio volume installed aftermarket.
Friday,18,September,2020,08:18:28:12561
VIN: WVGCM67L24D018322   License Plate:
Mileage: 176850km-109889mi   Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGCM67L24D018322   Mileage: 176850km-109889miles
Address 01: Engine        Labels: 077-907-560-AXQ.lbl
   Part No SW: 4D0 907 560 DA    HW: 8E0 907 560
   Component: 4.2L V8/5V      G   0020
   Coding: 0007875
   Shop #: WSC 31414 000 00000
   VCID: 6889BC9F3E60CA5BFA3-5160
Readiness: 0010 1101
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No: 09D 927 750 N
   Component: AL 600 6Q           0382
   Coding: 0004153
   VCID: 392F29DB154A83D355D-5160
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 C
   Component: ESP ALLRAD MK25     0107
   Coding: 0014337
   Part No SW: 3D0 909 135 M    HW: 5WK 470 26
   Component:    Kessy            6400
   Coding: 0131304
   VCID: 2F3B1783DB0E5D63FB9-5160
00003 - Control Module
Address 06: Seat Mem. Pass        Labels: None
   Part No: 7L0 959 760
   Component: Sitzverstellung     0701
   VCID: 77ABEFE363DE55A3639-5160
00538 - Reference Voltage
            007 - Short to Ground
02345 - Switch for Memory Position 1 (E218)
            003 - Mechanical Failure
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 D
   Component: CLIMAtronic R/L   X 2714
   Coding: 0001030
   VCID: 313F11FBCD3A4B93EDD-5160
00353 - Function Return Message from Fresh Air Blower Regulator
                    Voltage: 12.30 V
                    Voltage: 10.64 V
                    Voltage: 0.00 V
                    Voltage: 14.00 V
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 K
   Component:                     2703
   Coding: 0101598
   VCID: 44D1482F6288CE3B36B-5160
   Part No: 3D0 909 601 D
   Component: 02 Airbag 8.4E+ H07 0952
   Coding: 0012338
   VCID: 2411E8AF82C8EE3B16B-5160
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 B
   Component: Lenksäulenmodul     3201
   Coding: 0000032
   VCID: 3E253AC70C64A4EB60F-5160
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 970 D
   Component: KOMBIINSTRUMENT RB4 1735
   Coding: 0007231
   Shop #: WSC 01124 444 85793
   VCID: 38292CDF2E409ADBAA3-5160
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: 70B9D4FF06B0029BA23-5160
Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
   Part No: 7L6 919 879 A
   Component: JCI PathPoint       2200
   VCID: 45D7552B69B2F733215-5160
   Part No: 0AD 927 755 AB
   Component: TRANSFERCASE        0094
   VCID: 7BA3F3D35FF671C3071-5160
Address 29: Left Light        Labels: 3D0-909-157.lbl
   Part No: 3D0 909 157
   Component: EVG GDL+AutoLWR(l)  X012
   Coding: 0000002
   VCID: 6695B2A73474DC2BC8F-513C
01344 - HID (Xenon) Headlight
Address 46: Central Conv.        Labels: 7L0-959-933.lbl
   Part No: 7L0 959 933 C
   Component: B0 HSG              0101
   Coding: 0000085
   VCID: 3C2130CF1A78B6FB4EB-4B1E
   Subsystem 1 - Part No: 7L0 959 701 B
   Component: Tuersteuergeraet FS 0104
   Subsystem 2 - Part No: 7L0 959 702 B
   Component: Tuersteuergeraet BF 0104
   Subsystem 3 - Part No: 7L0 959 703 B
   Component: Tuersteuergeraet HL 0104
   Subsystem 4 - Part No: 7L0 959 704 B
   Component: Tuersteuergeraet HR 0104
00487 - Rear Left Outside Door Handle Central Locking Button (E371)
Address 68: Wiper Electr.        Labels: 7L0-955-119-V1.clb
   Part No: 7L0 955 119 F
   Component: Front Wiper         2416
   Coding: 0000004
   VCID: 372B2FE3235E95A3A39-5160
Address 6E: Ctrl Head Roof        Labels: None
   Part No: 7L6 919 044 F
   Component: DACHDISPLAY         0530
   Revision: 00600530    Serial number: 2009289.02
   VCID: 3A2D36D7104C88CB5C7-5160
End----------(Elapsed Time: 08:10, VBatt start/end: 13.3V/13.3V)-----------
Jef
HQ
Thank you for posting the full Auto-Scan! :thumbs:
Defective... so odds are the G85 needs to be replaced. :cry:
martinez
Florida, USA
C?ID=413973
I appreciate it wanted an extra set of eyes before purchase. Thank you
martinez
Florida, USA
C?ID=413973
My ESP has the warning light could the no signal from G85 make it inop? i cant find any codes for it? Thanks again
Yes, The G85 steering angle sensor is an essential component of the ESP system, which is an integral part of the ABS module, where the fault for G85 is shown in your scan.
