VW t5 DSG no tiptronic
JBoza
Stockholm, Sweden
C?ID=372497
Hello! im have one t5, some one have change gearbox on this car.. now there is no tiptronic option.. when you try put gear stick in tiptronic option then in cluster gone symbol (D1...) can some one check if there wrong mechatronic ? gearbox working well
Saturday,19,September,2020,08:25:24:47312
Dealer/Shop Name: Bilmetropolen i Norrort AB
Workshop Code: 444 03743 000001
VIN: WV2ZZZ7HZAH259974   License Plate: CWA
Mileage: 411130km-255464mi   Repair Order: 1
Chassis Type: 7H-VN75 (6N0)
Scan: 01 02 03 04 08 09 10 15 17 18 19 25 56 69 6E 0B
VIN: WV2ZZZ7HZAH259974   Mileage: 411130km-255464miles
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (J623-CCHA)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 022 GF    HW: 03L 907 309 K
   Component: R4 2,0L EDC   X33 9130
   Revision: 26X33---    Serial number: 00000000000000
   Coding: 0125401A233400080000
   Shop #: WSC 66565 257 00032
   ASAM Dataset: EV_ECM20TDI01103L906022GF 002008
   ROD: EV_ECM20TDI01103L906019DG.rod
   VCID: 6FBBD3A6F7168173BB9-803A
   Part No SW: 0BT 300 011 Q    HW: 0BH 927 711 C
   Component: DSG DQ500-7A  H08 2235
   Revision: 00H08V01
   VCID: 3C2134EAF6E02AEB4EB-8068
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 E    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0103
   Revision: 00H43001
   Coding: 208724AD09A9049E24AB90787A6216
   Shop #: WSC 02736 790 49152
   VCID: 34311CCADE30E2AB86B-8060
02846 - Button for Tire Pressure Monitoring Display (E492)
                    Reset counter: 104
                    Mileage: 411131 km
                    Count: 128
                    Count: 784
                    Count: 157
                    Count: 252
   Part No SW: 7E5 907 047 M    HW: 7E5 907 047 M
   Component: Climatic-T5   H10 0101
   Revision: 00004001
   Coding: 0000000002
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ClimaticT5 A01002
   ROD: EV_ClimaT5Basis.rod
   VCID: 392F2DFEF9D21FC355D-806C
   Part No SW: 7H0 937 089     HW: 7H0 937 089
   Component: BCM T5GP Li4  H46 0207
   Revision: BS046001    Serial number: 0112 077100171
   Coding: A0A0293A0E612402932846403CEB8ED48090638F60042841300000000000
   Shop #: WSC 40567 222 57223
   VCID: 73B3DFD69BBEA5935F1-8026
   Component: RLS 130310 05  54  0403
   Coding: 03302E
   Subsystem 2 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3311
   Subsystem 3 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3311
   Subsystem 4 - Part No: 7E1 951 172
   Subsystem 5 - Part No: 1K0 951 605 C
   Subsystem 6 - Part No: 7E1 951 172
   Subsystem 7 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
   Serial number: 40000000000000038188
   Coding: E30000
   Part No SW: 7E0 919 475     HW: 7E0 919 475
   Component: PARKHILFE 4K  H10 0008
   Revision: --------    Serial number: 33031007810008
   Coding: 110101
   Shop #: WSC 02736 790 50316
   ASAM Dataset: EV_VW75XParkAssis4K A01003
   ROD: EV_VW75XParkAssis4K_A01_VN75.rod
   Part No SW: 7E0 959 655 A    HW: 7E0 959 655 A
   Component: VW10Airbag00N H05 0011
   Revision: --------    Serial number: 003E5001KM6S
   Coding: 00000000000000000000000000000000304E
   Shop #: WSC 02734 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVN750 A01001
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 34311CCADEB0E2AB86B-8060
   Part No SW: 7E0 920 870 A    HW: 7E0 920 870 A
   Component: KOMBI         H16 0111
   Coding: 160A00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04041
   VCID: 270BFB861F669933339-8072
Address 18: Aux. Heat        Labels: None
   Part No: 7E0 819 008 C
   Component: J737__Standheizung  0404
   Revision: 00084000    Serial number: 09019169D00000
   Coding: 0000322
   Shop #: WSC 02757 790 00000
   VCID: 290FFDBE05F2AF4325D-807C
   Part No SW: 6N0 909 901     HW: 7H0 937 089
   Component: GW-K-CAN TP20 0207
   Coding: 042200
   VCID: 70B9D0DAEAA89E8BA23-8024
   Component: IMMO          H16 0111
   Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
   Component: Radio RCD310  016 0049
   Revision: 01000000    Serial number: VWZ1Z2L0395524
   Coding: 0900040104
   Shop #: WSC 03743 444 00001
   VCID: 6B83C7B6C38E7D53971-803E
00856 - Radio Antenna
                    Reset counter: 64
                    Mileage: 411130 km
                    Date: 2015.02.09
                    Time: 16:49:07
   Component: Anhaenger     H07 0070
   Revision: 3A001001    Serial number: 00000127933518
   Coding: 410D000100000000
   Shop #: WSC 02736 790 00000
   VCID: 303910DA2A28DE8BE23-8064
Address 6E: Ctrl Head Roof (J702)       Labels:. 7E5-919-037-W1.clb
   Part No SW: 7E5 919 037 E    HW: 7E5 919 037 E
   Component: Dachdisplay   H15 0165
   Revision: 10100008    Serial number: 159776
   Coding: 000002
   VCID: 33331FD6DB3EE5939F1-8066
End----(Elapsed Time: 02:00, VBatt start/end: 11.8V/11.8V. VIgn 11.9V)-----
Jef
HQ
Thank you for including a full Auto-Scan!!!! :thumbs:
So I run this VIN and to keep things short and simple, this has a CCHA engine, 2010 year.
Now I search of other Auto-Scans that have the same 0BT 300 011 Q installed and I find 3 examples.... with CFCA engine 2014/2015 year models.
I'm not going to outright say the wrong transmission has been installed... but I'll imply the living crap out of it. :eek:
E?ID=301324
E?ID=361382
E?ID=709182
